查看: 285|回复: 1
实现粒子群算法的MATLAB代码
发表于 2020-2-4 10:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 ulppknot 于 2020-2-4 10:29 编辑 - z( E$ n  q! w
& }# h; J. H6 F% s# t/ ?2 D
实现粒子群算法的MATLAB代码:+ a* }. R! _+ a: E* T4 P+ e8 A! x
  • function [x, fval, exitflag, output] =pso(objfunc, nvars, options)
  • % PSO  Particle SwARM Optimization Algorithm
  • % PSO attempts to solve continuousoptimization problem of the form
  • %      min OBJFUNC(X)
  • %       X
  • % No constraints on the values of entriesof X can be imposed, not ewen box contraints in form of
  • % the lower and upper bound. Any desiredconstraints should be dealth with by modification of the
  • % objective function: by introduction ofpenalty functions, by reformulation of the problem, or some
  • % other way.
  • % In the present implementation, onlyclassical 'star topology' PSO is considered, where each
  • % particle is interconnected with eachother particle, and there are no subswarms. Also, no
  • % additional, GA like, operators areapplied to the particles during the search.
  • %  PSO(OBJFUNC, NVARS) Optimizes objective OBJFUNC defined as a real-valuedfunction of a single,
  • %  real-valued vector argument. Dimensionality of the search space, that isthe number of entries
  • %  in the argument of OBJFUNC, is defined in NVARS. PSO expects at leastthese two arguments.
  • %  Failure to provide any of them will result in error.
  • %  PSO(OBJFUNC, NVARS, OPTIONS) Enables the user to specify a number ofsettings in order to
  • %  customize or fine-tune the peRFormance of the algorithm. OPTIONS is astructure containing
  • %  desired values of these settings. Detailed description of availableparameters is given in the
  • %  sequel.
  • %   X= PSO(...) Returns vector at which objective attains its minimal value. Due tothe nature of
  • %  PSO algorithm, this is not guaranteed to be neither exact global norlocal optimum, yet PSO is
  • %  robust optimizer, well suited for complex, multimodal problems. Welltuned, it can give VERY
  • %  GOOD and quite commonly EXCELENT solution to the problem at hand. Inmost cases, this is all
  • %  that is needed.
  • %  [X, FVAL] = PSO(...) In addition to the optimal X, it returns the valueof the objective at X,
  • %  FVAL = OBJFUNC(X).
  • %  [X, FVAL, EXITFLAG] = PSO(...) Returns indication concerning a reasonwhy the algorithm stopped.
  • %  In the current implementation the only supported return values are 0 and1. EXITFLAG 0 denotes
  • %  that maximum number of iterations has been achieved, while EXITFLAG 1 isused in testing mode,
  • %  if the value of global minimum has been found prior to achieving themaximal number of
  • %  iteration.
  • %  [X, FVAL, EXITFLAG, OUTPUT] = PSO(...) Returns OUTPUT structurecontaining valuable information
  • %  concerning performance of the algorithm in the present run. The exactmembers of this structure
  • %  are variable, and depend on the settings specified in the OPTIONSstructure. In general, there
  • %  are four levels of detail that can be specified. The 'LOW' detail levelmeans that the algorithm
  • %  keeps track of objective value for the best, the mean and the worstparticle in the swarm in
  • %  each generation. If the 'MEDIUM' level is specified, exact position andindex of the global best
  • %  particle are tracked for during each iteration. If the 'HIGH' level isspecified, exact position
  • %  of each particle in the swarm is logged during the entire searchprocess. If the swarm is large
  • %  and the number of generations is great, high level output logging canresult in considerable
  • %  memmory consumption. Finally, the output log level can be set to 'NONE',meaning that no data is
  • %  wanted within the OUTPUT structure. The exact way for specifying outputlogging level is given
  • %  below.
  • %  OPTIONS = PSO('options') Returns default options structure. Usefull whenone desires to change
  • %  values of only a handfull of options.
  • %  The OPTIONS structure contains the following entries
  • %    options.npart           The numberof particles in the swarm.
