查看: 3964|回复: 19
[allegro16.6][6层]瑞芯微RK3399EXCAVATOR开发板底板(HDMI_USB+AP6354+SJ109148)...
发表于 2019-12-24 15:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]瑞芯微RK3399EXCAVATOR开发板底板(HDMI_USB+AP6354+SJ109148)pcb文件
4 `% d+ v. }1 `6 O& o7 O% }& W3 {
文件描述:
2 S; X; g8 x0 f4 W
1. 作品用途:瑞芯微RK3399EXCAVATOR开发板底板
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片:HDMI_USB+AP6354+SJ109148
5. PCB尺寸:7874*6102mil
4 _" G4 W2 [7 |, }) }2 d% A, Z/ i
* V) F9 g3 v+ d- G2 [2 N" B* J
作品截图如下:
2 Q% u6 X8 x1 f$ y. }- k2 ?1 b. n* U* c6 t+ n, i8 ^
顶层截图:
$ d) v; l& D1 s$ N; {1 u* \' j! s" ]& V4 e/ z8 m1 k& O
底层截图:
4 r$ c5 q# A# ^- S
- l! t( ^3 _6 @9 u& y
8 m  ~3 @5 Y- G; {. I$ D* \* m: A
0 l2 v' x* g0 N$ d7 [7 o5 U
全层截图:
/ O, ~' N! r" f" Q6 a: `' {! O1 z0 N2 Y1 x: g
1 b* l( \
) ^1 ^! O! S1 F/ H. y
BOM:
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
ANT2_40R00X9R00ANT_1P1G_ANT2_40R00X9R00_ANT_DIANT_DIPOLE_1IC2ANT6102; ANT6104
ANT_JACKANT_1P2G_ANT_JACK_ANT_JACKANT_JACKIC2ANT6101; ANT6103
AS0B821-S55B-7HSJ109148_3_AS0B821-S55B-7H_SJ10SJ109148IC1J9001
BATT_7PINSBAT_0_BATT_7PINS_VBATVBATIC1BAT501
BGA80_7R00X7R00X1R00RK1000_1_BGA80_7R00X7R00X1R00_TTC358749XBGIC1U8503
C0201CAP NP_C0201_100NF100nFIC17C5001; C5002; C8303; C8304; C8305; C8306; C8307; C8310; C8311; C8312; C8313; C8927; C8929; C8931; C8932; C8933; C8934
C0402CAP NP_C0402_100NF100nFIC72C503; C514; C515; C518; C522; C903; C908; C1402; C1403; C1405; C2500; C2501; C2606; C2607; C2609; C2610; C2611; C2612; C2613; C2614; C2615; C2616; C2617; C2620; C2624; C2626; C2628; C2629; C2631; C2633; C4501; C6118; C6120; C7113; C7114; C7117; C7118; C7120; C7123; C7124; C7126; C7128; C8008; C8301; C8302; C8308; C8309; C8315; C8319; C8324; C8327; C8328; C8329; C8330; C8331; C8332; C8337; C8341; C8344; C8502; C8905; C8909; C8939; C8948; C9002; C9006; C9007; C9009; C9011; C50042; C50064; C50065
C0402CAP NP_C0402_10NF10nFIC5C504; C506; C7119; C8323; C8333
C0402CAP NP_C0402_47NF47nFIC2C507; C510
C0402CAP NP_C0402_1UF1uFIC13C517; C1404; C4502; C7102; C7122; C8503; C8508; C8926; C8945; C8946; C50038; C50056; C50057
C0402CAP NP_C0402_100PF100pFIC6C519; C520; C521; C2507; C2509; C2510
C0402CAP NP_C0402_15PF15pFIC1C904
C0402CAP NP_C0402_22PF22pFIC3C2601; C7110; C50060
