" E# N& _$ P- f8 q/ T
N0 E% E2 s1 a! P[AD 10][6层]RK3128核心板(转换的版本)(mcu_RK3128+DS8008+DDR)原理图和PCB文件. q; L+ F8 L/ w* ^
2 x( i7 H$ b# c; i- H7 y0 T
文件描述; A' P. |0 @$ c5 \4 h: v/ ?
1. 作品用途:RK3128核心板(转换的版本). J3 d0 Q5 L1 }7 J6 e2 x4 b
2. 软件版本:AD 10& J/ }% E$ O* T; z9 y+ G3 `3 y7 P; z
3. 层数:6层板
) W% m' _% g1 {9 W+ [4. 用到的主要芯片:MCU_RK3128+DS8008+DDR2 i; I+ e+ {7 E6 e. D' ~$ a
5. PCB尺寸:67*31 mm8 i8 W( h; Q( d: b$ U. C; ~
. _2 S3 T; y; K9 a作品截图如下:
* ?; R9 {7 E0 S" q7 N6 U顶层截图:1 L* |$ ~3 n* o- U
# p p8 x7 H8 x
' q8 X* B& J( k2 _2 }5 D8 S底层截图:
' u/ w6 X* V& B8 G5 n
( h* g' r: ]$ T7 o! B6 g: B) \
4 J; P; F A7 g4 C$ H% I- ~) P
全层截图:6 J0 ?) h% }* c, a6 w5 l, r' Y
. J' a$ T, S" z' V# J9 ?3 k% l) k
叠层信息截图如下:
0 u5 a0 o, T' o
( W h5 h( h" F: V7 e) p* uBOM:
, B& A: a7 h8 n+ ?9 ^% rComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | CAP NP_C0402_0.1UF | C39/NC, C1004, C1005, C1006, C1007, C1008, C1009, C1010, C1011, C1014, C1015, C1016, C1017, C1018, C1019, C1103, C1105, C1106, C1107, C1702, C1703, C3102, C3103, C3104, C3105, C3106, C3107, C3108, C3109, C3110, C3113, C3114, C3115, C3120, C3123, C3124, C3125, C3126, C3127, C3128, C4000, C4001, C4002, C8206, C8207 | C0402 | 45 | CAP NP_C0805_22UF | C1000, C1001, C1002, C1012, C1013, C3111 | C0805 | 6 | CAP NP_C0402_1UF | C1003, C1104, C3101, C8208 | C0402 | 4 | CAP NP_C0402_1NF | C1100 | C0402 | 1 | CAP NP_C0402_12PF | C1101, C1102 | C0402 | 2 | CAP NP_C0603_10UF | C1200, C3112, C3119, C3122 | C0603 | 4 | CAP NP_0_C0402_1UF | C1201 | C0402 | 1 | CAP NP_0_C0402_0.1UF | C1202, C1203, C1204, C1205, C3100, C3116 | C0402 | 6 | CAP NP_4_C0603_4.7UF | C2100, C2104, C2105, C2110, C2113, C2116, C2119, C2123, C2132 | C0603 | 9 | CAP NP_4_C0805_22UF | C2101, C2102, C2103, C2106, C2107, C2109, C2135 | C0805 | 7 | CAP NP_4_C0402_47PF | C2108 | C0402 | 1 | CAP NP_4_C0402_0.1UF | C2111 | C0402 | 1 | CAP NP_4_C0402_2.2UF | C2112, C2114, C2115, C2118, C2120, C2121, C2122, C2124 | C0402 | 8 | CAP NP_4_C0402_1UF | C2117, C2125, C2126, C2129 | C0402 | 4 | CAP NP_4_C0402_25PF | C2127, C2128 | C0402 | 2 | CAP NP_4_C1206_22UF/10V | C2130, C2134 | C1206 | 2 | CAP NP_4_C0805_10UF/10V | C2131, C2133, C2136 | C0805 | 3 | CAP NP_4_C0402_100PF | C2137 | C0402 | 1 | CAP NP_0_C0402_1NF | C3117, C3118 | C0402 | 2 | CAP NP_C0603_4.7UF | C3121, C7000, C7001, C7005, C8209, C8210 | C0603 | 6 | CAP NP_C0402_NC | C3129 | C0402 | 1 | DIODE BI-DIR TRIG_E0402_AZ5725- | ED2101 | E0402 | 1 | T POINT R_2_FIDICALMARK_FIDUCAL | FID1, FID2, FID3, FID4, FID5, FID6 | FIDICALMARK | 6 | CON2_R0603_NC | J4000 | R0603 | 1 | CON2_1_PAD_0D8X6D5_1_CON2_0 | J4001, J4002 | PAD_0D8X6D5_1 | 2 | INDUCTOR_2_IND-4X4_1UH/3.5A | L2100, L2104, L2105 | IND-4X4 | 3 | INDUCTOR_2_IND-3X3_1UH/2A | L2101, L2102, L2103 | IND-3X3 | 3 | RES 1B_R0402_22R | R3, R4, R5, R6, R7, R8, R1101 | R0402 | 7 | RES 1B_R0402_0R | R9, R10 | R0402 | 2 | RES 1B_R0402_133R%1 | R1100 | R0402 | 1 | RES 1B_R0402_10K | R1102 | R0402 | 1 | RES 1B_R0402_2K%1 | R1701 | R0402 | 1 | RES 1B_R0402_1K5 | R1800, R1801 | R0402 | 2 | RESISTOR_1_R0402_100R | R2100, R2101 | R0402 | 2 | RESISTOR_1_R0402_200K%1 | R2102 | R0402 | 1 | RESISTOR_1_R0402_100K%1 | R2103 | R0402 | 1 | RESISTOR_1_R0402_NC | R2104, R2105, R2109 | R0402 | 3 | RESISTOR_1_R0402_4K7 | R2106, R2107 | R0402 | 2 | RESISTOR_1_R0402_10K | R2108 | R0402 | 1 | RESISTOR_1_R1210_20MR%1 | R2110 | R1210 | 1 | RESISTOR_1_R0402_0R | R2111 | R0402 | 1 | RESISTOR_0_R0402_240R%1 | R3100, R3101 | R0402 | 2 | RESISTOR_R0402_100R | R3102 | R0402 | 1 | RESISTOR_0_R0402_10K%1 | R3103, R3104 | R0402 | 2 | RES 1B_R0402_22K | R3105 | R0402 | 1 | RES 1B_R0402_4K7 | R4000 | R0402 | 1 | RES 1B_R0402_NC | R4001, R4002 | R0402 | 2 | RESISTOR_0_R0402_2K%1 | R8213 | R0402 | 1 | T_POINT_R_TP_PAD_T_POINT_R | TP1, TP2 | TP_PAD | 2 | TESTPOINT1_0_TP_PAD_TEST | TP1100, TP1101 | TP_PAD | 2 | MCU_RK3128_BGA316-14X14-0_65_MC | U1000 | BGA316-14X14-0_65 | 1 | RK818_1_QFN68-7X7_RK818 | U2100 | QFN68-7X7 | 1 | LPDDR2-32_2_B-168P_12-12_LPDDR2 | U3100 | B-168P_12-12 | 1 | DS8008_4_SOT25_PT5108E23E-18 | U3101 | SOT25 | 1 | NANDFLASH_0_TSOP-48_NAND_FLASH | U4000 | TSOP-48 | 1 | J1_0_2013311-1_J1 | U7005 | 2013311-1 | 1 | J2_1_2013311-2_J2 | U7006 | 2013311-2 | 1 | CRYSTAL-4_0_CRY-D3225_24M-20PPM | Y1100 | CRY-D3225 | 1 | CRYSTAL_0_CRY_MC146_32.768K | Y2100 | CRY_MC146 | 1 | 附件:
& x( H( H# {' R0 Y" z原理图和PCB文件如下:/ A1 ]0 i; E$ s5 a, D* M9 ?
( A( E( O; V2 m0 G! r2 N' [, x3 f |
