查看: 212|回复: 0
[allegro16.5][10层] SAMA5D4X 评估板(SAMA5D44+WM8904+2片DDR)pcb文件
发表于 2020-2-10 13:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.5][10层] SAMA5D4X 评估板(SAMA5D44+WM8904+2片DDR)pcb文件' Q" B! y/ L6 w4 ]0 B' a1 K1 F4 y/ s3 `
1 }9 O8 O' k3 [! E文件描述:) P% [( T6 B: ^( _
: }4 z2 ~0 w" H7 k) a8 g, `5 m- L  W
1. 作品用途:SAMA5D4X 评估板
# i/ c7 o/ [3 w/ X6 u5 e( B2. 软件版本:allegro16.5* W& U! b7 t, R1 I+ ~+ e6 z
3. 层数:10层
, v* Z& q& t1 o# I' u4 x7 C4. 用到的主要芯片:SAMA5D44+WM8904+2片DDR: n" y- L0 u9 P
5. pcb尺寸: 6496.6* 5314.8 MIL
2 ^! N7 j+ B  ?! a6 O% u3 E4 I( n
. A. Y+ f7 L) b$ i作品截图如下:
% W6 t, @( P; o/ P. r/ t* p8 {" v# r
顶层截图:, R; }, O3 L1 E* s# B
$ s# m1 f& R( P" ^
底层截图:
, ?" D4 N& L+ z1 i1 S* ^5 k6 k
4 }2 }$ ~% M! E! j+ u+ }0 B; c& q6 X/ F" f1 x; i' m
全层截图:
/ n5 {8 Z( u  C+ M: |% d0 s) ~1 l7 [* H7 B( O- A# }+ q
; U. O& I1 k! |7 {$ g) w% Y: V; S4 U- ~9 G) B! b
BOM:
" M7 i$ u0 Y4 V  P9 ?0 [& L5 P
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
3D16-2L_10UH-150 MA_CMS_3D16-2_2.2UH2.2uHIC3L40; L42; L44
A06-H-E_138SWITCH2_A06-H-E_138_SWITCHSwitchIC4PB1; PB2; PB3; PB4
BAR2PTS02SIP2_BAR2PTS02_SIP2SIP2IC16JP2; JP3; JP5; JP6; JP7; JP8; JP10; JP11; JP13; JP14; JP15; JP16; JP17; JP18; JP21; JP24
BAR3PTS02SIP3-DROIT_BAR3PTS02_SIP3SIP3IC4JP12; JP19; JP20; JP22
BGA60_11X9_0315_047MT47H128M16RT_BGA84_4_BGA60_11XMT47H128M8CF-25EIC2U34; U35
BGA84_15X9_0315_354X492_047MT47H128M16RT_BGA84_BGA84_15X9_MT47H128M8CF-25EIC2U16; U17
BR20HDR_2X10_TH_BR20_BR20-HBR20-HIC1J23
C0402C0402_C0402_100NF100nFIC163C2; C4; C7; C11; C12; C13; C30; C37; C38; C42; C43; C48; C50; C51; C54; C56; C57; C58; C65; C67; C68; C69; C75; C76; C83; C84; C91; C92; C94; C105; C109; C110; C115; C116; C117; C118; C119; C131; C132; C133; C134; C136; C137; C138; C140; C144; C145; C146; C147; C151; C152; C154; C155; C156; C157; C158; C159; C160; C162; C163; C164; C166; C167; C168; C172; C173; C174; C175; C176; C178; C179; C182; C185; C188; C189; C194; C196; C197; C198; C199; C200; C201; C202; C203; C204; C205; C206; C208; C209; C210; C211; C212; C213; C214; C215; C216; C217; C218; C219; C220; C221; C222; C223; C224; C226; C227; C228; C229; C231; C232; C233; C234; C235; C236; C237; C239; C240; C241; C242; C243; C250; C251; C253; C255; C256; C259; C260; C291; C292; C293; C294; C296; C297; C298; C299; C300; C301; C302; C303; C304; C305; C306; C307; C308; C309; C310; C315; C316; C317; C318; C319; C320; C321; C322; C323; C324; C325; C326; C327; C328; C329; C367; C368