  • %    options.niter           Themaximal number of iterations.
  • %    options.cbi             Initialvalue of the individual-best acceleration factor.
  • %    options.cbf             Finalvalue of the individual-best acceleration factor.
  • %    options.cgi             Initialvalue of the global-best acceleration factor.
  • %    options.cgf             Finalvalue of the global-best acceleration factor.
  • %    options.wi              Initialvalue of the inertia factor.
  • %    options.wf              Finalvalue of the inertia factor.
  • %    options.vmax            Absolutespeed limit. If specified, the speed is clamped to the range
  • %                             [-options.vmax,options.vmax]. It is the primary speed limit, if set
  • %                             to NaN, theVMAXSCALE options is used.
  • %    options.vmaxscale       Relativespeed limit. Used only if absolute limit is unspecified, i.e.
  • %                             set to NaN. Ifused, must be a scalar quantity, and denotes the amount
  • %                             of initialpopulation span (the INITSPAN option) used as the speed
  • %                             limit.
  • %    options.vspaninit       Theinitial velocity span. Initial velocities are initialized
  • %                             uniformly in[-VSPANINIT, VSPANINIT]. This option must be specified.
  • %    options.initoffset      Offset ofthe initial population. Can be scalar or column-vector of
  • %                             dimension NVARS.
  • %    options.initspan        Span ofthe initial population. Can be scalar or column-vector of
  • %    options.trustoffset     If set to1 (true) and offset is vector, than the offset is
  • %                             believed to be agood solution candidate, so it is included in
  • %                             the initial swarm.
  • %    options.initpopulation  Theuser-suplied initial population. If this is set to something
  • %                             meaningfull, thenINITSPAN, INITOFFSET and TRUSTOFFSET are
  • %                             ignored. If set to NaN then the abovementioned offset is used.
  • %    options.verbose_period  Theverbose period, i.e. the number of iterations after which the
  • %                             results areprompted to the user. If set to 0, then verbosing is
  • %                             skipped.
  • %    options.plot            If set to1, evolution of the global best is ploted to the user after
  • %                             the optimizationprocess. The objective value of the best, mean
  • %                            and worseparticle troughout the optimization process are plotted
  • %                             in the singlegraph.
  • %    options.output_level    The outputlog level. Possible values are: 'none', 'low',
  • %                             'medium', 'high'.Each log level denotes a specific amount of
  • %                             information to bereturned to the end user. If less than 4 output
  • %                             arguments arespecified log level is ignored, since it would only
  • %                             occupate (possibly)large amount of useless memory.
  • %    options.globalmin       Globalminimum, used for testing only. If specified, the algorithm
  • %                             will stop as soonas the difference between GLOBALMIN option and
  • %                             current globalbest becomes less than TOL option.
  • %    options.tol             Precisiontolerance, used for testing only. It is maximal difference
  • %                             between currentglobal best and GLOBALMIN option at which the
  • %                             algorithm stops.If GLOBALMIN options is set to NaN this option is
  • %                             ignored, and thealgorithm stops after the maximal number of iteration
  • %                             has been achieved.
  • %  The OUTPUT structure is the fallowing
  • %    output.itersno          The actualnumber of iterations. Usualy the same as NITER options, but
  • %                             can be less if intesting mode (if GLOBALMIN option is specified).
  • %    If at least LOW level output logging is specified:
  • %    output.gbest_array
  • %    output.gmean_array
  • %    output.gworst_array     Arrayscontaining the objective value of the best, mean and worst
  • %                             particle in eachiteration. In fact, gmean_array does not contain
  • %                             objective valuefor any concrete particle, but instead it contains the
  • %                             mean objectivevalue for the entire swarm in each iteration.
  • %     If at least MEDIUM level output logging isspecified:
  • %    output.gbes**x_array   The arrayontaining indices of the best particle in each iteration.
  • %    output.Xbest            Matrix ofdimension NITERxNVARS, containing, as rows, global best
  • %                             particles in eachiteration.
