查看: 320|回复: 0
[allegro16.6][6层] SiI9396方案参考板(SiI9396+NUC123LC2AN1+W25Q16CVZPIG)pcb...
发表于 2020-2-11 12:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
, t" F" I0 [) S8 C2 u; N" A+ k[allegro16.6][6层] SiI9396方案参考板(SiI9396+NUC123LC2AN1+W25Q16CVZPIG)pcb文件5 h/ S7 c3 ]& M5 f: h
$ {9 v+ z3 n1 ]0 L- u
文件描述:
0 z# h( ]) N! J. j+ }& \. B0 o9 P. u
1. 作品用途:SiI9396方案参考板% x: _2 I8 v* l
2. 软件版本:allegro16.6
0 {& T  {7 L$ h3 n. y  m# @  v9 x3. 层数:6层# S; g! S0 D* W/ X5 l' }) s7 W
4. 用到的主要芯片:SiI9396+NUC123LC2AN1+W25Q16CVZPIG
0 r3 A/ \5 ]! G& F8 R4 d( ~+ ~5. pcb尺寸: 2615*1683 MIL( Y  v. h% @% E& k: ^
1 G9 W1 y8 k1 i1 v3 y
作品截图如下:
: e% v2 c' L: r2 O& A
  @0 Y  A1 p* a# N顶层截图:8 b( R( I0 A2 m) |; e
. U: O0 D, W  }! L, T1 z底层截图:) j! _5 k  q/ O* T+ ^# Z/ w
, P+ x/ G- u% C9 d2 w8 c; T
+ a+ X' J7 m1 n+ `3 i# K全层截图:0 u4 }7 i2 a1 U- ~, ?5 y- J
$ o* H6 `; [8 X5 u3 q; u% N- B2 }1 U; L0 ?
BOM:: K4 I5 |# E( v7 a4 T& _
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
1206FUSE_RESETTABLE/SMT_0_1206_1A1AIC1F1
ABRACON_ASPI-0418FSINDUCTOR_ABRACON_ASPI-0418FS_2.2.2uHIC1L8
C0402C_0402_C0402_18PF18pFIC2C17; C18
C0402C_0402_C0402_0.1UF0.1uFIC19C21; C23; C25; C26; C27; C29; C30; C32; C34; C36; C38; C39; C40; C41; C42; C45; C47; C133; C354
C0603C_0402_C0603_2.2UF2.2uFIC8C22; C24; C31; C33; C35; C37; C44; C46
C0603C_0402_C0603_1UF1uFIC1C56
C0805C_0402_C0805_10UF/16V10uF/16VIC4C19; C20; C28; C43
CAPC1005X55LCAP-NP_CAPC1005X55L_1.0UF1.0uFIC1C128
CAPC2013X140LCAP-NP_CAPC2013X140L_10UF10uFIC1C139
CC0402CAP NP_CC0402_0.1UF0.1uFIC6C5; C8; C306; C307; C308; C351
CC0402CAP NP_CC0402_0.015UF0.015uFIC1C11
CC0402CAP NP_CC0402_18PF18pFIC1C12
CC0402CAP NP_CC0402_2700PF2700pFIC1C93
CC0402CAP NP_CC0402_22PF22pFIC2C320; C321
CC0402CAP NP_CC0402_1000PF1000pFIC1C355
CC0603CAP NP_CC0603_1UF1uFIC1C14
CC0603CAP NP_CC0603_4.7UF4.7uFIC4C83; C141; C165; C353
CC0805CAP NP_CC0805_10UF10uFIC2C7; C10
CC1206CAP NP_CC1206_47UF47uFIC2C6; C127
CC1206CAP NP_CC1206_100UF100uFIC1C9
CC1206CAP-NP_CC1206_100UF100uFIC1C212
CHOKE_0504CHOKE_C-MODE_CHOKE_0504_EXC-24CEXC-24CE900UIC2L5; L12
CONN_1X4_125_THHEADER-1X4_CONN_1X4_125_TH_DF13Df13-4P-1.25DSAIC2J5; J8
CONN_DF40C_50DSCONN-DF40C-50DS_CONN_DF40C_50DSDF40C-50DS-0.4VIC1J4
CONN_HDMI_47151HDMI_TYPE_A_CONN_HDMI_47151_HDMHDMI_TYPE_AIC1J1
CONN_PWR_PJ057AHCONN-PWR-JACK_CONN_PWR_PJ057AH_2.1mmIC1J3
CRY_4P_2P5X2P0CRYSTAL-4P_CRY_4P_2P5X2P0_12.0012.000MHzIC1Y302
DFN100X60X40-2NESD8V0L1B-02LRH_DFN100X60X40-2NESD5V3L1U-02LRHIC4D12; D13; D14; D15
DLP11DLP11 SERIES-COMMON MODE CHOKE_DLP11SA350IC4L1; L2; L3; L4
FB0603BEAD_FB0603_FB_120_OHM_0.9A_POWFB_120_OHM_0.9A_PowerIC5FB1; FB2; FB3; FB4; FB5
