查看: 438|回复: 1
[allegro15.5][4层] 高端智能家居网关方案( G2 CS7522+LE88506DVC+DDR)原理图和p...
发表于 2020-1-16 15:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro15.5][4层] 高端智能家居网关方案( G2 CS7522+LE88506DVC+DDR)原理图和pcb文件' B. t. l1 v" C4 i1 Q0 }8 ]
2 n# z( a0 [5 ?8 H文件描述:# j0 r' g5 Z+ x$ `& L& s
2 W- ]& I" }5 l# E* U
1. 作品用途:高端智能家居网关方案
5 j. d: I- ^6 t+ F2. 软件版本:allegro15.5
1 r. |" m( |; M1 B6 |$ H3. 层数:4层
  v  ^0 s, i6 z1 u1 o; N4. 用到的主要芯片:G2 CS7522+LE88506DVC+DDR0 m% @' \; ~' ~7 N( R
5. pcb尺寸: 6496.06*4606.3 MIL
, L6 `' C3 x& z1 @# C
& D4 L, j7 G( T作品截图如下:
. G: j! R5 _8 K! ^) M+ W2 L4 b4 o; ^  ~
顶层截图:8 ]9 E- Z" q5 h% U2 j
. n, C, [6 z2 w& C5 G, C$ v, p2 [底层截图:, ~+ N' R+ j9 O% @. G
7 I" o+ [' x! l* b
" C9 I* l! o/ ~8 V: I# I全层截图:
5 [' h( M: h& P9 C* @+ N
9 h# L. X# m) G$ t6 A& z: G # K2 ^/ H* g4 }& l: {
叠层阻抗信息如下:
0 t# b' T% e7 c5 Q. V 7 p. j( }7 l4 O9 X: K3 n
BOM:9 A4 @& B5 Y6 W& g3 A8 p' s6 A& r
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BATC2-20BAT_BATC2-20_CR2032 SOCKETCR2032 SOCKETIC1BAT2
BGA96-32-0713DDR3 SDRAM96_BGA96-32-0713_MT41MT41J128M16HA-125: DIC1U2
BGA324-32-1515CPU CS7522_BGA324-32-1515_G2 CSG2 CS7522IC1U1
C0402CAP NP_C0402_20PF 50V20pF 50VIC2C1; C2
C0402CAP NP_C0402_0.1UF 16V0.1uF 16VDISCRETE133C4; C5; C7; C8; C10; C11; C13; C14; C19; C20; C21; C22; C23; C25; C32; C33; C34; C35; C36; C37; C38; C39; C40; C52; C60; C73; C74; C79; C80; C81; C82; C83; C84; C85; C86; C99; C100; C101; C117; C118; C119; C147; C150; C152; C155; C156; C158; C159; C160; C161; C162; C164; C165; C166; C169; C170; C171; C173; C174; C176; C186; C189; C191; C192; C193; C194; C195; C204; C210; C211; C213; C228; C231; C233; C234; C235; C239; C240; C241; C242; C243; C246; C252; C253; C281; C282; C283; C284; C285; C287; C288; C289; C290; C291; C292; C293; C297; C298; C299; C300; C301; C302; C303; C304; C314; C315; C327; C338; C339; C344; C347; C350; C351; C352; C353; C355; C357; C358; C359; C360; C361; C375; C376; C382; C383; C387; C395; C405; C406; C409; C417; C431; C432
C0402CAP NP_C0402_33PF 50V33pF 50VIC10C15; C16; C17; C18; C236; C237; C255; C256; C279; C294
C0402CAP NP_C0402_0.01UF 50V0.01uF 50VDISCRETE32C24; C26; C62; C75; C77; C78; C153; C244; C247; C248; C249; C250; C257; C258; C259; C260; C318; C319; C320; C321; C322; C323; C324; C325; C328; C329; C330; C331; C332; C333; C334; C335