C0402CAP NP_C0402_4.7NF4.7nFIC1C2602
C0402CAP NP_C0402_12PF12pFIC2C2603; C2604
C0402CAP NP_C0402_8PF8pFIC5C4601; C6112; C6113; C8505; C8506
C0402CAP NP_C0402_0.1UF0.1uFIC16C4604; C4605; C4607; C4608; C4609; C4610; C4611; C4612; C4613; C4703; C4705; C4706; C4708; C5004; C5006; C8504
C0402CAP NP_C0402_10PF10pFIC3C6101; C6104; C9004
C0402CAP NP_C0402_DNPDNPIC11C6102; C6103; C6105; C6106; C6107; C6108; C6109; C6110; C6111; C6114; C50059
C0402CAP NP_C0402_0.1UF/10V0.1uF/10VIC11C7112; C7129; C7130; C7131; C8001; C8004; C8005; C8006; C8007; C8009; C8010
C0402CAP NP_C0402_680PF680pFIC2C7121; C7125
C0402CAP NP_C0402_10NF/25V10nF/25VIC1C8002
C0402CAP NP_C0402_1UF/10V1uF/10VIC2C8003; C8011
C0402CAP NP_C0402_1NF1nFIC1C8101
C0402CAP NP_2_C0402_0.1UF0.1uFIC22C8507; C8509; C8516; C8517; C8518; C8519; C8520; C8521; C8522; C8525; C8526; C8527; C8528; C8907; C8913; C8914; C8915; C8916; C8917; C8918; C50040; C50063
C0402CAP NP_C0402_5PF5pFIC1C8510
C0402CAP NP_2_C0402_0.01UF0.01uFIC1C8511
C0402CAP NP_2_C0402_150PF150pFIC2C8512; C8513
C0402CAP NP_2_C0402_12P12PIC2C8901; C8906
C0402CAP_C0402_0.1UF0.1uFDISCRETE2C8922; C8923
C0402CAP NP_C0402_220PF220pFIC2C8928; C8930
C0402SMALL CAP_C0402_20PF20pFIC1C9001
C0402CAP NP_C0402_390PF390pFIC1C9005
C0402CAP NP_C0402_NCNCIC1C50035
C0603CAP NP_C0603_2.2UF2.2uFIC1C516
C0603CAP NP_C0603_10UF10uFIC14C2605; C2608; C2627; C4602; C4603; C4606; C4701; C4702; C4704; C4707; C5003; C5005; C8314; C50066
C0603CAP NP_C0603_4.7UF4.7uFIC11C2625; C2630; C6115; C6116; C6117; C7115; C8325; C8326; C8515; C50037; C50062
C0603SMALL CAP_C0603_4.7UF/10V4.7uF/10VIC1C7101
C0603SMALL CAP_C0603_2.2UF/10V2.2uF/10VIC4C7103; C7104; C7105; C7106
C0603CAP NP_C0603_4.7UF/10V4.7uF/10VIC1C7111
C0603CAP NP_C0603_22UF22uFIC5C8316; C8317; C8318; C8320; C8343
C0603CAP NP_6_C0603_475475IC2C8902; C8919
C0805CAP NP_C0805_10UF10uFIC31C501; C502; C508; C511; C512; C523; C905; C906; C1401; C2503; C2619; C2632; C6119; C7116; C7127; C8321; C8322; C8903; C8910; C8924; C8925; C8940; C8941; C8942; C8943; C8944; C9003; C9008; C9010; C90046; C90047
C0805CAP NP_C0805_22UF22uFIC3C505; C509; C8947
C0805CAP NP_C0805_2.2UF2.2uFIC1C513
C0805CAP NP_4_C0805_10UF10uFIC2C8911; C8912
