TA的每日心情 | 开心 2020-7-28 15:35 |
签到天数: 2 天 [LV.1]初来乍到
#include<intrins.h>
# e. [& Q7 [6 d2 w; W. i* R#include "reg51.h" //此文件中定义了单片机的一些特殊功能寄存器1 `2 p5 q2 }) R6 \
#include "oled.h"
" r5 u6 z; t8 Q' q" S# n6 l% t9 B% Y
sbit SO=P1^1;
% g/ R& a H- g0 v0 L% N* Jsbit SCK=P1^3;
5 `: g/ ^, u- B K. ksbit CS=P1^2; F3 S% X* h0 g# z5 O8 w
sbit key = P3^3;. U# A; `9 k j7 i K) }) y- _
9 H& r7 H0 B! j3 h% `. r% Xunsigned int MAX6675_Temp;
* F4 n( m' g# @5 d8 |
0 `4 ]9 D3 ~+ r9 {0 i2 R8 Tvoid delay(unsigned int i)3 p5 b6 a2 U+ I. q" g
" l7 W* E( X' R, {. a while(i--);
( l+ ?8 u9 }6 f}
' A" `2 _3 ?5 b% `8 b- v" g$ i( e" t/ u: V
8 ~+ m2 V! M8 ]% S
unsigned int Re_Convert() //热电偶数据读取,返回温度1 a2 \: p% K+ m4 ~" y: m1 Y
6 ~ D9 A" f) F" A% v5 | long int a=0x7ff8;, o7 q! y' A9 N$ w' V0 n: P
long int wendu=0,wendu_1;
' r5 y/ B- B8 d- k& | float wendu_2;
% e9 { Y* d# F1 C$ B3 Z4 ] unsigned int i;
3 ^6 _8 u! v. n0 B3 H# C5 o CS=1;9 Z" y+ o+ J" t% d2 _
SCK=0;
9 a7 P. U6 D/ F8 E( g+ _$ F# a3 j delay(200);6 [5 I% z( v7 W5 p; N
_nop_();. C6 |6 V1 V3 R. e: ]
_nop_();& k/ ?/ y' ?1 }) n) w
CS=0;) }) D) T# a9 F6 f6 O( L0 G
for(i=1;i<=16;i++)6 u: y# \4 r$ _
{ wendu=wendu<<1;9 j, {" u8 e( v+ G3 S& m* `9 H. @& [
_nop_();
# F& j0 `; ~# j1 F- G! O6 k SCK=1;; ]" V, v; _* C+ \. T! H
if(SO==1){wendu=wendu|0x01;} ! ~( i& S. z9 w7 j/ ]
else wendu=wendu|0x00;( Y/ H. C! y! c6 G
_nop_();9 E/ T+ ]' z/ G% Z" _, R
_nop_();5 R2 ^# ~9 @# l
SCK=0;
I, M1 |: \$ F' ]- q _nop_();
0 j( R( L7 o8 z8 I. ]1 _6 G4 ~ _nop_();: x! `3 o! Z+ o2 g/ r
}9 M! t- T% e, L4 y$ l7 e
wendu_1=wendu&a;; Y w% h- Y, I0 }; \+ }0 l
wendu_1=wendu_1>>3;
; E G3 M& N' ~4 f wendu_2=wendu_1*0.25;
- e1 [# E2 e8 |9 z! l% \* w0 h; x/ d7 C } v2 X, H+ t1 P& e
return wendu_2; //返回带两位小数的实际温度' `6 \6 i: w# o
# K: N, d$ V% F8 p
+ D( E+ w- A% D3 L2 F4 m8 ^/ _5 A4 P( Z4 R# Y$ E
void main()
5 C/ e5 Q" K# I8 J6 ?3 ?/ C{
, r$ A% A* i: U8 D
, W4 v" S# f) {$ s/ [( f3 W% D OLED_Init(); //初始化OLED * q4 z0 a6 m, F s
OLED_Clear();
, A7 D, H7 \0 l3 y5 V6 X! n: h4 k! M7 |5 q
while(1)
$ |9 t s( b3 F) u {
# {0 _- t$ p3 `( R6 b0 I; T if(key==0)7 Q" t v0 x5 o1 u1 U
{# H; l+ G1 F8 B- w+ K3 f
delay(1000);
) l* h* x7 a! @( j2 R* g if(key==0)' `. D- S' u( H& O/ L5 u
{1 B. ^* s. o5 a, }( o+ o9 E
while(key==0);
, }2 m' A* {0 `( `8 T" D7 s MAX6675_Temp=Re_Convert();
3 H+ m5 V+ S8 |* ?" i3 }6 o }
, m& @, K3 n: P- }: g }+ o# l. V! c% C( o9 m; y
8 T& p- r1 ]) M" w; s1 O9 R
OLED_ShowNum(103,6,MAX6675_Temp,3,16);
9 U& r7 {# }& `1 d' u, m
4 T) K$ P1 A2 f3 e o }
# W7 w! I! J& R}
5 c' v9 K( G" U% t) U* Z1 E! {& e, M" M( x