C0402CAP NP_C0402_1UF 6.3V1uF 6.3VIC13C51; C107; C109; C114; C120; C121; C122; C280; C306; C316; C348; C398; C435
C0402CAP NP_C0402_X_0.1UF 16VX_0.1uF 16VDISCRETE2C59; C167
C0402CAP NP_C0402_1000PF 50V1000pF 50VIC13C61; C64; C65; C66; C76; C340; C345; C414; C419; C438; C439; C440; C441
C0402CAP NP_C0402_4700PF 50V4700pF 50VIC2C63; C216
C0402CAP NP_C0402_47PF 50V47pF 50VIC1C98
C0402CAP NP_C0402_1UF 10V1uF 10VIC1C108
C0402CAP NP_C0402_100PF 50V100pF 50VIC1C190
C0402CAP NP_C0402_0.1UF 25V0.1uF 25VIC11C209; C218; C219; C220; C221; C223; C224; C225; C226; C342; C356
C0402CAP NP_C0402_X_22PF 50VX_22pF 50VDISCRETE1C229
C0402CAP NP_C0402_68PF 50V68pF 50VDISCRETE1C337
C0402CAP NP_C0402_X_0.01UF 50VX_0.01uF 50VDISCRETE1C349
C0402CAP NP_C0402_0.047UF 16V0.047uF 16VIC4C374; C388; C396; C413
C0402CAP NP_C0402_1800PF 50V1800pF 50VIC2C378; C410
C0402CAP NP_C0402_820PF 50V820pF 50VIC1C379
C0402CAP NP_C0402_560PF 50V560pF 50VIC1C385
C0402CAP NP_C0402_1200PF 50V1200pF 50VIC2C386; C394
C0402CAP NP_C0402_56PF 50V56pF 50VIC2C391; C397
C0402CAP NP_C0402_680PF 50V680pF 50VIC1C393
C0402CAP NP_C0402_82PF 50V82pF 50VIC1C407
C0402CAP NP_C0402_0.22UF 10V0.22uF 10VIC2C416; C436
C0402CAP NP_C0402_220PF 50V220pF 50VIC2C420; C423
C0603CAP NP_C0603_2.2UF 10V2.2uF 10VIC5C3; C6; C9; C12; C232
C0603CAP NP_C0603_10UF 6.3V10uF 6.3VDISCRETE28C31; C105; C106; C110; C111; C113; C126; C127; C142; C143; C151; C157; C163; C168; C172; C175; C178; C185; C196; C214; C227; C238; C295; C296; C309; C354; C430; C437
C0603CAP NP_C0603_1UF 25V1uF 25VIC2C341; C346
C0805CAP NP_C0805_22UF 6.3V22uF 6.3VIC9C70; C71; C72; C87; C88; C112; C115; C116; C245
C0805CAP NP_C0805_10UF 16V10uF 16VIC16C145; C146; C148; C149; C364; C365; C372; C373; C381; C384; C389; C390; C408; C411; C412; C422
C0805CAP NP_C0805_4.7UF 16V4.7uF 16VIC3C197; C198; C230
C0805CAP NP_C0805_X_4.7UF 16VX_4.7uF 16VIC2C206; C207
C0805CAP NP_C0805_0.22UF 100V0.22uF 100VIC1C217
C1206CAP NP_C1206_0.1UF 250V0.1uF 250VIC4C201; C202; C212; C215
C1206CAP NP_C1206_22000PF 250V22000pF 250VIC2C203; C205
C1210CAP NP_C1210_68000PF 250V68000pF 250VIC2C199; C200
C1210CAP NP_C1210_47UF 16V47uF 16VDISCRETE3C343; C367; C368
C1812CAP NP_C1812_0.01UF 2KV0.01uF 2KVIC5C251; C326; C336; C362; C363
C2220CAP NP_C2220_1UF 250V1uF 250VIC2C254; C261
CMS06DIODE SCHOTTKY_CMS06_ES1D-13-FES1D-13-FIC2D9; D11
CON4-79TM-WAFERCONN WAFER-4P_CON4-79TM-WAFER_WWAFER 4P 2.00 WHITEIC1CON1
