查看: 561|回复: 1
matlab中的conv2卷积运算的三种形式
发表于 2020-1-14 10:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
! G1 F# P, m7 m  y
( E, j. c: G! B' r# S: X. Y2 Hmatlab中的conv2是用于对二维数据进行卷积运算,有三个参数可供选择,下面是help content of conv2. q9 ~8 g) s/ C0 r5 x7 D/ O
1 w+ V7 b2 R, o5 b. b5 G# V
conv2 Two dimensional convolution.* @7 T) V$ `5 S& t2 e
. J+ G& F. C+ ]$ d1 O0 C: D    C = conv2(A, B) peRForms the 2-D convolution of matrices A and B.
" u) b1 v/ ]& M! n    If [ma,na] = size(A), [mb,nb] = size(B), and [mc,nc] = size(C), then4 x; g$ @. K) D% a/ S
    mc = max([ma+mb-1,ma,mb]) and nc = max([na+nb-1,na,nb]).
# V8 B) }( F1 _8 P6 p/ C6 x 6 Q, O' ]/ r5 d6 x9 }
    C = conv2(H1, H2, A) first convolves each column of A with the vector
' _7 C7 ^& W0 B7 w! F9 V7 p  A    H1 and then convolves each row of the result with the vector H2.  If- {* n+ T' R% Y! }' W9 V
    n1 = length(H1), n2 = length(H2), and [mc,nc] = size(C) then
1 p( e% e% {0 K9 n" P) _    mc = max([ma+n1-1,ma,n1]) and nc = max([na+n2-1,na,n2]).
9 {7 @2 d/ t# V: ]$ a8 P    conv2(H1, H2, A) is equivalent to conv2(H1(:)*H2(:).', A) up to4 }- D5 X; ?0 k+ m
    round-off.
8 t* v( p8 N/ d
6 X! N$ _) B9 f! w  [$ k9 n    C = conv2(..., SHAPE) returns a subsection of the 2-D
  b5 U0 Q4 v$ e! ]/ z8 I6 W! f    convolution with size specified by SHAPE:
8 l) f2 ~$ e8 ?5 V6 n1 R. N      'full'  - (default) returns the full 2-D convolution,- Q6 L0 L8 p0 v/ b
      'same'  - returns the central part of the convolution
9 _/ `4 X  _0 F% x" K* r# U% T! G                that is the same size as A.
  y7 V* d0 D2 O; B: w, P, r      'valid' - returns only those parts of the convolution; b1 W4 v) k: K- E/ F3 ]
                that are computed without the zero-padded edges.
* T5 G- W9 H' Q% s                size(C) = max([ma-max(0,mb-1),na-max(0,nb-1)],0).
& [0 H, F! H5 R2 J8 X8 o/ x2 I- }  F7 m
7 P/ S8 V) {9 h6 B- I1 c关于full, same以及valid三种参数的区别,如下面的实例所示:* d' S  [1 c8 _4 e0 p2 O" I, o
, B8 D( ^0 D2 c
full
; R9 Q& ]# j: u; S; t1 m- M$ r' m5 f, |( t4 W, Z# p; ?  k
1 @" v9 p" S) _6 a4 Z$ l
( P3 `( k" ]% _5 P5 E
5 ^2 {4 \1 M6 A: D. H7 U2 msame
% _  I5 K0 d( y* N4 R0 s; m7 N8 |  N0 _8 d) r/ t/ K
7 H: E2 Y. j" Q7 G* b% S2 B8 v1 q
/ s$ k  u. Q& y/ m7 X$ v' Q, ~- v, ~: ~
valid; _9 D7 n8 f) _( c  F
$ K/ r% b9 n3 _" y% X8 j+ I  I' x  E+ J% W; I
7 W4 {: ^# ]9 J6 R8 m- Q: @, H
0 G) }* M# k  z/ m
    2019-11-29 15:37
    发表于 2020-1-14 19:49 | 只看该作者
    三种形式的matlab中的conv2卷积运算
    GMT+8, 2025-10-5 21:19 , Processed in 0.156250 second(s), 26 queries , Gzip On.
