查看: 934|回复: 9
[allegro16.5][6层]inter雷电接口转SATA板(LPC1114+Port Ridge+ASM1053)pcb文件
发表于 2019-12-26 14:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
1 `  h0 Y# D7 @- A  p8 h( Q" F" a6 T. @2 R+ P4 T" t# O3 S6 s5 W6 X
( ]3 o. `, S, t. t
文件描述:
* _! r+ p" a* r! Y$ |. O' d" E
$ ]6 M* H4 P3 c7 Z0 k3 b
1. 作品用途:inter雷电接口转SATA板
2. 软件版本:allegro16.5
3. 层数:6层
4. 用到的主要芯片:LPC1114+Port Ridge+ASM1053 @' l* ?3 ]) I4 B3 c, B
4 v5 w- D7 @- Z9 L# L! B4 H% M5. pcb尺寸:3346.46*3053.17 MIL
9 |# F: ~4 e" ]
作品截图如下:
1 q* l. u# D, a3 T  `, \) M. p2 N4 D8 O  ~4 S2 g. F! q% n" H1 K7 U; ], l" v; `
顶层截图:
* B8 R: Y, A0 ~, `. _1 i
5 `9 M) D( M2 M; q, |( {6 K
底层截图:
4 e: v# e* l" b2 J# M" q: W% ~8 ^3 M# k8 s: S9 I( }6 z! m+ k" u; l
; z% u5 q$ c+ P* }! Y6 f( p% F' g# p$ h8 v7 u- V) p6 I+ w
全层截图:
4 k$ f- ~: ^- B; Q# b! Y: g# S8 L) v0 I/ T  N4 e0 j' `
! L1 ^+ r. p+ J: t" b# G5 i% G( f7 ]* B* N  p. ^
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
201CAP-SM0603_0_0201_DISCRETE_1U1uDISCRETE15C6; C8; C9; C10; C12; C13; C14; C16; C18; C19; C21; C22; C23; C24; C25
201CAP-SM0603_0_0201_DISCRETE_0.010.01UDISCRETE2C7; C17
201CAP-SM0603_0_0201_DISCRETE_10U10uDISCRETE1C11
201RES-SM0603_0201_DISCRETE_20K20kDISCRETE2R4; R5
201RES-SM0603_0201_DISCRETE_12.112.1DISCRETE3R6; R8; RB48
201RES-SM0603_0201_DISCRETE_49.949.9DISCRETE4RB57; RB61; RB62; RB66
256H134Y-V8256H134Y-V8_256H134Y-V8_256H134256H134Y-V8IC2H1; H2
402CAP NP_0402_DISCRETE_1U1uDISCRETE2C26; CB4
402CAP-SM0603_0_0402_DISCRETE_0.1U0.1UDISCRETE40C28; C32; C33; C35; C38; C39; C40; C41; C42; C43; C46; C47; CB24; CB32; CB35; CB39; CB40; CB46; CB48; CB50; CB51; CB53; CB54; CB58; CB63; CB66; CB68; CB69; CB70; CB71; CB72; CB73; CB75; CB83; CB91; CB92; CB93; CB94; CB95; CB97
402CAP NP_0402_10N10nIC18C30; C31; C34; C36; C48; C49; C50; C51; CB7; CB10; CB20; CB41; CB56; CB59; CB76; CB77; CB78; CB79
402CAP-SM0603_0_0402_DISCRETE_12P12PDISCRETE1C44
402CAP NP_0402_100N100nIC13CB5; CB6; CB8; CB12; CB13; CB14; CB15; CB17; CB22; CB44; CB96; CB98; CB99
402CAP NP_0402_330P330pIC1CB18
402CAP NP_0402_100P100pIC1CB19
402CAP-SM0603_0_0402_DISCRETE_0.010.01UDISCRETE4CB27; CB45; CB49; CB57
402CAP NP_0402_DISCRETE_220N220nDISCRETE1CB30
402CAP NP_0402_DISCRETE_0.1U_0.1uDISCRETE8CB34; CB36; CB81; CB82; CB86; CB87; CB89; CB90
402CAP NP_0402_220P220pIC1CB37
402CAP NP_0402_100U100uIC1CB43
402CAP-SM0603_0_0402_DISCRETE_0.470.47uFDISCRETE2CB52; CB55
402CAP-SM0603_0_0402_DISCRETE_220N220nDISCRETE2CB60; CB62
402CAP-SM0603_0_0402_DISCRETE_15P15PDISCRETE1CB64