C1206CAP NP_C1206_102/2KV102/2KVIC1C2618
CN3_2R54_DIPCON2_0_CN3_2R54_DIP_GND_GATEGND_GATEIC1J8303
CNN20_2X10_1R27_PCON20_2X10_CNN20_2X10_1R27_P_COCON20_2X10_1R27IC1J7101
CNN30_1R00_FP05SL_VLCD_HITACHI_TX05D99VM1AAA_24_CN30PIN FPC CONIC1J4601
CNN30_1R00_FP05SL_VLCD_HITACHI_TX05D99VM1AAA_25_CN30PIN FPC CONIC3J4701; J4702; J5001
CNN40_2R54_DIPHEADER 28X2_1_CNN40_2R54_DIP_GPGPIO_EXTIC1J9002
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R80_25MHzIC1Y2601
CRY4_3R20X2R50X0R80CRYSTAL_4P_CRY4_3R20X2R50X0R8_137.4MHzIC1Y6101
CRY6_7R00X5R00X1R80D7SP100E00002E_0_CRY6_7R00X5R00D7SP100E00002EIC1U8916
CRY-D3225CRYSTAL-4_0_CRY-D3225_27MHZ-10P27MHz-10ppmIC1Y8501
CRY-D3225CRYSTAL-4_1_CRY-D3225_24M-20PPM24M-20ppmIC1Y8901
DC3_DC_0007_5PDCJACK_0_DC3_DC_0007_5P_DC-0007DC-0007-5PIC1J508
DFN8_2R00X3R00X0R90GAGE-CW2013_DFN8_2R00X3R00X0R90CW2015IC1U23033
DFN9L_3R00X3R00X0R80MOSFET D N 9L_1_DFN9L_3R00X3R00SiZ340DTIC2Q503; Q504
ESD0402DIODE BI_DIR TRIG_ESD0402_ESD54ESD5451NIC13ED2500; ED2501; ED7101; ED7102; ED7103; ED7104; ED8101; ED8501; ED8502; ED8503; ED8504; ED8901; ED8902
F8050FUSE_F8050_JK-SMD200LJK-SMD200LIC1F501
HDMIA19_HDMI_01AHDMI_A_HDMIA19_HDMI_01A_HDMI_AHDMI_AIC1J4501
HDMI_USB_29HDMI_0_HDMI_USB_29_HDMI_USBHDMI_USBIC1J8501
HOLE_C4R10_C6R00HOLE_HOLE_C4R10_C6R00_HOLE_4R10HOLE_4R10IC6H501; H502; H503; H504; H508; H509
HSMT8_3R30X3R30X0R90MOSFET N 8L1_0_HSMT8_3R30X3R30XRQ3E120ATIC7Q501; Q502; Q505; Q8301; Q8302; Q8305; Q8306
IJ3_IRM_3638IR_FT_009_IJ3_IRM_3638_IRM_3638IRM_3638IC1IR9001
IND_303012INDUCTORS OF FERRITE_IND_3030124.7uHIC1L6101
IND_303015INDUCTORS OF FERRITE_IND_3030152.2uHIC1L2601
IND_404030INDUCTORS OF FERRITE_IND_4040304.7uHIC1L900
IND_606020INDUCTORS OF FERRITE_IND_6060202.2uHIC1L501
L0402BEAD_L0402_120R-100M120R-100MIC2FB8301; FB8302
L0603BEAD_L0603_180R-100M180R-100MIC4FB2601; FB2602; FB2603; FB2604
L0603BEAD_L0603_600R-100M600R-100MIC2FB7101; FB7102
L0603INDUCTOR_L0603_BLM18PG221SN1BLM18PG221SN1IC1L8501
L0603INDUCTOR_L0603_BLM18PG181SN1BLM18PG181SN1IC1L8901
L0603INDUCTOR_L0603_1.8UH1.8uHIC1L9001
LED0603LED_LED0603_LED_GREENLED_GREENIC2LED501; LED1401
LED0603LED_LED0603_LED_BLUELED_BLUEIC1LED1402
LED0603LED_LED0603_LED_REDLED_REDIC1LED1403