C0402C0402_C0402_22PF22pFIC4C17; C18; C26; C27
C0402C0402_C0402_15PF15pFIC2C63; C64
C0402C0402_C0402_20PF20pFIC2C70; C71
C0402C0402_C0402_10PF10pFIC1C74
C0402C0402_C0402_33PF33pFIC1C77
C0402C0603_C0402_15PF15pFIC3C108; C336; C337
C0402C0402_C0402_1NF1nFIC16C143; C153; C165; C169; C177; C181; C184; C207; C225; C230; C238; C247; C311; C312; C330; C331
C0402C0402_C0402_470PF470pFIC4C257; C258; C261; C262
C0402C_GENERIC_C0402_47NF_10%47nFIC1C285
C0402C_GENERIC_C0402_10NF_10%10nFIC1C290
C0603C0603_C0603_10NF10nFIC3C14; C130; C334
C0603C0603_C0603_2.2UF2.2uFIC15C21; C24; C36; C39; C40; C41; C87; C88; C89; C246; C295; C313; C314; C332; C369
C0603C0603_C0603_100NF100nFIC41C22; C25; C33; C44; C45; C90; C97; C98; C99; C100; C103; C123; C124; C183; C192; C195; C333; C340; C341; C342; C343; C345; C346; C347; C348; C349; C350; C351; C352; C354; C355; C356; C357; C358; C359; C361; C362; C363; C364; C365; C366
C0603C0603_C0603_47PF47pFIC1C46
C0603C0603_C0603_4.7UF4.7uFIC9C47; C49; C72; C81; C82; C85; C86; C252; C254
C0603C0603_C0603_150PF150pFIC2C52; C53
C0603C0603_C0603_10UF10uFIC9C59; C60; C61; C62; C141; C142; C190; C244; C245
C0603C_GENERIC_C0603_1UF_10%1uFIC4C101; C186; C191; C289
C0603C0603_C0603_1UF1uFIC2C248; C249
C0603C_GENERIC_C0603_100NF_10%100nFIC4C263; C284; C287; C288
C0603C0603_C0603_10PF10pFIC1C335
C0603TVS_4_C0603_TVSTVSIC4D12; D13; D14; D17
C0603TVS_3_C0603_TVSTVSIC1D16
C0805C0805_C0805_10UF10uFIC6C8; C10; C20; C23; C73; C193
C0805C0805_C0805_22UF22uFIC1C187
C0805C_GENERIC_C0805_4.7UF_10%4.7uFIC8C267; C268; C269; C270; C273; C276; C277; C286
C0805C_GENERIC_C0805_2.2UF_10%2.2uFIC2C271; C272
C0805C_GENERIC_C0805_10UF_10%10uFIC7C274; C278; C279; C280; C281; C282; C283
C0805C0805_C0805_4.7UF4.7uFIC3C344; C353; C360
C1206C1206_C1206_10UF10uFIC2C338; C339
C1808C1808_C1808_470PF470pFIC2C106; C107
CE1206CE1206_CE1206_10UF10uFIC1C102
CON5P_USB_MOLEXUSB_MICROAB_7_CON5P_USB_MOLEX_447589-0001IC1J1
CON5P_USB_MOLEX_2USB_MICROB_CON5P_USB_MOLEX_2_10105017-0001IC1J22
CON10P_200X510_50TC2050-IDC_0_CON10P_200X510_50_TC2050-IDCIC1J21
