26# zwp98
6 L) w# }" b/ Y; J$ N导进去什么都没有,用viewlog查看提示以下错误,是怎么回事啊?
9 j# h% S$ H3 q5 c: W# a! m' R
7 P2 X$ a# v8 U( e- ^* ?Cadence Design Systems, Inc. netrev 15.5 Thu Jul 09 11:25:57 2009
, `& [" ?% g! L( e$ ](C) Copyright 2002 Cadence Design Systems, Inc.
. ~. w" X' S( }3 p+ u; g0 Q! f------ Directives ------- E# r; I' q$ y+ p1 ^9 K
RIPUP_ETCH FALSE;
- W7 C4 Z6 S$ F ^% E) bRIPUP_SYMBOLS ALWAYS;
) l @9 h/ i! V, I* V. \# rMISSING SYMBOL AS ERROR FALSE;, u" A C$ u0 D' e+ O V0 \% ^
SCHEMATIC_DIRECTORY 'C:/Documents and Settings/Administrator/桌面/现场信息记录仪资料09.4.19/Project';# Q4 a7 K* H, }' i: g
BOARD_DIRECTORY '';/ Z8 u2 F, \- m( O
OLD_BOARD_NAME 'C:/Documents and Settings/Administrator/桌面/现场信息记录仪资料09.4.19/Project/cmos原理图/allegro/mt9d111.brd';4 o6 M# L9 I& V" y/ Z3 u+ ?
NEW_BOARD_NAME 'C:/Documents and Settings/Administrator/桌面/现场信息记录仪资料09.4.19/Project/cmos原理图/allegro/mt9d111.brd';
$ G5 `8 c E9 y9 f: KCmdLine: netrev -$ -5 -i C:/Documents and Settings/Administrator/桌面/现场信息记录仪资料09.4.19/Project -y 1 C:/Documents and Settings/Administrator/桌面/现场信息记录仪资料09.4.19/Project/cmos原理图/allegro/#Taaaaaa03240.tmp
( `$ B; C" g" l" v4 s------ Preparing to read pst files ------
3 |7 }) M6 g! R" I
; ]7 R- _1 H& N: e, @3 K#1 ERROR(24) File not found% S) s! @/ X. [
Packager files not found- o% N' d. H- H- S" v) a1 v
#2 ERROR(102) Run stopped because errors were detected
U1 p8 c, z5 X5 |2 Tnetrev run on Jul 9 11:25:57 2009
% N, i( @8 R% o COMPILE 'logic'
& [& h4 w. _0 l% i- |& d CHECK_PIN_NAMES OFF3 t E2 A* C7 r! `! t* A/ K" M; p8 U
CROSS_REFERENCE OFF
* D1 p$ n1 V+ K9 S" C FEEDBACK OFF+ h1 g& ]3 W9 g2 q ?
INCREMENTAL OFF
' v+ ?6 ?4 `& `3 k# ] INTERFACE_TYPE PHYSICAL; z# f o( j( h4 E( A
MAX_ERRORS 500) p6 p N# D) Q8 L8 Q
MERGE_MINIMUM 5 F; g5 c4 t1 _9 Q9 a0 e/ ?: M1 W4 w
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
" ~0 P5 I1 L: \1 ~" N$ W5 O" E8 K NET_NAME_LENGTH 24# N8 w6 G6 m. q% F% J
OVERSIGHTS ON& ?3 e0 w1 ^/ I ^
REPLACE_CHECK OFF
! a7 b. N" Y, D$ I' x SINGLE_NODE_NETS ON
9 E/ c; X( o" M! `+ H SPLIT_MINIMUM 0
5 i4 I3 i0 e1 C$ K- W+ z' L b. h SUPPRESS 20' C) D( M4 {+ i' T8 g. ~0 _2 Z
WARNINGS ON
) {5 [0 \( U2 \' {2 L 2 errors detected
7 ?/ d+ S4 m9 D& J+ F( A No oversight detected; l# E( f( g/ |
No warning detected. {5 K5 ?3 v- r( `. `# f
cpu time 0:00:04
$ x# }( R4 [; U3 p- R9 X5 Relapsed time 0:00:00 |
