查看: 675|回复: 6
[allegro16.6][8层]英伟达 T30SL 平板电脑(u_pmu_max77663+u_cpu_ap30_lc+BGA_42_...
发表于 2019-12-31 13:53 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][8层]英伟达 T30SL 平板电脑(u_pmu_max77663+u_cpu_ap30_lc+BGA_42_16_112X119)pcb文件
文件描述:
1. 作品用途:英伟达 T30SL 平板电脑
2. 软件版本:allegro16.6
3. 层数:8层
4. 用到的主要芯片:u_pmu_max77663+u_cpu_ap30_lc+BGA_42_16_112X119
5. PCB尺寸:异形
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
402402DISCRETE566C1; C5; C20; C23; C26; C37; C40; C42; C44; C45; C50; C51; C52; C55; C56; C57; C60; C66; C76; C77; C81; C82; C86; C87; C91; C92; C102; C122; C130; C133; C139; C145; C149; C154; C502; C503; C504; C505; C506; C508; C509; C511; C512; C513; C514; C515; C517; C518; C521; C523; C524; C529; C530; C531; C532; C534; C536; C537; C539; C540; C541; C542; C551; C552; C556; C557; C559; C564; C568; C569; C571; C573; C574; C577; C578; C579; C584; C585; C586; C587; C588; C589; C590; C593; C594; C595; C596; C598; C606; C608; C609; C613; C614; C616; C631; C635; C637; C638; C646; C648; C649; C661; C662; C1015; C1016; C1201; C1501; C1503; C1505; C1506; C1507; C1508; C1509; C1510; C1511; C1512; C1513; C1514; C1515; C1517; C1585; C1586; C1602; C1703; C1704; C1707; C1708; C1709; C1710; C1711; C1712; C1713; C1714; C1715; C1716; C1801; C1803; C1804; C1805; C1806; C1807; C1809; C1816; C1822; C1823; C1824; C1825; C1826; C1827; C1890; C1903; C1904; C2002; C2003; C2004; C2005; C2006; C2009; C2010; C2011; C2013; C2015; C2017; C2103; C2105; C2106; C2107; C2108; C2109; C2201; C2203; C2205; C2206; C2207; C2301; C2302; C2303; C2304; C2306; C2308; C2310; C2404; C2405; C2407; C2408; C2501; C2502; C2503; C2606; C2610; C2612; C2613; C2614; C2615; C3110; C3111; C3501; C3503; E301; E302; E303; E305; E1101; E1102; E1103; E1104; E1105; E1106; E1107; E1108; E1603; E1604; E1605; E1606; E1607; E1608; E1609; E1901; E1902; E1903; E1904; FB1803; FB1804; FB1805; FB1806; FB2002; FB2101; L2102; LB624; LB626; R6; R16; R23; R24; R48; R50; R54; R58; R63; R67; R68; R72; R73; R76; R77; R78; R79; R80; R81; R501; R502; R503; R504; R505; R506; R507; R508; R511; R514; R517; R518; R519; R520; R521; R522; R523; R524; R525; R526; R528; R529; R531; R532; R534; R535; R536; R537; R540; R541; R542; R543; R544; R545; R546; R547; R548; R549; R550; R551; R552; R553; R554; R555; R556; R557; R558; R559; R560; R561; R562; R563; R564; R565; R566; R567; R568; R569; R570; R571; R572; R573; R578; R584; R585; R586; R587; R589; R590; R595; R596; R597; R599; R601; R603; R610; R611; R613; R618; R619; R622; R623; R625; R630; R631; R635; R639; R640; R641; R642; R643; R644; R645; R646; R647; R648; R652; R653