的设计原理图、元器件列表及PCB元件布局图。
3 N" ]* u- @7 x1 s# n& T, J2 f+ N. B8 w2 P- ^/ F% V
The TPS22967 is a small, ultra-low RON, single channel load switch with controlled turn on. The device contains an N-channel MOSFET that can operate over an input voltage range of 0.8V to 5.5V and can support a maximum continuous current of 4A. The switch is controlled by an on/off input (ON), which is capable of inte
RFacing directly with low-voltage control signals. In the TPS22967, a 225-Ω pull-down resistor is added for quick output discharge when switch is turned off.
1 u X! ? P8 V0 \& l+ X
2 x! v( U5 R% T& p5 p! WThe TPS22967 is available in a small, space-saving 2mm x 2mm 8-pin SON package (DSG) with integrated thermal pad allowing for high power dissipation. The device is characterized for operation over the free-air temperature range of –40°C to 85°C.
* C" }9 i5 G, w) ]$ O9 \
. t, Y2 i* V/ t$ PTPS22967主要特性:
+ `- ]; d! d# A. c2 C! `
/ f7 H! F& v' N! t
Integrated Single Channel Load Switch
; r2 R7 h# ], K. X! Q0 KInput Voltage Range: 0.8V to 5.5V
: T- ]: |9 c6 U2 z g4 CUltra low RON Resistance
* x8 h- {# k# V2 BRON = 22mΩ at VIN = 5V (VBIAS = 5V)
5 Y7 J8 w$ M+ f5 o5 q2 O
RON = 22mΩ at VIN = 3.6V (VBIAS = 5V)
. {) N- \! D' m0 o1 H
RON = 22mΩ at VIN = 1.8V (VBIAS = 5V)
; G3 f/ @9 n$ }8 Q' d+ v7 w; `% R+ @
4A Maximum Continuous Switch Current
% I. Z: e$ ?6 ^. a1 yLow Quiescent Current (50µA)
- O4 u0 ~# L7 pLow Control Input Threshold Enables Use of 1.2V/1.8V/2.5V/3.3V Logic
; R' B) I1 V7 G" Z
Configurable Rise Time
0 L1 i5 t. f2 j0 FQuick Output Discharge (QOD)
7 R5 [5 H1 D8 m K) @1 u
SON 8-pin Package With Thermal Pad
0 a) I4 E3 y3 ~# l
ESD Performance Tested per JESD 22
+ @' J/ O- P E. d1 Z' X
2KV HBM and 1KV CDM
: Q1 E& t5 a( s* h; S6 m& r8 I
; _/ L& e9 V1 f* l1 ~+ X! KTPS22967应用:
; T- A9 U4 \: H* `5 |9 W. [8 O6 W+ X' S5 r
Ultrabook
4 M* M6 | S2 y, s
Notebooks/Netbooks
0 q( c- _0 V* ?: s
Tablet PC
: F9 m6 e- ^/ \8 G; \$ ^Consumer Electronics
# S8 Z4 K& z! e1 a' D$ `' _
Set-top Boxes/Residental Gateways
3 s; {" [/ E/ E
, w6 s2 A8 m( u u. o) ~, m) p% U
TPS22967方案介绍:
% K. a& ~0 _% x5 U% i8 H
! `5 ~7 Z5 C6 G1 y
The TPS22967EVM-023 evaluation module contains a single channel, ultra low ON resistance, 4-A load switch with controlled turn-on and adjustable rise time。
' T: m# g! |* W, D' v
, h2 Y2 e' ^9 P+ \' Q( X8 }8 \3 ]
TPS22967方案原理图:
! v& D( ~; F" R$ C Y
# m9 F' x2 Z: ]9 K# D9 f
图2. TPS22967方案原理图
$ r: v+ I& ~* _8 c* G; ]- }
TPS22967方案材料清单:
$ Y7 X1 Z" G* e' u/ J5 k; Y- r4 x* H% x+ L j% K+ l) M# i% e
( `8 Q4 }6 |# G9 | F3 _8 m; u, j$ z
PCB元件布局图:
' @- F3 E5 T: \ Y; q! T
' ^' s& r1 G4 S6 g; U3 h4 \% V
6 V d) D. p$ m7 t
/ q% R" N& e$ U, o1 n1 I4 G% f& g
- L+ N E2 o7 J# L1 j7 S9 U$ {
9 d7 W; _; l( g& c$ q![]()
