查看: 476|回复: 7
[allegro16.6][4层] 845E电脑主板(SMD_VT8754+SMD_VT8235+SMD_ZIF478)原理图和pc...
发表于 2020-2-18 18:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
( }) R% d, k, R$ S5 r0 {5 m- ?
[allegro16.6][4层] 845E电脑主板(SMD_VT8754+SMD_VT8235+SMD_ZIF478)原理图和pcb文件/ ~6 }6 u8 ^6 l5 I2 t2 ^
2 @) y  f  X2 z* Y" ^4 _1 A% ]
文件描述:3 J- y% e( m/ R* _
4 k+ h, i# L) A
1. 作品用途: 845E电脑主板
  H; l5 B1 E) M2. 软件版本:allegro16.6
/ T7 a' L* J, N; M  q5 }" ?3. 层数:4层2 ^  x% M( g6 {
4. 用到的主要芯片:SMD_VT8754+SMD_VT8235+SMD_ZIF478
/ B0 S, {$ X; }0 {+ K5. pcb尺寸: 9592*9592 MIL
) N% `9 H+ c2 j( I7 x
: _( E) D4 _# a+ C作品截图如下:
; G7 o' t! F3 R/ h+ G* Y8 d8 L8 y
2 w8 B( M+ ]" u* m" a7 h2 o顶层截图:+ n8 b% C/ n9 n- O
! o2 F* p3 g5 Y底层截图:# O6 e- v9 ~0 ?' k, r
# {% i: M9 F* L1 D3 G, w3 s0 R# s8 Z$ L- I: n
全层截图:  k" q  M$ H  D" s/ }
  }  n2 ~. }& C8 A9 V
" O# R- m9 ?# C7 @
! Q. c: V" y: |4 D) g3 c6 w% CBOM:! P5 e! L, r3 U) ?
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
8P4CSMD_CAP-PACK-8P4CYESDISCRETE11SCN1; SCN3; SCN4; SCN5; SCN6; SCN7; SCN8; SCN9; SCN10; SCN13; SCN14
8P4RSMD_R-PACK-8P4RYESDISCRETE100RN1; RN2; RN3; RN4; RN6; RN8; RN9; RN10; RN11; RN12; RN13; RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN27; RN28; RN29; RN30; RN31; RN32; RN33; RN34; RN35; RN36; RN37; RN38; RN39; RN40; RN41; RN42; RN43; RN44; RN45; RN46; RN47; RN48; RN49; RN50; RN51; RN52; RN53; RN54; RN55; RN56; RN57; RN58; RN59; RN60; RN61; RN62; RN63; RN65; RN66; RN68; RN69; RN70; RN73; RN74; RN86; RN87; RN99; RN101; RN102; RN103; RN104; RN105; RN106; RN107; RN108; RN109; RN110; RN111; RN112; RN113; RN114; RN115; RN116; RN117; RN118; RN119; RN120; RN121; RN122; RN123; RN124; RN125; RN126; RN127; RN128; RN129
AGPUNIVERSALDIP_AGP-SLOT_132PAGP SLOT UNIVERSALIO1AGP1
AUDIO-GAMEDIP_CONN_AUDIO-GAMEAUDIO_CONN-PC99IC1AUDIO_GAME1
BATDIP_COIN_BATBATTERY SOCKETDISCRETE1BAT1
C1206SMD_CAP_1206YESDISCRETE38CB19; CB20; CB21; CB22; CB23; CB24; CB25; CB26; CB27; CB38; CB39; CB40; CB41; CB42; CB43; CB44; CB45; CB68; CB69; CB70; CB71; CB75; CB76; CB79; CB80; CB81; CB82; CB104; CB105; CB106; CB107; CB108; CB109; CB226; CB227; CB228; CB229; CB230
CAP250DIP_CAP_D250MILDISCRETE1C16
CN1X4-2MMWHDIP_CONN_CDIN_1X4-PP20IO1CN12
CN1X4-25MMWHDIP_CONN_CDIN_1X4-PP25IO1CN11
COIL-17MMDIP_COIL_L165-P89-H140YESDISCRETE3L7; L9; L11
CT_TYPE-CSMD_CAP_TYPE-CIC2C26; C27
DB9MDIP_CONN_DTYPE-9PIO2COM1; COM2
DB25FDDIP_CONN_DTYPE-25PIO1COM_LPT1
DIMM184DIP_DDR-SLOT-184PDIMM184-NYLOW-WDISCRETE2DDR1; DDR2
DIP_CAP_D130-P50DIP_CAP_D130-P50IO14CE1; CE3; CE5; CE8; CE10; CE12; CE13; CE14; CE15; CE16; CE17; CE20; CE25; CE27