; R818; R819; R901; R902; R903; R904; R905; R906; R907; R908; R909; R910; R911; R912; R913; R1203; R1515; R1516; R1519; R1521; R1522; R1525; R1526; R1527; R1528; R1529; R1530; R1531; R1532; R1533; R1534; R1535; R1536; R1537; R1538; R1539; R1540; R1541; R1542; R1543; R1544; R1545; R1546; R1547; R1548; R1549; R1550; R1551; R1552; R1553; R1554; R1555; R1556; R1557; R1558; R1559; R1560; R1561; R1562; R1563; R1564; R1565; R1566; R1567; R1568; R1569; R1570; R1571; R1572; R1573; R1574; R1575; R1576; R1577; R1578; R1579; R1580; R1587; R1588; R1589; R1701; R1702; R1703; R1704; R1705; R1706; R1707; R1708; R1709; R1710; R1711; R1712; R1713; R1801; R1802; R1803; R1804; R1805; R1806; R1807; R1808; R1809; R1810; R1811; R1812; R1813; R1814; R1815; R1817; R1818; R1819; R1820; R1821; R1822; R1823; R1824; R2001; R2002; R2003; R2006; R2007; R2008; R2009; R2101; R2102; R2103; R2104; R2105; R2106; R2107; R2108; R2109; R2110; R2111; R2112; R2113; R2114; R2115; R2116; R2117; R2118; R2119; R2120; R2121; R2122; R2123; R2124; R2125; R2126; R2127; R2128; R2129; R2130; R2131; R2132; R2133; R2134; R2135; R2202; R2203; R2204; R2205; R2206; R2301; R2302; R2303; R2304; R2305; R2306; R2404; R2405; R2406; R2502; R2503; R2504; R2505; R2506; R2507; R2602; R2603; R2604; R2605; R2606; R2607; R2608; R2609; R2610; R2611; R2612; R2613; R2614; R2615; R2616; R2617; R2618; R2619; R2620; R2621; R2622; R2623; R2624; R2625; R2626; R2627; R2628; R3119; R3120; R3121; R3122; R3123; R3124; R3125; R3126; R3401; R3402; R3403; R3405; R3501; R3502
603603DISCRETE86C28; C36; C47; C69; C70; C78; C93; C94; C100; C146; C147; C507; C526; C528; C533; C535; C538; C543; C544; C545; C546; C547; C549; C550; C553; C558; C560; C561; C562; C565; C566; C567; C572; C575; C576; C581; C582; C583; C600; C603; C605; C1701; C1702; C1705; C1706; C1814; C1815; C2001; C2007; C2008; C2014; C2016; C2020; C2021; C2101; C2102; C2104; C2110; C2111; C2202; C2204; C2305; C2307; C2309; C2311; C2406; C2601; C2602; C2603; C2604; C2605; C2607; C2608; C2609; C2611; C3109; C3112; C3113; C3502; C3504; FB1801; FB1802; R2010; R2011; R2501; R2601
805805DISCRETE24C21; C22; C43; C53; C67; C116; C117; C119; C131; C141; C148; C621; C1516; C1601; C1808; C1810; C1811; C1812; C1813; C1817; C1818; C1819; C1820; C1821
120612064.7ufDISCRETE1R612
1212H151212H152.2uh_1.48aDISCRETE1L2101
1616H181616H18mdmk4040t 2r2mDISCRETE1L3106
2016MM2016MMDISCRETE1LB504
ANT3-3X3-H1_35ANT3-3X3-H1_35DISCRETE1J2101
BGA28-1_6X2_8-P0_4-H0_625BGA28-1_6X2_8-P0_4-H0_625IC1U505
BGA72-4_5X4_5-P0_4-H1BGA72-4_5X4_5-P0_4-H1IC1U1571
BGA_9_16_46X48BGA_9_16_46X48tpa2038d1IC2U1802; U1803