CON4-100TM-WAFERCONN WAFER-4P_CON4-100TM-WAFER_WAFER 4P 2.54 WHITEIC1SATAPWR1
DC-JACK-ACONN DC-JACK5P_DC-JACK-A_DC JACDC JACK 5P 半包IC1J5
DSW5_SMKEY5_DSW5_SM_6.2X6.2MM 5P SMD6.2X6.2mm 5P SMDIC1SW4
HOLE138-315-8STARHOLE 8STAR_HOLE138-315-8STAR_HOHOLE3.5-8.6 星月IC4H1; H2; H3; H4
KEY_2P_ACONN SW-90BTN-4_KEY_2P_A_3.5X6M3.5X6mm 90 SMDIC2J13; SW1
LED2-100R-D3LED COMBO 1X B_LED2-100R-D3_D=3D=3 R/G 单层灯套 2PIC1D13
LED2-100R-D3LED COMBO 1X_LED2-100R-D3_D=3 GD=3 G 单层灯IC1D16
LED4-100R-D3LED COMBO 2X_LED4-100R-D3_D=3 GD=3 G/G 双层灯IC5D17; D18; D19; D20; D21
LQFP128-R4-1414TPDNET RTL8367RB_LQFP_LQFP128-R4-1RTL8367RB-CGIC1U68
MARK-1030MARK POINT_MARK-1030_MARK_10MARK_10IC6ID1; ID2; ID3; ID4; ID5; ID6
MINI-DIN6-DIPCONN MINI-DIN6_MINI-DIN6-DIP_MIMINI-DIN 6PIC1J18
MPCI52-F-RCONN MINI PCIE52-F_MPCI52-F-R_MMINIPCIE H=5.2IC1MPCIE1
MUSB5-32_SMCONN MINI USB 5P_MUSB5-32_SM_MIMINI USB 5P BENTIC1USB2
PH2-100TMJUMPER 2_PH2-100TM_JUMPER 2P 2.JUMPER 2P 2.54mm DIP180IC2JP2; JP4
PH3-100TM-H6JUMPER 3_PH3-100TM-H6_JUMPER 3PJUMPER 3P 2.54mm DIP180IC2JP1; JP3
PH0205-79TM_BCONN JN2X5_PH0205-79TM_B_JN 2X5JN 2X5P 2.00 180IC1J12
PH0208-79TM_BCONN JN2X8_PH0208-79TM_B_JN 2X8JN 2X8P 2.00 180IC1J11
PH0210-79TM_BCONN JN2X10_PH0210-79TM_B_JN 2XJN 2X10P 2.00 180IC1J9
PH0210-100TM_BCONN JN2X10_PH0210-100TM_B_JN 2JN 2X10P 2.54 180IC1J4
PH0220-79TM_BCONN JN2X20_PH0220-79TM_B_JN 2XJN 2X20P 2.00 180IC1J8
PWC4-156TMCONN PWR HEAD4_PWC4-156TM_JS-11JS-1120R-04 PITCH=3.96mmIC1J17
QFN24-R8-0606TPDCIO LE88830_QFN24-R8-0606TPD_LELE88830KQCIC1U10
QFN48-R4-0606TPDNET RTL8211DE_QFN48-R4-0606TPD_RTL8211E-VB-CGIC1U14
R0402RESISTOR_R0402_X_4.75K 1%X_4.75K 1%DISCRETE29R1; R2; R5; R6; R7; R9; R10; R11; R12; R13; R14; R15; R118; R119; R229; R234; R236; R239; R241; R245; R246; R249; R251; R268; R628; R629; R630; R631; R667
R0402RESISTOR_R0402_4.75K 1%4.75K 1%DISCRETE33R3; R4; R8; R47; R50; R107; R108; R126; R127; R130; R218; R226; R230; R231; R232; R238; R240; R243; R244; R247; R248; R250; R363; R384; R385; R386; R387; R388; R398; R399; R400; R401; R673
R0402RESISTOR_R0402_1M 1%1M 1%DISCRETE6R16; R21; R23; R228; R341; R591
