查看: 659|回复: 4
[allegro16.3][6层]tiny210V2参考板 (S5PV210+NT5TU128M8GE-AC+WM8960GEFL)pcb文件
发表于 2019-12-27 15:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 `  h0 Y# D7 @- A  p8 h( Q" F" a6 T. @2 R+ P4 T" t# O3 S6 s5 W6 X" U; p/ N+ s/ u$ ^! j1 g# f9 ]' ]* w) Z/ J' p3 z/ L+ ?& d2 q, Z. P. D# \
文件描述:
* _! r+ p" a* r! Y$ |. O' d" E. k+ X* q- Y; f5 T  G4 L
1. 作品用途:tiny210V2参考板
2. 软件版本:allegro16.3
3. 层数:6层
4. 用到的主要芯片:S5PV210+NT5TU128M8GE-AC+WM8960GEFL' l* ?3 ]) I4 B3 c, B! x6 H$ P; j5 W& u5 R; B; v
5. pcb尺寸:4299.22000 *3110.24000 Mil
/ D" w! E* |- p" T, q' D# Y2 l
  U, ~0 R6 w0 [+ T. }# S
作品截图如下:
1 q* l. u# D, a3 T  `, \) M. p2 N4 D8 O  ~4 S4 M' m& R. s1 l$ r* c# c* f* l' N' P% E' x3 y5 p4 @
' B4 Q3 ^$ |& M# `# x5 E; o/ z" \
顶层截图:
* B8 R: Y, A0 ~, `. _1 i, V% ~! P7 b% J, \, \( I# ?$ k# G% A" g2 V: C* l$ i+ v$ p$ R
底层截图:
4 e: v# e* l" b2 J# M" q: W% ~8 ^3 M# k8 s: S9 I; q9 @; C! C! B+ _" r; R/ y" _# L) o, n+ v9 \1 G, B
5 [; M( S2 A+ ?0 Z' {. f) R8 i
; z% u5 q$ c+ P* }! Y6 f( p% F' g* o) l0 \: c: m) @7 g% T/ z
全层截图:
4 k$ f- ~: ^- B; Q# b! Y: g# S8 L) v0 I' b7 u9 ^$ o' |1 a
' ?& C- s) S; j
5 X% P0 t0 C) O7 N7 d( T# {  ~/ E6 e& A5 F. V, Q' P$ i7 Z" m, e! g- K
! L1 ^+ r. p+ J: t" b# G5 i% G( f' G5 Q( Y4 Z5 M: e4 a/ L
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
C5MMD3MMID-BOARD_C5MMD3MM_ID-BOARDID-BOARDIC4ID11; ID12; ID13; ID14
FM4PID-BOARD_FM4P_ID-BOARDID-BOARDIC10ID1; ID2; ID3; ID4; ID5; ID6; ID7; ID8; ID9; ID10
SKD_ANT_MM9329-2700ANT4PIN_SKD_ANT_MM9329-2700_ANTANT/MM9329-2700IC1A4
SKD_BAT_HOLDERCON2_SKD_BAT_HOLDER_MS614MS614IC1BAT1
SKD_C0402CAP NP_SKD_C0402_104104IC132C1; C2; C3; C7; C9; C10; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C42; C43; C44; C45; C46; C47; C48; C49; C50; C51; C52; C53; C54; C55; C56; C57; C58; C61; C62; C63; C64; C65; C66; C67; C68; C69; C70; C71; C72; C73; C77; C79; C81; C83; C84; C85; C86; C87; C88; C90; C91; C92; C93; C94; C95; C96; C98; C99; C100; C102; C103; C104; C105; C106; C107; C108; C109; C129; C131; C134; C136; C138; C140; C144; C146; C153; C159; C161; C163; C165; C170; C171; C173; C177; C181; C182; C186; C188; C191; C192; C193; C195; C197; C214; C247; C254; C257; C264; C268; C270; C282; C292; C295; C299; C303; C337; C346; C349; C352
SKD_C0402CAP NP_SKD_C0402_182182IC1C4