BGA_15_20_69X106BGA_15_20_69X106bq27425yzfr-g2aIC1U2603
BGA_42_16_112X119BGA_42_16_112X119IC1U2002
BGA_0090_P065_068X062BGA_0090_P065_068X062u_pmu_max77663IC1U8
BGA_0096_P080_133X100BGA_0096_P080_133X100IC2M1; M2
BGA_0169_P050_120X160_E1595BGA_0169_P050_120X160_E1595u_mem_fl_inand_lcIC1U503
BGA_0681_P050_140X140BGA_0681_P050_140X140u_cpu_ap30_lcIC1U9
BTB24-7_5X2_3-H0_77BTB24-7_5X2_3-H0_77IC1J2301
BTB_24_16_291X113BTB_24_16_291X113con_b2b_24IO1J2201
CON4SSS-7_2X5_3-P0_5-H2CON4SSS-7_2X5_3-P0_5-H2DISCRETE1CON2401
CON6SSS-7_1X4_5-P0_5-H1_5-FCON6SSS-7_1X4_5-P0_5-H1_5-Fcon_fpc_1x6IO1J2
CON7SSS-13_9X5_5-P1_25-H2_1CON7SSS-13_9X5_5-P1_25-H2_1IO1J2601
CON12SSS-9_1X5_6-P0_5-H2CON12SSS-9_1X5_6-P0_5-H2IO1J1610
CON27SDS-9_6X3_2-P0_6-H0_95CON27SDS-9_6X3_2-P0_6-H0_95DISCRETE1CON1701
CON39SDS-13_5X3_4-P0_6-H0_95CON39SDS-13_5X3_4-P0_6-H0_95IC1CON1514
DFN06_P050_015X010_BDFN06_P050_015X010_BDISCRETE1U2001
DFN08_P050_020X020_BDFN08_P050_020X020_Bnm/u_temp_sensorIC1U508
H-C2D2H-C2D2DISCRETE1NUT1610
H-C2_3D2_3H-C2_3D2_3DISCRETE1NUT1609
HDMI-QJ111R1-N120H1-7H-H2_6HDMI-QJ111R1-N120H1-7H-H2_6IO1J901
HDR2SSS-7_65X5_5-P1_25-H1_96HDR2SSS-7_65X5_5-P1_25-H1_96IO1J1802
IND_NONRKO_SMD_012X010_CIND_NONRKO_SMD_012X010_Ccmm11t-900m-nDISCRETE4L901; L902; L903; L904
IND_NONRKO_SMD_040X040IND_NONRKO_SMD_040X0401.0uhDISCRETE3L5; L6; L15
IND_SMD_0402IND_SMD_0402DISCRETE9L2001; L2002; LB501; LB502; LB503; LB507; LB522; LB1903; LB1904
IND_SMD_0603IND_SMD_0603DISCRETE3FB2001; LB1501; LB1611
L0805L0805DISCRETE2L1515; L1516
L-1_6X0_8-P1_75-H0_8L-1_6X0_8-P1_75-H0_8DISCRETE2L1701; L1702
L-7_4X6_7-P6-H2L-7_4X6_7-P6-H2DISCRETE1L2601
L-P3_75-4_5X4_1-H1_2L-P3_75-4_5X4_1-H1_21.0uhDISCRETE3L16; L17; L18
LED2X2_SMD_016X008LED2X2_SMD_016X008DISCRETE1DS1
LGA14-2-2X2_2-P0_4-H1LGA14-2-2X2_2-P0_4-H1IC1U2501
LGA_56_20_394X260LGA_56_20_394X260IC1U2101
LTPT28C49PLTPT28C49PlabtestpointIO3TP512; TP535; TP539
LTPT35C49PLTPT35C49PlabtestpointIO95TP1; TP2; TP4; TP5; TP6; TP7; TP8; TP10; TP11; TP12; TP13; TP14; TP15; TP16; TP17; TP18; TP19; TP20; TP21; TP26; TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP501; TP502; TP503; TP504; TP505; TP506; TP507; TP508; TP509; TP510; TP511; TP513; TP514; TP515; TP516; TP518; TP519; TP520; TP522; TP523; TP525; TP526; TP527; TP528; TP529; TP530; TP532; TP533; TP534; TP536; TP537; TP540; TP541; TP547; TP548; TP550; TP551; TP552; TP555; TP561; TP566; TP567; TP581; TP614; TP615; TP901; TP1701; TP1704; TP1801; TP1802; TP1807; TP1808; TP1809; TP1810; TP1811; TP1812; TP1813; TP1814; TP1815; TP2101; TP2601; TP2602; TP2607; TP2608; TP2637; TP2639; TP2640; TP2701
