查看: 356|回复: 0
[allegro16.6][4层] S32K142EVB S32K142评估板S32K142EVB-QSP-RevD版(PS32K142+UJ...
发表于 2020-2-10 13:40 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][4层] S32K142EVB S32K142评估板S32K142EVB-QSP-RevD版(PS32K142+UJA1169TK/F+USB)原理图和pcb文件! p8 }$ C& h7 u+ g
4 A" k: a; U$ X9 s文件描述:8 V3 a% Z' \3 a* C8 Q! a
/ f1 w* t4 ?9 I' t6 i( R1. 作品用途:S32K142EVB S32K142评估板S32K142EVB-QSP-RevD版
* R5 x4 w4 v! c7 J2 j4 ?0 e( x  H2. 软件版本:allegro16.69 U/ h/ S' ]  q& m0 o
3. 层数:4层
) V: t! {$ k2 O$ v$ [/ r' h4. 用到的主要芯片:PS32K142+UJA1169TK/F+MK20DX128VFM58 F* `4 n, y) k- D5 `" {: V% p
5. pcb尺寸:4950*2300 MIL
6 `9 g+ Y4 a0 I1 M4 o! V' t$ E1 K% ?4 t2 S; E8 D8 `# p
作品截图如下:- Y) [0 D! V/ R$ D: {2 s
  O1 F$ V( x" a
顶层截图:3 ~. T6 J+ e( R4 a0 Z8 K
" D& q4 V6 o7 c+ Y6 I
底层截图:& Q$ V  a/ g9 I8 ]
8 a& d9 |+ e' X7 m0 U/ c+ c4 }* C
全层截图:
& _: g0 K% S! Q0 x# ^   ~$ t: s: ^2 ]* J- c# W) z1 ?4 L
& A* Z+ z2 H; z" U1 c: Y3 `
BOM:1 x) p8 Y" j, N- _* g# M
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE4C2; C3; C8; C18
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE8C4; C5; C7; C10; C19; C25; C26; C549
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE1C6
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.7MM10uFDISCRETE1C11
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.1UFDISCRETE2C16; C28
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.9 M0.1uFDISCRETE8C22; C47; C544; C545; C546; C547; C548; C550
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M0.01UFDISCRETE1C59
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_112PFDISCRETE2C126; C127
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_20.1uFDISCRETE11C129; C131; C133; C140; C141; C142; C146; C540; C541; C543; C552
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.25M2.2UFDISCRETE1C9
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1MM_110uFDISCRETE1C12
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.965220PFDISCRETE1C17
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_1.0MM4700 PFDISCRETE2C40; C551
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM10pFDISCRETE2C533; C535
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.27M10.0uFDISCRETE4C21; C24; C27; C536
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE5C49; C143; C144; C539; C542
CCE6P8X6P8CAP_POL_CCE6P8X6P8_DISCRETE_6.147uFDISCRETE1C128
CON2X8_2P54_THHDR_2X8_M_CON2X8_2P54_TH_IO_8.6CON 2X8IO3J1; J3; J4
CON3_PWR_JACK_TH_PJ051ADC_POWER_JACK_SHD_CON3_PWR_JACKCON PWR 3IO1J16
CON20_2P54_THCONN_HDR_10X2_CON20_2P54_TH_IO_CON 2X10IO3J2; J5; J6
CON_2RH_10_50CONN_HDR_5X2_CON_2RH_10_50_IO_3HDR 2X5IO2J12; J14
CON_HDR_4M_100_TH_RACONN_HDR_4X1_CON_HDR_4M_100_TH_HDR 1X4 RAIO2J11; J13
CON_MICROAB_10F_25_SM_RAMICRO_USB_CONN_10PIN_CON_MICROAUSB_MICRO_ABIO1J7
DSN0603-2DIODE_BIDIR_DSN0603-2_IC_0.32MMPESD5V0R1BSFIC3D17; D18; D19
ELECTRODE_SQ_15MMELECTRODE_ELECTRODE_SQ_15MM_IC_ElectrodeIC2SW7; SW8
HDR103_ACONN_HDR_3X1_HDR103_A_IO_8.74MMHDR 1X3IO3J10; J104; J107
IND_0402INDUCTOR_FERRITE_IND_0402_DISCR30 OHMDISCRETE1L512
IND_1608BEAD_IND_1608_DISCRETE_0.95MM_1330 OHMDISCRETE2L1; L2
LED6_5X6MMLED_TRI_COLOR_LED6_5X6MM_IC_2.6LED RED/GRN/BLIC1D11
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D1
LED_0603LED_LED_0603_IC_0.67MM_370-7656LED GREENIC1D2
LED_0603LED_LED_0603_IC_0.85MM_370-7654GREENIC1D3
LFPAK5_1P27_5X4PMOS_5P_LFPAK5_1P27_5X4_IC_1.2PHPT61003PYIC1Q1
LQFP100_0P5_14X14PS32K142_LQFP_1_LQFP100_0P5_14XPS32K142IC1U35
POT3_3352TPOT_POT3_3352T_DISCRETE_4.32 MM5KDISCRETE1R13
QFN8_1P6X1P6MM74LVC2T45GM_8P_QFN8_1P6X1P6MM_I74LVC2T45GM,125IC1U2
QFN32_S142EPPK20DX128V_QFN_32P_QFN32_S142EPMK20DX128VFM5IC1U8
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE9R1; R15; R30; R52; R57; R562; R571; R572; R576
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__2330 OHMDISCRETE1R2
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__110.0KDISCRETE9R3; R16; R31; R39; R42; R51; R607; R608; R609
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_180KDISCRETE1R4