SKD_C0402CAP NP_SKD_C0402_202202IC1C5
SKD_C0402CAP NP_SKD_C0402_15P15pIC6C110; C111; C114; C115; C119; C121
SKD_C0402CAP NP_SKD_C0402_104/NC104/NCIC17C116; C179; C230; C283; C297; C307; C311; C312; C313; C315; C316; C317; C318; C319; C320; C321; C326
SKD_C0402CAP NP_SKD_C0402_13P13pIC2C118; C120
SKD_C0402CAP NP_SKD_C0402_1UF/10V1uF/10VIC9C122; C148; C149; C167; C205; C249; C250; C278; C279
SKD_C04021.0UF-6.3V-10%-X5R-0402_SKD_C041uF/10V/NCIC2C132; C262
SKD_C0402CAP NP_SKD_C0402_10P10pIC6C141; C154; C166; C176; C198; C339
SKD_C0402CAP NP_SKD_C0402_100P100pIC4C142; C143; C174; C175
SKD_C0402CAP NP_SKD_C0402_680P680pIC4C150; C151; C156; C157
SKD_C0402C_SKD_C0402_22PF/NC_10%22PF/NCIC2C206; C238
SKD_C0402C#1_SKD_C0402_104_10%104IC2C209; C241
SKD_C0402C#1_SKD_C0402_680P_10%680pIC1C212
SKD_C0402C#1_SKD_C0402_102_10%102IC1C244
SKD_C0402CAP NP_SKD_C0402_102102IC2C246; C291
SKD_C0402CAP NP_SKD_C0402_22P22pIC3C265; C266; C271
SKD_C04021.0UF-16V-10%-X5R-0603_SKD_C0401uF/10V/NCIC1C289
SKD_C040218PF-50V-5%-NPO-0402_SKD_C0402_22p/NCIC2C302; C314
SKD_C0402CAP NP_SKD_C0402_102/NC102/NCIC1C309
SKD_C0402CAP NP_0_SKD_C0402_1.5P1.5pIC1C340
SKD_C0402CAP NP_0_SKD_C0402_1UF/10V1uF/10VIC1C342
SKD_C0402CAP NP_0_SKD_C0402_1UF/10V/NC1uF/10V/NCIC1C344
SKD_C0603CAP NP_SKD_C0603_10UF/6.3V10uF/6.3VIC30C6; C8; C11; C28; C40; C41; C59; C60; C82; C89; C97; C101; C130; C133; C158; C160; C169; C185; C189; C190; C194; C196; C253; C267; C280; C290; C296; C347; C350; C351
SKD_C0603C_0_SKD_C0603_10UF/6.3V10uF/6.3VIC3C76; C78; C80
SKD_C0603C_0_SKD_C0603_10UF/6.3V/NC10uF/6.3V/NCIC1C112
SKD_C0603CAP NP_SKD_C0603_4.7UF/6.3V4.7uF/6.3VIC4C135; C137; C162; C164
SKD_C0603C#1_SKD_C0603_2.2UF/16V_20%2.2uF/16VIC5C210; C242; C300; C301; C353
SKD_C0603CAP NP_SKD_C0603_10UF/6.3V/NC10uF/6.3V/NCIC1C215
SKD_C0603CAP NP_SKD_C0603_2.2UF/16V2.2uF/16VIC3C248; C256; C260
SKD_C06034.7UF-6.3V-20%-X5R-0603_SKD_C064.7uF/6.3V/NCIC1C308
SKD_C0805CAP NP_SKD_C0805_10UF/16V10uF/16VIC14C139; C152; C172; C183; C216; C224; C225; C227; C228; C258; C269; C287; C293; C294
SKD_C0805CAP NP_SKD_C0805_10UF/16V/NC10uF/16V/NCIC4C178; C180; C217; C298
SKD_C0805C#1_SKD_C0805_10UF/16V_10%10uF/16VIC7C207; C208; C213; C239; C240; C251; C252
SKD_C0805C#1_SKD_C0805_10UF/16V_20%10uF/16VIC1C243
SKD_C1206C#1_SKD_C1206_22UF/25V_20%22uF/25VIC1C211