MARKMARKDISCRETE6NUT1607; NUT1608; NUT1611; NUT1612; NUT1613; NUT1614
MIC2-BOM6022GL-G423-C1033-H1_3MIC2-BOM6022GL-G423-C1033-H1_3DISCRETE1MIC1
MTH-C4D2MTH-C4D2DISCRETE3NUT1603; NUT1604; NUT1605
MTH-C4D2_3MTH-C4D2_3DISCRETE1NUT1606
M_SD8-WQ2182C-DES1-7F-H1_95M_SD8-WQ2182C-DES1-7F-H1_95IO1J1101
PAD3_33X1_65PAD3_33X1_65DISCRETE4MEC1701; MEC1702; MEC2002; MEC2003
PH5-JAT361-06AAA5B-8HPH5-JAT361-06AAA5B-8HDISCRETE1J1901
QFN16-3X3-P0_5-H0_8QFN16-3X3-P0_5-H0_8IC1U3101
QFN016Q_P050_0035_T175X175_VIASQFN016Q_P050_0035_T175X175_VIASvr_adj=0.8vIC1U12
QFN24CQFN24Cbq24196IC1U2601
QFN40BQFN40Btlv320aic3256IC1U1801
QFN_34_16_157X177_TH110X130QFN_34_16_157X177_TH110X130IC1U1701
SHIELDING_CLIP_065X008SHIELDING_CLIP_065X008DISCRETE20MEC4; MEC5; MEC6; MEC7; MEC9; MEC10; MEC11; MEC12; MEC13; MEC14; MEC15; MEC16; MEC17; MEC18; MEC19; MEC21; MEC22; MEC23; MEC24; MEC25
SOD123SOD123mmvz5246bgpIO1D3105
SOT23SOT23q_fet_p_enhIO8Q4; Q503; Q505; Q507; Q509; Q512; Q517; Q1517
SOT23_5SOT23_5fix=2.8vIC6U5; U507; U2301; U2302; U3001; U3501
SOT323SOT323q_fet_n_enhIO19Q8; Q501; Q502; Q504; Q506; Q510; Q513; Q514; Q515; Q518; Q519; Q522; Q523; Q524; Q1519; Q2601; Q2602; Q2603; Q3101
SOT346_123SOT346_123tlv809i50dbvrIC1U2602
SSOP8-3_15X2_9-P0_65-H1_3SSOP8-3_15X2_9-P0_65-H1_3IC1U1590
SW_3_48_177X139_H128SW_3_48_177X139_H128sw_spst_pbIC3S301; S302; S303
SW_4_197X197SW_4_197X197sw_spst_pbIC1S305
TP-C30TP-C30t_point_rIO46TP1569; TP1570; TP1571; TP1572; TP1575; TP1576; TP1612; TP1613; TP1614; TP1615; TP1616; TP1617; TP1618; TP1619; TP1620; TP2001; TP2401; TP2402; TP2403; TP2404; TP2405; TP2406; TP2407; TP2408; TP2409; TP2410; TP2411; TP2603; TP2604; TP2605; TP2606; TP2609; TP2610; TP2611; TP2612; TP2642; TP3116; TP3117; TP3118; TP3119; TP3120; TP3121; TP3122; TP3123; TP3124; TP3125
XTAL4-7X26000030-3_2X2_5-H1XTAL4-7X26000030-3_2X2_5-H1DISCRETE1X1572
XTAL_4_55X43_79X63XTAL_4_55X43_79X6326mhzIC2X1701; X2101
XTAL_4_73X61_98X79XTAL_4_73X61_98X79DISCRETE1Y2001
XTAL_5_53X41XTAL_5_53X41IC2FL2001; FL2002
XTAL_SMD_4_032X025XTAL_SMD_4_032X02526mhzIC1Y2
XTAL_SMD_4_069X014XTAL_SMD_4_069X01432.768khzIC1Y3
附件:" Z" l& g7 |) n. t5 N& T
pcb文件
游客,如果您要查看本帖隐藏内容请回复
, r. {+ B9 d; T* g- K
发表于 2020-3-12 00:49 | 只看该作者
发表于 2020-4-12 09:36 | 只看该作者
    无聊
    2025-6-15 15:21
  • 签到天数: 3 天
    [LV.2]偶尔看看I
    发表于 2020-4-13 09:12 | 只看该作者
    学习一下,来下个
    $ d" \. z6 l; ^" ~' V
    2023-11-2 15:14
  • 签到天数: 34 天
    [LV.5]常住居民I
    发表于 2021-5-15 15:47 | 只看该作者
    下一个试看一下
    发表于 2022-7-31 00:10 | 只看该作者
    看一下,多谢分享
    ) ]# j# ~  ?0 s% p4 f/ s
    GMT+8, 2025-10-13 11:07 , Processed in 0.156250 second(s), 27 queries , Gzip On.
