作品名:[AD 16][4层]3G网络摄像机GM8216核心模块(LQFP176+DVM008+HY57V641620)PCB文件 1 i4 Z/ R2 Y2 [+ r( l5 ]
6 v, M% G8 {9 v! d文件描述
$ |; i0 |: n" C2 T* }3 ]$ r% `/ |, k1. 作品用途:3G网络摄像机GM8216核心模块1 M; ?, {' @; O) Q0 z
2. 软件版本:AD 16
& Q+ X5 |& o: S8 `( z/ @" J3. 层数:4层板
; S3 R, L. p) h7 N E$ ~* G' t4. 用到的主要芯片:LQFP176+DVM008+HY57V6416202 Z/ e% h2 Q( F+ r5 f+ c. z; k; u
5. PCB尺寸:30.2mm*50.9mm
0 z: B4 y3 t! }: H1 Z$ h/ J+ ~
- T$ I) O+ y9 h! l; a4 s- i& f8 Y1 r作品截图如下:
+ g8 o" m. |' `. Q8 m, j& y顶层截图:
$ g6 p0 n# K1 K! m% s
( B( [# o* [8 P; V
; [, z- {" M: `底层截图:! K# `; T6 E m
" X6 D8 o) B# l
: ^9 p3 o G3 ~ e4 N' q( k4 b; D
全层截图:
; ^* F' O( L/ ~6 S
4 h3 b/ O: B0 Z5 }* c- {* A5 f0 X% |" e* R
叠层信息截图如下:& {# n" x0 K! Y& {
( N2 H/ Y& {0 L: |9 H, z+ H
$ z- G9 L* I8 u3 c3 f/ m1 s6 KBOM:
* M1 [* b; d; ^1 X' zComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10uF | C1, C2, C3, C4, C5, C10, C12, C17, C19, C20, C21, C23, C29, C34, C37, C51, C55, C58, CT3 | C0805 | 19 | 22pF | C6, C7, C8, C9, C15, C16, C38, C39 | C0402 | 8 | 1uF | C11, C18, C22, C24, C30, C35, C52, C53, C54, C57 | C0402 | 10 | 15pF | C13, C14 | C0402 | 2 | NC(330pF) | C25 | C0402 | 1 | NC(47nF) | C26 | C0402 | 1 | NC(22pF) | C27, C28, C42, C43, C44, C45, C46, C47, C110 | C0402 | 9 | 0.1uF | C31, C32, CB1, CB2, CB3, CB4, CB5, CB6, CB7, CB8, CB9, CB14, CB15, CB16, CB22, CB23, CB24, CB25, CB26, CB27, CB28, CB30, CB31, CB32, CB44, CB45, CB46, CB47, CB48, CB50 | C0402 | 30 | 0.01uF | C33, C36, CW1, CW2, CW3, CW4, CW6, CW7, CW8, CW9, CW10, CW11, CW12, CW13, CW14, CW17 | C0402 | 16 | NC(10pF) | C59, C60 | C0402 | 2 | T-FLASH CARD CONNECTOR | CN1 | TF-2 | 1 | 47uF,6.3V | CT1, CT4 | CB3528 | 2 | 100M,30 | FB1, FB2, FB3, FB4, FB5, FB6, FB7, FB8, FB9, FB10, FB11, FB13, FB14 | 0603R | 13 | NC(0R) | J1 | R0402 | 1 | Mini_PCI-E_Socket | J3 | MINIPCIE_X2 | 1 | FPC_0.5MM_24PIN | J12 | FPC_0.5MM_24PIN | 1 | GREEN | LED1 | LED0603 | 1 | 22 | R1, R2, R3, R4, R6, R7, R8, R9, R53, R55, R60, R61, R62, R63, R66, R67, R69, R70, R71, R72, R73, R212, R213 | R0402 | 23 | 10K | R5, R74, R75, R153, R155, R156, R158, R159, R160 | R0402 | 9 | 220 | R10 | R0402 | 1 | NC | R11 | R0402 | 1 | 0 | R12, R17, R25, R167 | R0402 | 4 | 4.7K | R14, R15, R26, R28, R189, R190, R191 | R0402 | 7 | 1K 1 | R19, R20, R64, R65 | R0402 | 4 | NC(5.1K) | R21 | R0402 | 1 | 12K 1 | R22, R23 | R0402 | 2 | 3K | R24 | R-0402 | 1 | 100 | R68 | R0402 | 1 | 100M,30 | R128 | R0603 | 1 | NC(10K) | R149, R150, R151 | R0402 | 3 | NC(0) | R215 | R0402 | 1 | 22 | RN1, RN2, RN3, RN4, RN5, RN6, RN7, RN8, RN9, RN10, RP4, RP5, RP6 | 8P4R-0402 | 13 | GM8126 | U1 | LQFP176 | 1 | DVM008 | U2 | SOP8 | 1 | NC(RT9167/A-1.8) | U3 | SOT-23-5 | 1 | HY57V641620(K4T1G164QF-BCE7) | U4 | FBGA_84 | 1 | RT9167/A-1.5 | U5 | SOT-23-5 | 1 | MXIC MX25L12845EMI(SPI_FLASH,SOP16) | U19 | SO16-300 | 1 | 32768HZ | Y1 | XTAL2\3.2X1.5X0.75 | 1 | 30MHz | Y2 | XTAL4\4.2\3.2X2.5S | 1 |
: S. B2 n# I) `. p附件:
# D1 X: Q( ~; L% d( p! p) M# z8 BPCB源文件如下:
. {# J! z3 n, \7 N! }* u8 r
( j/ E9 _4 f3 x& e) ~
, T, W: Y( P* t0 |" Y |