SKD_C1206CAP NP_SKD_C1206_22UF/25V22uF/25VIC2C255; C259
SKD_C1206CAP NP_SKD_C1206_10UF/35V10uF/35VIC1C261
SKD_CON7_88231_0400CON6_SKD_CON7_88231_0400_ACES_8ACES_88231_04001IC1J13
SKD_CON7_88231_0700TOUCH_CONN6_EP0700M01_0_SKD_CONACES_88231_07001IC1J8
SKD_DIODE_SMD_SMAD_SCHOTTKY_SKD_DIODE_SMD_SMA_RBRB051M-2YIC1D20
SKD_DIO_SOD123DIODE_SKD_DIO_SOD123_1N5819W1N5819WIC3D9; D10; D21
SKD_DIO_SOD123DIODE ZENER1_2_SKD_DIO_SOD123_11N5819WIC1D17
SKD_DIO_SOD123DIODE_SKD_DIO_SOD123_1N5819W/NC1N5819W/NCIC1D27
SKD_DIO_SOD123DIODE ZENER1_2_SKD_DIO_SOD123_BBZT52C13IC1D29
SKD_DIO_SOD123DIODE ZENER1_2_SKD_DIO_SOD123_21N5819W/NCIC1D30
SKD_FB0402INDUCTOR_SKD_FB0402_NCNCIC1L6
SKD_FB0603FB_SKD_FB0603_120R,2A120R,2AIC21FB4; FB5; FB6; FB8; FB9; FB10; FB11; FB12; FB13; FB14; FB15; FB16; FB17; FB18; FB20; FB25; FB26; FB27; FB28; FB29; FB30
SKD_FB0603FB_SKD_FB0603_120R,2A/NC120R,2A/NCIC2FB7; FB31
SKD_FB0603INDUCTOR_SKD_FB0603_120R,2A120R,2AIC3FB19; FB23; FB32
SKD_FB0603INDUCTOR_SKD_FB0603_120R,2A/NC120R,2A/NCIC2FB22; FB24
SKD_FCF584S5PV210_SKD_FCF584_S5PV210S5PV210IC1U1
SKD_FPC_CON10_88511CON10_SKD_FPC_CON10_88511_ACES_ACES_88511-1001IC1J15
SKD_FPC_CON24_88511CAM_JHCT 200W_SKD_FPC_CON24_885ACES_88511-2401IC1J11
SKD_FPC_CON30_20347LP097X02_SKD_FPC_CON30_20347_IPIPX 20347-030E-1IC1J19
SKD_FPC_CON50_88511CON50_SKD_FPC_CON50_88511_ACES_ACES_88511-5041IC1J23
SKD_FUSE1812FUSEHOLDER_SKD_FUSE1812_SMD1812SMD1812P260TFIC1F1
SKD_INAD169SDIN4C2-8G_3_SKD_INAD169_SDIN5CSDIN5C1-4GIC1U2
SKD_IND_4M4INDUCTOR_SKD_IND_4M4_2.2UH/WQPI2.2UH/WQPIG4018-2R2MIC3L5; L13; L15
SKD_IND_4M4INDUCTOR_SKD_IND_4M4_10UH/WQPIG10UH/WQPIG4018-100IC1L14
SKD_IND_070X065L_SKD_IND_070X065_6.8UH/MMD-06A6.8UH/MMD-06AH-6R8M-S1IC1L4
SKD_IND_070X065L_SKD_IND_070X065_4.7UH/MMD-06A4.7UH/MMD-06AH-4R7M-S1IC1L8
SKD_IND_070X065L_SKD_IND_070X065_10UH/MMD-06AH10UH/MMD-06AH-100M-S1IC1L9
SKD_L0402INDUCTOR1_SKD_L0402_3.3NH3.3nHIC1L7
SKD_L0805INDUCTOR1_SKD_L0805_1UH1uHIC1L17
SKD_LED0603ALED_SKD_LED0603A_RED/NCRED/NCIC3LED1; LED3; LED5
SKD_LED0603ALED_SKD_LED0603A_REDREDIC1LED2
SKD_LED0603ALED_SKD_LED0603A_GREEN/NCGREEN/NCIC1LED4
SKD_LED0603ALED_0_SKD_LED0603A_REDREDIC2LED6; LED7
SKD_LINE_CON6XM8CON6_SKD_LINE_CON6XM8_ACES_88_1ACES_88460-0601/NCIC1J5
SKD_LINE_CON6XM8CON6_SKD_LINE_CON6XM8_ACES_8846ACES_88460-0601IC2J14; J20