RC0402_25RES_RC0402_25_DISCRETE_0.45 M_10DISCRETE2R18; R24
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__433DISCRETE2R21; R25
RC0402_25RES_RC0402_25_DISCRETE_0.45 MM_0DISCRETE77R32; R35; R47; R49; R84; R88; R122; R123; R124; R125; R126; R127; R128; R129; R136; R137; R146; R147; R152; R153; R154; R155; R156; R161; R162; R164; R169; R529; R532; R567; R568; R577; R578; R579; R580; R581; R582; R583; R584; R585; R586; R587; R588; R589; R590; R591; R592; R629; R630; R632; R633; R634; R635; R636; R637; R638; R640; R642; R643; R644; R649; R651; R653; R655; R656; R658; R659; R660; R661; R662; R663; R664; R666; R667; R668; R669; R670
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__510.0KDISCRETE2R44; R74
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__610.0KDISCRETE1R60
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__310.0KDISCRETE2R62; R77
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_115KDISCRETE1R68
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__71.0KDISCRETE1R69
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_4710KDISCRETE9R121; R573; R574; R575; R598; R601; R603; R604; R623
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_433KDISCRETE4R599; R600; R602; R605
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__1220DISCRETE1R12
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_1680DISCRETE4R56; R95; R96; R97
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM__21.0MDISCRETE1R91
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE16R117; R133; R134; R165; R167; R172; R300; R527; R533; R534; R593; R624; R625; R626; R627; R628
RC0603_OVRES_RC0603_OV_DISCRETE_0.55MM_44.7KDISCRETE2R525; R528
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 MM_4.7KDISCRETE3R536; R538; R594
RC0603_OVRES_RC0603_OV_DISCRETE_0.55 M_11KDISCRETE3R595; R596; R597
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42KDISCRETE2R80; R171
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_12.2DISCRETE1R535
RC0805_OVRES_RC0805_OV_DISCRETE_0.65 MM_10kDISCRETE1R537
RC1206_OVRES_RC1206_OV_DISCRETE_0.6MM_4760.4DISCRETE2R92; R98
SC_75NPN_SC_75_IC_0.9 MM_480-75477_MMMBT3904TT1GIC4Q6; Q7; Q8; Q9
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10DISCRETE1SH1
SO8_1P27_4X5TJA1027T_8P_SO8_1P27_4X5_IC_1.7TJA1027T/20IC1U21
SOD-128DIODE_SCHTKY_SOD-128_IC_1.1 MM_PMEG3050EPIC2D6; D9
SON20_0P5_3P6X5P6UJA1169TKF_3_SON20_0P5_3P6X5P6_UJA1169TK/FIC1U19
SOT23-6_AMIC2005-0.8YM6_SOT23-6_A_IC_1.4MIC2005-0.8YM6IC1U11
SOT23_5SSPX3819M5_FIX_0_SOT23_5S_IC_1.4SPX3819M5-L-3-3IC1U15
SOT891_6P_0P35_1P05X1P05NC7WP14_SOT891_6P_0P35_1P05X1P074LVC2G14GF,132IC1U9
SW4_SPST_4P8X3P6_2P5EDGE_MOUNT_PB_SW_2_SW4_SPST_4P8EVQ-P2402WIC4SW2; SW3; SW5; SW9
TESTPOINT_135_070MILTEST_POINT_4_TESTPOINT_135_070MTESTLOOPIC8TS1; TS2; TS3; TS4; TS5; TS6; TS7; TS8
TPAD_030TESTLOOP_TPAD_030_IO_0.1MM_211-TPAD_030IO59TP5; TP6; TP7; TP8; TP10; TP11; TP12; TP18; TP28; TP29; TP30; TP503; TP504; TP505; TP506; TP507; TP508; TP509; TP510; TP511; TP512; TP513; TP514; TP515; TP516; TP517; TP518; TP519; TP520; TP521; TP523; TP524; TP525; TP528; TP529; TP530; TP531; TP532; TP533; TP534; TP535; TP536; TP537; TP538; TP539; TP540; TP541; TP542; TP543; TP544; TP545; TPAD93; TPAD94; TPAD95; TPAD96; TPAD97; TPAD98; TPAD99; TPAD100
TP_TH_063TEST_POINT_3_TP_TH_063_IC_5.6MM5006IC2GND1; GND2
TP_TH_063TEST_POINT_0_TP_TH_063_IC_5.59MTEST_POINTIC5TP4; TP9; TP522; TP526; TP527
UDFN6_1X1P5MM74LVCH1T45_6P_UDFN6_1X1P5MM_IC_74LVCH1T45IC3U4; U7; U10
XQFN8_1P45X1P25MMNTSX2102GU8H_8P_XQFN8_1P45X1P25NTSX2102GU8HIC1U1
XQFN8_1P45X1P25MMNTSX2102GU8H_0_XQFN8_1P45X1P25MNTSX2102GU8HIC4U26; U32; U33; U34
XTAL2_3P3X2P6XTAL_CS10_XTAL2_3P3X2P6_IC_1MM_8MHZIC1Y3
XTAL3_3P35X1P45_SMXTAL_CS_XTAL3_3P35X1P45_SM_IC_08.00MHZIC1Y1
附件:4 B+ P$ @+ f; V
原理图和pcb文件如下:4 F" K8 r% A0 @6 E, N
游客,如果您要查看本帖隐藏内容请回复
" H# K- ?/ y9 U; w2 l5 ^- q6 ^
GMT+8, 2025-9-14 02:40 , Processed in 0.140625 second(s), 28 queries , Gzip On.