CON19P_HDMIHDM19SW_CON19P_HDMI_HDM19SW-4-1HDM19SW-4-1R-HIC1J18
CONN6P_JACK_CUI_43515STEREO CMS_0_CONN6P_JACK_CUI_43STEREO_3.5mmIC2J16; J17
CONN20P_10X2_1000_TE_102975CON20P_0_CONN20P_10X2_1000_TE_12X10 headerIC1J11
CONN30TSW_2X15_DIP_RA_CONN30_ESW-115-ESW-115-33-L-DIC1J9
CONN30HD2X20_0_CONN30_TSW-115-07-L-DTSW-115-07-L-DIC1J15
CONN40BCS_2X20_DIP_RA_CONN40_ESW-120-ESW-120-33-L-DIC1J10
CONN60P_20X3_1000_SAMTEC_TSWCONN-3X20_CONN60P_20X3_1000_SAMCONN-3x20IC1J19
CON_8_USB_A_610CCUSBA-32002-30X_0_CON_8_USB_A_USB-A-D-S-W-TH-RIC1J5
CON_KINGCONN_7SDMM_2211SD_MMCPLUS_CON_KINGCONN_7SDMM_27SDMM-B0-2211IC1J20
CON_RJ45_J00_00XX_SHIELDJ0061NL_CON_RJ45_J00_00XX_SHIELJ00-0061NLIC2J6; J7
C_6032CE_SMT_C_6032_33UF33uFIC4C3; C5; C6; C16
DFN6_0197_80X63_040_THERMNCP349MNAETBG_3_DFN6_0197_80X63NCP349MNAETBGIC1U25
F6127TVB200SC-L_F6127_TB3100M-13-FTB3100M-13-FIC1D2
FB0402BEAD_FERRITE_0_FB0402_120 OHM120 OhmIC5L4; L5; L19; L20; L33
FB0603BEAD_FERRITE_0_FB0603_60 OHM60 OhmIC5L10; L11; L12; L14; L32
FB0805BEAD_ FERRITE_1_FB0805_80 OHM80 OhmIC4L34; L35; L36; L37
GDCS968DC POWER JACK_GDCS968_DC POWERDC POWER JACKIC1J4
IND4P_NETSWAP_NCMS20C900COMMON_CHOKE_IND4P_NETSWAP_NCMSNCMS20C900IC4L15; L16; L17; L18
L1008_075L_SMT_L1008_075_10UH_150MA10uH_150mAIC2L8; L13
L1008_075L_0_L1008_075_10UH_150MA10uH_150mAIC1L47
LAN0019LAN0061-00_0_LAN0019_LAN0066-50LAN0066-50IC1TX1
LED2SM_126X39_059LED_LED2SM_126X39_059_HSMB-C170HSMB-C170IC1D10
LED4SM_63X49_026LED_4PIN_LED4SM_63X49_026_APTB1APTB1612YSGC-F01IC2D5; D6
LED0805LED_LED0805_GREENGreenIC2D8; D18
LED0805LED_LED0805_REDRedIC2D9; D15
MICRO_SD_PJS008PJS008-2120-0_MICRO_SD_PJS008_PPJS008-2120-0IC1J14
MNPTH138RPTH_2_MNPTH138R_PTHPTHIC3MH1; MH3; MH4
MNPTH138RPTH_3_MNPTH138R_PTHPTHIC1MH2
MSOP10P_118X118_20RCLAMP0514M_MSOP10P_118X118_20_RClamp0514MIC2MN9; MN11
OSC-7MCRYSTAL_4PIN_OSC-7M_12MHZ12MHzIC1Y5
PILE_KEYSTONE_3000_DIA12MM0BATTERYHOLDER_PILE_KEYSTONE_300BatteryHolderIC1J12
QFN16CX20548-11Z_0_QFN16_CX20548-11ZCX20548-11ZIC1MN5
QFN32P_SQ_16WM8904_0_QFN32P_SQ_16_WM8904WM8904IC1MN8
QFN32_0157_157_032_THERMACT8865_0_QFN32_0157_157_032_THACT8865QI305-TIC1MN12
QFN32_0197_197_035_THERMKSZ8081_QFN32_0197_197_035_THERKSZ8081RNBIC2U7; U10
QFN72P_SQ_20AD9389BBCPZ-165_0_QFN72P_SQ_20_SiI9022ACUNIC1MN7