SKD_MDT56-050DS90C385A_0_SKD_MDT56-050_DS90CDS90C385AIC1U8
SKD_NC024_LGA648787_0_SKD_NC024_LGA64_NC024NC024IC1U30
SKD_OSC5032CRYSTAL/2P_SKD_OSC5032_24MHZ24MHzIC2X1; X2
SKD_OSC5032CRYSTAL/2P_SKD_OSC5032_27MHZ27MHzIC1X3
SKD_OSC5032CRYSTAL/2P_SKD_OSC5032_24MHZ/NC24MHz/NCIC1X6
SKD_OSCFC-225CRYSTAL/2P_SKD_OSCFC-225_32.76832.768KHzIC1X4
SKD_PQFP_N32WM8960GEFL_1_SKD_PQFP_N32_WM896WM8960GEFLIC1U10
SKD_QFN8MP3302DD_SKD_QFN8_MP3302DDMP3302DDIC1U29
SKD_QFN16LIS3DH/LIS331DL_SKD_QFN16_MMA84MMA8452QIC1U14
SKD_QFN36USB2514B_QFN36_MIN_SKD_QFN36_USUSB2514B/NCIC1U16
SKD_R0402INDUCTOR_SKD_R0402_270NH/5%/110270nH/5%/110mA/0402IC2L19; L21
SKD_R0603R_SKD_R0603_100K100KIC31R1; R7; R8; R9; R11; R12; R14; R53; R74; R75; R96; R114; R123; R132; R135; R137; R144; R177; R182; R186; R187; R189; R203; R205; R208; R215; R226; R272; R294; R297; R299
SKD_R0603R_SKD_R0603_0R/NC0R/NCIC29R2; R5; R6; R17; R26; R27; R37; R112; R128; R136; R153; R154; R157; R158; R159; R161; R162; R164; R166; R167; R170; R172; R173; R174; R175; R176; R179; R214; R246
SKD_R0603R_SKD_R0603_0R0RIC13R3; R4; R15; R24; R25; R91; R92; R102; R111; R131; R134; R142; R202
SKD_R0603R_SKD_R0603_100K/NC100K/NCIC8R10; R110; R116; R178; R190; R193; R220; R302
SKD_R0603R_SKD_R0603_44R2,1%44R2,1%IC2R13; R16
SKD_R0603R_SKD_R0603_4.7K4.7KIC12R18; R19; R20; R21; R22; R23; R83; R121; R125; R230; R271; R290
SKD_R0603RESISTOR_SKD_R0603_10K10KIC1R28
SKD_R0603R_SKD_R0603_22R22RIC29R29; R30; R31; R32; R34; R35; R55; R63; R70; R79; R97; R98; R118; R133; R138; R139; R140; R141; R185; R188; R204; R217; R274; R280; R281; R282; R286; R295; R298
SKD_R0603R_SKD_R0603_10K10KIC10R33; R38; R42; R106; R107; R243; R254; R268; R269; R276
SKD_R0603R_SKD_R0603_22R/NC22R/NCIC4R36; R169; R192; R300
SKD_R0603R_SKD_R0603_NCNCIC7R39; R115; R160; R163; R197; R201; R277
SKD_R0603R_SKD_R0603_10K/1%10K/1%IC8R40; R41; R43; R45; R46; R47; R48; R49
SKD_R0603R_SKD_R0603_10K/NC10K/NCIC4R44; R171; R194; R289
SKD_R0603R_SKD_R0603_5.1M5.1MIC3R50; R51; R56
SKD_R0603R_SKD_R0603_47K47KIC3R52; R209; R210
SKD_R0603R_SKD_R0603_100R/NC100R/NCIC1R54
SKD_R0603R_SKD_R0603_10M10MIC1R57
SKD_R0603RESISTOR_SKD_R0603_47K47KIC4R58; R67; R68; R69
SKD_R0603R_SKD_R0603_200R200RIC7R81; R82; R84; R86; R87; R88; R90
SKD_R0603R_SKD_R0603_100R100RIC2R85; R105
