查看: 382|回复: 1
[allegro16.6][4层]KITPF3000FRDMEVM评估套件-PF30001电源管理集成电路(F300XEP+...
发表于 2020-1-20 17:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
& m" _2 g* }) [! \[allegro16.6][4层]KITPF3000FRDMEVM评估套件-PF30001电源管理集成电路(F300XEP+ADG715+MCP6V07)原理图和pcb文件
! n! M3 |0 T  \5 u: V
, c0 ^2 g, b5 B1 u: l5 ^文件描述:
( U3 L6 d7 K$ V% s4 r  F; q* @/ z* K  C  ~) h. z- H
1. 作品用途:KITPF3000FRDMEVM评估套件-PF30001电源管理集成电路9 a! A3 E) J+ B- G+ k, c- ^  h* H" S
2. 软件版本:allegro16.6' u$ _% }* n4 |/ J. E- G
3. 层数:4层* }9 S5 a! x+ p9 k! f7 Z3 @
4. 用到的主要芯片:F300XEP+ADG715+MCP6V07! r! p7 N/ w: T1 ~- H5 K
5. pcb尺寸:4249*4621.5 MIL
" M9 U/ }% d' P8 o8 m
! [  O9 _7 A4 e1 Q8 h; h  \作品截图如下:8 h' m  j8 g7 T9 V
/ s: p! v/ l1 x* w顶层截图:: e# ]# {. J9 ]: S4 c
( _: c% P: f$ D8 j底层截图:/ G5 i% e* g% f1 y
* }2 j; P0 C( U  Y
9 f9 D! u4 j1 G& }
全层截图:
) Z2 l) y. |1 F
. k# M& {: q1 x; }' m
; @5 q/ h( f! J* o2 `叠层阻抗信息如下:7 b. K% v* d4 j* D3 N, o
) H2 d& U6 G% \BOM:% P/ e: Q4 Z( [6 c3 z: @
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BATT_MSLICELL_BATT_MS_IC_2.8MM_670-000LICELLIC1BAT1
C035ST POINT R_C035S_IC_0.1 MM_280-7TEST POINTIC4TP3; TP8; TP10; TP17
C280-130TMOUNT_HOLE_C280-130T_IC_0 MM_28MTGIC4BH1; BH2; BH3; BH4
CASE6627RES_CASE6627_DISCRETE_470-759191DISCRETE2R37; R39
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.55M0.22uFDISCRETE2C8; C13
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6MM1.0UFDISCRETE8C9; C11; C12; C21; C25; C26; C29; C59
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.64M0.1UFDISCRETE13C10; C22; C28; C33; C34; C35; C46; C47; C48; C49; C54; C56; C60
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_10.47uFDISCRETE1C15
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.65M4.7uFDISCRETE3C16; C27; C58
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5_12.2UFDISCRETE3C24; C30; C42
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.740.01UFDISCRETE1C38
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.90M1.0UFDISCRETE2C3; C6
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM4.7uFDISCRETE1C43
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4547uFDISCRETE2C1; C2
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.45M22uFDISCRETE12C4; C5; C14; C17; C18; C19; C20; C23; C31; C32; C36; C39
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4MM10UFDISCRETE6C7; C37; C41; C50; C53; C55
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.350.1UFDISCRETE5C63; C65; C67; C68; C70
CC0805_OVCAP_NP_CC0805_OV_DISCRETE_1.4_110UFDISCRETE3C64; C66; C69
CON2X10_2P54_THCONN_HDR_10X2_CON2X10_2P54_TH_ICON_2X10IO1J20
CONN_HDR_3X1CONN_HDR_3X1_CONN_HDR_3X1_IO_8.HDR 1X3IO5J5; J10; J11; J12; J13
CON_BANANA_571CONN_HDR_2X1_CON_BANANA_571_IO_BANANA REDIO2J2; J4