R0402RESISTOR_R0402_0 5%0Ω 5%DISCRETE77R19; R20; R22; R35; R36; R41; R42; R109; R113; R114; R115; R120; R121; R122; R123; R124; R125; R147; R148; R150; R151; R158; R237; R259; R262; R263; R300; R362; R364; R366; R367; R368; R372; R376; R377; R378; R379; R390; R396; R437; R438; R444; R445; R451; R452; R460; R493; R499; R574; R577; R578; R579; R586; R587; R589; R607; R608; R609; R610; R611; R612; R613; R614; R615; R616; R617; R618; R619; R620; R621; R622; R623; R625; R626; R627; R668; R669
R0402RESISTOR_R0402_22.1 1%22.1Ω 1%DISCRETE41R24; R29; R69; R70; R71; R72; R73; R74; R75; R76; R77; R78; R79; R80; R82; R83; R84; R85; R86; R88; R89; R90; R135; R219; R220; R221; R222; R223; R256; R257; R297; R298; R299; R301; R302; R303; R304; R395; R498; R688; R689
R0402RESISTOR_R0402_X_249 1%X_249Ω 1%DISCRETE3R25; R26; R27
R0402RESISTOR_R0402_249 1%249Ω 1%DISCRETE1R28
R0402RESISTOR_R0402_X_2.21K 1%X_2.21K 1%DISCRETE1R30
R0402RESISTOR_R0402_2.21K 1%2.21K 1%DISCRETE4R31; R32; R33; R34
R0402RESISTOR_R0402_1K 1%1K 1%DISCRETE22R39; R40; R43; R44; R48; R49; R55; R56; R129; R162; R163; R204; R209; R212; R272; R273; R373; R431; R447; R454; R494; R576
R0402RESISTOR_R0402_243 1%243Ω 1%DISCRETE2R45; R54
R0402RESISTOR_R0402_121 1%121Ω 1%DISCRETE1R46
R0402RESISTOR_R0402_X_0 5%X_0Ω 5%DISCRETE12R52; R110; R260; R261; R305; R318; R588; R592; R593; R606; R684; R685
R0402RESISTOR_R0402_10K 1%10K 1%DISCRETE48R60; R61; R62; R65; R66; R155; R156; R157; R171; R175; R196; R197; R200; R201; R202; R210; R211; R213; R214; R270; R271; R365; R404; R436; R448; R449; R450; R455; R458; R459; R489; R492; R497; R500; R546; R583; R584; R590; R595; R605; R624; R634; R636; R641; R642; R644; R648; R653
R0402RESISTOR_R0402_100 1%100Ω 1%IC2R143; R146
R0402RESISTOR_R0402_3.01K 1%3.01K 1%IC2R144; R154
R0402RESISTOR_R0402_330 5%330Ω 5%IC3R159; R160; R161
R0402RESISTOR_R0402_44.2 1%44.2Ω 1%IC1R165
R0402RESISTOR_R0402_100K 1%100K 1%IC14R173; R339; R369; R370; R371; R374; R375; R406; R439; R446; R453; R488; R501; R692
R0402RESISTOR_R0402_75K 1%75K 1%IC1R187
R0402RESISTOR_R0402_47.5K 1%47.5K 1%IC1R191
R0402RESISTOR_R0402_X_10K 1%X_10K 1%DISCRETE2R195; R403
R0402RESISTOR_R0402_X_47.5K 1%X_47.5K 1%IC1R198
R0402RESISTOR_R0402_10 1%10Ω 1%IC1R203
R0402RESISTOR_R0402_2K 1%2K 1%IC1R205
R0402RESISTOR_R0402_1.50K 1%1.50K 1%IC1R216
R0402RESISTOR_R0402_2.49K 1%2.49K 1%IC2R224; R338
R0402RESISTOR_R0402_75 1%75Ω 1%IC20R252; R253; R254; R255; R342; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357
R0402RESISTOR_R0402_X_2.49K 1%X_2.49K 1%IC1R266
R0402RESISTOR_R0402_562 1%562Ω 1%IC1R277
