作品名:[AD 16][6层]PE-HMI1产品示例_原理图和PCB源文件2 ~/ `" B0 B% D( ]( E% U, v0 @; p
* I) [# c8 x: }$ y c
文件描述
5 u% h n5 H; C' a, f3 d4 q* H/ x' i. [9 {" F# O' S
1. 作品用途:PE-HMI1产品示例_原理图和PCB源文件
- h b& S2 N- V1 e- ?- O a) H
5 x( D Y$ N; Y' i( a2. 软件版本:AD 16
I' B5 \; \- C
) C* U4 w# ?# ^ }3. 层数:6层板
/ g+ }% w: x5 }+ S/ C. w$ }4 c" S2 N* q4 e9 b7 r5 r
4. PCB尺寸:165mm*119.3mm
' z, m4 W3 c8 d: Y
5 f& s3 i( ^' C1 |+ a
/ E P* v4 l) j0 }作品截图如下:
& w# c+ I; I5 W8 u+ \+ U. \
8 j7 Z- b; m' Z顶层截图:2 {) `) L2 u% Z: l. r" ]
( G+ g4 V: c3 X6 S: f( W
+ P. r6 Z2 E7 B7 `( m. G7 H4 p底层截图:
/ y8 W' @& `: n) H
% A: Z6 V2 [9 `: |$ R3 T
& E, S' P2 U" Y" a q- q# l全层截图:2 r' L, A/ y0 G# u9 W
& F6 B% k0 a3 `) y
+ [8 {, \+ `) s) T叠层信息截图如下:( ]5 @& k# \) p$ R- b5 C
5 x& K# h4 x; d2 j
8 o( [8 a) A1 q; ~8 _5 K. I9 RBOM:# ]2 w0 G( u% n8 G
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | CON-000049-01 | BAT1 | KEYSTONE_3000 | 1 | CAP-000057-01 | C1, C2, C4, C7, C8, C11, C17, C18, C20, C21, C25, C26, C27, C28, C29, C30, C31, C32, C33, C37, C40, C45, C48, C49, C51, C53, C54, C75, C76, C77, C78, C79, C81, C83, C85, C86, C87, C88, C90, C91, C98, C100, C101, C102, C103, C104, C105, C106, C107, C108, C109, C110, C112, C113, C114, C115, C116, C122, C123, C124, C125, C126 | CAPC0201-01 | 62 | CAP-000086-01 | C3 | CAPC0805-01 | 1 | CAP-000072-01 | C5, C6, C15, C50 | CAPC0603-01 | 4 | CAP-000013-01 | C9 | CAPC0603-01 | 1 | CAP-000066-01 | C10, C13, C94 | CAPC0603-01 | 3 | CAP-000042-01 | C12 | CAPC1206-01 | 1 | CAP-000031-01 | C14 | CAPC0402-01 | 1 | CAP-000073-01 | C16, C34 | CAPC0402-01 | 2 | CAP-000063-01 | C19, C35, C73, C74, C80, C82, C84, C89, C97, C111 | CAPC0402-01 | 10 | CAP-000077-01 | C22, C23, C24, C68 | CAPC0402-01 | 4 | CAP-000070-01 | C36 | CAPMP7343-31-01 | 1 | CAP-000059-01 | C38, C39 | CAPC0402-01 | 2 | CAP-000095-01 | C41, C42, C43, C44 | CAPC0402-01 | 4 | CAP-000064-01 | C46, C92, C93 | CAPC0402-01 | 3 | CAP-000067-01 | C47, C96, C127, C128 | CAPC0402-01 | 4 | CAP-000019-01 | C52 | CAPC1206-01 | 1 | CAP-000093-01 | C55 | CAPC1206-01 | 1 | CAP-000106-01 | C56 | CAPC1210-01 | 1 | CAP-000098-01 | C57 | CAPC0402-01 | 1 | CAP-000102-01 | C58, C60 | CAPC1206-01 | 2 | CAP-000105-01 | C59 | CAPEL_F | 1 | CAP-000104-01 | C61 | CAPEL_B | 1 | CAP-000051-01 | C62, C63 | CAPC1206-01 | 2 | CAP-000107-01 | C64 | CAPEL_B | 1 | CAP-000090-01 | C65 | CAPC0603-01 | 1 | CAP-000103-01 | C66 | CAPC0805-01 | 1 | CAP-000099-01 | C67 | CAPC0805-01 | 1 | CAP-000100-01 | C69 | CAPC0603-01 | 1 | CAP-000101-01 | C70, C95 | CAPC0402-01 | 2 | CAP-000041-01 | C71 | CAPC0603-01 | 1 | CAP-000097-01 | C72 | CAPC0402-01 | 1 | CAP-000114-01 | C99 | CAPC0402-01 | 1 | CAP-000083-01 | C117, C118, C119, C120, C121 | CAPC0201-01 | 5 | DIO-000027-01 | D1, D2 | DIODES_POWERDI123 | 2 | DIO-000015-01 | D3 | DIODES_POWERDI123 | 1 | DIO-000011-01 | D4 | SOT-23 | 1 | DIO-000019-01 | D5 | DO-221AC | 1 | DIO-000020-01 | D6, D9 | SMD_4P-MINI-DIP | 2 | DIO-000018-01 | D7 | SOD-323 | 1 | DIO-000021-01 | D8 | DIODES_SMA | 1 | DIO-000014-01 | D10 | SOT-23 | 1 | ICN-000152-01 | D11 | SOT-23 | 1 | DIO-000022-01 | D12 | SOT-23 | 1 | IND-000011-01 | FB1 | FB_0402 | 1 | IND-000005-01 | FB2 | FB_0805 | 1 | IND-000016-01 | FB3, FB4 | FB_0805 | 2 | CON-000145-01 | J1 | MOLEX_503471-0200 | 1 | CON-000116-01 | J2 | FCI_10118192 | 1 | CON-000036-01 | J3 | SAMTEC_USB-A-S-F | 1 | CON-000144-01 | J4 | AMPHENOL_RJSSE-5381 | 1 | CON-000107-01 | J5 | OMRON_XF2W-4015 | 1 | CON-000129-01 | J6 | OMRON_XF2W-0815 | 1 | CON-000126-01 | J7, J8 | JST_SM02B-GHS | 2 | CON-000050-01 | J9 | SAMTEC_SSW-106-02-F-D-RA-PMOD | 1 | CON-000080-01 | J10 | FCI_20020110-C081 | 1 | CON-000148-01 | J11 | SAMTEC_SSW-106-02-F-S-RA | 1 | CON-000172-01 | J12 | SAMTEC_FTSH-110-01-X-DV-007-K | 1 | CON-000153-01 | J13, J14 | HARWIN_M20-9960345 | 2 | IND-000007-01 | L1, L3 | BOURNS_SRN3015 | 2 | IND-000008-01 | L2 | BOURNS_SRR5028 | 1 | IND-000015-02 | L4 | BOURNS_SM51108PEL | 1 | IND-000017-01 | L5 | BOURNS_SRN4018 | 1 | LED-000001-01 | LED1, LED2 | LED_DIALIGHT-598-8610 | 2 | LED-000002-01 | LED3 | LED_0603-ORG | 1 | LED-000003-01 | LED4 | LED_0603-GRN | 1 | FET-000001-01 | Q1 | SSOT-6 | 1 | RES-000139-01 | R1, R3, R6, R14, R29, R50, R51, R54, R57, R65, R71 | RESC0402-01 | 11 | RES-000177-01 | R2 | RESC0402-01 | 1 | RES-000125-01 | R4, R42, R47 | RESC0402-01 | 3 | RES-000109-01 | R5 | RESC0402-01 | 1 | RES-000154-01 | R7 | RESC0402-01 | 1 | RES-000124-01 | R8, R11 | RESC0402-01 | 2 | RES-000137-01 | R9, R43, R52, R53, R55, R56, R60, R61, R62, R63, R64 | RESC0402-01 | 11 | RES-000135-01 | R10 | RESC0402-01 | 1 | RES-000140-01 | R12 | RESC0402-01 | 1 | RES-000203-01 | R13 | RESC0402-01 | 1 | RES-000123-01 | R15 | RESC0402-01 | 1 | RES-000127-01 | R16, R75 | RESC0402-01 | 2 | RES-000200-01 | R17 | RESC0402-01 | 1 | RES-000171-01 | R18, R19 | RESC0402-01 | 2 | RES-000201-01 | R20 | RESC0402-01 | 1 | RES-000141-01 | R21, R22, R37, R39, R66, R67, R68, R69, R70 | RESC0402-01 | 9 | RES-000175-01 | R23, R58 | RESC0402-01 | 2 | RES-000176-01 | R24, R25, R26, R27 | RESC0402-01 | 4 | RES-000161-01 | R28 | RESC0402-01 | 1 | RES-000184-01 | R30 | RESC0402-01 | 1 | RES-000133-01 | R31, R32 | RESC0402-01 | 2 | RES-000189-01 | R33 | RESC0603-01 | 1 | RES-000187-01 | R34 | RESC0603-01 | 1 | RES-000188-01 | R35 | RESC0603-01 | 1 | RES-000186-01 | R36 | RESC0805-01 | 1 | RES-000178-01 | R38 | RESC1206-01 | 1 | RES-000185-01 | R40 | RESC0402-01 | 1 | RES-000179-01 | R41 | RESC0402-01 | 1 | RES-000180-01 | R44 | RESC0402-01 | 1 | RES-000190-01 | R45 | RESC1206-01 | 1 | RES-000191-01 | R46 | RESC1206-01 | 1 | RES-000181-01 | R48 | RESC0402-01 | 1 | RES-000182-01 | R49 | RESC0402-01 | 1 | RES-000193-01 | R59 | RESC0402-01 | 1 | RES-000199-01 | R72, R73 | RESC0805-01 | 2 | RES-000156-01 | R74 | RESC0402-01 | 1 | RES-000108-01 | RA2, RA3, RA4, RA5, RA6, RA7, RA8, RA10, RA14 | RESCAF0804 | 9 | RES-000118-01 | RA9, RA15 | RESCAF0804 | 2 | RES-000164-01 | RA11, RA12 | RESCAF0804 | 2 | RES-000113-01 | RA13 | RESCAF0804 | 1 | RES-000106-01 | RA16, RA17 | RESCAF0804 | 2 | OEM-000007-01 | RF1 | NETCOM_GT202 | 1 | OEM-000011-01 | RF2 | PANASONIC_PAN132X | 1 | SWT-000001-01 | S1 | SW_C&K_KSC222J | 1 | SWT-000011-01 | S3 | SW_CTS_219-5LPST | 1 | FAS-000020-01 | SO1, SO2, SO3, SO4 | PEM_SMTSO-M3-6 | 4 | SPK-000009-01 | SPK1 | BESTAR_BBASS | 1 | IND-000018-01 | T1 | PULSE_PA1283 | 1 | CON-000047-01 | TP1, TP2, TP3, TP4, TP5, TP6, TP7, TP8 | KEYSTONE_5015 | 8 | ICN-000198-01 | U1 | RENESAS_FBGA224 | 1 | ICN-000012-01 | U2 | SOT-23 | 1 | ICN-000148-01 | U3 | INTERSIL_DFN8 | 1 | ICN-000189-01 | U4 | AVAGO_ADPS-9005 | 1 | ICN-000017-01 | U5 | SOT23-5 | 1 | ICN-000072-01 | U6 | TI_PVSON-N10 | 1 | ICN-000165-01 | U7, U9 | TI PDSO-N5 | 2 | ICN-000121-01 | U8 | SILABS_DFN2025-4 | 1 | ICN-000149-01 | U10 | MICREL_QFN55-32 | 1 | ICN-000146-01 | U11 | SILABS_DFN2025-4 | 1 | ICN-000150-01 | U12 | TI_TSSOP14 | 1 | OPT-000001-01 | U13, U14 | OPTO_DIP4 | 2 | ICN-000131-01 | U15 | TI_DSE-PWSON-N6 | 1 | ICN-000154-01 | U16 | NXP_DHVQFN-16 | 1 | ICN-000155-01 | U17 | SILABS_DFN2025-4 | 1 | ICN-000168-01 | U18 | MAXIM_TDFN-EP-14 | 1 | ICN-000153-01 | U19 | QFN16-3X3 | 1 | ICN-000108-01 | U20 | INTERSIL_QFN40-6X6 | 1 | ICN-000022-01 | U21 | TI_SOIC8 | 1 | ICN-000101-01 | U22 | MICRON_WFBGA153 | 1 | ICN-000169-01 | U23 | MICRON_VFBGA54 | 1 | XTL-000006-01 | X1 | ABRACON_ABS07 | 1 |
# B' {! k2 g9 O) x5 Q0 b! U# w附件:3 h3 I$ y8 ^( O. A+ I- d
! s' H- p4 l6 y* X( L: V8 R' X6 { a
原理图和PCB源文件如下:& w! X6 T1 k8 Y/ B$ D
$ F" t4 X ?. X- w/ d
5 M/ G0 i' [4 |4 j0 b3 s$ U9 W' n4 `4 X$ h3 z
