查看: 216|回复: 0
[allegro16.6][8层]S32K148EVB S32K148评估板(PS32K118UEX0MLUT+PS32K118UEX0MLQT...
发表于 2020-2-10 17:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]S32K148EVB S32K148评估板(PS32K118UEX0MLUT+PS32K118UEX0MLQT+TXB0104)原理图和pcb文件
2 _6 y/ ^4 H* V0 a+ i
  c# D6 m9 p; m6 C8 b0 ^  A文件描述:# u5 y' u) H, }( ?  K9 \
: H. Y; b0 r5 p  F3 m) V6 p4 B
1. 作品用途:S32K148EVB S32K148评估板
, ^( z: j1 t$ v- q" F* i6 R2 ^3 M2. 软件版本:allegro16.66 G7 D. t8 E+ l2 B/ c7 q7 _, m* H
3. 层数:8层$ R" P7 e# W% k6 b" t  E+ _
4. 用到的主要芯片:PS32K118UEX0MLUT+PS32K118UEX0MLQT+TXB0104
2 O5 C, I* J+ I: ~5. pcb尺寸:4950*3350 MIL
7 p$ a' N6 v  |$ ~! b5 w& k' X2 ?+ O
作品截图如下:( M$ C. y3 T! Q5 H( z
/ c+ }$ h) V$ s  X; v
顶层截图:
* {! l8 Q) L$ M) {- c$ ?/ x0 v: a 0 ^; y: ]! [4 t7 Y  c5 Q
底层截图:
5 w, P( L+ @0 e$ m8 p- a3 a ) z! u, k- Z' s; H
全层截图:
" A2 f6 T5 v* S; l5 i * m- z7 {' h) S" z* h6 \9 H$ X4 u7 r
叠层阻抗信息:8 E$ u9 ^9 f4 t2 N
  B% Z. I5 l9 `0 q! u" J' J
BOM:
6 B% @- D8 D: r
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.1uFDISCRETE32C1; C2; C10; C12; C13; C14; C21; C22; C31; C60; C79; C82; C85; C86; C87; C88; C109; C110; C114; C115; C512; C513; C514; C515; C519; C520; C521; C522; C526; C547; C548; C549
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_412PFDISCRETE2C3; C4
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_31000pFDISCRETE9C6; C7; C23; C44; C73; C502; C508; C516; C524
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_2100PFDISCRETE2C20; C25
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UFDISCRETE2C29; C43
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_50.1uFDISCRETE2C48; C49
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_10.1uFDISCRETE12C50; C72; C99; C112; C503; C504; C505; C506; C507; C509; C525; C551
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE6C89; C97; C533; C538; C540; C544
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uFDISCRETE1C111
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE4C535; C539; C542; C546
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE1C545
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uFDISCRETE3C5; C104; C113
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PFDISCRETE5C15; C63; C64; C69; C116
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.8_11000PFDISCRETE5C17; C28; C32; C529; C530
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.970.1UFDISCRETE21C18; C19; C26; C27; C30; C41; C46; C55; C56; C61; C68; C75; C80; C81; C83; C84; C501; C517; C523; C527; C531
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_222uFDISCRETE1C24
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_310uFDISCRETE3C53; C59; C532
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965220PFDISCRETE2C58; C77
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.87M4.7pFDISCRETE2C78; C108
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_410uFDISCRETE1C536
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C541
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE7C9; C45; C47; C54; C57; C528; C550
CC1210CAP_NP_CC1210_DISCRETE_2.7MM_1522uFDISCRETE2C70; C71
CCE6P8X6P8CAP_POL_CCE6P8X6P8_DISCRETE_6.147uFDISCRETE3C8; C11; C16
CON3_PWR_JACK_TH_PJ051ADC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3IO1J9
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO1J20
CON_3X8_100_THHDR-3X8_A_CON_3X8_100_TH_IO_16.ESQ-108-33-T-TIO3J1; J3; J4
CON_3X10_100_THHDR-3X10_A_CON_3X10_100_TH_IO_1ESQ-110-33-T-TIO2J2; J6
CON_60S_QSH_SM_AQSH030_CON_60S_QSH_SM_A_IO_3.25QSH-030-01-L-D-A-K-TRIO1J16
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RAIO3J11; J13; J17
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_ABIO1J24