LGA14L_2R50X3R00X0R86LSM6DS3_2_LGA14L_2R50X3R00X0R86LSM6DS3IC1U8003
MD44_AP6XXX_13RX15RX1R5MODULE_AP6354_MD44_AP6XXX_13RX1AP6354IC1U6101
MIC-SMT2-4020MIC_MIC-SMT2-4020_MIC-4020MIC-4020IC1MIC2500
MLP14_2R50X2R50X0R80USB_FUSB302_MLP14_2R50X2R50X0R8FUSB302MPXIC1U8914
MSOP8_3R00X3R00X1R10AMPLIFIER_PT1505_MSOP8_3R00X3R0PT1505EMSHIC1U7102
OFJ5_DQT_003OPTICAL_JACK_1_OFJ5_DQT_003_DLTDLT1150AIC1J7102
OPLGA6_2R35X1R80X1R00CM3217_1_OPLGA6_2R35X1R80X1R00_CM32181IC1U8005
PCIE12-64JBHF-XXXPCIE_4X_CON_0_PCIE12-64JBHF-XXXPCIE64_SplintIC1J8301
PJ7_PJ3536PHONEJACK_2_PJ7_PJ3536_PJ-3536PJ-3536IC1J7103
QFN24_3R00X3R00X0R90SENSOR_MPU6500_QFN24_3R00X3R00XMPU6500IC1U8002
QFN32_4R00X4R00X1R00_TCHARGER_BQ25700_QFN32_4R00X4R00BQ25700IC1U501
QFN32_5R00X5R00X1R00_TCDCM61001_QFN32_5R00X5R00X1R00_CDCM61001IC1U8302
QFN36LUSX2046_0_QFN36L_USX2064USX2064IC1U8904
QFN40_5R00X5R00X1R00ALC5651_3_QFN40_5R00X5R00X1R00_ALC5651IC1U7101
QFN42_9R00X3R50X0R80_TSWITCH_TS3DV520ERUAR_QFN42_9R00TS3DV520ERUARIC1U4601
QFN48_6R00X6R00X1R00_TETHERNET_RTL8211_QFN48_6R00X6R0RTL8211E-VB-CGIC1U2601
R0201RESISTOR_R0201_100K100KIC2R8924; R8925
R0201RESISTOR_R0201_2M2MIC2R8926; R8927
R0402RESISTOR_R0402_0R0RDISCRETE66R501; R506; R507; R2619; R2620; R2621; R2622; R2623; R2627; R2629; R2632; R2633; R2634; R4602; R4603; R6102; R6104; R6110; R6111; R7104; R7105; R7106; R7122; R7124; R7127; R8002; R8021; R8301; R8302; R8303; R8316; R8317; R8318; R8320; R8321; R8322; R8324; R8509; R8510; R8511; R8514; R8515; R8518; R8519; R8522; R8523; R8525; R8532; R8542; R8543; R9001; R9005; R9006; R9007; R9008; R9009; R9020; R9021; R9023; R89530; R89531; R89534; R89537; R89543; R89548; R89549
R0402RESISTOR_R0402_10K10KIC35R504; R505; R522; R909; R4503; R4504; R4604; R6105; R6106; R6107; R6108; R6109; R7118; R7120; R7123; R8013; R8015; R8020; R8101; R8328; R8329; R8330; R8331; R8337; R8546; R8921; R8930; R8946; R9014; R9016; R9019; R89527; R89540; R89542; R89545
R0402RESISTOR_R0402_2K2KIC5R508; R1401; R1402; R1403; R8103
R0402RESISTOR_R0402_1K1KIC8R509; R7103; R7121; R8332; R8338; R8507; R8524; R8527
R0402RESISTOR_R0402_10R10RIC7R510; R514; R515; R904; R7116; R8102; R9011
R0402RESISTOR_R0402_5.1K5.1KIC1R511
R0402RESISTOR_R0402_47K47KIC4R512; R519; R8335; R8545
