查看: 463|回复: 1
[Allegro15.5][6层]OMAP3430+ TFP410+TWL4030 pcb文件
发表于 2019-12-12 16:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 ssccc5597 于 2019-12-12 16:36 编辑 " h, Y9 {2 N8 A; Z; o
- i# C9 r2 x* W; W, n( h9 ^+ S; e) d; b! X/ z
3 {+ X# d. ]& r
文件描述:
' Q+ H6 _: ~( B
9 `% b: r  q) y' E/ M
1. 软件版本:allegro15.5
2. 层数:6层
3. 用到的主要芯片:OMAP3430+ TFP410+TWL4030
4.pcb尺寸:3.1*3.0 MM
% v" k5 S& L; u% Z/ X1 [/ q
作品截图如下:
9 a+ K" I; R5 w% F+ i6 n; _
顶层截图:
2 H- F9 S6 \. _. L; `
3 p6 O8 y. z2 m6 k9 u! {
底层截图:
  C! d- v; ^% {$ L
' n8 L. k$ x- u/ |+ l* U% y
" l) C( v2 r; L8 \" y! N- Z# z
全层截图:
4 ]6 m1 f, F: D7 N. f( t4 {
$ f- k- u' R$ v2 I; h5 X" s* o5 _/ {7 Z& ]8 f' v
BOM:
3 S0 F+ t# b4 C5 i+ M$ i
SYM_NAME
COMP_DEVICE_TYPE
COMP_VALUE
COMP_CLASS
QUANTITY
REFDES
名称
类型
属性
类别
数量
位号
BGA2X4-YZP
TXB0102_1_BGA2X4-YZP_TXS0102 (Y
TXS0102 (YZP)
IC
U9
BGA2X4-YZP
TXB0102_0_BGA2X4-YZP_TXS0102 (Y
TXS0102 (YZP)
IC
U11
BGA5X5-4MM
USB3319_0_BGA5X5-4MM_USB3319 (C
USB3319 (CSP)
IC
U7
BGA515-CBB
OMAP3430_ES2_5.0_BGA515-CBB_OMA
OMAP35xx_ES2.0
IC
U3
BGA-ZXN-209
TWL4030_6_BGA-ZXN-209_FBGA209_1
FBGA209_15-74_280x280
IC
U5
C402-25
CAP_0402_0R1UF_X7R_10V_C402-25_
0.1uF
IC
81
C1; C3; C4; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C24; C25; C26; C27; C28; C29; C30; C31; C32; C33; C34; C35; C36; C37; C38; C39; C40; C41; C42; C43; C46; C50; C73; C74; C75; C78; C79; C80; C81; C82; C84; C86; C87; C88; C89; C90; C91; C92; C93; C94; C96; C98; C99; C100; C103; C105; C107; C110; C111; C113; C114; C115; C116; C117; C118; C119; C120; C121; C122; C123; C124; C125; C126
C402-25
207-0229-000_0_C402-25_DISCRETE
150pF
DISCRETE
C5; C6
C402-25
100NF-16V X7R_2_C402-25_DISCRET
0.1uF
DISCRETE
C7; C8
C402-25
CAP_0402_0R1UF_X7R_10V_C402-2_1
0.22uF
IC
C44; C45
C402-25
CAP_207-0009-000_C402-25_DISCRE
100PF
DISCRETE
C51; C60; C61; C62; C63; C70
C402-25
0402_0R01UF_X7R_16V_10_C402-25_
0.1uF
IC
C52
C402-25
CAPACITOR NON-POL_C402-25_100PF
100pF
IC
C58; C59
C402-25
CAP_0402_0R1UF_X7R_10V_C402-2_2
0.1uF,CER
IC
C64; C65
C402-25
CAP_207-0009-000_C402-25_DISC_1
22PF
DISCRETE
C68; C69
C402-25RD
0402C-47P_1_C402-25RD_47PF
47pF
IC
C56; C57; C66; C67
C603-35X45
7343L_100UF_TANT_10V_10_C603-35
1uF
IC
C2
C603-35X45
0402_0R01UF_X7R_16V_10_C603-35X
1uF
IC
C47; C48; C49
C603-35X45
207-0000-075_1UF_C603-35X45_DIS
1UF
DISCRETE
C55
C603-35X45
207-0000-075_0_C603-35X45_DISCR
1UF
DISCRETE
C71
C1210-70X102
