查看: 399|回复: 1
verilog简单实现除法器功能(续)
发表于 2020-1-3 10:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
引言
& ?: X4 [( K0 ~; r/ s9 Y, `. {' k" q
1,改成clk方式。( ]6 m5 V: |  A$ R) K) h
2,添加clk,50MHz。9 [3 H% A5 r6 J2 n
3, 添加rst,同步复位。9 y; n2 }' j* q) y0 _8 E8 Y# e
4,添加calc_done,指示计算完成,高有效。
- l% Q7 ~$ r6 `/ C5 f+ h
, r  B9 F0 J9 h- Y3.1 模块代码
7 B) s# Q3 V2 W# z/ \7 V/ L+ V" X* O; w' G0 j
  • * module:div_rill
  • * file name:div_rill.v
  • * syn:yes
  • * author:network
  • * modify:rill
  • * date:2012-09-10
  • module div_rill
  • input clk,
  • input rst,
  • input[31:0] a,
  • input[31:0] b,
  • output reg [31:0] yshang,
  • output reg [31:0] yyushu,
  • output reg calc_done
  • reg[31:0] tempa;
  • reg[31:0] tempb;
  • reg[63:0] temp_a;
  • reg[63:0] temp_b;
  • reg [5:0] counter;
  • always @(a or b)
  • begin
  •     tempa <= a;
  •     tempb <= b;
  • end
  • always @(posedge clk)
  • begin
  •         if(!rst)
  •                 begin
  •                         temp_a <= 64'h0000_0000_0000_0000;
  •                         temp_b <= 64'h0000_0000_0000_0000;
  •                         calc_done <= 1'b0;
  •                 end
  •         else
  •                 begin
  •                         if(counter <= 31)
  •                                 begin
  •                                         temp_a <= {temp_a[62:0],1'b0};
  •                                         if(temp_a[63:32] >= tempb)
  •                                                 begin
  •                                                         temp_a <= temp_a - temp_b + 1'b1;
  •                                                 end
  •                                         else
  •                                                 begin
  •                                                         temp_a <= temp_a;
  •                                                 end
  •                                         counter <= counter + 1;
  •                                 end
  •                         else
  •                                 begin
  •                                         counter <= 0;
  •                                         calc_done <= 1'b1;
  •                                         temp_a <= {32'h00000000,tempa};
  •                                         temp_b <= {tempb,32'h00000000};
  •                                         yshang <= temp_a[31:0];
  •                                         yyushu <= temp_a[63:32];
  •                                 end
  •                 end
  • end
  • endmodule
  • /*************** EOF ******************/
    " D( S5 {" s, S5 w$ \; \/ D9 q) C1 i
           + A! q0 A7 r6 M; @9 ~/ @8 f
( e3 q- o$ c. Z$ H& i
3.2 testbench
& M* Q8 n: A0 F0 o
  • * module:div_rill_tb
  • * file name:div_rill_tb.v
  • * syn:no
  • * author:rill
  • * date:2012-09-10
  • `timescale 1ns/1ns
  • module div_rill_tb;
  • reg clk;
  • reg rst;
  • reg [31:0] a;
  • reg [31:0] b;
  • wire [31:0] yshang;
  • wire [31:0] yyushu;
  • wire calc_done;
  • initial
  • begin
  •         clk = 0;
  •         rst = 0;
  •         #20 rst = 1;
  •         #40 a = $random()%10000;
  •                 b = $random()%1000;
  •         #1000 a = $random()%1000;
  •                 b = $random()%100;
  •         #1000 a = $random()%100;
  •                 b = $random()%10;
  •         #1000 $stop;
  • end
  • always #10 clk = ~clk;
  • div_rill DIV_RILL
  • .clk (clk),
  • .rst (rst),
  • .a (a),
  • .b (b),
  • .yshang (yshang),
  • .yyushu (yyushu),
  • .calc_done (calc_done)
  • endmodule
  • /******** EOF ******************/
    . f0 |  q9 X; x1 X: v
          5 o- y5 J! j. N+ [  i# k
  j1 H- o4 m3 p$ P) ?; y" H
3.3 仿真
4 \$ K9 Q% w5 ^. Z6 X, t, d9 x/ j2 [5 c
  Z- W! y3 Q$ K- A" Z" y1 [' ^$ Y8 _# T9 W
/ m' R3 b3 a8 d" H* c
6 ?9 T: h3 v) r7 l! I6 u
发表于 2020-1-3 18:02 | 只看该作者
这是续篇啊
GMT+8, 2025-8-24 22:02 , Processed in 0.125000 second(s), 26 queries , Gzip On.