  • %    Only if HIGH level output logging is specified:
  • %    output.X                3D matrixof dimension NPARTxNVARSxNITER containing the entire
  • %                             population in eachiteration.
  • %  The following examples ilustrate the use of PSO function in severalcommon cases.
  • %  Suppose we are attempting to optimize 5-dimensional objective f(x) =x*x'. Since, it is assumed
  • %  that objective receives a row-vector, the objective is in fact a 5Dparaboliod. The easiest way
  • %  to optimize would be to write
  • %  obj = @(x) x*x';
  • %  [xopt, fopt] = pso(obj, 5);
  • %  The preseding code lines would yield XOPT as the found near-optimalsolution and FOPT as the
  • %  objective value in such point. Of course, other outputs can be obtainedas described earlier.
  • %  If one should choose to change the default options (say to specifydifferent number of particles
  • %  and iterations), the code would look something like this
  • %  options = pso('options');
  • %  options.niter = 500;
  • %  options.npart = 60;
  • %  Other options can be specified as well on the exactly the same way. Thebest way to explore the
  • %  option structure is to experiment.
  • %  PSO is compatible with MATLAB 7 and higher. Some modifications areneeded for it to work under
  • %  lower versions of MATLAB.
  • % Copyright (C) Milan Rapaic(repmilan@yahoo.com), 2007-05-10 ... 2008-10-12
  • % Checking the number of input and outputarguments.                                              %
  • msg = nargchk(1, 3, nargin);
  • if ~isempty(msg)
  •    error('mrr:myoptim:pso:pso:narginerr', 'Inadequate number of inputarguments.');
  • end
  • msg = nargchk(0, 4, nargout);
  • if ~isempty(msg)
  •    error('mrr:myoptim:pso:pso:nargouterr', 'Inadequate number of outputarguments.');
  • end
  • % The body of the algorithm.        %
  • if nargin==1 && ischar(objfunc)&& strcmp(objfunc, 'options')
  •     %User desired only to access the default OPTIONS structure.
  •    if nargout<=1
  •        x = getDefaultOptions();
  •    else
  •        % The user required multiple outputs, yet only default options can bereturned.
  •        error('mrr:myoptim:pso:pso:nargouterr', ...
  •            'Cannot expext more than one output when only OPTIONS are required.');
  •    end
  • else
  •     %User requested optimization to be conducted on a given objective.                            %
  •     %The following code deals with initializations and validations of optionsstructure.          %
  •     %If no options are specified, use the default ones.
  •    if nargin<3, options=getDefaultOptions(); end
  •     %Determination of output level, that is of amount of data to be collected inOUTPUT structure.
  •    if nargout == 4
  •        % User supplied four output arguments, therefore output level isdetermined from the OPTIONS
  •        % structure. The output_level variable is used to code the desired loglevel: 0 ('none'), 1
  •        % ('low'), 2 ('medium') and 3 ('high).
  •        if strcmp(options.output_level, 'none')
  •            if options.plot == 0
  •                 output_level = 0;
  •            else
  •                 output_level = 1;
  •            end
  •        elseif strcmp(options.output_level, 'low')
  •            output_level = 1;
  •        elseif strcmp(options.output_level, 'medium')
  •            output_level = 2;
  •        elseif strcmp(options.output_level, 'high')
  •            output_level = 3;
  •        else
  •            error('mrr:myoptim: pso:pso: optionserr: output_level', ...
  •                 'Invalid value of theOUTPUT_LEVEL options specified.');
  •        end
  •    else
  •        % User has not supplied forth output argument. The only reason to loginformation during the
  •        % run is to be able to plot to to the user after the optimizationprocess. Therefore, if
  •        % ploting is requested low level logging is used.
  •        if options.plot == 1
  •            output_level = 1;
  •        else
  •            output_level = 0;
  •        end
  •    end
  •     %Maximum velocity can be specified in absolute amount, or relative to theinitial span.