R0402RESISTOR_R0402_348K348KIC1R516
R0402RESISTOR_R0402_390K390KIC1R517
R0402RESISTOR_R0402_249K249KIC1R518
R0402RESISTOR_R0402_220K220KIC1R520
R0402RESISTOR_R0402_33K33KIC1R521
R0402RESISTOR_R0402_100K100KIC10R905; R2628; R5001; R5002; R8314; R8315; R8526; R8908; R89541; R89550
R0402RESISTOR_R0402_91K91KIC2R906; R907
R0402RESISTOR_R0402_15K15KIC3R908; R8106; R8933
R0402RESISTOR_R0402_30K30KIC4R910; R7125; R7126; R7128
R0402RESISTOR_R0402_22R22RDISCRETE12R1404; R1405; R4601; R6112; R7117; R8513; R8517; R8521; R8528; R8529; R8530; R8534
R0402RESISTOR_R0402_200K200KIC2R2233; R2237
R0402RESISTOR_R0402_100R100RIC3R2234; R2501; R9015
R0402RESISTOR_R0402_2.2K2.2KIC3R2500; R2504; R7119
R0402RESISTOR_R0402_33R33RIC15R2601; R2610; R6113; R6114; R6115; R6116; R6117; R6118; R7107; R7108; R7109; R7110; R7111; R7112; R7114
R0402RESISTOR_R0402_DNPDNPDISCRETE34R2602; R2605; R2607; R2609; R2612; R2613; R2615; R2617; R2631; R6101; R6103; R8001; R8004; R8012; R8014; R8308; R8309; R8310; R8311; R8323; R8325; R8326; R8327; R8540; R8541; R8928; R8963; R9017; R9018; R9022; R89529; R89546; R89547; R89551
R0402RESISTOR_R0402_4.7K4.7KIC25R2603; R2604; R2606; R2608; R2611; R2614; R2616; R2618; R2624; R2625; R2626; R4501; R4505; R8333; R8334; R8909; R8915; R8923; R89532; R89533; R89535; R89536; R89538; R89539; R89544
R0402RESISTOR_R0402_2.49K2.49KIC1R2630
R0402RESISTOR_R0402_510R510RIC2R2636; R2637
R0402RESISTOR_R0402_1.5K1.5KIC2R4502; R4506
R0402RESISTOR_0_R0402_10K10KIC3R8003; R8009; R8017
R0402RESISTOR_0_R0402_NCNCIC6R8005; R8006; R8008; R8011; R8016; R8019
R0402RESISTOR_0_R0402_0R0RIC4R8007; R8010; R8018; R8901
R0402RESISTOR_R0402_3.3K3.3KIC1R8104
R0402RESISTOR_R0402_6.8K6.8KIC1R8105
R0402RESISTOR_R0402_150R150RIC2R8304; R8305
R0402RESISTOR_R0402_470R470RIC2R8306; R8307
R0402RESISTOR_R0402_56R56RIC2R8312; R8313
R0402RESISTOR_R0402_120K120KIC1R8336
R0402R_0_R0402_22R22RIC1R8502
R0402RESISTOR_R0402_NC/4K7NC/4K7IC1R8505
R0402R_0_R0402_560K560KIC1R8506
R0402R_0_R0402_100R100RIC1R8508
R0402RESISTOR_R0402_4K74K7IC3R8512; R8516; R8537
R0402RESISTOR_R0402_27K27KIC1R8520
R0402RESISTOR_R0402_2K%12K%1IC1R8531
R0402RESISTOR_R0402_NCNCIC1R8533
R0402RESISTOR_0_R0402_1.5K1.5KIC1R8535
