目录( I, I' k- y; R' b0 ]
1 方案比较与论证..............................................................................................................................1) v5 P) D( u' t6 G# m- n' R! G
1.1 AC-DC 主回路拓扑............................................................................................................. 1% j1 P+ i M) k4 z+ t' }# D
1.2 PFC 控制电路方案论证...................................................................................................... 2& c* b1 V1 v' T% D, K+ x5 c
1.3 数据采集部分.......................................................................................................................3
. m# w$ Y# D7 x- Z: n! a4 ]1.4 系统总体框图.......................................................................................................................3 a0 V& ^9 F3 K1 `; h7 {$ m' O
2 系统理论分析与计算......................................................................................................................4
# I. H3 ?9 ]8 G( Z! l% J! N8 R2.1 提高效率的方法...................................................................................................................4
. I( F+ I# I/ x4 N: Y5 b: E2.2 功率因数调整方法...............................................................................................................4
q+ |& R+ X: m$ ~( M2.3 稳压控制方法.......................................................................................................................56 K+ H/ o4 ^0 ^* h% @
3 电路设计及参数计算......................................................................................................................52 O9 L1 [1 j( W
3.1 主回路与器件选择...............................................................................................................5! T T5 e& g0 q
3.2 功率因数校正控制电路设计与参数计算.......................................................................... 5- ^' N/ A$ t+ w7 `2 t4 z% H
3.3 过流保护...............................................................................................................................6
8 W$ C, f* M! v0 }( R3.4 特色设计..............................................................................................................................6
: ~# u8 ]% g* ^0 |" Q7 k, H; A4 软件设计..........................................................................................................................................6
# T0 W! B M1 E+ p! o* o5 系统测试结果及分析......................................................................................................................7
, I6 @5 }; `" z0 e5.1 测试使用的仪器...................................................................................................................7
, o% H& k) ?2 `/ `! X# r, _& a5.2 测试方法........................................................................... ..................................................8& [1 ] j/ K, V) S8 a! V
5.3 测试数据..............................................................................................................................8- Q+ \# _0 H. @' ? \: p
5.4 测试分析与结论...................................................................................................................9, v* M8 f( U4 r; Y: L* m: Q
6 参考文献........................................................................................................................................10
% V/ q% m* Z$ R" c! I附录1:电路原理图........................................................................................................................10% W W* m# ~' \, J# ?2 r$ l
单相AC-DC 变换电路(A 题)
" g: }# \" S4 J; c8 x摘要& I% ~- q% h/ X6 |: z
本系统采用Boost PFC 变换器实现高功率因数AC-DC 的变换,采用基于单周期PFC/ [5 i/ `. \3 U0 q7 ~. }
控制芯片IR1150。实现系统接近1 的功率因数。同时系统实现稳定的输出直流电压,负7 K( g/ d7 A( ^. I( D2 B
载调整率SI,电压调整率SU 均小于0.5%。系统具有软硬件双限流保护及报警功能,同
; y0 A2 P2 X* u$ B, ?3 A( e+ a时具有功率因数测量功能及实现根据设定自动调整功率因数。数字电路以单片机5 H# b7 i( s' L6 b
MC9S12XS128 为核心,实现AD 采样,参数设定显示,按键数字给定。本系统功能完善,
6 c3 C$ F8 e$ _3 T4 B. n达到了各项设计指标。" f) V6 {0 c6 N. p |% \) H4 K
/ t3 L, d$ S$ C* ]' Q S3 d
: E( k' f8 g2 h$ G
) g/ H$ ]: a/ [4 Z. ^1 T