  •     %If both values are specified, the absolute velocity limit is taken intoaccount, while the
  •     %relative is ignored. Whatever the initial specification of the maximalvelocity, the curent
  •     %code block will generate a column vector, vmax, containing maximal velocityalong each
  •     %dimension of search space.
  •    if ~all(isnan(options.vmax))
  •        % It is not allowed to let some of the entries of the VMAX option to beNaN and others to
  •        % have numerical or Inf values.
  •        if any(isnan(options.vmax))
  •            error('mrr:myoptim: pso: pso: optionserr:vmax', ...
  •                 'VMAX option cannot have someInf and some numerical (or Inf) values.');
  •        end
  •        % Warning of the confusing entries within the OPTIONS structure.
  •        if ~isnan(options.vmaxscale)
  •            warning('mrr:myoptim: pso:pso: optionserr:vmaxconflict', ...
  •                'Both relative andabsolute velocity limit are specified. The relative limit is ignored.');
  •        end
  •        if length(options.vmax) == 1
  •            vmax = options.vmax*ones(nvars, 1);
  •        elseif length(options.vmax) == nvars
  •            % Maximal velocity should be a column-vector or a scalar.
  •            if size(options.vmax, 1) ~= length(options.vmax)
  •                error('mrr:myopim: pso:pso: optionserr:vmax', ...
  •                     'VMAX option should bespecified as column-vector, or as a scalar value.');
  •            end
  •            vmax = options.vmax;
  •        else
  •            error('mrr:myoptim: pso:pso: optionserr:vmax', ...
  •                 'Inadequate dimension of VMAXoption. Should be a scalar, or a column vector with NVARS elements.');
  •        end
  •    else
  •        % It is not valid to specify both VMAX and VMAXSCALE option as NaN.
  •        if isnan(options.vmaxscale)
  •            error('mrr:myoptim:pso:pso: optionserr:vmaxscale', ...
  •                 'Either VMAX or VMAXSCALEoptions should be different than NaN.');
  •        end
  •        % Contrary to the VMAX options, VMAXSCALE option must allways be ascalar. The initial span
  •        % should take into account the different scaling among the cooedinatesof the search space.
  •        if length(options.vmaxscale) == 1
  •            if length(options.initspan) == 1
  •                 vmax =options.vmaxscale*options.initspan*ones(nvars, 1);
  •            else
  •                 % If the dimension of INITSPANoption is not correct, the function will break later,
  •                 % therefore, no need to checkvalidity now.
  •                 vmax =options.vmaxscale*options.initspan;
  •            end
  •        else
  •            error('mrr:myoptim:pso:pso: optionserr:vmax', ...
  •                 'Inadequate dimension ofVMAXSCALE option. Must be a scalar.');
  •        end
  •    end
  •    vmax = repmat(vmax', options.npart, 1);
  •     %Initial population.
  •     %If the initial population is not supplied by the user, each particle of theinitial population
  •     %is spred in [INITOFFSET-INITSPAN, INITOFFSET+INITSPAN] where both INITOFFSETand INITSPAN
  •     %are specified within the OPTIONS structure. Both of these options are eitherscalars or
  •     %column-vectors of appropriate size. If INITPOPULATION option is specified, bothINITOFFSET and
  •     %INITSPAN options are ignored.
  •    if ~isnan(options.initpopulation)
  •        % The user supplied complete initial population within the OPTIONSstructure.
  •        % The size of the supplied population must be consistent with populationsize and number of
  •        % variables. If no, an error is reported.
  •        [pno, pdim] = size(options.initpopulation);
  •        if (pno ~= options.npart) || (pdim ~= nvars)
  •            error('mrr:myoptim: pso: pso: optionserr:initpopulation', ...
  •                 ['The format of initialpopulation is inconsistent with desired population', ...
  •                  'size or dimension of searchspace - INITPOPULATION options is invalid']);
  •        end
  •        X = options.initpopulation;
  •    elseif (length(options.initoffset) == 1) &&(length(options.initspan) == 1)
  •        % The same offset and span is specified for each dimension of the searchspace
  •        X = (rand(options.npart, nvars)-0.5)*2*options.initspan +options.initoffset;
  •    elseif (length(options.initoffset) ~= size(options.initoffset, 1)) ||...