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_ElectrodeIC2SW1; SW2
HDR1X2_5P48X2P69JUMPER_2_2MM_HDR1X2_5P48X2P69_IHDR1X2IO2J12; J21
HDR102CONN_HDR_2X1_HDR102_IO_9.6 MM_2HDR_1X2IO1J19
HDR103CONN_HDR_3X1_HDR103_IO_8.72MM_2HDR TH 1X3IO4J7; J8; J18; J22
HDR210_ESQ_SKTCONN_HDR_10X2_HDR210_ESQ_SKT_IOCON 2X10IO1J5
HDR210_FTSH_SMCONN_HDR_10X2_HDR210_FTSH_SM_IOHDR_2X10IO1J10
HDR225CONN_HDR_25X2_HDR225_IO_8.59MM_TSW-125-07-F-DIO1P1
HTQFP48_0P65_10X10_EP_5MMUJA1132HW_FD_HTQFP_48P_EP_7_HTQUJA1131HW/FD/5V/0IC1U9
IND2_6P5X6P2MM_SMINDUCTOR_IND2_6P5X6P2MM_SM_DISC22uHDISCRETE1L8
IND_5P2X5P2INDUCTOR_IND_5P2X5P2_DISCRETE_24.7uHDISCRETE1L3
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR30 OHMDISCRETE4L1; L6; L7; L500
IND_0603BEAD_IND_0603_DISCRETE_0.95MM_1120OHMDISCRETE1L4
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHMDISCRETE3L2; L9; L501
LED2_2P1X1P5_NSPLED_LED2_2P1X1P5_NSP_IC_1.4MM_3ORANGEIC3DS1; DS2; DS3
LED6_5X6MMLED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BLIC1D6
LED_0603LED_LED_0603_IC_0.67MM_370-7670LY L29K-H1K2-26-ZIC1D7
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D10
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D11
LQFP144_0P5_20X20MMS32K1XX_LQFP_144P_LQFP144_0P5_2PS32K118UEX0MLQTIC1U7
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R186
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125IC1U513
QFN14_RGYTXB0104_QFN14_RGY_IC_1MM_312-78TXB0104IC5U11; U13; U14; U16; U22
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U510
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_433 OHMDISCRETE47R1; R2; R5; R7; R8; R38; R46; R58; R62; R63; R74; R79; R81; R91; R102; R109; R111; R115; R309; R310; R311; R312; R313; R314; R315; R316; R317; R318; R319; R320; R321; R322; R323; R324; R325; R326; R327; R328; R329; R331; R332; R581; R585; R586; R590; R591; R595
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE129R39; R40; R55; R61; R76; R78; R110; R112; R114; R119; R122; R124; R126; R127; R128; R129; R130; R131; R134; R135; R136; R139; R141; R148; R149; R150; R154; R165; R173; R175; R177; R179; R183; R184; R187; R191; R192; R193; R195; R196; R197; R198; R203; R204; R205; R206; R208; R210; R212; R219; R221; R223; R224; R227; R230; R231; R232; R233; R242; R243; R246; R249; R250; R253; R259; R260; R261; R264; R265; R268; R269; R270; R272; R274; R275; R277; R284; R287; R289; R302; R304; R506; R507; R508; R510; R511; R512; R515; R516; R519; R520; R524; R528; R529; R530; R532; R533; R534; R535; R536; R537; R538; R540; R541; R542; R543; R544; R549; R553; R554; R555; R561; R562; R563; R564; R565; R567; R574; R580; R583; R604; R609; R624; R625; R635; R636; R638; R639; R641
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__81.0KDISCRETE1R92
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_41.69KDISCRETE1R97
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710.0KDISCRETE11R132; R140; R222; R245; R255; R335; R336; R504; R505; R525; R531
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__151KDISCRETE3R176; R214; R234
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_33KDISCRETE5R228; R248; R257; R502; R503
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__210.0KDISCRETE5R281; R605; R606; R608; R612
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310.0KDISCRETE8R285; R286; R611; R613; R616; R623; R626; R630
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_115KDISCRETE1R296
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__51.0KDISCRETE1R300
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__410.0KDISCRETE1R301
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__6330 OHMDISCRETE1R337
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE5R610; R615; R621; R622; R631
