作品名:[AD 10][4层] 直流桩计费控制板(LAN7820AI+TDA2822+B0505)PCB源文件
& A8 p0 I+ n" L9 d6 z" X7 I2 e
! f% Q0 D6 h; W8 @9 S) [文件描述$ o5 K) I. D3 T
1. 作品用途:直流桩计费控制板
& @3 g9 G" J1 [6 m5 T# R# g5 k2. 软件版本:AD 10' h+ ^0 y( O6 L p5 y
3. 层数:4层板0 g0 v/ N$ s+ o; s7 t, \
4. 用到的主要芯片:LAN7820AI+TDA2822+B0505& E* {. I4 d [
5. PCB尺寸:231mm*150mm
8 _6 R8 ], `% U/ N1 X: l# x4 \: z( Q; W
作品截图如下:2 ~$ N9 i6 z! D% s
顶层截图:7 ^( `( v2 m2 ]% [' p
) ^7 \# g; T. @ o
底层截图:
( j+ j# n# L$ k+ _( Y4 P: P
, t B& z3 A" T) W+ B( i1 v全层截图:; G$ k# }/ g! M% g: O, P7 d T- W
. C1 w W. H/ `6 o- {' ?! w叠层信息截图如下:
% L$ o% f7 o% L8 t* T1 s( a" f
E3 E' a% l: V6 {BOM:0 X! E( f: D0 c/ k
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | R0603 | 10K | R0402 | 1 | BH1220_SMD | BT1 | BH-1220 Battery | 1 | 100nF | C1, C3, C4, C5, C6, C7, C12, C16, C17, C25, C27, C29, C31, C32, C33, C34, C36, C37, C39, C40, C41, C42, C44, C47, C50, C51, C52, C53, C55, C56, C58, C59, C63, C64, C65, C66, C68, C70, C72, C74, C76, C92, C96, C106, C107, C108, C110, C111, C116, C126, C128, C130, C132, C133, C135, C136, C137, C139, C140, C143, C144, C145, C146, C147, C148, C150, C_31, C_32 | R0402 | 68 | 4.7uF | C2, C14, C15 | C0805_M2013 | 3 | 18pF | C8, C9 | R0402 | 2 | 1uF | C10, C11, C35, C45, C94, C138, C149 | R0402 | 7 | 22uF | C18 | AE4 | 1 | 100nF | C19, C100 | CC1210 | 2 | 220uF | C20 | AE6 | 1 | 22uF | C21, C112, C113 | CC1212 | 3 | 0.01uF | C22 | C0603_M1608 | 1 | 330uF | C23, C114, C117 | CC7343 | 3 | 22uF | C24, C26 | CC3558 | 2 | 100nF | C28, C43, C60, C93, C95, C97, C121, C131, C153 | C0603_M1608 | 9 | 0.1uF | C30 | R0402 | 1 | 22pF | C38, C109 | R0402 | 2 | 10uF | C46 | R0402 | 1 | 10uF | C48, C54, C57 | C0805_M2013 | 3 | 4.7uF | C61 | R0402 | 1 | 0.1F | C62 | R0402 | 1 | 10uF | C67, C69, C71, C73, C75, C77, C105, C125, C127, C129, C134 | CC1210 | 11 | 4.7uF | C78 | CC1210 | 1 | 470nF | C79, C80, C81, C82, C83, C84 | R0402 | 6 | 22uF | C85, C86 | CC1210 | 2 | 100uF | C87, C88, C89 | AE4 | 3 | 470uF | C90, C91 | DIP5*10 | 2 | 22nF | C115, C118 | R0402 | 2 | 220pF | C119 | R0402 | 1 | 22uF | C120 | C0805_M2013 | 1 | 1uF | C122, C123 | C0603_M1608 | 2 | 4F | C124 | CCAE63 | 1 | 10uF | C141 | C0603_M1608 | 1 | 220pF | C142 | C0603_M1608 | 1 | 1uF | C151 | L0603 | 1 | 100nF | C152 | L0603 | 1 | 100nF | C221 | CC1212 | 1 | 220uF | C248 | CC7343 | 1 | SM15T33A | D1 | SM15T33 | 1 | RCLAMP0502B | D2, D3, D4, D9, D58 | RAMLP0502 | 5 | LED | D6 | SOD323 | 1 | SK34 | D7, D43, D44 | D0-214AA | 3 | LED3 | D8, D11, D18, D19, D20, D34, D51, D52, D53, D54, D55, D56, D57 | LED_2PIN | 13 | STPS340U | D10 | D0-214AA | 1 | SMBJ15CA | D13, D14 | D0-214AA | 2 | SML4752 | D21, D22, D25, D27, D29, D31 | DIODE2 | 6 | 1N4148 | D23, D24, D26, D28, D30, D32 | SOD323 | 6 | SK34A | D33 | D0-214AA | 1 | BAT54C | D35 | RAMLP0502 | 1 | LCTVS | D36, D37, D38, D39 | RAMLP0502 | 4 | LED | D40, D42, D45 | SMD_LED | 3 | LED | D41 | LED_2PIN | 1 | MINI_USB | J1 | MiniUSB | 1 | Header 3 | J3, J7 | 3P_3.5MM | 2 | LCD | J5 | FPC54 | 1 | LVDS_CON | J6 | DVI_32P | 1 | RJ45 | J8, J9 | HR911105A | 2 | Header 5 | J10 | 3.5MM_SJ3245 | 1 | SIM卡座 | J11, J13, J14 | SIMCARD | 3 | MNI_PCIE | J12 | 4G_FPC | 1 | Header 10 | J15 | HDR1X10 | 1 | EDG2RH | J16, J36 | DOP16 | 2 | COM9PIN | J18 | DB9/M | 1 | MHDR1X6 | J22 | MHDR1X6 | 1 | Header 2 | J24, P_ANTEN1 | SMD_ANTEN | 2 | SHU_USB | J28 | USB-C | 1 | JTAG | J59 | IDC20S | 1 | 继电器 | K1, K2, K3, K4, K5, K6 | JK_RELAY | 6 | Inductor | L2, L3, L9, L10 | L220 | 4 | 150R@100MHz | L5 | C0805_M2013 | 1 | 150R@100MHz | L7 | L0603_M1608 | 1 | 150R@100MHz | L8 | L0603 | 1 | mark | M1, M2, M3, M4 | SMD_MARK | 4 | 电池座 | P12 | JK2_BATTY | 1 | MMBT5551 | Q7, Q8, Q9, Q10, Q11, Q12, Q21 | SO-G3 | 7 | 2N3904 | Q15, Q16, Q19, Q20 | SO-G3 | 4 | BZX84C12V | Q17, Q18 | RAMLP0502 | 2 | 22R | R1, R2, R18, R19, R52, R127, R163, R164, R167, R168, R169, R170, R171, R172, R173, R175, R177, R178, R183, R184, R185, R186, R197, R198, R199, R200, R201, R202, R280 | R0402 | 29 | 100K | R3, R4, R5, R7, R8, R22, R30, R90, R179, R181, R195, R232, R233, R234, R235, R236, R237, R238, R239, R240, R241, R242, R243, R244, R245, R246, R247, R248, R249, R250 | R0402 | 30 | 12K | R6, R187, R188 | R0402 | 3 | 10K | R9, R11, R20, R33, R35, R36, R37, R38, R40, R41, R42, R45, R46, R47, R91, R92, R93, R94, R126, R130, R131, R142, R146, R165, R174, R176, R205, R253, R284, R285 | R0402 | 30 | 0R | R12, R13, R48, R53, R54, R151, R211, R251, R252 | C0805_M2013 | 9 | 10K | R23 | R0603_M1608 | 1 | 3.24K | R24 | R0603_M1608 | 1 | 0R | R34, R87, R125, R134, R157, R158, R_10, R_13 | R0402 | 8 | 180R | R44 | R0603_M1608 | 1 | 510R | R50 | R0402 | 1 | 470R | R58, R63 | R0402 | 2 | 120R | R59, R61, R67, R73 | R0402 | 4 | 4.7K | R60, R62, R64, R65, R66, R70, R71, R72, R81, R88, R89, R95, R96, R129, R140, R144, R153, R161, R203, R212, R281, R_8, R_9 | R0402 | 23 | 1K | R68, R69, R74, R75, R79, R83, R84, R85, R86, R97, R99, R101, R103, R105, R107, R110, R112, R114, R116, R118, R120, R122, R124, R128, R133, R148, R149, R150, R166, R180, R182, R189, R190, R193, R194, R213, R_1, R_2, R_18, R_19, RH1, RH2 | R0402 | 42 | 10K | R76 | C0603_M1608 | 1 | 47K | R77, R80, R82, R121, R123, R139, R143, R162 | R0402 | 8 | 1K | R98, R100, R102, R104, R106, R108 | C0805_M2013 | 6 | 220R | R109, R111, R113, R115, R117, R119 | R0402 | 6 | 33R | R132, R135, R136, R137, R138 | R0402 | 5 | 20K | R141, R145 | R0402 | 2 | 330R | R147 | R0402 | 1 | 2K | R152, R155 | R0603 | 2 | 10K | R156, R160 | R0603 | 2 | 49.9 | R_3, R_4, R_5, R_6, R_14, R_15, R_16, R_17 | R0402 | 8 | 4.7K | R_7 | R0603 | 1 | 0603 | S1 | boma_switch | 1 | SW-PWR | SW1 | SW_4PIN | 1 | Header 5 | T1, T2, T3, T4 | 5PIN_ALTEN | 4 | 1.27mm SMT Connect pin | U1, U2 | 1.27mm SMT connect pin | 2 | LAN7820AI | U3, U28 | QFN25_0.5MM | 2 | USB2514QFN36 | U4 | QFN36(USB251x) | 1 | MAX3232E | U5, U53 | SOIC-16N | 2 | TPS5430 | U6 | SOIC8-5430 | 1 | DS90C385AMT | U7 | SSOP56 | 1 | L5973D | U8, U9 | SOP8_5973 | 2 | MAX7359 | U10 | TQFN24_7359 | 1 | SLE66 | U11, U45 | DIP8_SL66 | 2 | TLV320AIC3106 | U12 | QFN48(TLV320) | 1 | LM1117_1.8V | U13 | AMS1117 | 1 | TDA2822 | U14 | SOP8 | 1 | PC357 | U15, U16, U17, U18, U19, U20, U21, U22, U23, U24, U25, U27 | SOP4_357 | 12 | LM1117_3.3V | U26, U47, U49 | AMS1117 | 3 | SDCARD_KMSD18 | U30 | SDcard_KDMS18 | 1 | ISO1050 | U31, U33 | SOP8-ISO1050 | 2 | B0505 | U32, U34 | SIP-4P-156 | 2 | ADUM1201AR | U35, U38, U48 | SO8_N - ADUM1201 | 3 | MAX13487ESA | U36, U39 | SOIC-8N | 2 | XR21V1414 | U37 | TQFP48_1414 | 1 | M1_BLUE | U40 | SMD_M1BLUE | 1 | UM220 | U41 | SMD_UM220 | 1 | SIM800A | U42 | SMD_SIM900 | 1 | TS3A5018 | U43, U51 | SOP16_5018 | 2 | F100 | U44 | F100 | 1 | Buzzer | U46 | BUZZER | 1 | RX8010 | U52 | SOP8-RX8010 | 1 | 74LVC245 | U70 | MTC20 | 1 | 50MHZ_XTAL | X1, X2, X3, X4 | Cystal_50M | 4 | 24MHz | Y1 | Crystals_3225 | 1 | 附件:5 S. {0 |- a& I6 x0 i
PCB源文件如下:
, w8 w7 W' d0 }3 N
) J1 f/ \% v# W& V, u4 A4 f( F/ l8 K
