查看: 292|回复: 1
ZCC2007替代SY7066
发表于 2020-2-13 21:52 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
he ZCC2007 is a high efficiency, high power
density, current mode, fully integrated boost
converter with output disconnect, which can
start up from  an input voltage as low as 1.8V
and convert up to 5.5V output  voltage. During
shutdown, it can disconnect the output  from
input.
( v: e7 g, ]$ A# T
Features
1 u( Z7 q3 P7 |4 F3 T
; k: m# h* W' Y
Input Voltage Range: 1.8V to 5.5V
/ C0 U2 S; B- M6 e) U/ O
Output Voltage Range: 2.5V to 5.5V
7-A Peak Switching Current Limit
Two 20-mΩ(LS)/20-mΩ(HS) MOSFETs
40uA Quiescent Current
Internal Compensation and Soft-start
True Load Disconnect from Input
Low Shutdown Current  < 1µA
+ ?- I. T% A% T& [" E1 r
This converter integrates two 7A/20mΩ power
switches for high converter efficiency and can
deliver up to 2.5-A  output current  at 5V output
with 2.5V input  supply. When the output is
shorted, the ZCC2007 enters  hiccup protection
mode and recover automatically when  the
output short is removed.
8 j* _/ Z; `+ @4 a
Output Overvoltage Protection
+ z: A4 C1 M3 N1 Z
OVP, OCP, SCP  and OTP Protection
High Efficiency over  Whole Load Range
Small 2x2mm QFN 11-Pin Package
/ k2 B+ Z0 m* c! t) q6 e2 Y6 s
Applications
4 M/ l! _% ]1 G7 P/ R8 d
The ZCC2007 also includes input under-voltage
lockout, output over-voltage protection, cycle-
by-cycle over-current protection, short circuit
protection and thermal  shutdown to prevent
7 _# ~! p- K1 bdamage in the event of output overload. " p" c  ^$ O' Z5 v* P
ZCC2007 替代SY7066.pdf
820.28 KB, 下载次数: 0, 下载积分: 威望 -5
发表于 2020-2-25 20:16 | 只看该作者
ZCC2007替代SY7066
GMT+8, 2025-10-27 18:39 , Processed in 0.156250 second(s), 26 queries , Gzip On.