QFN100P_SQ_20AT91SAM3UE_0_QFN100P_SQ_20_SAM3SAM3U_LQFP100IC1U36
R0402R0402_R0402_10K10KIC9R2; R53; R123; R172; R199; R202; R203; R207; R443
R0402R0402_R0402_1M1MIC4R8; R9; R76; R97
R0402R0402_R0402_0R0RIC27R13; R25; R37; R51; R86; R102; R109; R124; R137; R138; R157; R230; R232; R249; R254; R258; R277; R283; R375; R376; R444; R445; R446; R518; R520; R525; R526
R0402R0402_R0402_1K1KIC4R20; R21; R38; R44
R0402R0402_R0402_1R_1%1R_1%IC2R49; R95
R0402R0402_R0402_1K_1%1K_1%IC2R50; R52
R0402R0402_R0402_200R_1%200R_1%IC2R58; R59
R0402R0603_R0402_22R22RDISCRETE111R62; R63; R64; R65; R66; R67; R68; R69; R79; R80; R81; R83; R84; R87; R88; R89; R92; R93; R94; R104; R105; R106; R119; R120; R121; R131; R132; R133; R134; R135; R136; R140; R141; R142; R143; R144; R145; R148; R149; R150; R151; R152; R153; R251; R256; R261; R262; R263; R265; R270; R271; R272; R273; R274; R275; R276; R279; R280; R281; R284; R285; R287; R288; R291; R292; R293; R294; R295; R296; R297; R298; R301; R302; R303; R304; R305; R314; R315; R355; R356; R357; R358; R359; R360; R361; R362; R367; R368; R369; R370; R371; R372; R377; R378; R379; R380; R381; R382; R383; R384; R385; R386; R387; R388; R389; R390; R391; R392; R393; R394; R456
R0402R0402_R0402_5.62K_1%5.62K_1%IC1R110
R0402R0402_R0402_4.7K4.7KIC3R111; R112; R286
R0402R0402_R0402_2.2K2.2KIC5R114; R162; R163; R316; R317
R0402R_GENERIC_R0402_0R_5%0RIC8R117; R339; R340; R341; R343; R345; R347; R374
R0402R0402_R0402_22R22RDISCRETE58R118; R441; R442; R457; R458; R459; R460; R461; R462; R463; R464; R465; R466; R467; R468; R469; R470; R471; R472; R473; R474; R475; R476; R477; R478; R479; R480; R481; R482; R483; R484; R485; R486; R487; R488; R489; R490; R491; R492; R493; R494; R495; R496; R497; R498; R499; R500; R501; R502; R503; R504; R505; R506; R507; R508; R509; R510; R511
R0402R0402_R0402_20R_1%20R_1%IC4R158; R159; R324; R325
R0402R0402_R0402_200K_1%200K_1%IC1R175
R0402R0402_R0402_100K_1%100K_1%IC1R176
R0402R_GENERIC_R0402_10K_5%10KIC2R195; R209
R0402R0402_R0402_100R_1%100R_1%IC1R238
R0402R0603_R0402_10K10KIC3R239; R395; R396
R0402R0402_R0402_100K100KIC3R241; R250; R328
R0402R0402_R0402_47K47KIC3R321; R323; R330
R0402R_GENERIC_R0402_330R_5%330RIC1R342