R0402RESISTOR_R0402_NC/0RNC/0RIC1R8536
R0402RESISTOR_0_R0402_2K22K2IC1R8538
R0402RESISTOR_0_R0402_1K1KIC1R8539
R0402RESISTOR_0_R0402_12K%112K%1IC1R8902
R0402RESISTOR_0_R0402_1M1MIC1R8905
R0402RESISTOR_4_R0402_10K10KIC2R8906; R8907
R0402RESISTOR_0_R0402_100K100KIC4R8910; R8911; R8912; R8913
R0402R_R0402_5.1R5.1RDISCRETE4R8916; R8917; R8918; R8919
R0402RESISTOR_R0402_150K150KIC1R8944
R0402RESISTOR_R0402_75R75RIC1R9012
R0402RESISTOR_R0402_1.65M1.65MIC1R9013
R0402RESISTOR_R0402_267K267KIC1R9025
R0603RESISTOR_R0603_10R10RIC1R2635
R0603RESISTOR_0_R0603_0R0RDISCRETE2R8903; R8904
R1206CON2_1_R1206_CON2CON2IC1J7104
R1206RESISTOR_R1206_0.01R0.01RIC2R502; R513
R1210RESISTOR_R1210_2R2RIC1R503
RCAPHONE_RCA_PHONEPHONEIC1J9003
RJ45_HR911130CHR911130C_0_RJ45_HR911130C_HR91HR911130CIC1J2601
SMT2_6R00X3R50X4R20KEY_2PIN_SMT2_6R00X3R50X4R20_MAMASROMIC1SW2
SOD_123DIODE ZENER1_SOD_123_BZT52C3V3BZT52C3V3IC1D8901
SOD_323DIODE_SOD_323_B5819WSB5819WSIC2D4501; D4502
SON10_2R50X1R00X0R50ESD_TPD4E05U06_SON10_2R50X1R00XTPD4E05U06IC8U4501; U4502; U4503; U8504; U8505; U90004; U90005; U90006
SOT_23DIODE DOUBLE F_SOT_23_BAT54SBAT54SIC1D9001
SOT_23NPN_SOT_23_S8050S8050IC4Q506; Q507; Q8303; Q8504
SOT_23NPN_SOT_23_2SC27122SC2712IC1Q8501
SOT_23MOSFET P_SOT_23_WPM2341-3/TRWPM2341-3/TRIC1Q8505
SOT_23ESD_ESDA6V8UL_SOT_23_ESD5302FESD5302FIC9U1402; U8902; U8903; U8906; U8907; U8909; U90007; U90008; U90009
SOT_23SENSOR_HALL_SOT_23_HAL248TWCLHAL248TWCLIC1U8004
SOT_23_5DS8008_4_SOT_23_5_PT5108E23E-33PT5108E23E-33IC1U8303
SOT_23_5SWITCH_SY6280_SOT_23_5_SY6280AASY6280AACIC4U8901; U8905; U8913; U90010
SOT_23_5LDO_TT2102_SOT_23_5_TT2102BTT2102BIC1U8911
SOT_23_5SWITCH_SY6280_SOT_23_5_SY6288CASY6288CAAIC1U8912
SOT_23_5DS8008_4_SOT_23_5_PT5108E23E-18PT5108E23E-18IC1U23031
SOT_323MOSFET N_SOT_323_WNM2021-3/TRWNM2021-3/TRIC8Q237; Q4501; Q4502; Q4503; Q8304; Q8307; Q8502; Q8503
SSOP28_10R20X5R30X2R00INTERFACE_FT232RL_SSOP28_10R20XFT232RLIC1U1401
SW3-JT601-103AB2RA22KKFR0FL_D1PSW3_BIC1S501
SW6_10R00X10R00X8R80KEY_0_SW6_10R00X10R00X8R80_VOL+VOL+/RECOVERYIC1U8101
SW6_10R00X10R00X8R80KEY_0_SW6_10R00X10R00X8R80_VOL-VOL-IC1U8102
SW6_10R00X10R00X8R80KEY_0_SW6_10R00X10R00X8R80_ESCESCIC1U8104
SW6_10R00X10R00X8R80KEY_0_SW6_10R00X10R00X8R80_MENUMENUIC1U8105