402CAP-SM0603_0_0402_DISCRETE_20P20pDISCRETE2CB65; CB74
402RESISTOR_0402_10K10KIC1R2
402RES-SM0603_0402_DISCRETE_1K1kDISCRETE5R7; RB27; RB40; RB44; RB51
402RES-SM0603_0402_DISCRETE_4.7K4.7KDISCRETE15R9; R10; R13; R15; R16; R17; RB16; RB21; RB31; RB58; RB71; RB76; RB96; RB97; RB99
402RESISTOR_0402_00IC3R11; R12; RB45
402RES-SM0603_0402_DISCRETE_12.1K12.1K 1%DISCRETE3R14; RB63; RB85
402RESISTOR_0402_4.74.7IC3R18; R19; R20
402RESISTOR_0402_200K200KIC1RB1
402RESISTOR_0402_DISCRETE_100K100KDISCRETE5RB2; RB3; RB11; RB25; RB35
402RESISTOR_0402_DISCRETE_1K1KDISCRETE5RB4; RB18; RB98; RB101; RB102
402RESISTOR_0402_DISCRETE_10K10KDISCRETE3RB5; RB19; RB100
402RESISTOR_0402_35K35KIC1RB6
402RESISTOR_0402_16.5K16.5KIC1RB7
402RESISTOR_0402_2K2KIC2RB8; RB22
402RESISTOR_0402_6.49K6.49KIC1RB9
402RESISTOR_0402_1.5K1.5KIC1RB10
402RESISTOR_0402_4.99K4.99KIC1RB12
402RESISTOR_0402_20K20KIC1RB13
402RES-SM0603_0402_DISCRETE_10K10KDISCRETE27RB14; RB15; RB17; RB20; RB28; RB29; RB32; RB34; RB36; RB39; RB41; RB42; RB43; RB49; RB50; RB52; RB53; RB54; RB55; RB60; RB64; RB67; RB69; RB70; RB81; RB82; RB84
402RESISTOR_0402_2.8K2.8KIC1RB23
402RES-SM0603_0402_DISCRETE_1M1MDISCRETE1RB24
402RESISTOR_0402_15.4K15.4KIC1RB26
402RES-SM0603_0402_DISCRETE_2.05K2.05kDISCRETE1RB30
402RESISTOR_0402_DISCRETE_4.7K4.7KDISCRETE5RB37; RB38; RB46; RB47; RB59
402RES-SM0603_0402_DISCRETE_3.3K3.3KDISCRETE4RB56; RB78; RB79; RB80
402RES-SM0603_0402_DISCRETE_470K470KDISCRETE4RB65; RB68; RB72; RB75
402RES-SM0603_0402_DISCRETE_2.2K2.2KDISCRETE2RB73; RB74
402RES-SM0603_0402_DISCRETE_100100DISCRETE1RB77
402R_0402_DISCRETE_10KOHM10KOhmDISCRETE2RB86; RB89
402RES-SM0603_0402_DISCRETE_100K100KDISCRETE1RB95
603CAP-SM0603_0_0603_DISCRETE_0.1U0.1UDISCRETE2C1; C2
603CAP-SM0603_0_0603_DISCRETE_10U/10U/6.3VDISCRETE6C5; C27; C37; CB47; CB61; CB85
603CAP NP_0603_10U10uIC2C15; C20
603CAP-SM0603_0_0603_DISCRETE_10_110U/10VDISCRETE1C29
603CAP-SM0603_0_0603_DISCRETE_1U/11U/10VDISCRETE1C45
603CAP NP_0603_DISCRETE_10U10uDISCRETE1CB11
603FERRITE_0603_330330IC2L1; LB4
603RES-SM0603_0603_DISCRETE_10K10KDISCRETE2R1; RB87
603RESISTOR_0603_330330IC1R3
603RES-SM0603_0603_DISCRETE_17.8K17.8KDISCRETE1RB88
805CAP-SM0603_0_0805_DISCRETE_10U/10U/10VDISCRETE2C3; C4
805CAP NP_0805_DISCRETE_10U10uDISCRETE7CB1; CB2; CB3; CB9; CB25; CB31; CB33
805CAP NP_0805_DISCRETE_22U22uDISCRETE6CB16; CB21; CB23; CB28; CB29; CB38
1206CAP-SM0603_0_1206_DISCRETE_22U22UDISCRETE1CB42
BGA102_5X6_045MMPORT RIDGE_BGA102_5X6_045MM_PORPort RidgeIC1UB10