R0402RESISTOR_R0402_511 1%511Ω 1%IC12R361; R516; R518; R519; R526; R527; R533; R535; R536; R537; R539; R540
R0402RESISTOR_R0402_22.1K 1%22.1K 1%IC3R433; R443; R491
R0402RESISTOR_R0402_20K 1%20K 1%IC1R440
R0402RESISTOR_R0402_825 1%825Ω 1%IC1R441
R0402RESISTOR_R0402_80.6K 1%80.6K 1%IC1R456
R0402RESISTOR_R0402_42.2K 1%42.2K 1%IC1R490
R0402RESISTOR_R0402_768 1%768Ω 1%IC1R547
R0402RESISTOR_R0402_3.65K 1%3.65K 1%IC1R548
R0402RESISTOR_R0402_18.2K 1%18.2K 1%IC1R549
R0402RESISTOR_R0402_475 1%475Ω 1%IC1R585
R0402RESISTOR_R0402_33.2 1%33.2Ω 1%DISCRETE4R596; R597; R598; R599
R0402RESISTOR_R0402_49.9 1%49.9Ω 1%IC4R600; R601; R603; R604
R0402RESISTOR_R0402_150 1%150Ω 1%IC1R602
R0603MAG FERRITE BEAD_R0603_80 3A80Ω 3A DCR40m�IC24FB4; FB6; FB7; FB8; FB9; FB11; FB14; FB15; FB16; FB18; FB19; FB22; FB23; FB24; FB26; FB27; FB28; FB29; FB31; FB32; FB33; FB36; FB37; FB38
R0603MAG FERRITE BEAD_R0603_600 1A600Ω 1A DCR200m�IC1FB35
R0603RESISTOR_R0603_0 5%0Ω 5%IC12R141; R142; R170; R172; R177; R215; R217; R225; R227; R233; R242; R267
R0603RESISTOR_R0603_X_0 5%X_0Ω 5%IC3R184; R235; R269
R0603RESISTOR_R0603_4.75K 1%4.75K 1%IC1R190
R0603RESISTOR_R0603_14.3K 1%14.3K 1%IC1R442
R0805RESISTOR_R0805_200K 1%200K 1%IC4R180; R181; R182; R183
R0805RESISTOR_R0805_X_402K 1%X_402K 1%IC2R185; R186
R0805RESISTOR_R0805_3.01K 1%3.01K 1%IC2R188; R189
R0805RESISTOR_R0805_X_150K 1%X_150K 1%IC1R194
R0805RESISTOR_R0805_402K 1%402K 1%IC2R207; R208
R1206MAG COIL_R1206_1UH 0.1A DCR400M1uH 0.1A DCR400m�IC4L1; L2; L3; L4
R1206RESISTOR_R1206_0 5%0Ω 5%IC2R192; R193
R1206RESISTOR_R1206_20 1%20Ω 1%IC1R199
R1206RESISTOR_R1206_50M 1%50mΩ 1%IC1R206
RESET-90KEY4_RESET-90_6X6MM 906X6mm 90IC2SW2; SW3
RJ11-6CONN RJ11-6P6C_RJ11-6_DY9759-10DY9759-1001IC1J6
RJ45-8S-S-JACKRJ45-8P NLED_RJ45-8S-S-JACK_RJ4RJ45 SINGLEIC1LAN1
RJ45-8SL-4S-JACKRJ45X4 NLED_RJ45-8SL-4S-JACK_RJRJ45X4IC1J2
SATA7-TFCONN SATA 7P_SATA7-TF_SATA 7PSATA 7PIC1SATA1
SC70-5PWR TPS380X_SC70-5_TPS3801I50DCTPS3801I50DCKIC1U30
SC70-5PWR TPS380X_SC70-5_TPS3801K33DCTPS3801K33DCKIC1U34
SD0603DIODE LED_SD0603_LED RLED RIC3D1; D2; D3
SHOUT2525SHOUT_SHOUT2525_SHOUT2525SHOUT2525IC7S3; S4; S5; S6; S7; S8; S9
SLN4-3216MAG COMMONCHOKE_SLN4-3216_X_90X_90Ω0.37AIC1L8
SOD323DIODE SCHOTTKY_SOD323_RB751V40TRB751V40T1GIC6D10; D12; D24; D25; D26; D27
SOP8-50-150TISP61089A_SOP8-50-150_TISP6108TISP61089BDIC1U11