SKD_R0603R_SKD_R0603_680R680RIC4R93; R95; R126; R127
SKD_R0603R_SKD_R0603_2K2KIC10R94; R117; R143; R147; R156; R181; R184; R206; R207; R296
SKD_R0603R_SKD_R0603_15K 1%15K 1%IC1R100
SKD_R0603R_SKD_R0603_2K/NC2K/NCIC7R101; R103; R109; R168; R191; R301; R303
SKD_R0603R_SKD_R0603_470R470RIC1R104
SKD_R0603R_SKD_R0603_20K/1%20K/1%IC3R108; R155; R267
SKD_R0603R_SKD_R0603_390K/1%390K/1%IC1R113
SKD_R0603R_SKD_R0603_8.25K 1%8.25K 1%IC1R120
SKD_R060310K-1/16W-5%-0603_SKD_R0603_10K10K/NCIC3R129; R130; R200
SKD_R0603100K-1/16W-5%-0603_SKD_R0603_10100K/NCIC5R145; R146; R239; R244; R250
SKD_R0603R_SKD_R0603_100K_5%100KIC1R148
SKD_R0603R_SKD_R0603_63.4K 1%_1%63.4K 1%IC1R149
SKD_R0603R_SKD_R0603_12K/1%_1%12K/1%IC1R150
SKD_R0603R_SKD_R0603_47K/1%47K/1%IC1R151
SKD_R0603R_SKD_R0603_1K/NC1K/NCIC1R152
SKD_R0603R_SKD_R0603_ORORIC1R165
SKD_R0603R_SKD_R0603_47K /1%_1%47K /1%IC1R180
SKD_R0603R_SKD_R0603_15K 1%_1%15K 1%IC1R183
SKD_R0603R_SKD_R0603_100K/1%100K/1%IC5R196; R198; R199; R223; R242
SKD_R0603R_SKD_R0603_27K_5%27KIC2R211; R213
SKD_R060312.0K-1/16W-1%-0603_SKD_R0603_112K/1%/NCIC1R212
SKD_R0603R_SKD_R0603_1.62R/1%1.62R/1%IC1R216
SKD_R06031.0MEG-1/16W-5%-0603_SKD_R0603_1M/NCIC1R219
SKD_R0603R_SKD_R0603_27K/NC27K/NCIC1R234
SKD_R0603R_SKD_R0603_200K/1%200K/1%IC1R240
SKD_R06031.0K-1/16W-5%-0603_SKD_R0603_1K1K/NCIC1R249
SKD_R0603R_SKD_R0603_1K1KIC2R270; R275
SKD_R0603RES_0_SKD_R0603_100K100KIC2R279; R287
SKD_R0603RES_0_SKD_R0603_100K/NC100K/NCIC1R283
SKD_R0603RES_0_SKD_R0603_1K1KIC3R284; R285; R293
SKD_R0603R_SKD_R0603_4.7K/NC4.7K/NCIC2R288; R292
SKD_R0603R_SKD_R0603_20K/1%/NC20K/1%/NCIC1R291
SKD_R2010R_SENSE_SKD_R2010_0.1R/1%_1%0.1R/1%IC1RS2
SKD_RN4_0603RN_SKD_RN4_0603_22R_1050.0000522RIC4RN1; RN3; RN4; RN5
SKD_RN4_0603RN_SKD_RN4_0603_22R/NC_1050.00022R/NCIC1RN2
SKD_RN4_0603RN_SKD_RN4_0603_200R_1050.00005200RIC6RN6; RN7; RN8; RN9; RN10; RN15
SKD_RN4_0603RN_SKD_RN4_0603_51K_1050.0000551KIC2RN13; RN23
SKD_RN4_0603RN_SKD_RN4_0603_51K/NC_1050.00051K/NCIC1RN14
SKD_SC70-5XC6209_SKD_SC70-5_RT9030-11GU5RT9030-11GU5IC1U45
SKD_SOP8APM4317K_0_SKD_SOP8_AO4423AO4423IC2Q12; Q18
SKD_SOP8_DDAAPW7145_SKD_SOP8_DDA_APW7145APW7145IC2U19; U25
SKD_SOP8SI4435_SKD_SOP8_AO4423AO4423IC2U23; U27
SKD_SOT23NDS356P/SOT_SKD_SOT23_AO3415AAO3415AIC4Q5; Q9; Q16; Q24