1812-X5R-10V-47UF_C1210-70X102_
47uF,CER
IC
C53; C54
C1210-70X120
C_47UF25V_POL_3528_C1210-70X120
C47uf, 25V
IC
C101
C3216-35X55
0603C-2U2_0_C3216-35X55_2.2UF
2.2uF
IC
C72
C3216-35X55
10UF-10V-293D-C_1_C3216-35X55_D
10UF
DISCRETE
C76; C77; C83; C85; C95; C97; C112
C3216-35X55
CAP3528
4.7uF
DISCRETE
C102; C104; C106
CONN3-PWR-PJ102A
CONN JACK PWR_1_CONN3-PWR-PJ102
PJ-002A
IC
J1
CONN4-DIN-RT
SVIDEOCONN_0_CONN4-DIN-RT_SVIDE
SVideoConn
IC
P4
CONN-6N1-MMC-SD
MMC4_2.0_CONN_CONN-6N1-MMC-SD_M
MHC-W21-601
IC
P8
CUI-SJ1-3513-SMT
PHONOJACK STEREO-R_CUI-SJ1-3513
PHONOJACK STEREO-R
IC
P5; P6
DBV6-27X39-6
SN74LVC2G07DCKR_DBV6-27X39-6_IC
SN74LVC2G07DCKR
IC
U4
DGN-16X60
TPS2061_2_DGN-16X60_TPS2061 (DG
TPS2061 (DGN)
IC
U6
DRB8-14X33-PAD
TPS73701_0_DRB8-14X33-PAD_TPS73
TPS73701
IC
U2
F603-41X39
DIODE BI-DIR TRIG_F603-41X39_PG
PGB0010603MR
IC
D1; D15
F603-41X39
DIO_V5.5MLA0603_F603-41X39_PG_1
PGB0010603MR,DNI
IC
D2
F603-41X39
DIO_V5.5MLA0603_F603-41X39_PGB0
PGB0010603MR
IC
D3; D4; D13; D14
F603-41X39
DIO_V5.5MLA0603_F603-41X39_DIO_
DIO_V5.5MLA0603
IC
D8; D9; D10; D11
HDMI-SMT-W-FLANGE
HDMI_CONN_3_HDMI-SMT-W-FLANGE_H
HDMI_Conn
IC
P10
IND603-24X32
INDUCTOR_IND603-24X32_FERRITE,
FERRITE, MMZ1608R301A
IC
L4; L5; L6
IND-LPS3010
INDUCTOR 1.0UH_IND-LPS3010_1UH
1uH
IC
L2
IND-LPS3015
INDUCTOR 1.0UH_IND-LPS3015_1UH,
1uH,2A
IC
L1; L3
JUMP2-6040
JUMPER_0_JUMP2-6040_JUMPER
JUMPER
IC
J2
JUMP2X5-6040
HEADER 5X2_1_JUMP2X5-6040_HEADE
HEADER 5X2
IC
P9
JUMP2X7-6040-K6
JUMP_0_JUMP2X7-6040-K6_IO_76385
76385-407LF
IO
P2
JUMP2X14-6040-1
HEADER 14X2_JUMP2X14-6040-1_HEA
HEADER 14X2
IC
J3
LED1206-59X59
LED_LTST-C150GKT_0_LED1206-59X5
LTST-C150CKT
DISCRETE
D5; D6; D7; D12
PAP64-12X70
TFP513_1_PAP64-12X70_TFP410
TFP410
IC
U8
POLYSW200-5638-310
PTC_POLYSW200-5638-310_RXEF010
RXEF010
IC
RT1
PWP14-12X70
TPS21XX_1_PWP14-12X70_TPS2141
TPS2141
IC
U1
R402-25RD
RES_0_R402-25RD_DISCRETE_56.2K,
56.2K,0603
DISCRETE
R7
R402-25RD
RES_272-0065-000_R402-25RD_DISC
33
DISCRETE
R10
R402-25RD
RES_0_R402-25RD_DISCRETE_10K_1%
10K
DISCRETE
23
R11; R12; R13; R14; R36; R49; R51; R54; R55; R56; R57; R58; R59; R60; R61; R62; R63; R66; R82; R98; R101; R102; R109
R402-25RD
RESISTOR_R402-25RD_10K
10K
IC
R15; R16; R22; R37
R402-25RD
RESISTOR_R402-25RD_100K
100K
IC
R17; R18; R19; R20; R21
R402-25RD
RES_272-0065-000_R402-25RD__1.6
1.65K
IC
R27; R28
R402-25RD
RES_0_R402-25RD_DISCRETE_33_1%
33
DISCRETE
R38; R40; R42
R402-25RD