  •           (length(options.initspan) ~= size(options.initspan, 1))
  •        error('mrr:myoptim:pso:pso: optionserr:initoffset_initspan', ...
  •            'Both INITOFFSET and INITSPAN options must be either scalars orcolumn-vectors.');
  •    elseif (length(options.initoffset) ~= nvars) ||(length(options.initspan) ~= nvars)
  •        error('mrr:myoptim: pso: pso: optionserr:init', ...
  •            'Both INITOFFSET and INITSPAN options must be scalars or column-vectorsof length NVARS.');
  •    else
  •        initoffset = repmat(options.initoffset', options.npart, 1);
  •        initspan   =repmat(options.initspan', options.npart, 1);
  •        X = (rand(options.npart, nvars)-0.5)*2.*initspan + initoffset;
  •        % TRUSTOFFSET option is used when OFFSET option is, in fact, previouslyknown good (or very
  •        % good) solution to the problem at hand. When set to logical true (1),offset is inserted in
  •        % the initial population. Thus, it is guaranteed that objective value atsolution is not
  •        % greater than objective value at that, previously known, good point.
  •        if (options.trustoffset)
  •            X(1, : ) = options.initoffset';
  •        end
  •    end
  •     %Initial velocities.
  •     %Velocities are initialized uniformly in [-VSPANINIT, VSPANINIT].
  •    if any(isnan(options.vspaninit))
  •        error('mrr:myoptim: pso:pso: optionserr:vspaninit', ...
  •                 'VSPANINIT option must notcontain NaN entries.');
  •    elseif isscalar(options.vspaninit)
  •        V = (rand(options.npart, nvars)-0.5)*2*options.vspaninit;
  •    else
  •        if (length(options.vspaninit) ~= size(options.vspaninit, 1)) || ...
  •           (length(options.vspaninit) ~= nvars)
  •                 'VSPANINIT option must beeither scalar or column-vector of length NVARS');
  •        end
  •        V = (rand(options.npart,nvars)-0.5)*2.*repmat(options.vspaninit', options.npart, 1);
  •    end
  •     %Initial scores (objective values).
  •     %Initialization of the best personal score and position, as well as global bestscore and
  •     %position.
  •     Y= calcobjfunc(objfunc, X);
  •    Ybest = Y;                      %The best individual score for each particle - initialization.
  •    Xbest = X;                      %The best individual position for each particle -
  •                                     %initialization.
  •    [GYbest, gbest] = min(Ybest);   %GYbest is the best score within the entire swarm.
  •                                     % gbest isthe index of particle that achived YGbest.
  •    gbest = gbest(1);               %In case when more than one particle achieved the best
  •                                     % score, wechoose the one with the lowest index as the
  •                                     % best one.
  •     %These variables are used in testing mode only.
  •    tolbreak = ~isnan(options.globalmin);
  •    foundglobal = 0;
  •    if tolbreak && ~isscalar(options.globalmin)
  •        error('mrr:myoptim:pso:pso:  optionserr:globalmin', ...
  •            'globalmin option, if specified, option must be a scalar value equal tothe global minimum of the objective function');
  •    end
  •     %Initialization of the OUTPUT structure.
  •     %The output structure is filled and initialized differently depending on theOUTPUT_LEVEL
  •     %options, or equivalently depending on the output_level variable.
