TA的每日心情 | 开心 2019-11-29 15:37 |
签到天数: 4 天 [LV.2]偶尔看看I
元器件降额速查表 元器件种类 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 在按照芯片设计要求考虑了散热方式以降低结温的前 提下,最高使用环境温度下,表面温度应不大于芯片结 温-30 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1.3/1.8/2.5/3.3/4.5/6.5/9.2/13.0 | | | | 17.0/23.0/33.0/44.0/60.0/81.0 |
双极型数字电路降额准则 HP电压降额标准 器件型号 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 不同功率下的峰值电压:1/6 W-200(150)V;1/4 W-250V;1/2 W-350 V;1W-350 V;2W-350V;3W-500 V;5W-500V | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 85 | | | | | | | | | | | | | | | | | | Electrolytic (85° C, 2000 h) | | | 80 | | | 60 | | | 95 | | | 70 | Electrolytic (105° C, 2000 h) | | | 80 | | | 60 | | | 95 | | | 70 |
Component Typ | | | | | | | | | | | | 80 | | | Tj min. = 150°C Note: Tj to Tcase has to be calculated for verification in any case | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 85 | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 90 | | | 100 | [tr][/tr]8 ~% A6 P0 Z5 N; t9 n$ X- p
DC-DC booster
' z5 p3 \* k2 w' d& R7 Q' U2 qMOSFET | [tr][/tr]% D, C3 T' d! [1 |( }& p
| [tr][/tr]! g j! }- d- T6 l8 U' }1 x
C. g* ?" `9 ~9 e
7 u# M% n6 ^0 v* d1 T. p |
