查看: 193|回复: 0
[allegro16.6][8层]S32K148EVB(Q176)REV B版本 官方评估板(PS32K118UEX0MLUT+P...
发表于 2020-2-11 12:47 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]S32K148EVB(Q176)REV B版本  官方评估板(PS32K118UEX0MLUT+PS32K118UEX0MLQT+UJA1131HW/FD/5V/0)原理图和pcb文件
  b2 k8 p! G* w8 l" N
' `, [; w6 u2 Y) s& w8 ~2 A文件描述:
& K* `& N3 t  }! H' ?& i
3 F- w+ L# |: B0 L& Q& M1. 作品用途:S32K148EVB(Q176)REV B版本  官方评估板1 ~3 b1 q! W* D4 Y. h
2. 软件版本:allegro16.66 j& L. Q  S! A2 ^
3. 层数:8层2 X$ I: i7 D# ]; d: H
4. 用到的主要芯片:PS32K118UEX0MLUT+PS32K118UEX0MLQT+UJA1131HW/FD/5V/0
5 a; ?2 j: g' L# A5. pcb尺寸:4950*3350 MIL( T5 q& h1 R$ V. V8 B; H- e  w! _
+ T  p: u# l  F6 m
作品截图如下:
9 V# q* W' |% O0 f) w; t( i' F5 ^5 u. r! _5 }
顶层截图:
: q4 }. u8 M. k; F ' u3 A# U/ f- |& T* |0 [6 s$ f5 Z* d0 o
底层截图:
1 e& U0 S3 z) q  Z$ K. O
4 v+ R$ z: B6 o  J, X: h6 R+ z) ]全层截图:& D% k3 a9 @0 F
7 y' k( P4 A' r8 J( n6 t
叠层阻抗信息:8 N- R8 U: r! R$ O9 {' U# ~' T
6 F1 b1 j+ F- K, v7 ~
BOM:
: W9 J# Q+ }0 K) W4 s: {" e$ K' Y
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uFDISCRETE32C1;C2;C10;C12;C13;C14;C21;C22;C31;C60;C79;C82;C85;C86;C87;C88;C109;C110;C114;C115;C512;C513;C514;C515;C519;C520;C521;C522;C526;C547;C548;C549
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_412PFDISCRETE2C3;C4
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31000pFDISCRETE9C6;C7;C23;C44;C73;C502;C508;C516;C524
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_2100PFDISCRETE2C20;C25
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UFDISCRETE2C29;C43
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_50.1uFDISCRETE2C48;C49
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.1uFDISCRETE12C50;C72;C99;C112;C503;C504;C505;C506;C507;C509;C525;C551
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE6C89;C97;C533;C538;C540;C544
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uFDISCRETE1C111
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE4C535;C539;C542;C546
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE1C545
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uFDISCRETE3C5;C104;C113
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PFDISCRETE5C15;C63;C64;C69;C116
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.8_11000PFDISCRETE5C17;C28;C32;C529;C530
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE21C18;C19;C26;C27;C30;C41;C46;C55;C56;C61;C68;C75;C80;C81;C83;C84;C501;C517;C523;C527;C531
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_222uFDISCRETE1C24
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_310uFDISCRETE3C53;C59;C532
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965220PFDISCRETE2C58;C77
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.87M4.7pFDISCRETE2C78;C108
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_410uFDISCRETE1C536
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C541
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE7C9;C45;C47;C54;C57;C528;C550
CC1210CAP_NP_CC1210_DISCRETE_2.7MM_1522uFDISCRETE2C70;C71
CCE6P8X6P8CAP_POL_CCE6P8X6P8_DISCRETE_6.147uFDISCRETE3C8;C11;C16
CON3_PWR_JACK_TH_PJ051ADC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3IO1J9
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO1J20
CON_3X8_100_THHDR-3X8_A_CON_3X8_100_TH_IO_16.ESQ-108-33-T-TIO3J1;J3;J4
CON_3X10_100_THHDR-3X10_A_CON_3X10_100_TH_IO_1ESQ-110-33-T-TIO2J2;J6
CON_60S_QSH_SM_AQSH030_CON_60S_QSH_SM_A_IO_3.25QSH-030-01-L-D-A-K-TRIO1J16
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RAIO3J11;J13;J17
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_ABIO1J24