R0402R_GENERIC_R0402_1R_1%_5%1R_1%IC1R349
R0402R_GENERIC_R0402_100K_5%100KIC1R354
R0402R0603_R0402_0R0RIC7R400; R401; R402; R403; R404; R435; R512
R0603BEAD_ FERRITE_2_R0603_180 OHM180 OhmIC1L41
R0603BEAD_ FERRITE_0_R0603_180 OHM180 OhmIC3L43; L45; L46
R0603R0603_R0603_100K100KIC6R3; R411; R417; R418; R419; R420
R0603R0603_R0603_1K1KIC8R4; R75; R289; R322; R326; R334; R414; R415
R0603R0603_R0603_0R0RIC39R5; R10; R11; R54; R55; R85; R100; R154; R155; R156; R179; R180; R222; R228; R229; R235; R236; R245; R246; R255; R260; R306; R307; R308; R309; R310; R311; R312; R313; R331; R408; R422; R425; R426; R427; R454; R519; R524; R527
R0603R0603_R0603_1.6K1.6KIC1R6
R0603R0603_R0603_47K47KIC2R7; R410
R0603R0603_R0603_6.49K_1%6.49K_1%IC2R16; R17
R0603R0603_R0603_110R110RIC1R22
R0603R0603_R0603_3.01R_1%3.01R_1%IC2R27; R31
R0603R0603_R0603_100R_1%100R_1%IC1R35
R0603R0603_R0603_22R22RDISCRETE11R43; R128; R327; R363; R364; R365; R366; R436; R437; R438; R439
R0603R0603_R0603_10K10KIC3R107; R248; R264
R0603R0603_R0603_4.7K4.7KIC5R113; R398; R399; R405; R521
R0603R0603_R0603_4.3K_1%4.3K_1%IC1R115
R0603R0603_R0603_1.5K_1%1.5K_1%IC3R139; R147; R278
R0603R_GENERIC_R0603_49.9K_1%_5%49.9K_1%IC2R146; R352
R0603R0603_R0603_470R470RIC7R164; R197; R201; R205; R206; R332; R333
R0603RES-4.7K-0603-5%_R0603_0R_5%0RIC3R346; R348; R429
R0603R_GENERIC_R0603_1K_5%1KIC1R353
R0603R_GENERIC_R0603_1R_5%1RIC1R373
R0603R0603_R0603_6.8K_1%6.8K_1%IC1R409
R0603R0603_R0603_39R39RIC2R412; R413
R0603R0603_R0603_150R150RIC6R416; R421; R423; R424; R428; R517
R0603R0603_R0603_68K68KIC1R522
R0603R0603_R0603_110K110kIC1R523
R0805BEAD_ FERRITE_2_R0805_220 OHM220 OhmIC10L1; L21; L23; L24; L25; L26; L27; L28; L29; L48
R0805BEAD_ FERRITE_R0805_220 OHM220 OhmIC2L49; L50
R0805R0805_R0805_237K_1%237K_1%IC1R23
R0805R0805_R0805_6.81M_1%6.81M_1%IC2R24; R32
R0805R0805_R0805_0R0RIC4R160; R161; R299; R300
R0805R0603_R0805_0R0RIC1R455
R1206C1206_R1206_47NF47nFIC1C15
R1206R1206_R1206_9.1R_1%9.1R_1%IC1R15
R1206R1206_R1206_280R_1%280R_1%IC4R196; R204; R215; R219
RJ6-RZ2RJ12_RJ6-RZ2_MJM0606GE06-HMJM0606GE06-HIC1J3
RN0402RR0402_RN0402_10K10KIC4RR4; RR5; RR6; RR7
RN0402RR0402_RN0402_0R0RIC2RR18; RR19
RN0402X4_022RNX4_RN0402X4_022_68K68KIC2RR1; RR12
RN0402X4_022RR0402_RN0402X4_022_100K100KIC3RR13; RR14; RR17