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_2180KDISCRETE1R614
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__733DISCRETE2R617; R618
RC0402_25RES_RC0402_25_DISCRETE_0.45 M_10DISCRETE2R620; R627
RC0603RES_RC0603_DISCRETE_0.6MM_470-70DISCRETE24R6; R41; R59; R60; R106; R133; R137; R161; R182; R189; R215; R266; R291; R294; R298; R299; R500; R509; R514; R517; R521; R527; R550; R633
RC0603RES_RC0603_DISCRETE_0.6MM_470-3560DISCRETE5R9; R12; R229; R247; R256
RC0603RES_RC0603_DISCRETE_0.60MM_470-1.8KDISCRETE2R13; R262
RC0603RES_RC0603_DISCRETE_0.6MM_470_110.0KDISCRETE1R575
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_410KDISCRETE15R72; R80; R95; R107; R153; R156; R178; R185; R199; R200; R518; R523; R539; R551; R556
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_11.0KDISCRETE1R163
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_47220DISCRETE4R194; R306; R307; R308
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_24.7KDISCRETE2R278; R330
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__10DISCRETE2R280; R333
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_10KDISCRETE1R334
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42KDISCRETE4R225; R226; R276; R279
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4DISCRETE2R125; R138
SC74_6P_1P7X3P1NC7WP14_SC74_6P_1P7X3P1_IC_1.1M74LVC2G14GVIC1U23
SC_75NPN_SC_75_IC_0.9 MM_480-75477_MMMBT3904TT1GIC5Q1; Q2; Q3; Q500; Q501
SO8_1P27_4X5AP1509_ADJ_SO8_1P27_4X5_IC_1.75AP1509-SG-13IC1U1
SO8_WMX25L6433FM2R_SOP8_SO8_W_IC_2.1MX25L6433FM2R-08GIC1U508
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1 MM_PMEG3050EPIC3D4; D8; D9
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1MM_4PMEG6045ETPIC2D5; D500
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U24
SOT666RCLAMP0502A_6P_SOT666_IC_0.6MM_RClamp0502A.TCTIC1U515
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WIC4SW3; SW4; SW5; SW6
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOPIC16TS1; TS2; TS3; TS4; TS5; TS6; TS7; TS8; TS9; TS10; TS11; TS12; TS13; TS14; TS15; TS16
TPAD_028TESTLOOP_TPAD_028_IO_0.1 MM_211TPAD_028IO56TP1; TP2; TP3; TP4; TP6; TP7; TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP20; TP21; TP22; TP24; TP25; TP27; TP28; TP29; TP30; TP34; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP51; TP52; TP53; TP54; TP56; TP58; TP59; TP60; TP61; TP500; TP501; TP502; TP503; TP504; TP505; TP506; TP507
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO66TP55; TP57; TP508; TP509; TP510; TP511; TP512; TPAD1; TPAD2; TPAD3; TPAD4; TPAD5; TPAD6; TPAD7; TPAD8; TPAD9; TPAD10; TPAD11; TPAD12; TPAD13; TPAD14; TPAD15; TPAD16; TPAD17; TPAD18; TPAD19; TPAD20; TPAD21; TPAD22; TPAD23; TPAD24; TPAD25; TPAD26; TPAD28; TPAD29; TPAD30; TPAD31; TPAD32; TPAD33; TPAD34; TPAD35; TPAD36; TPAD37; TPAD38; TPAD39; TPAD40; TPAD41; TPAD42; TPAD43; TPAD44; TPAD45; TPAD46; TPAD47; TPAD48; TPAD49; TPAD50; TPAD51; TPAD52; TPAD53; TPAD54; TPAD500; TPAD501; TPAD502; TPAD503; TPAD504; TPAD505
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006IC5GND1; GND2; GND3; GND4; GND5
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINTIC3TP5; TP8; TP26
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45IC3U511; U512; U514
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC12U3; U10; U12; U500; U501; U502; U503; U504; U505; U506; U507; U509
XTAL2_3P3X2P6XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_8MHZIC1Y1
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1Y501
附件:8 o4 j$ T3 d' U, J' p1 ?
原理图和PCB文件如下:" @) a6 d, L  l  [7 @9 z
游客,如果您要查看本帖隐藏内容请回复
# X$ U8 p5 M/ G
GMT+8, 2025-9-14 02:40 , Processed in 0.156250 second(s), 28 queries , Gzip On.