FCI_10118194-0001LFUSB-MICRO-B-MID-RCPT_FCI_101181USB-MICRO-BIC1J2
FCI_10118194-0001LFUSB-MICRO-B-RCPT_FCI_10118194-0USB-MICRO-BIC1J9
HD1X3JUMPER3 - C_0_HD1X3_NP HDR3X1NP HDR3x1IC2JP15; JP16
HDR1TESTPOINT_HDR1_IO_M1_DETECTM1_DETECTIO1TP6
INDC1608X65LFERRITE-BEAD_INDC1608X65L_220OH220ohm100MHzIC1FB21
INDC1608X65LFERRITE-BEAD_INDC1608X65L_NP INNP INDC1608X65LIC1FB22
LED_RA_0805LED_LED_RA_0805_GREENGreenIC1D1
LED_SMD_0603LED_0_LED_SMD_0603_GREENGreenIC2D9; D10
MTH_PL_D087C107MOUNTING_HOLE_MTH_PL_D087C107_22.2mm DIAIC5Z1; Z2; Z3; Z4; Z5
PG-TSLP-9-1ESD5V3U4U-HDMI_PG-TSLP-9-1_ESD5ESD5V3U4UIC3U1; U2; U3
PL3230INDUCTOR_PL3230_1.5UH1.5uHIC1L7
QFN16_3X3TPS54218_QFN16_3X3_TPS54318TPS54318IC1U5
QFN50P300X300X60-17NSC183C_QFN50P300X300X60-17N_SC1SC183CIC1U16
QFN_76_SOCKETSII9396_QFN_76_SOCKET_SII9396SiI9396IC1U8
QFP48-050-0707NUC123LC2AN1_4_QFP48-050-0707_NNUC123LC2AN1IC1U409
R0603R_0402_R0603_0R06030R0603IC5R51; R75; R76; R77; R79
R0603R_0402_R0603_0.1 1%0.1 1%IC6R71; R73; R74; R78; R80; R81
RC0402CAP-NP_RC0402_1000PF1000pFIC1C229
RC0402FERRITE-BEAD_RC0402_220OHM100MH220ohm100MHzIC2FB36; FB39
RC0402RES_RC0402_2727DISCRETE2R12; R15
RC0402RES_RC0402_330330IC3R14; R16; R23
RC0402RES_RC0402_100K100KIC2R17; R66
RC0402RES_RC0402_31.6K31.6KIC1R18
RC0402RES_RC0402_22.6K22.6kIC1R19
RC0402RES_RC0402_3333IC2R21; R529
RC0402RES_RC0402_2.0K2.0KIC2R25; R31
RC0402R_0402_RC0402_51K51KIC1R45
RC0402R_0402_RC0402_4.7K4.7KIC5R46; R47; R151; R152; R519
RC0402R_0402_RC0402_1010IC3R48; R72; R507
RC0402R_0402_RC0402_1M1MIC1R50
RC0402RES_RC0402_00IC8R102; R520; R521; R522; R523; R524; R525; R526
RC0402RES_RC0402_10K10KIC6R268; R510; R514; R515; R516; R518
RC0402RES_RC0402_30.1K30.1kIC1R270
RC0402RES_RC0402_13.7K13.7kIC1R271
RC0402RES_RC0402_1.0M1.0MIC1R506
RC0402R_0402_RC0402_5.1K 1%5.1K 1%IC1R508
RC0402R_0402_RC0402_300K300KIC1R509
RC0402R_0402_RC0402_2.2K2.2KIC2R511; R512
RC0402R_0402_RC0402_47K47KIC1R513
RC0402VARISTOR_RC0402_AVR-M1005C120MTAVR-M1005C120MTAABIC2RV8; RV11
RC0603RES_RC0603_182K182kIC1R20
RESC1005X40LRES_RESC1005X40L_1010IC1R101
SMD_5MM3_2MMCRYSTAL 11_2.0592 MHZ_SMD_5MM3_27 MHzIC1Y1
SW_KMS221GPSWITCH-MOMENTARY_4_SW_KMS221GP_SPST-NO,MomIC2SW1; SW9
TLSP-2-17ESD8V0L1B-02L_TLSP-2-17_ESD8V0LESD8V0L1B-02LIC1D2
TSWR7-SSSS810701LY-SK02-1 5H_1_TSWR7-SSSS810701NP SSSS810701IC1SW8
VC0603VARISTOR_VC0603_AVR-M1608C120MTAVR-M1608C120MTABIC2RV1; RV2
WSON8_6X5W25X16ALZPIG_WSON8_6X5_W25Q16CVW25Q16CVZPIGIC1U6
附件:8 m1 D3 y' q$ M" H* _
PCB文件如下:  {3 ~: n0 E# k: d0 S
游客,如果您要查看本帖隐藏内容请回复
# X/ r" s& z. ^& _
* d! c& J5 K1 X, R8 d, u
GMT+8, 2025-9-14 02:40 , Processed in 0.171875 second(s), 29 queries , Gzip On.