SKD_SOT23NPN_0_SKD_SOT23_MMBT3904MMBT3904IC8Q6; Q10; Q11; Q14; Q15; Q21; Q22; Q23
SKD_SOT23NPN_0_SKD_SOT23_MMBT3904/NCMMBT3904/NCIC3Q8; Q25; Q28
SKD_SOT23Q_FET_N_ENH#2_SKD_SOT23_SI2306/SI2306/NCIC2Q17; Q19
SKD_SOT23NDS356P/SOT_SKD_SOT23_AO3415A/NAO3415A/NCIC2Q20; Q26
SKD_SOT23PNP_SKD_SOT23_MMBT3906MMBT3906IC2Q27; Q29
SKD_SOT23NDS356P/SOT_1_SKD_SOT23_AO3415AAO3415AIC1Q30
SKD_SOT23NDS356P/SOT_1_SKD_SOT23_AO341_1AO3415A/NCIC1Q31
SKD_SOT23-6RT9011-MGPJ6_SKD_SOT23-6_RT9011RT9011-MGPJ6IC1U11
SKD_TDFN8STM6503_SKD_TDFN8_STM6503STM6503IC1U40
SKD_TF_C-PTFBT1-08GLBS1NN4H0TF_C-PTFBT1-08GLBS1NN4H0_SKD_TFC-PTFBT1-08GLBS1NN4H0IC1J24
SKD_TSSOP20HB6298B_SKD_TSSOP20_HB6298BHB6298BIC1U21
SKD_TVSDF2S6_8SDIODE ZENER1_2_SKD_TVSDF2S6_8S_DF2S6.8SIC9D1; D7; D8; D16; D18; D22; D23; D24; D31
SKD_X8_FBGA60_HY_SMK4T1G084QQ-HCE6 OR HCF7_SKD_X8_NT5TU128M8GE-ACIC4U3; U4; U5; U6
SOT23-5XC6209_SOT23-5_XC6209B332MRN/NCXC6209B332MRN/NCIC1U13
SOT23-5XC6209_SOT23-5_XC6209B122MRNXC6209B122MRNIC1U15
SOT23-5XC6209_SOT23-5_XC6210B182MRXC6210B182MRIC1U31
SOT23-5RT8008_SOT23-5_RT8059RT8059IC3U42; U43; U44
TP1MMT POINT R_TP1MM_DEBUG_RXD2DEBUG_RXD2IC1TP1
TP1MMT POINT R_TP1MM_DEBUG_TXD2DEBUG_TXD2IC1TP2
TP1MMT POINT R_TP1MM_CLKOUTCLKOUTIC1TP3
TP1MMT POINT R_TP1MM_XPWRRGTONXPWRRGTONIC1TP4
TP1MMT POINT R_TP1MM_XI2SCDCLK1Xi2sCDCLK1IC1TP5
TP1MMT POINT R_TP1MM_XM1CKE1Xm1CKE1IC1TP6
TP1MMT POINT R_TP1MM_XNRSTOUTXnRSTOUTIC1TP7
TP1MMTP-10MIL_TP1MM_NCNCIC1TP10
TP1MMT POINT R_TP1MM_XM1SCLKNXm1SCLKnIC1TP12
TP1MMT POINT R_TP1MM_M1SCLKM1SCLKIC1TP13
TP1MMT POINT_TP1MM_T POINTT POINTIC1TP15
TP1MMLABTESTPOINT_TP1MM_LABTESTPOINTLABTESTPOINTIC4TP16; TP17; TP26; TP28
TP1MMT POINT R_TP1MM_V_ARMV_ARMIC1TP18
TP1MMT POINT R_TP1MM_V_INTV_INTIC1TP25
TP1MMLABTESTPOINT#1_TP1MM_LABTESTPOILABTESTPOINTIC1TP27
TP1MMT POINT R_TP1MM_PWR_SYSPWR_SYSIC1TP29
TP1MMT POINT R_TP1MM_V_MEMV_MEMIC1TP30
TP1MMT POINT R_TP1MM_V_PLLV_PLLIC1TP31
TP1MMT POINT R_TP1MM_V_ALIVEV_ALIVEIC1TP32
TP1MMT POINT R_TP1MM_VDD_SYS_3.3VVDD_SYS_3.3VIC1TP33
TP1MMT POINT R_TP1MM_V_BLV_BLIC1TP37
TP1MMT POINT R_TP1MM_LCD_APLCD_APIC1TP39
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
% \7 t: @+ F. m' u
发表于 2022-11-21 14:22 | 只看该作者
文档可以参考下吗?
! Q8 H* ?; b8 K2 V5 Q, p0 q5 O: e0 `9 u4 |7 c
GMT+8, 2025-10-13 06:14 , Processed in 0.171875 second(s), 27 queries , Gzip On.