SW6_10R00X10R00X8R80KEY_0_SW6_10R00X10R00X8R80_POWEPOWER_KEYIC1U8917
TDFN10_2R00X2R50X0R85SI50122_TDFN10_2R00X2R50X0R85_SSi50122IC1U8301
TP_0R50TP_TP_0R50_TP_0.5TP_0.5IC11TP501; TP502; TP4601; TP7101; TP7102; TP7103; TP7104; TP9002; TP50262; TP50264; TP50265
TP_1R00TP_TP_1R00_TP_1.0TP_1.0IC9TP8301; TP8302; TP8303; TP8304; TP8305; TP50263; TP50266; TP50267; TP50268
TSOP6_3R00X3R10X1R10LM1086_2_TSOP6_3R00X3R10X1R10_NNL27WZU04IC1U8502
TSOT_23_8DCDC_MP1495_TSOT_23_8_MP1495SMP1495SIC1U900
UB1112C-8FDH-4FCON4_0_UB1112C-8FDH-4F_USB_HOSTUSB_HOSTIC2J8901; J8902
USB20MICRO5_WKD_1USB20_MICRO_USB20MICRO5_WKD_1_UUSB20_microIC1J1400
USB30A9_25R70X7R32X13R85USBA_0_USB30A9_25R70X7R32X13R85USB_A_30IC1CON8901
USB_TYPEC_115H0USB31_TYPE_C_USB_TYPEC_115H0_USUSB_TYPEC_115H0IC1J8903
VFLGA12_2R00X2R00X1R00LIS3MDL_0_VFLGA12_2R00X2R00X1R0LIS3MDLIC1U8001
XI60_PIN2CON2_1_XI60_PIN2_CON2CON2IC1J8302
附件:
pcb文件和原理图
游客,如果您要查看本帖隐藏内容请回复
! R' O! S1 H& ?5 l6 J4 m9 @
9 x2 h0 P+ h$ T3 D+ o, b. }
推荐
发表于 2020-4-28 10:46 | 只看该作者
BYF 发表于 2020-4-28 10:41
9 w) J9 I6 E/ {# B2 U& o3 u1 Cpcb文件和原理图什么格式?
" p1 \" D( t7 {8 C. V' k
就一块底板,没有RK3399芯片
2 L0 N& ]9 C+ g& L5 {( ^
    慵懒
    2025-9-26 15:01
  • 签到天数: 195 天
    [LV.7]常住居民III
    推荐
    发表于 2020-12-19 08:49 | 只看该作者
    下载你的文件,欣赏下你的作品- R8 X) e) E0 O/ _! Q: Z
    推荐
    发表于 2020-8-5 18:44 | 只看该作者
    谢谢分享,学习一下学长的设计! k4 F& I* d9 D/ \, G) d7 b: }* _
    2020-3-4 15:29
    发表于 2020-4-3 11:28 | 只看该作者
    怎么没人关注呢?
    难过
    2023-12-27 15:52
  • 签到天数: 405 天
    [LV.9]以坛为家II
    发表于 2020-4-19 17:04 | 只看该作者
    这个是厂家提供的吗?
    3 P' {+ x0 f  ^, v( B
    发表于 2020-4-28 10:41 | 只看该作者
    pcb文件和原理图什么格式?
    BYF
    就一块底板,没有RK3399芯片  详情 回复 发表于 2020-4-28 10:46
    发表于 2020-5-18 15:58 | 只看该作者
    好东西啊,谢谢
    2020-4-9 15:45
    发表于 2020-7-3 17:17 | 只看该作者
    kkkkkkkkkkkkkkk
    , |0 T/ I+ A% j
    发表于 2020-8-5 22:39 | 只看该作者
    gsdgsdgsdgsd
    % L$ L- J+ s/ W) U
    13#
    发表于 2020-8-24 16:26 | 只看该作者
    学习学习
    “来自电巢APP”
    14#
    发表于 2020-12-21 13:52 | 只看该作者
    看一看 瞧一瞧
    15#
    发表于 2021-5-21 13:46 | 只看该作者
    想用这个板上的MXM接口封装1 D+ H8 h0 e# F, m; p6 I, P$ N
    GMT+8, 2025-10-11 07:26 , Processed in 0.187500 second(s), 33 queries , Gzip On.