SC70_5P_0431G126_0_SC70_5P_043_IC_NL17SZ12NL17SZ126DFT2GIC2U19; U20
SKT_BGA361_19X19_0315_048_ASAMA5D4_5_SKT_BGA361_19X19_0315SAMA5D44IC1U22
SMD1812MINI-FUSE_SMD1812_1812L160/121812L160/12IC1F1
SOD-123SCH_SOD-123_RB160M-60RB160M-60IC1D7
SOIC8_0197_122_035NL27WZ126USG_2_SOIC8_0197_122_0NL27WZ126USGIC1U39
SOIC8_0500_314_085AT25DF321_SU_SOIC8_0500_314_085AT25DF321AIC1U15
SOP6-50-150DS28EC20P_0_SOP6-50-150_DS28EC2DS28EC20PIC1U23
SOP8_244_0500_069SP2526A-SO8_SOP8_244_0500_069_AAIC1526-1GSIC2MN1; MN3
SOP8_0256_193_043TPS3619_SOP8_0256_193_043_TPS36TPS3619-33IC1U32
SOP24-26-173ADM3312EARU_SOP24-26-173_ADM331ADM3312EARUIC1U38
SOT23MMBD3004S_1_SOT23_MMBD3004S-7-FMMBD3004S-7-FIC2D3; D4
SOT23MMBAT42_0_SOT23_MMBAT42MMBAT42IC4Q1; Q3; Q4; Q5
SOT23-5SPX3819_SOT23-5_SPX3819M5-L-3-3SPX3819M5-L-3-3IC1U37
SOT23T02PMOS_1_SOT23T02_IRLML6402IRLML6402IC1Q6
SOT23_3P_044NMOS_SOT23_3P_044_IRLML2502TRIRLML2502TRIC1Q7
SOT23_3P_044LM4040_SOT23_3P_044_LM4040BIM3-LM4040BIM3-3.0+TIC1U6
SOT23_5P_04374LVC1G08GV_SOT23_5P_043_74LVC174LVC1G08GVIC1U2
SOT23_6SN74LVC2GU04_0_SOT23_6_SN74LVC2SN74LVC2GU04IC3MN2; MN4; MN10
SOT-23NMOS_SOT-23_BSN20BSN20IC1Q9
SUBD9MDSUB9_M_SUBD9M_DB9M_RDB9M_RIC1J24
SW3P_492X382_492RES_3_SW3P_492X382_492_10K10KIC1P2
SW3P_512X311_585SWITCH_3PIN_A_8_SW3P_512X311_58SDKTA20100IC1SW1
TEST_POINTT_0_TEST_POINT_TTIC4T1; T2; T3; T4
TP_KEYSTONE_5012TEST_POINT_TP_KEYSTONE_5012_TPTPIC13TP1; TP2; TP3; TP4; TP5; TP6; TP7; TP8; TP9; TP10; TP11; TP12; TP13
TP_SMTTP_TP_SMT_SMDSMDIC1TP26
TSOP48_0197_787_047NAND4G_TSOP48_TSOP48_0197_787_0MT29F4G08ABAEAWPIC1U21
TSSOP4SM_87X53NCP4682DSQ20T1G_0_TSSOP4SM_87X5NCP4682DSQ20T1GIC1U31
TSSOP5_0256_084_04374LVC1G66GW_0_TSSOP5_0256_084_074LVC1G66GWIC2U27; U28
TSSOP20_0256_252_04374AHC244P_2_TSSOP20_0256_252_0474LVC244APWIC1U8
XTAL2SM_126X63_035CRYSTAL_XTAL2SM_126X63_035_32.732.768KHzIC1Y4
XTAL4SM_126X98_030XTAL_13Y_A_XTAL4SM_126X98_030_I25MHzIC2Y1; Y2
XTAL4SM_126X98_030XTAL_13Y_A_XTAL4SM_126X98_030_112MHzIC1Y3
ZEN3SM-163X163-81ZEN056V230A16LS_ZEN3SM-163X163-ZEN056V230A16LSIC1U40
附件:
! e/ W) P. d5 D5 DPCB文件如下:/ s% f8 Z: x1 j' ~" M, S- H
游客,如果您要查看本帖隐藏内容请回复
$ c; w7 X2 k1 p# b( z& q; a: m% k
GMT+8, 2025-9-14 02:40 , Processed in 0.140625 second(s), 28 queries , Gzip On.