SOP8-50-150CLK ICS830401_SOP8-50-150_X_ICSX_ICS8304AM-01IC1U60
SOP8-50-150PWR TPS2052BD_SOP8-50-150_TPS20TPS2052BDIC1U65
SOP8-50-156TPDPWR RT9199PSP_SOP8-50-156TPD_RTRT9199PSPIC1U52
SOP8-50-156TPDPWR RT9018_SOP8-50-156TPD_RT901RT9018B-PSPIC1U71
SOP16-50-300FLASH S25FL128P_SOP16-50-300_S2S25FL128PIC1U37
SOT23-3DIODE BAT54 SOT-23_SOT23-3_BAS2BAS20LT1GIC1D28
SOT23-3NMOSFET SOT-23_SOT23-3_2N7002ET2N7002ET1GIC1Q28
SOT23-3TRANSISTOR NPN SOT-23_SOT23-3_MMMBT3904LT1GIC1Q29
SOT23-5PWR RT9013 SOT23-5_SOT23-5_RT90RT9013-33VPBIC1U66
SOT223-4NMOSFET SOT-223_SOT223-4_FQT7N1FQT7N10LIC1Q39
SOT363-6MBT3946_SOT363-6_MBT3946 PNP+NPMBT3946 PNP+NPNIC1Q1
SOT753-5LOGIC 74AHC1G08_SOT753-5_74AHC174AHC1G08GVIC4U21; U33; U36; U69
SPL0707-H4MAG COIL_SPL0707-H4_4.7UH 5.5A4.7uH 5.5A DCR37m�IC3L10; L16; L19
SPL0707-H4MAG COIL_SPL0707-H4_2.2UH 8A DC2.2uH 8A DCR20m�IC2L17; L18
SPL-3R5X3MAG COIL_SPL-3R5X3_4.7UH 10% 1.4.7uH 10% 1.22A DCR158m�IC1L11
SSOP16-26-173CIO MAX3221_SSOP16-26-173_MAX32MAX3221CDBIC2U12; U13
STC7343-H1R8CAP EL_STC7343-H1R8_220UF 6.3V220uF 6.3VIC4CE4; CE5; CE6; CE11
STC7343-H1R8CAP EL_STC7343-H1R8_220UF 10V220uF 10VIC1CT2
STFM24-50-480-HC5007TRANS H5007_STFM24-50-480-HC500H5007NLIC1U15
STFM50-40-300-H5020TRANS H5020_STFM50-40-300-H5020H5020NLIC2U19; U20
SX4-3208CRYSTAL-32_SX4-3208_32.768KHZ32.768KHzIC1Y1
SX4-5032OSC-4_SX4-5032_16.384MHZ16.384MHzIC1OSC1
SX4-5032OSC-4_SX4-5032_24.000MHZ24.000MHzIC1OSC2
SX4-5032CRYSTAL 4PIN SMD5032_SX4-5032_124.000MHzIC2Y2; Y3
SX4-5032CRYSTAL 4PIN SMD5032_SX4-5032_225.000MHzIC3Y6; Y8; Y11
TP-D20TESTPOINT_TP-D20_TP D20TP D20IC17TP10; TP11; TP12; TP13; TP14; TP15; TP19; TP20; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41
TP-D50TESTPOINT_TP-D50_TP D50TP D50IC12TP17; TP18; TP21; TP22; TP23; TP24; TP25; TP26; TP29; TP30; TP31; TP32
TQFP64-R5-1010CIO LE88506_TQFP64-R5-1010_LE88LE88506DVCIC1U9
TSOP48-20-700NAND FLASH_TSOP48-20-700_K9F4G0K9F4G08U0B-IIC1U67
TSSOP16-26-173CLK CY24293_TSSOP16-26-173_CY24CY24293ZXCIC1U38
TSSOP20-26-173TPPWR TPS54310PWP_TSSOP20-26-173TTPS54310PWPIC4U56; U57; U58; U62
附件:8 v- _5 l1 L6 I1 c8 u( z
原理图和PCB文件如下:' f7 ^! J. o9 i# o" y% G* ~/ r; }
游客,如果您要查看本帖隐藏内容请回复
) Q' g) V1 l, v1 T9 q4 v& e- S6 @% R: `4 \
    郁闷
    2019-11-20 15:02
    发表于 2022-7-22 17:21 | 只看该作者
    学习一下把这个
    GMT+8, 2025-10-13 06:54 , Processed in 0.171875 second(s), 27 queries , Gzip On.
