本帖最后由 um352 于 2020-2-17 18:07 编辑 3 v2 R7 Y) S m# l j6 C4 d
& J9 P/ [8 I, _* a! y
[AD 15][2层]12V 15A开关电源(UF1003+UF1007+TEA19161T)原理图和PCB文件4 R. ~+ w V) k- s2 ]
- g0 \7 j: ^: T% n0 G, A文件描述
! t# Q8 Z( ?6 m+ H) _1. 作品用途:12V 15A开关电源
2 o' p; a& j' }% S2. 软件版本:AD 15# m8 m! a6 E2 M. z, y" @
3. 层数:2层板* c3 m1 t1 D& @4 h: x+ x% z
4. 用到的主要芯片:UF1003+UF1007+TEA19161T5. PCB尺寸:2313*6338 MIL ?. ]( l5 r$ U) `
4 F8 }0 u! X* p! W; o6 L3 p作品截图如下:
7 \ V; Y' w& a- O# p, y4 ~
( }4 F5 }% b% ?: L底层截图:
' \8 [& b7 U, c$ _
1 i3 [* p' P" q0 W/ s7 E
7 R% e" K1 Z( m1 W2 |
全层截图:
9 m$ C3 \) i( K) |. _/ U5 }6 Q
/ X; {, X0 O2 G' l, g; F4 i
叠层信息截图如下:* C. v% C5 n2 l+ g5 a; h2 s+ X% Y
8 A* j3 z) B: M6 [4 z9 s' m/ s: PBOM:! i H! \8 i& z
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 606 | BD1 | BR2 | 1 | 35V/47UF | C2 | ec6 | 1 | 10UF/25V | C3 | ec5 | 1 | 474/450V | C104, C106 | C2.5A | 2 | 101 | C108, C111, C203, C203A, C308 | 0805-B | 5 | 154 | C109, C305 | 0805-B | 2 | 474 | C110 | 0805-B | 1 | 103 | C112 | 0805-B | 1 | 104 | C113, C204, C306, C318 | 0805-B | 4 | 472 | C114 | 0805-B | 1 | 180UF | C115 | C100A | 1 | 103/630V | C116, C117 | 1206-1 | 2 | 222 | C207, C210 | 0805-B | 2 | 47PF/1kv | C208 | cm5 | 1 | 102/1kv | C209 | cm5 | 1 | 391/1kv | C211, C216 | cm5 | 2 | 332 | C212 | 0805-B | 1 | 334 | C213 | 0805-B | 1 | 105 | C214 | 0805-B | 1 | 106 | C215 | 1206-1 | 1 | 152 | C217 | 0805-B | 1 | 104/630V | C220 | C2.5A | 1 | 2200UF/16V | C301, C302, C303, C304, C309 | C13MM | 5 | 473 | C307 | 0805-B | 1 | 10UF/25V | C310, C311, C312, C313, C314, C315 | 1206-1 | 6 | 102 | C316, C317 | 0805-B | 2 | 224 | CX1, CX2 | C15MM | 2 | 222/250V | CY1, CY2 | C200A | 2 | STTH8R06D | D102 | TO-23 | 1 | IN5406 | D103 | D25 | 1 | 4148 | D104, D201, D202, D207, D208 | 1206-1 | 5 | UF1003 | D203, D204, D205 | DSO-C2/X2.3 | 3 | UF1007 | D206 | DSO-C2/X2.3 | 1 | 20C60D | D301, D302 | TO-23 | 2 | | F1 | C5MM | 1 | | FL1 | DG-4PA | 1 | 18*10*9 | FL2 | DG-4P | 1 | 339 | IC105 | SO8 | 1 | 1*10MM | J1, J6 | jp10 | 2 | 0.6*8MM | J2 | jp08 | 1 | 0.6*12MM | J3, J9 | jp12 | 2 | 0R | J4, R198, R216, R217 | 0805-B | 4 | 1*8MM | J5, J7, J14 | jp08 | 3 | 1*12MM | J8, J13 | jp12 | 2 | | J10 | J600 | 1 | 0.8*15MM | J11 | jp15 | 1 | 1*35MM | J12 | JP35 | 1 | 1*15MM | J15 | jp15 | 1 | 30UH | L1 | C11.5 | 1 | 70UH | L3 | C11.5 | 1 | RM10 | L104 | DG-4PB | 1 | 4*15*2.5TS | L301 | DR5*15 | 1 | | LED1 | LED-2P | 1 | 1R5 | NTC1 | C-2P | 1 | | NTC2 | C2.5A | 1 | 8050 | Q1 | SOT89M | 1 | 5R199 | Q101 | TO-23 | 1 | 8550 | Q102 | SOT-23-431 | 1 | 5R520 | Q201, Q202 | TO-23 | 2 | | R1, R2 | 1206-1 | 2 | 6.8M | R101, R102, R102A | 1206-1 | 3 | 10R | R103, R203A, R203B, R301, R302, R303, R304, R311, R312 | 0805-B | 9 | 4.7R | R104 | 0805-B | 1 | 1K | R106, R229 | 0805-B | 2 | 0.05R | R107 | 2010 | 1 | 5.1K | R110 | 0805-B | 1 | 3.6K | R111 | 0805-B | 1 | 33K | R112, R307 | 0805-B | 2 | 100K | R113 | 0805-B | 1 | 1.2M | R114, R115, R116, R117 | 0805-B | 4 | 30K | R118 | 0805-B | 1 | 1R | R119, R122 | 0805-B | 2 | 3.9K | R120 | 0805-B | 1 | 360k | R121 | 0805-B | 1 | 10R | R201, R210 | 1206-1 | 2 | 10K | R201A, R201B, R314 | 0805-B | 3 | 10R | R202, R204 | r06 | 2 | 22R | R203 | 1206-1 | 1 | 47K | R206, R308, R313 | 0805-B | 3 | 8.2K | R207 | 0805-B | 1 | 2.2M | R208, R209 | 1206-1 | 2 | 18K | R211 | 0805-B | 1 | 68K | R212 | 0805-B | 1 | 6.2K | R213, R214, R231, R232 | 0805-B | 4 | 20K | R215 | 0805-B | 1 | 2.7K | R298, R305 | 0805-B | 2 | OR | R299 | 0805-B | 1 | 4.99K | R309 | 0805-B | 1 | 2.7K | R310 | 1206-1 | 1 | PQ3220 | T1 | PQ3220 | 1 | TEA19162 | U101 | SO-8 | 1 | TEA19161T | U201 | M14A | 1 | PC817 | U202 | DIP4 | 1 | 431 | U302 | SOT-23-431 | 1 | 16V | ZD1 | 1206-1 | 1 | | [NoValue], FG, GND, L, N, V+ | HP | 6 | 附件:8 H" Y" S" m* P) N; t. m
原理图和PCB文件如下:* w; J9 N) {- Z5 f9 V5 E! |
, u/ b2 H/ I# P) M; p. v% Y
