+ ^- P; q* T4 r. Y6 o, l
& a- _! [5 X& {! W) _) U& ^- _5 V★ pads最新外挂工具一一PowerAccess ★
8 k% t0 V1 |6 d+ x* c K8 P Part searches
Parametric part search with Logic & Layout symbol preview. Customizable attribute set for searching different Logic families This function is free - works without a license (in pDB). . h P7 w+ A4 ~9 V0 e6 u! y: w
Design Verify
Quickly compare parts in a Logic or a Layout file to your reference library and find the differences. You will find new parts (or parts not in your library), verify part level attributes and also the decal level attributes for PADS Layout.9 t& W1 ]. {- f0 E/ I4 N
Variants
Define variants with ease. You can define variants in the tool and back annotate to Logic file. The tool creates a variant table to show variants graphically in Logic. Variant definition can be annotated to PADS Layout as well.! F o8 T y5 c
Excel inteRFace
For BOMs the tool will collect attributes (and possibly linked data) also for substituted parts. 8 u# }" S1 V7 d2 Z* l
Take the advantage of spreadsheet. You can convert the entire parttype library to an Excel spreadsheet, modify and convert back. 2 K5 @3 i$ D" E3 ~; H0 U* _' F6 q& t
Manage Library paths You can also run an attribute update by index. This can be used to add attribute information to PADS library.
6 w, L% h3 A4 dAlso, you can import data from an external source to be shown in component searches and to be included in BOMs. The data can be directly linked (by an index field) or cross-linked. PowerAccess has a tool to build cross-link index tables easily.$ P0 w5 {2 x* x* Y9 H# i- x
The tool saves the PADS library paths in the backend database. When launched it will compare the current PADS library path to saved values and indicate if there are differences. You can then update PADS paths with a single click.
# \/ ]' j) w+ X& JThe function is useful when different library sets are used. It is easy to update the library paths for each library set (each library set is saved in it's own backend database).
) g! Q; ^% W* FAlso in a multiuser environment it makes it easy to distribute the correct library paths. 9 T3 s; d* H4 ?2 R, v
Logic Renumber Renumbers parts by page or linear. Definable RefDes offset. Batch or interactive. Renumbers both schematic and Layout at the same time (driven by schematic). ) V7 h, N! J2 x
LPG- Logic Part Generator Use Excel to create a complete part (single or multi-gate, symbol and parttype) on a single Excel spreadsheet. Reads data from the spreadsheet and writes to PADS Library. Use copy/paste to enter pin numbers and names to Excel - avoid typing errors. Extremely easy to move groups of pins from one gate to another. Free option -works without a license. ; S/ a( r# m9 N1 c( L) c
Waiting for build ...
4 h6 L2 q" P& H: D8 R
' _; [; F* x% s下载地址:( a4 \, C' r% a5 y6 v7 W
& O( D0 M R* K; b/ W7 C2 ^( H
如果不能下载就用下面这个下载工具:
RaySource.part1.rar
(1.81 MB, 下载次数: 965)
RaySource.part2.rar
(1.18 MB, 下载次数: 861)
