查看: 371|回复: 1
STC89C52单片机+12864串口图片显示
    2019-11-21 15:51
    发表于 2020-1-20 10:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    #include<reg52.h>
    #define uint unsigned int
    #define uchar unsigned char
    sbitCS=P2^0;
    sbitSID=P2^1;
    sbitSCLK=P2^2;
    sbitPSB=P2^3;
    uchar code denglong[64][16]={
               0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
         0x03,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
         0x1F,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
         0x7F,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,
         0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,
         0xFF,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,
         0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,
         0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,
         0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,
         0xFF,0xFF,0xFF,0x80,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,
         0xFF,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
         0xFF,0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,
         0xE0,0x00,0xFF,0xE0,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFE,
         0x03,0xF8,0x1F,0xF0,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF8,
         0xFF,0xFF,0xC3,0xF0,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xE3,
         0xFF,0xFF,0xF9,0xF8,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xCF,
         0xFF,0xFF,0xFE,0x78,0x00,0x00,0x00,0x00,
          0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x3F,
         0xFF,0xFF,0xFF,0x3C,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0x7F,
         0xFF,0xFF,0xFF,0xDC,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x0D,0xFF,
         0xFF,0xFF,0xFF,0xEC,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xFB,0xFF,
         0xFF,0xFF,0xFF,0xF6,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xFF,
         0xFF,0xFF,0xFF,0xFA,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xC7,0xFF,
         0xFF,0xFF,0xFF,0xFF,0xDC,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,
         0xFF,0xFF,0xFF,0xFE,0xDC,0x00,0x00,0x00,
         0xF0,0x01,0xFF,0xFE,0x5C,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0x8F,0xF0,
         0x00,0x00,0x03,0xFF,0xDC,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xAF,0x03,
         0xFF,0xFF,0xF8,0x3E,0xDC,0x00,0xC0,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xFC,0x7F,
         0xFF,0xFF,0xFF,0x8E,0x5C,0x00,0xC0,0x00,
         0x00,0x00,0x00,0x00,0x00,0x03,0xE3,0xFF,
         0xFF,0xFF,0xFF,0xFA,0xDC,0x00,0xC0,0x00,
         0x00,0x00,0x00,0x00,0x00,0x03,0xCF,0xFF,
         0xFF,0xFF,0xFF,0xFF,0xDC,0x00,0xC0,0x00,
         0xFF,0xFF,0xFF,0xFE,0xDC,0x00,0xC0,0x00,
         0x3F,0xFF,0xFF,0xFF,0x83,0xFF,0xBF,0xFF,
         0xFF,0xFF,0xFF,0xFE,0x5F,0xFF,0xC0,0x00,
         0x3F,0xFF,0xFF,0xFF,0xB8,0x03,0x8F,0xFF,
         0xFF,0xFF,0xFF,0xFF,0xDF,0xFF,0xC0,0x00,
         0x3F,0xFF,0xFF,0xFF,0xB8,0x03,0xAF,0xFF,
         0x3F,0xFF,0xFF,0xFF,0x80,0x03,0xFF,0xFF,
         0xFF,0xFF,0xFF,0xFE,0x5C,0x00,0xC0,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xEF,0xFF,
         0x00,0x00,0x00,0x00,0x03,0xFF,0x87,0xFF,
         0x00,0x00,0x00,0x00,0x00,0x03,0xF9,0xFF,
         0xFF,0xFF,0xFF,0xE2,0x5C,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x03,0xBE,0x0F,
         0xFF,0xFF,0xFE,0x1E,0xDC,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0x8F,0xC0,
         0x3F,0xFF,0x80,0x7F,0xDC,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xAF,0xFE,
         0x00,0x00,0x0F,0xFE,0xDC,0x00,0x00,0x00,
         0xFF,0xFF,0xFF,0xFE,0x5C,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x03,0xEF,0xFF,
         0x00,0x00,0x00,0x00,0x00,0x03,0x87,0xFF,
         0xFF,0xFF,0xFF,0xFE,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x03,0xFF,0xFD,0xFF,
         0xFF,0xFF,0xFF,0xF4,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x0E,0xFF,
         0xFF,0xFF,0xFF,0xCC,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x7F,
         0xFF,0xFF,0xFF,0x9C,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x9F,
         0xFF,0xFF,0xFF,0x78,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xC7,
         0xFF,0xFF,0xFC,0xF8,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xF1,
         0xFF,0xFF,0xE3,0xF8,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFC,
         0x3F,0xFF,0x87,0xF0,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,
         0x80,0x00,0x3F,0xE0,0x00,0x00,0x00,0x00,
         0xF8,0x03,0xFF,0xE0,0x00,0x00,0x00,0x00,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,
         0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
         0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,
         0x7F,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,
         0x0F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,
    voiddelay_1ms(uint x)
           uchar i=110;
           while(x--)
                       i=110;
                       while(i--);
    void send_command(uchar command_data)
             uchari;
             uchari_data;
             i_data=0xf8;//写指令第一个字节11111000
             CS=1;
             SCLK=0;
             for(i=0;i<8;i++)
                       SID=(bit)(i_data&0x80);
                       SCLK=0;
                       SCLK=1;
                       i_data<<=1;
             i_data=command_data;
             i_data&=0xf0;
             for(i=0;i<8;i++)
                       SCLK=0;
                       SCLK=1;
                       i_data<<=1;
             i_data<<=4;
             for(i=0;i<8;i++)
                       SCLK=0;
                       SCLK=1;
                       i_data<<=1;
             CS=0;
             delay_1ms(10);
    void send_data(uchar command_data)
           uchar i;
             uchari_data;
             i_data=0xfa;//写数据11111010
             CS=1;
             for(i=0;i<8;i++)
                       SCLK=0;
                       SCLK=1;
                       i_data<<=1;
             i_data&=0xf0;
             for(i=0;i<8;i++)
                       SCLK=0;
                       SCLK=1;
                       i_data<<=1;
             i_data<<=4;
             for(i=0;i<8;i++)
                       SCLK=0;
                       SCLK=1;
                       i_data<<=1;
             CS=0;
             delay_1ms(10);
    void lcd_init()
             PSB=0;
             delay_1ms(100);
             send_command(0x30);//设置8位数据接口,基本指令模式
             send_command(0x02);//DDRAM
             send_command(0x06);//游标显示右移一位
             send_command(0x0c);//整体显示开,游标关,反白关
             send_command(0x01);//写入空格清屏
             send_command(0x80);//设定首次显示位置
    void display()
             uchari,j;
             send_command(0x34);//开扩充指令集
             for(i=0;i<32;i++)
                       send_command(0x80+i);
                       send_command(0x80);
                       for(j=0;j<16;j++)
                                send_data(denglong[j]);
             for(i=0;i<32;i++)
                       send_command(0x88);
                       for(j=0;j<16;j++)
                                send_data(denglong[i+32][j]);
             send_command(0x36);    //开绘图
             send_command(0x30);//返回基本指令集
    void main()
             lcd_init();
             display();
             while(1);
    1 S5 T$ J1 E/ Q; T7 z# O1 ?) z
    发表于 2020-1-20 15:46 | 只看该作者
    楼主,你试过这个代码吗?我怎么跑不通?
    GMT+8, 2025-10-7 04:04 , Processed in 0.125000 second(s), 24 queries , Gzip On.