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_ElectrodeIC2SW1;SW2
HDR1X2_5P48X2P69JUMPER_2_2MM_HDR1X2_5P48X2P69_IHDR1X2IO2J12;J21
HDR102CONN_HDR_2X1_HDR102_IO_9.6 MM_2HDR_1X2IO1J19
HDR103CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR TH 1X3IO4J7;J8;J18;J22
HDR210_ESQ_SKTCONN_HDR_10X2_HDR210_ESQ_SKT_IOCON 2X10IO1J5
HDR210_FTSH_SMCONN_HDR_10X2_HDR210_FTSH_SM_IOHDR_2X10IO1J10
HDR225CONN_HDR_25X2_HDR225_IO_8.59MM_TSW-125-07-F-DIO1P1
HTQFP48_0P65_10X10_EP_5MMUJA1132HW_FD_HTQFP_48P_EP_7_HTQUJA1131HW/FD/5V/0IC1U9
IND2_6P5X6P2MM_SMINDUCTOR_IND2_6P5X6P2MM_SM_DISC22uHDISCRETE1L8
IND_5P2X5P2INDUCTOR_IND_5P2X5P2_DISCRETE_24.7uHDISCRETE1L3
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR30 OHMDISCRETE4L1;L6;L7;L500
IND_0603BEAD_IND_0603_DISCRETE_0.95MM_1120OHMDISCRETE1L4
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHMDISCRETE3L2;L9;L501
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_3ORANGEIC3DS1;DS2;DS3
LED6_5X6MMLED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BLIC1D6
LED_0603LED_LED_0603_IC_0.67MM_370-7670LY L29K-H1K2-26-ZIC1D7
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D10
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D11
LQFP144_0P5_20X20MMS32K1XX_LQFP_144P_LQFP144_0P5_2PS32K118UEX0MLQTIC1U7
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R186
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125IC1U513
QFN14_RGYTXB0104_QFN14_RGY_IC_1MM_312-78TXB0104IC5U11;U13;U14;U16;U22
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U510
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_433 OHMDISCRETE47R1;R2;R5;R7;R8;R38;R46;R58;R62;R63;R74;R79;R81;R91;R102;R109;R111;R115;R309;R310;R311;R312;R313;R314;R315;R316;R317;R318;R319;R320;R321;R322;R323;R324;R325;R326;R327;R328;R329;R331;R332;R581;R585;R586;R590;R591;R595
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE129R39;R40;R55;R61;R76;R78;R110;R112;R114;R119;R122;R124;R126;R127;R128;R129;R130;R131;R134;R135;R136;R139;R141;R148;R149;R150;R154;R165;R173;R175;R177;R179;R183;R184;R187;R191;R192;R193;R195;R196;R197;R198;R203;R204;R205;R206;R208;R210;R212;R219;R221;R223;R224;R227;R230;R231;R232;R233;R242;R243;R246;R249;R250;R253;R259;R260;R261;R264;R265;R268;R269;R270;R272;R274;R275;R277;R284;R287;R289;R302;R304;R506;R507;R508;R510;R511;R512;R515;R516;R519;R520;R524;R528;R529;R530;R532;R533;R534;R535;R536;R537;R538;R540;R541;R542;R543;R544;R549;R553;R554;R555;R561;R562;R563;R564;R565;R567;R574;R580;R583;R604;R609;R624;R625;R635;R636;R638;R639;R641
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__81.0KDISCRETE1R92
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_41.69KDISCRETE1R97
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE11R132;R140;R222;R245;R255;R335;R336;R504;R505;R525;R531
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__151KDISCRETE3R176;R214;R234
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_33KDISCRETE5R228;R248;R257;R502;R503
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__210.0KDISCRETE5R281;R605;R606;R608;R612
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310.0KDISCRETE8R285;R286;R611;R613;R616;R623;R626;R630
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_115KDISCRETE1R296
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51.0KDISCRETE1R300
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410.0KDISCRETE1R301
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__6330 OHMDISCRETE1R337
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE5R610;R615;R621;R622;R631