  •    if output_level >= 0
  •        % NONE log level
  •        output.itersno = options.niter;
  •        if output_level >= 1
  •            % LOW log level
  •            output.gbest_array = NaN*ones(options.niter+1, 1);
  •            output.gmean_array = NaN*ones(options.niter+1, 1);
  •            output.gworst_array = NaN*ones(options.niter+1, 1);
  •            output.gbest_array(1) = GYbest;
  •            output.gmean_array(1) = mean(Ybest);
  •            output.gworst_array(1) = max(Ybest);
  •            if output_level >= 2
  •                 % MEDIUM log level
  •                 output.gbes**x_array =NaN*ones(options.niter+1, 1);
  •                 output.Xbest =NaN*ones(options.niter+1, nvars);
  •                 output.gbes**x_array(1) =gbest;
  •                 output.Xbest(1, : ) = X(gbest,: );
  •                 if output_level == 3
  •                     % HIGH log level
  •                     output.X =NaN*zeros(options.npart, nvars, options.niter+1);
  •                     output.X(:,:,1) = X;
  •                 end
  •            end
  •        end
  •    end
  •    if options.verbose_period ~= 0
  •        disp 'PSO algorithm: Initiating the optimization process.'
  •    end
  •     %Denotes normal algorithm termination.
  •    exitflag = 0;
  •     %The main loop.        %
  •    for iter = 1:  options.niter
  •        % Verbosing, if neccessary.
  •            if rem(iter, options.verbose_period) == 0
  •                disp(['iteration ', int2str(iter),'. best criteria = ', num2str(GYbest)]);
  •            end
  •        end
  •        % Calculating PSO parameters
  •        w = linrate(options.wf, options.wi, options.niter, 0, iter);
  •        cp = linrate(options.cbf, options.cbi, options.niter, 0, iter);
  •        cg = linrate(options.cgf, options.cgi, options.niter, 0, iter);
  •        % For later calculations only
  •        GXbest = repmat(Xbest(gbest, : ), options.npart, 1);
  •        % Calculating speeds
  •        V = w*V + cp*rand(size(V)).*(Xbest-X) + cg*rand(size(V)).*(GXbest-X);
  •        V = min(vmax, abs(V)).*sign(V);
  •        % Population is moving
  •        X = X + V;
  •        Y = calcobjfunc(objfunc, X);
  •        % Calculating new individually best values
  •        mask = Y<Ybest;
  •        mask = repmat(mask, 1, nvars);
  •        Xbest = mask.*X +(~mask).*Xbest;
  •        Ybest = min(Y,Ybest);
  •        % Calculating new globally best value
  •        gbest = gbest(1);
  •        % Filling in the OUTPUT structure.
  •            % NONE log level
  •                 % LOW log level
  •                 output.gbest_array(iter+1)  = GYbest;
  •                 output.gmean_array(iter+1)  = mean(Ybest);
  •                 output.gworst_array(iter+1) =max(Ybest);
  •                     output.gbes**x_array(iter+1)= gbest;
  •                     output.Xbest(iter+1, : ) =X(gbest, : );
  •                         % HIGH log level
  •                         output.X(:,:,iter+1) =X;
  •                     end
  •                 end
  •             end
  •        end
  •        % The code used in testing mode only.
  •        if tolbreak && abs(GYbest - options.globalmin)<options.tol
  •            output.itersno = iter;
  •            foundglobal = 1;
  •            break
  •        end
  •    end
  •        disp 'Optimization process finished.'
  •    end
  •     %Setting up the output variables.
  •     %X is set to be the final global best position, since that is the best positionever achieved
  •     %by any of the particles in the swarm. FVAL is set to be the value of theobjective in X.
  •     x= Xbest(gbest, : ); x = x(: );
  •    fval = GYbest;
  •     %The global moptimum has been found prior to achieving the maximal number ofiteration.
  •    if foundglobal, exitflag = 1; end;
  •     %Plotting the algorithm behavior at each iteration.
  •    if options.plot
  •        r = 0:  options.niter;
  •        figure
  •        plot(r, output.gbest_array, 'k.', r, output.gmean_array, 'r.', r,output.gworst_array, 'b.');
  •        str = sprintf('Best objective value : %g', fval);
  •        title(str);
  •        legend({'best objective', 'mean objective', 'worst objective'})
  •    end
  • end
  • function Y = calcobjfunc(func, X)
  • % CALCOBJFUNC   A helper function used to calculateobjective function value for a series of points.