CON_BANANA_571CONN_HDR_2X1_CON_BANANA_571_I_1CONN BANANA BLACK 2IO1J3
CON_SKT2X6_THCONN_HDR_6X2_CON_SKT2X6_TH_IO_8CON 2X6 SKTIO1J22
CON_SKT2X8_THHDR_2X8_M_CON_SKT2X8_TH_IO_8.76CON 2X8IO2J19; J21
HDR102CONN_HDR_1X2_HDR102_IO_8.6MM_21HDR 1X2 THIO11J6; J7; J8; J9; J14; J15; J16; J17; J18; J24; J25
IND2_2P2X2P7_SMINDUCTOR_IND2_2P2X2P7_SM_DISCRE1.5uHDISCRETE4L2; L3; L4; L5
IND_COILCRAFT_3X3MMINDUCTOR_IND_COILCRAFT_3X3MM_DI2.2UHDISCRETE1L1
LED_0603LED_LED_0603_IC_1.1MM_370-76425LED GreenIC1D2
MLP6_2X2MM_SLUGFDMA510PZ_MLP6_2X2MM_SLUG_IC_0.FDMA908PZIC1Q2
MSOP08_0P65_3P2X3P2AD8606ARMZ-R7_8P_MSOP08_0P65_3PAD8606ARMZ-R7IC1U3
MSOP_10_0P5_3X3MCP4728_MSOP_10_0P5_3X3_IC_1.1MMCP4728IC1U23
QFN48_0P5_7X7_EP4P14X4P22MC32PF300XEP_48P_QFN48_0P5_7X7_MC32PF300XEPIC1U2
RAPC722DC_POWER_JACK_3_RAPC722_IO_11.0CON_1_PWRIO1J1
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_4100KDISCRETE10R2; R4; R7; R8; R9; R10; R19; R24; R25; R26
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_1100KDISCRETE2R22; R23
RC0603_OVRES_RC0603_OV_DISCRETE_0.4MM_470DISCRETE8R1; R3; R11; R14; R15; R16; R18; R21
RC0805_OVRES_RC0805_OV_DISCRETE_0.4MM_471KDISCRETE4020; 21; R27; R41
RC0805_OVMOT_RES_RC0805_OV_DISCRETE_0._14.7KDISCRETE4R5; R6; R17; R20
RC0805_OVMOT_RES_RC0805_OV_DISCRETE_0.4300DISCRETE1R12
RC0805_OVRES_RC0805_OV_DISCRETE_0.4MM__11.80KDISCRETE1R36
RC0805_OVRES_RC0805_OV_DISCRETE_470-754615.0KDISCRETE2R38; R40
SC82_4NCP562_SC82_4_IC_1.1MM_312-7732NCP562IC1U1
SO8_1P27_4X5MOSFET_N_S3_D4_SO8_1P27_4X5_IC_SI4156DYIC2Q20; Q21
SO8_1P27_4X5OPAMP_DUAL_8P_D_SO8_1P27_4X5_ICMCP6V07IC2U21; U24
SOD123LFDIODE_SCHTKY_SOD123LF_IC_1.0MM_MBR120LSFT1GIC1D1
SOT23-6ADR34XX_SOT23_6P_SOT23-6_IC_1.4ADR3425ARJZIC1U4
SW2_9P11_6X3P5_SMSW2P_SW2_9P11_6X3P5_SM_IC_4.57MFSMSMIC1SW2
SW3_SPDT_4P3X8P6_THSW_MAG_SPDT_SW3_SPDT_4P3X8P6_THSPDT_SWITCHIC1SW1
TESTPOINT_35MILT POINT R_TESTPOINT_35MIL_IC_0.TP_35MILIC2TP32; TP33
TEST_PIN_10_201-XXTEST_POINT_10-201-X_TEST_PIN_10TESTPOINTIC10TP2; TP5; TP18; TP21; TP23; TP27; TP28; TP31; TP37; TP44
TEST_PIN_TP107TESTLOOP_TEST_PIN_TP107_IO_2.28TESTLOOPIO4TP1; TP4; TP19; TP22
TP_TH_063T POINT TH_TP_TH_063_IC_5.6 MM_5007IC11TP6; TP7; TP9; TP13; TP14; TP15; TP16; TP35; TP36; TP41; TP42
TP_TH_063TESTLOOP_TP_TH_063_IO_8.13MM_21TESTLOOP_REDIO8TP11; TP12; TP20; TP24; TP25; TP26; TP29; TP30
TSSOP24_0P65_7P9X4P5ADG715_24P_TSSOP24_0P65_7P9X4P5ADG715IC2U5; U6
附件:
# L$ V2 v% A+ U- q* x原理图和PCB文件如下:5 w* ~4 j# B7 I4 F) P  n; c
游客,如果您要查看本帖隐藏内容请回复
) ]7 b" l. r  @! I# z- |3 U. O% N* ~/ l  k$ Y5 L( i# u0 |
发表于 2023-7-20 08:25 | 只看该作者
谢谢分享·······
/ K' A: }) U3 Q+ b( F
GMT+8, 2025-10-12 12:33 , Processed in 0.140625 second(s), 27 queries , Gzip On.