CHOKE-DLW21SCHOKE_CM-YFD2012T_0_CHOKE-DLW21WCM2012S-900IC1L3
CON_USB30-1USB3.0_1.0B_CON_USB30-1_IC_UEB1UEB11123-2JK1-4FIC1J4
CRYSTAL-S3225AXTAL-CRYSTAL6035_0_CRYSTAL-S32225MHZ/20P-3225IC1Y1
CRYSTAL-S3225AXTAL-CRYSTAL6035_0_CRYSTAL-S3_120MHZ/20P-3225IC1YB1
HEADER1X1_100_THHEADER 1X1 TH_HEADER1X1_100_TH_HEADER 1x1 THIC1J2
INDUCTOR_MPL73INDUCTOR_INDUCTOR_MPL73_5.6UH5.6uHIC1LB1
INDUCTOR_MPL73INDUCTOR_INDUCTOR_MPL73_15UH15uHIC2LB2; LB3
MINI_DP_REV3TBT_SOURCE_MINI_DP_REV3_DP3R020DP3R020SU32JQ1R400IC1J3
QFN14_3X4_05MMMP28253_QFN14_3X4_05MM_MP28253MP28253IC3UB1; UB2; UB4
QFN33_7X7_065MMLPC1114_QFN33_7X7_065MM_LPC1114LPC1114IC1UB5
QFN-49-P04-B6ASM1053_0_QFN-49-P04-B6_ASM1053ASM1053IC1U1
QFN-49-P05-B7-E42ASM1061_QFN-49-P05-B7-E42_ASM10ASM1061IC1UB11
SATA-SR-F122125M1-1CN-SATA_C16661-XXXXX-X_4_SATA-SC16661-12204IC1J1
SC70_POWERPAKSIA417_SC70_POWERPAK_SIA417SiA417IC1QB4
SM0806_FBCHOKE-3L-TC-600M-3A-5026_SM0806SMTDR31-4R7MDISCRETE2L2; LB5
SMBDIODE SCHOTTKY_SMB_SL23SL23IC2D2; D3
SMT_LEDLED_SMT_LED_GREENGREENIC1D1
SO150P50-8SFLASH-PM25LV512-25SC_0_SO150P5Pm25LV512A-100SCEIC1UB8
SO-8-P127-B4SFLASH-PM25LV512-25SC_0_SO-8-P1Pm25LV512A-100SCEIC1UB13
SOIC8_150MILPFET_SOIC8_150_SOIC8_150MIL_DMPDMP2022LSSIC3QB6; QB9; QB13
SOIC8_150MILAT25_EEPROM_SOIC8_150MIL_AT2532AT25320BIC1UB9
SOT23-32N7002_SOT23-3_2N70022N7002IC5QB1; QB2; QB3; QB5; QB10
SOT23-3PMOS_SOT23_3_SOT23-3_SI2301DSSi2301DSIC1QB12
SOT23-5TPS2065DBV_SOT23-5_TPS2065DBVTPS2065DBVIC1UB6
SOT223LDO-G1117-33T63U_0_SOT223_IC_AXAX1117E18AIC1UB7
SOT363BC846S_SOT363_BC846SBC846SIC1QB7
TP40SMDTP SMT_TP40SMD_TP SMTTP SMTIC1TP1
TQFN-29-P05-B35ASM1453_1_TQFN-29-P05-B35_IC_ASASM1456IC1UB12
TSOT23-5LT1761-ADJ_TSOT23-5_IC_LT1761-ALT1761-AdjIC1UB3
XTAL_3_2X2_5_4PINCRYSTAL_4_pads_XTAL_3_2X2_5_4PI25MHzIC1YB2
附件:
PCB文件如下:
游客,如果您要查看本帖隐藏内容请回复
6 }. g1 v2 h# M6 j
发表于 2020-4-23 07:57 | 只看该作者
学习一下,感谢分享~
5 U! j4 E% Q/ H( B3 Q0 k
发表于 2020-8-20 22:42 | 只看该作者
感谢无私分享的楼主
    2025-10-12 15:36
  • 签到天数: 1237 天
    [LV.10]以坛为家III
    发表于 2020-8-25 10:05 | 只看该作者
    谢谢分享,学习一下
    8 M( ]" z: f) Y, Q
    奋斗
    2025-10-12 15:06
  • 签到天数: 586 天
    [LV.9]以坛为家II
    发表于 2020-9-6 12:57 | 只看该作者
    感谢楼主分享!
    # H5 T6 M  O. R; s6 u
    发表于 2020-12-24 11:35 | 只看该作者
    看看。有没有参考价值。。。
    ! |( Y! Y- N% r2 M! C
    发表于 2021-10-9 21:48 | 只看该作者
    学习学习阿 阿 6 F7 P' Z* }) C1 Y2 h- ]" {
    2025-8-12 15:03
  • 签到天数: 74 天
    [LV.6]常住居民II
    发表于 2022-5-23 14:37 | 只看该作者
    5 C8 ?4 ]5 S; F. K感谢楼主分享~# W
    GMT+8, 2025-10-13 11:07 , Processed in 0.156250 second(s), 27 queries , Gzip On.