DO1545-12SMD_DIODE_DO1545-12DISCRETE14D1; D2; D3; D8; D9; D10; D11; D12; D13; D18; D27; D28; D29; D30
DRILL-150_PAD-300DRILL-150_PAD-300IO7MH1; MH2; MH3; MH4; MH5; MH6; MH7
EC_D50-P20-H70DIP_CAP_D50-P20IC47CE6; CE7; CE9; CE19; CE21; CE23; CE24; CE26; CE30; CE31; CE32; CE33; CE37; CE42; CE49; CE52; CE53; CE54; CE56; CE57; CE58; CE62; CE65; CE66; CE67; CE68; CE69; CE73; CE74; CE75; CE86; CE87; CE88; CE89; CE90; CE92; CE94; CE95; CE98; CE101; CE102; CE103; CE104; CE105; CE108; CE109; CE110
EC_D60-P25-H70DIP_CAP_D63-P25IC4CE22; CE35; CE96; CE97
EC_D80-P35-H110DIP_CAP_D80-P35DISCRETE4CE70; CE79; CE106; CE107
EC_D100-P50-H200DIP_CAP_D100-P50DISCRETE7CE18; CE28; CE29; CE34; CE64; CE91; CE93
FAN_CONNDIP_FAN_1X3PIO2FAN2; FAN3
FDD_CNTR_2X17DIP_BOX-HEADER_2X17DISCRETE1FDD1
H1102SMD_H1102_SOP16IC1T1
HEADER_2X4HEADER_2X4IC1JP4
IDEDIP_BOX-HEADER_2X20_P20NCIO2IDE1; IDE2
JP2DIP_HEADER_1X2PIO1RT1
JP3DIP_HEADER_1X3PIO5JP1; JP3; JP6; JP7; JP8
JP5DIP_HEADER_1X5PIO2J1; J2
JP5X2DIP_HEADER_2X5PIO2USB1; USB2
JP6X2DIP_HEADER_2X6PIO1J3
JP8X2VDIP_HEADER_2X8PIC1J5
L0603SMD_L_0805DISCRETE4L20; L24; L32; L33
L0805SMD_L_0805DISCRETE31L1; L2; L3; L4; L5; L8; L10; L12; L13; L19; L21; L23; L26; L30; L35; L36; L49; L50; L51; L52; L53; L54; L55; L56; L57; L58; L59; L60; L61; L62; L63
MINI-SMDC110SMD_POLY-SW_MINI-C110DISCRETE4FS1; FS2; FS3; FS4
PCISLOTDIP_PCI-SLOT_120PIO3PCI1; PCI2; PCI3
PLCC32SMD_PLCC32IC1U27
POWER-ATXDIP_ATXPWR_2X10PIO1ATXPWR2
POWER_2X2PDIP_ATXPWR_2X2PDISCRETE1ATXPWR1
PQFP128SMD_TQFP128IC1U22
PS2X2DIP_CONN_KB-PS2IO1PS2KBMS1
RJ45_USBDIP_CONN_USB-RJ45DISCRETE1CN2
SMD-SSOP56SMD-SSOP56IC1U14
SMD_CAP_0603SMD_CAP_0603IC412C2; C3; C4; C6; C7; C8; C9; C10; C12; C13; C15; C18; C19; C20; C22; C23; C24; C25; C28; C29; C30; C31; C52; C57; C58; C59; C63; C64; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C101; C102; C103; C104; C105; C106; C107; C108; C110; C111; C112; C115; C116; C120; C121; C122; C123; C124; C125; C452; C453; C509; C512; C513; C532; C533; C534; C535; C536; C537; C538; C539; C540; C541; C542; C543; C544; C545; C546; C547; C548; C549; C550; C551; C552; C553; C554; C555; C556; C557; C558; C559; C560; C561; C562; C563; C564; C565; C566; C567; C568; C569; C570; C571; C572; C573; C574; C575; C576; C577; C578; C579; C580; C581; C582; C583; C584; C585; C586; C587; C588; C589; C590; C591; C592; C593; C594; C595; C596; C597; C598; C599; CB2; CB5; CB8; CB9; CB10; CB13; CB16; CB17; CB18; CB30; CB31; CB32; CB33; CB34; CB36; CB37; CB46; CB47; CB48; CB49; CB50; CB51; CB52; CB53; CB57; CB58; CB59; CB60; CB61; CB62; CB63; CB64; CB65; CB66; CB67; CB72; CB73; CB74; CB77; CB78; CB83; CB84; CB85; CB86; CB87; CB88; CB89; CB90; CB91; CB92; CB93; CB94; CB96; CB97; CB98; CB99; CB100; CB101; CB102; CB103; CB110; CB111; CB112; CB115; CB117; CB119; CB123; CB125; CB126; CB127; CB128; CB129; CB131; CB132; CB133; CB134; CB135; CB136; CB137; CB138; CB139; CB140; CB142; CB143; CB144; CB145; CB147; CB148; CB149; CB150; CB151; CB152; CB153; CB156; CB157; CB158; CB160; CB161; CB162; CB163; CB164; CB165; CB166; CB167; CB168; CB169; CB170; CB171; CB172; CB173; CB174; CB179; CB180; CB181; CB184; CB190; CB191; CB192; CB193; CB194; CB195; CB196; CB197; CB198; CB199; CB200; CB201; CB202; CB203; CB204; CB205; CB206; CB207; CB208; CB209; CB210; CB211; CB212; CB213; CB216; CB217; CB218; CB219; CB221; CB225; CB255; CB256; CB257; CB258; CB259; CB260; CB262; CB263; CB264; CB265; CB266; CB267; CB268; CB269; CB270; CB271; CB272; CB273; CB274; CB275; CB276; CB278; CB279; CB280; CB281; CB282; CB304; CB305; CB306; CB307; CB308; CB309; CB310; CB311; CB312; CB313; CB314; CB315; CB316; CB317; CB318; CB319; CB320; CB321; CB322; CB323; CB324; CB325; CB326; CB327; CB328; CB329; CB330; CB331; CB332; CB334; CB335; CB337; CB338; CB339; CB340; CB341; CB342; CB343; CB344; CB345; CB346; CB347; CB348; CB349; CB350; CB351; CB352; CB353; CB354; CB355; CB356; CB357; CB358; CB359; CB360; CB361; CB362; CB363; CB364; CB365; CB366; CB367; CB368; CB369; CB370; CB371; CB372; CB373; CB374; CB375; CB376; CB377; CB378; CB379; CB380; CB381; CB382; CB383; CB384; CB385; CB386; CB387; CB388; CB389; CB390; CB391; CB392; CB393; CB400; CB401; CB402; CB403; CB404; CB405; CB406; CB407
SMD_CAP_0805SMD_CAP_08051uIC1C600
SMD_R_0603SMD_R_0603IC363R2; R3; R4; R10; R11; R12; R13; R15; R16; R17; R18; R19; R20; R21; R22; R23; R24; R25; R26; R27; R28; R29; R30; R31; R32; R33; R34; R35; R36; R37; R38; R39; R40; R41; R42; R43; R44; R45; R46; R48; R49; R51; R52; R53; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R66; R67; R68; R71; R72; R73; R74; R75; R77; R78; R79; R80; R81; R82; R83; R84; R85; R86; R87; R88; R89; R90; R93; R94; R95; R96; R100; R101; R102; R103; R108; R109; R110; R115; R117; R119; R125; R135; R136; R137; R138; R142; R147; R148; R149; R150; R151; R155; R156; R157; R161; R163; R164; R169; R170; R176; R177; R178; R179; R184; R185; R186; R187; R188; R189; R190; R191; R192; R193; R194; R195; R196; R197; R198; R199; R200; R201; R202; R203; R204; R206; R207; R208; R209; R210; R211; R213; R215; R216; R217; R221; R224; R229; R230; R231; R232; R233; R234; R235; R236; R237; R238; R239; R240; R241; R242; R243; R255; R256; R257; R258; R259; R260; R261; R262; R263; R264; R265; R266; R269; R270; R271; R272; R273; R274; R275; R276; R277; R278; R284; R285; R286; R287; R289; R290; R295; R297; R300; R304; R306; R307; R308; R309; R310; R311; R313; R315; R316; R317; R318; R322; R324; R330; R331; R332; R333; R334; R335; R338; R339; R341; R342; R343; R344; R345; R346; R347; R348; R353; R354; R355; R356; R357; R363; R371; R372; R374; R437; R438; R439; R440; R441; R444; R445; R446; R447; R448; R492; R493; R494; R495; R496; R497; R498; R499; R500; R501; R502; R505; R507; R508; R509; R510; R511; R512; R515; R516; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R527; R528; R529; R530; R531; R533; R535; R536; R537; R538; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553; R554; R555; R556; R557; R558; R559; R560; R561; R562; R563; R564; R565; R566; R567; R568; R569; R570; R571; R572; R573; R574; R575; R576; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R593; R594; R595; R596; R597; R598; R599; R600; R601; R602; R603; R604; R605; R606; R607; R608; R609; R610; R611; R612; R613; R614; R615; R616; R617; R618; RA1; RB1; RC1
SMD_R_0805SMD_R_0805IC6R8; R9; R442; R443; R539; R540
SMD_VT8235_BGA487SMD_VT8235_BGA487DISCRETE1U20
SMD_VT8754_BGA858SMD_VT8754_BGA858IC1U15
SOP8SMD_SOP8IC6Q13; Q18; U10; U16; U18; U33
SOP14SMD_SOP14IC5U3; U7; U21; U24; U28
SOP16SMD_SOP16IC2U4; U6
SOT23-5SMD_SOT23-5IC2U36; U37
SOT23-BCESMD_SOT23-BCEDISCRETE8Q12; Q15; Q16; Q30; Q32; Q34; Q36; Q39
SOT23-GDSSMD_SOT23-GDSDISCRETE5Q9; Q11; Q14; Q19; Q31
SOT223-123SMD_SOT223-123DISCRETE1Q38
SOT223-BCESOT223-BCEIC1Q17
SSOP28SSOP28IC1U5
SSOP48SMD_SSOP48IC1U19
TO92-123DIP_TO92-123DISCRETE1Q24
TO92-RACTO92-RACIC1Q8
TO252-GDSSMD_TO252-GDSDISCRETE3Q21; Q28; Q37
TO263AB-GDSSMD_TO263AB-GDSDISCRETE7Q1; Q2; Q3; Q4; Q5; Q6; Q7
TQFP48SMD_TQFP48IC1U17
TSSOP20SMD_TSSOP20IC2U8; U38
WOLDIP_CONN-WOL_1X3PIO1J4
XTAL_49USDIP_XTAL_49USDISCRETE3Y1; Y2; Y3
XTAL_CYLINDERDIP_XTAL_CYLINDERDISCRETE1Y4
ZIF478SMD_ZIF478IC1U11
附件:8 M, r) Z7 v) y8 z* B
PCB文件如下:
( q1 w; T4 }! b; _, p' O: f, D
游客,如果您要查看本帖隐藏内容请回复
6 Z% N, Q' |( [0 W/ V( R
$ j% j$ m# i7 q/ j+ T
    郁闷
    2020-3-10 15:59
    发表于 2021-5-24 17:44 | 只看该作者
    845E电脑主板
    2023-12-7 15:29
  • 签到天数: 99 天
    [LV.6]常住居民II
    发表于 2021-10-16 14:41 | 只看该作者
    1111111111111111111
    奋斗
    2025-6-9 15:24
  • 签到天数: 337 天
    [LV.8]以坛为家I
    发表于 2021-10-26 10:20 | 只看该作者
    20年前的板子了吧
    2025-10-11 15:00
  • 签到天数: 280 天
    [LV.8]以坛为家I
    发表于 2023-7-18 23:30 | 只看该作者
    原理图和PCB文件
    GMT+8, 2025-10-12 12:33 , Processed in 0.171875 second(s), 27 queries , Gzip On.
