作品名:[AD 10][4层]网口转接板(LM2576S-5.0V)PCB源文件
) _0 H' R5 q& Y. S" D8 |, z* z; ?
文件描述/ k: D) a+ D9 q: _
1. 作品用途:网口转接板
! E. B7 d) {6 v! ]& q8 @' _2. 软件版本:AD 10+ ~) ~# J$ R& K1 X0 O% p4 _+ K
3. 层数:4层板 E3 [) n" l8 `1 t% d/ Y9 X
4. 用到的主要芯片:LM2576S-5.0V
: p3 O z: S3 `% w9 O; {1 H" K5. PCB尺寸:105.8mm*98.8mm
7 ^1 N9 A3 W. f- ~7 L) `" n K8 H* c5 P4 d$ L" q
作品截图如下:8 u" T% Z- ]7 i0 m6 g6 ]- t
顶层截图:+ _+ k# Q% t; c" f9 c
! J# z9 E% K- H9 s4 O; ~
: w/ d0 E8 Y# {' ? S
底层截图:) X$ B* _4 A3 A* _: L0 w! x7 E
) D* ]6 Q) l4 s$ M, W) t
0 D( C8 l! _1 | ]# X) x全层截图:
$ }, Z% a9 Q$ O" \1 B' [ V
8 D" K% Z6 Y+ r e9 |1 q9 c: e% h3 S$ P. ]( H
叠层信息截图如下:$ v% u* R s- @ k [: W% m: z
( C! z! o/ C( f8 w* `( [" B) }: r( V$ p% J, q0 _
BOM:
7 `' W- V% H+ V3 I! ]* OComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 100nF/50V 0603 | C1, C2, C4, C5, C7, C8, C10, C11, C13, C22, C23, C24, C25, C27, C28 | 0603C | 15 | 220uF | C3, C9, C19, C20 | C_8MMx8MM | 4 | 470uF/35V | C6, C12, C21, C26 | C_8MMx8MM | 4 | 1000pF | C14, C15, C16, C17, C18 | 1812C | 5 | Console Port | COM | RJ45-1 | 1 | 1N5824 | D1, D2 | SMC/DO-214AB | 2 | 2000mAF | F1, F2 | 1206F | 2 | 1000mAF | F3 | 1206F | 1 | 1200mAF | F4 | 1206F | 1 | FE1 | FE1 | RJ45-1 | 1 | FE2 | FE2 | RJ45-1 | 1 | FE4 | FE4 | RJ45-1 | 1 | FE6 | FE6 | RJ45-1 | 1 | FE8 | FE8 | RJ45-1 | 1 | GE1 | GE1 | RJ45-1 | 1 | GE2 | GE2 | RJ45-1 | 1 | hole | H1, H2, H3, H4 | Hole-4 | 4 | connect | J2, J3, J4, J5 | 0603R | 4 | 100uH | L1, L2 | L_12MMx12.7MM | 2 | PIN2 | P1, P2 | 两针绿色直端子3.81 | 2 | BTB2x40_F | P13 | 61083-80PIN-SOP | 1 | BTB2x30 | P15 | 61083-60PIN-SOP | 1 | 0 2512 | R1, R4 | 2512R | 2 | n.b. | R2, R6, R8 | 0603R | 3 | 22 | R3, R5, R7 | 0603R | 3 | 0 | R9 | 1206R | 1 | 75 | R10, R11, R12, R13, R14, R15, R16, R17, R18, R19 | 0603R | 10 | LM2576S-5.0V | U1 | TO-263 | 1 | LM2576S-3.3V | U2 | TO-263 | 1 | SMBJ5.0A | V1 | SMB | 1 | SMBJ12A | V2 | SMB | 1 |
% u' J5 \# d" m1 R5 j0 y) G附件:
9 T7 ]5 r! h: l. Y/ j @* S; |PCB源文件如下:7 V9 l' A f8 _# ?- Y- K' v
9 H; T1 ?/ I3 Z( J0 H+ O) l3 H2 L8 n1 b