  • np = size(X,1);
  • Y = zeros(np,1);
  • for i = 1:np
  •    Y(i) = func(X(i,: ));
  • end
  • function opts = getDefaultOptions
  • % GETDEFAULTOPTIONS     Returns a structure containing the defaultoptions.
  • %  This function, in fact, defines default values of the options within theoptions structure.
  • opts.npart          = 30;       % The number of particles.
  • opts.niter          = 100;      % The number of iterations.
  • opts.cbi            = 2.5;      % Initial value of the individual-bestacceleration factor.
  • opts.cbf            = 0.5;      % Final value of the individual-bestacceleration factor.
  • opts.cgi            = 0.5;      % Initial value of the global-bestacceleration factor.
  • opts.cgf            = 2.5;      % Final value of the global-bestacceleration factor.
  • opts.wi             = 0.9;      % Initial value of the inertia factor.
  • opts.wf             = 0.4;      % Final value of the inertia factor.
  • opts.vmax           = Inf;      % Absolute speed limit. It is the primaryspeed limit.
  • opts.vmaxscale      = NaN;      % Relative speed limit. Used only ifabsolute limit is unspecified.
  • opts.vspaninit      = 1;        % The initial velocity span. Initialvelocities are initialized
  • opts.initoffset     = 0;       % Offset of the initial population.
  • opts.initspan       = 1;        % Span of the initial population.
  • opts.trustoffset    = 0;       % If set to 1 (true) and offset is vector, than the offset is
  •                                 % believed tobe a good solution candidate, so it is included in
  •                                 % the initialswarm.
  • opts.initpopulation = NaN;      % The user-suplied initial population. Ifthis is set to something
  •                                 % meaningfull,then INITSPAN, INITOFFSET and TRUSTOFFSET are
  •                                 % ignored.
  • opts.verbose_period = 10;       % The verbose period, i.e. the number ofiterations after which the
  •                                 % skipped.
  • opts.plot           = 0;        % If set to 1, evolution of the gbestis ploted to the user after
  •                                 % theoptimization process. The objective value of the best, mean
  • opts.output_level   = 'low';   % The output log level. Possible values are: 'none', 'low',
  •                                 % 'medium','high'.
  • opts.globalmin      = NaN;      % Global minimum, used for testing only
  • opts.tol            = 1e-6;     % Precision tolerance, used for testingonly
  • function x = linrate(xmax, xmin, tmax,tmin, t)
  • % LINRATE  Linear interpolation of value X in instant T, defined by previouslyknown points
  • %          (tmin, xmin), (tmax, xmax)
  • x = xmin + ((xmax-xmin)/(tmax-tmin))*(tmax-t);! L2 ^; U$ u5 j1 U/ l. e$ _
( G& D1 P+ p0 P& m6 t9 V. k
9 ]  x& d: ^/ J. J& X' g$ u( M
# a( I, Y2 Z. C$ P+ T- ?* e3 n( ]2 l3 T9 X' r8 b  S
2 T% ]. D1 W3 T, I' y' Z* H# R: {2 M8 I0 a" H, o
+ d. `$ G+ A; H7 q/ B/ f' j5 B
+ \. K0 s3 a0 n; k" h) B+ e5 d; A- l7 [
7 \+ r- E; D. f' B/ N$ f6 o+ I+ o) g) [$ `
2 M' w% N) [$ i& E$ u
% |6 z# D0 z4 j2 y+ a. y, Y7 W( }6 @
2 z; F/ o) e' Q9 E* ]# a& s; V. L3 y9 R, C
0 ^  m  u; z. Z2 q( m7 V+ p  l
1 n* ]! |5 b3 _8 r8 j+ f4 u) O
2 z3 e9 A3 ]  L3 i. P
% c" T. [7 X  j9 e- S  g5 @; q2 Q
发表于 2020-2-4 18:47 | 只看该作者
最爱代码,虽然看不懂
GMT+8, 2025-11-2 12:29 , Processed in 0.156250 second(s), 24 queries , Gzip On.