R_R402-25RD_10K
10K
IC
R39
R402-25RD
0402_4R7K_1_R402-25RD_DISCRETE_
4.7K
DISCRETE
R41; R45; R47
R402-25RD
272-0067-000_0_R402-25RD_DISCRE
33
DISCRETE
R44; R46
R402-25RD
RES_0_R402-25RD_DISCRETE_1K_1%
1K
DISCRETE
R96; R99
R402-25RD
RES_0_R402-25RD_DISCRETE_4.7K_1
4.7K
DISCRETE
R97; R100
R603-35X45
RESISTOR2_R603-35X45_0,0603
0,0603
IC
R1
R603-35X45
RESISTOR_1_R603-35X45_620K,1%,0
620K,1%,0603
IC
R3
R603-35X45
RESISTOR_2_R603-35X45_200K,1%,0
200K,1%,0603
IC
R4
R603-35X45
RES_0_R603-35X45_DISCRETE_10K,0
10K,0603
DISCRETE
8
R5; R29; R30; R31; R32; R33; R64; R65
R603-35X45
RES_0_R603-35X45_DISCRETE_22.6K
22.6K,0603
DISCRETE
R8
R603-35X45
0805_200_1_V_R603-35X45_8,200,6
8,200,603
IC
R9
R603-35X45
RES_272-0065-000_R603-35X45__0_
0
IC
R23; R26
R603-35X45
0805_200_1_V_R603-35X45_200.060
200.0603
IC
R34; R35
R603-35X45
RES_0_R603-35X45_DISCRETE_0_1%
0
DISCRETE
R43
R603-35X45
RES_0_R603-35X45_DISCRETE_820_5
820
DISCRETE
R48
R603-35X45
R_R603-35X45_820,603
820,603
IC
R50
R603-35X45
0402_10K_1_R603-35X45_DISCRETE_
8.064k
DISCRETE
R52
R603-35X45
RES_0_R603-35X45_DISCRETE_510_1
510
DISCRETE
R95
R603-35X45
RES_0_R603-35X45_DISCRETE_1K,06
1K,0603
DISCRETE
R103; R104; R105; R110
R603-35X45
RES_0_R603-35X45_DISCRETE_0,DNI
0,DNI
DISCRETE
R106; R107
R603-35X45
RES_0_R603-35X45_DISCRETE_0.DNI
0.DNI
DISCRETE
R108
R805-35X60
RES_0_R805-35X60_DISCRETE_1.0,0
1.0,0805
DISCRETE
R6
RPAK16-10X25-2HV
RPAK_RPAK16-10X25-2HV_DISCRETE_
10
DISCRETE
RP1; RP2; RP3; RP4
SC88
RN1907_SC88_RN1907
RN1907
IC
Q1
SW4-6040-PUSH
SW_KT11P2JM_4_SW4-6040-PUSH_DIS
B3F-1000
DISCRETE
S1; S2
TP1-20SMT
TESTPT1_0_TP1-20SMT_TESTPT1
TESTPT1
IC
15
TP3; TP4; TP7; TP8; TP9; TP10; TP11; TP12; TP13; TP14; TP19; TP20; TP21; TP22; TP23
TP1-20SMT
TESTPT1_0_TP1-20SMT_TESTPT2
TESTPT2
IC
TP5; TP6
TP1-8040
TESTPT1_0_TP1-8040_TESTPT1
TESTPT1
IC
TP1; TP2
TSSOP16-14X70
MAX3221_1_TSSOP16-14X70_SN65C32
SN65C3221EPW
IC
U10
USB-MINI-SMT-NUM
MINI-USB-AB-SOCKET_1_USB-MINI-S
UX60-MB-5ST, miniUSB Type AB
IC
P1
USB_A_SH
CONN_54819-0578_2_USB_A_SH_IO_U
USB-A Conn. - 87520-xx1xx
IO
P7
XTAL2_FX135
QUARTZ-32KHZ-CM200S_0_XTAL2_FX1
32KHz,FX135
DISCRETE
Y2
XTAL4-47X51-ECXO
OSC_230-0067-000_0_XTAL4-47X51-
ECLIPTEK_26MHZ
IC
Y1A
XTAL4-SG210
OSC_230-0067-000_0_XTAL4-SG210_
ECLIPTEK_26MHZ
IC
Y1
附件:
pcb文件如下:
游客,如果您要查看本帖隐藏内容请回复
: c  z% W) Z* M# l
GMT+8, 2025-9-13 07:46 , Processed in 0.171875 second(s), 28 queries , Gzip On.