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_2180KDISCRETE1R614
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__733DISCRETE2R617;R618
RC0402_25RES_RC0402_25_DISCRETE_0.45 M_10DISCRETE2R620;R627
RC0603RES_RC0603_DISCRETE_0.6MM_470-70DISCRETE24R6;R41;R59;R60;R106;R133;R137;R161;R182;R189;R215;R266;R291;R294;R298;R299;R500;R509;R514;R517;R521;R527;R550;R633
RC0603RES_RC0603_DISCRETE_0.6MM_470-3560DISCRETE5R9;R12;R229;R247;R256
RC0603RES_RC0603_DISCRETE_0.60MM_470-1.8KDISCRETE2R13;R262
RC0603RES_RC0603_DISCRETE_0.6MM_470_110.0KDISCRETE1R575
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410KDISCRETE15R72;R80;R95;R107;R153;R156;R178;R185;R199;R200;R518;R523;R539;R551;R556
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11.0KDISCRETE1R163
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_47220DISCRETE4R194;R306;R307;R308
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_24.7KDISCRETE2R278;R330
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__10DISCRETE2R280;R333
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_10KDISCRETE1R334
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42KDISCRETE4R225;R226;R276;R279
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4DISCRETE2R125;R138
SC74_6P_1P7X3P1NC7WP14_SC74_6P_1P7X3P1_IC_1.1M74LVC2G14GVIC1U23
SC_75NPN_SC_75_IC_0.9 MM_480-75477_MMMBT3904TT1GIC5Q1;Q2;Q3;Q500;Q501
SO8_1P27_4X5AP1509_ADJ_SO8_1P27_4X5_IC_1.75AP1509-SG-13IC1U1
SO8_WMX25L6433FM2R_SOP8_SO8_W_IC_2.1MX25L6433FM2R-08GIC1U508
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1 MM_PMEG3050EPIC3D4;D8;D9
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG6045ETPIC2D5;D500
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U24
SOT666RCLAMP0502A_6P_SOT666_IC_0.6MM_RClamp0502A.TCTIC1U515
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WIC4SW3;SW4;SW5;SW6
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOPIC16TS1;TS2;TS3;TS4;TS5;TS6;TS7;TS8;TS9;TS10;TS11;TS12;TS13;TS14;TS15;TS16
TPAD_028TESTLOOP_TPAD_028_IO_0.1 MM_211TPAD_028IO56TP1;TP2;TP3;TP4;TP6;TP7;TP9;TP10;TP11;TP12;TP13;TP14;TP15;TP16;TP17;TP20;TP21;TP22;TP24;TP25;TP27;TP28;TP29;TP30;TP34;TP37;TP38;TP39;TP40;TP41;TP42;TP43;TP44;TP45;TP46;TP47;TP48;TP49;TP50;TP51;TP52;TP53;TP54;TP56;TP58;TP59;TP60;TP61;TP500;TP501;TP502;TP503;TP504;TP505;TP506;TP507
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO66TP55;TP57;TP508;TP509;TP510;TP511;TP512;TPAD1;TPAD2;TPAD3;TPAD4;TPAD5;TPAD6;TPAD7;TPAD8;TPAD9;TPAD10;TPAD11;TPAD12;TPAD13;TPAD14;TPAD15;TPAD16;TPAD17;TPAD18;TPAD19;TPAD20;TPAD21;TPAD22;TPAD23;TPAD24;TPAD25;TPAD26;TPAD28;TPAD29;TPAD30;TPAD31;TPAD32;TPAD33;TPAD34;TPAD35;TPAD36;TPAD37;TPAD38;TPAD39;TPAD40;TPAD41;TPAD42;TPAD43;TPAD44;TPAD45;TPAD46;TPAD47;TPAD48;TPAD49;TPAD50;TPAD51;TPAD52;TPAD53;TPAD54;TPAD500;TPAD501;TPAD502;TPAD503;TPAD504;TPAD505
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006IC5GND1;GND2;GND3;GND4;GND5
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINTIC3TP5;TP8;TP26
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45IC3U511;U512;U514
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC12U3;U10;U12;U500;U501;U502;U503;U504;U505;U506;U507;U509
XTAL2_3P3X2P6XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_8MHZIC1Y1
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1Y501
( M5 T, S* H) Q+ M" {/ s3 \. e* x0 D. Z* K; w8 z% l( q8 q
附件:
2 }* U! _) R# |1 w9 Z! _9 p) I原理图和PCB文件如下:
& V" ~# S* v5 }5 f# _. I2 ]# x
游客,如果您要查看本帖隐藏内容请回复
* d; h6 e6 N1 D3 B# C
GMT+8, 2025-9-14 02:40 , Processed in 0.156250 second(s), 29 queries , Gzip On.
