作品名:[AD 10][2层]数控充电器(TL494CJ+PC817+LM2596)原理图和PCB源文件
; J! e2 I. [! R8 Z8 w# O9 W
5 i4 j1 Z, t4 N; |& v, u! L2 R$ a6 K文件描述7 b& ^( u. A% p, w; n) ]5 }# k
+ W/ h6 x4 R7 O2 |0 K1 ^
1. 作品用途:数控充电器, D. }- V+ f9 X! Q" y
* L, s6 U7 n7 m% T2. 软件版本:AD 101 U7 h: y! E$ H2 n
. @3 x3 o4 z* r
3. 层数:2层板" b# H7 W( c5 ?6 w
6 {2 f# X4 u7 ~. w7 V: e& `4. 用到的主要芯片:TL494CJ+PC817+LM2596) Z$ `! S4 w3 `6 h* f& |8 o
. |$ M. m9 T7 r# N0 M& k$ o5. PCB尺寸:100mm*100mm
6 n/ R3 o4 X) ~; m$ h+ Z9 I9 ~3 x6 N: m: e
: Y8 ?# Q# F7 g! _
作品截图如下:
- y" F' ?$ h" z) I+ O
# u+ F4 E2 Z( v$ Z顶层截图:7 d* Z! w! @: M1 M( f1 J
* {0 }' D/ \ G' L+ Z7 p o! W0 O- P# y) ^7 C
底层截图:
' R( `& }, P8 h5 F3 G% n% s& o4 P
) ~& k) n& |# j
0 Y7 U# Y6 Y3 K; I+ b
全层截图:/ j" A5 |2 r9 k$ `$ K# N
9 K, A- m, x2 D$ \2 j4 U
, h3 x0 O) U4 V+ G- w* U, T叠层信息截图如下:/ e1 Q z v5 h3 ~( ^" D0 R/ `' I' F
- O3 l9 ^% Y5 d+ n1 Z) i
3 C2 l1 [/ S; iBOM: V/ q+ F0 c* W, D8 r. k- W! b! i
Comment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 10nF | C1, C5 | CBB_474 | 2 | Cap Pol 2.5x6.3 | C2, C3 | C13x20 | 2 | Cap Chip 0805 | C4, C8 | WIMA MKP10 0.22 | 2 | Cap Pol | C6, C7 | CAPPR7.5-16X20 | 2 | Cap Pol 2.5x6.3 | C9, C10 | CAP_25V_100uf | 2 | Cap Chip 0805 | CC1, CC4, CC5, CC6, CC7, CC8, CC9, CC10, CC11, CC12, CC13, CC14, CC15, CC16, CC17, CC18, CC19, CC20 | CC0805 | 18 | Cap Chip 0805 | CC2, CC3 | CC2012-0805 | 2 | Resistor Chip 0805 | CR1, CR2, CR3, CR4, CR5, CR6, CR7, CR8, CR9, CR10, CR11, CR12, CR13, CR14, CR15, CR16, CR17 | CR0805 | 17 | Diode Glass | D1, D2 | DO-35 | 2 | Fuse | F1 | FUSE | 1 | CONNECT-2 | J1, J2, J3 | HB-9500 2P | 3 | INDUCTOR | L1 | INDUCTOR_120UH | 1 | INDUCTOR | L2 | INDUCTOR_100UH | 1 | Header 3 | P1, P2, P4 | HDR1X3 | 3 | Header 3X2 | P3 | HDR2X3 | 1 | Header 5X2 | P5 | IDC2.54-10 | 1 | MOSFET-N | Q1, Q2 | TO220_3 | 2 | Resistor AXIAL0.3 | R1 | constantan_wire | 1 | Resistor AXIAL0.3 | R2, R3 | AXIAL-0.3 | 2 | Res Adj Pot Small | RP1, RP2 | 3296W | 2 | INA210 | U1 | SOT23-6 | 1 | TL494CJ | U2 | SOP16 | 1 | MIC4102 | U3 | SOIC8 | 1 | PC817 | U4 | DIP-4_N | 1 | LM2596 | U5 | TO220_5 | 1 | LM1117 | U6 | SOT-223 | 1 | TLV5638 | U7 | SOP8 | 1 |
8 w6 v S' K! Y9 r$ y, I* V [7 W! S附件:
$ c! h9 C y& ~3 G6 |+ A; p9 @
4 t& A2 Y- E! X7 Z; z6 y/ H原理图和PCB源文件如下:! v8 u& |+ W/ g
@1 C6 }: R3 m- P" R6 j
( D# X# y# P& J( @# L3 x
" W1 }) }: ?( P w u/ v9 t
2 G, k$ u3 U/ p. s: e8 W8 L |
