查看: 970|回复: 1
MT8382/MT8127/MT8163处理器相关参数比较
发表于 2019-11-28 16:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                                      MT8382                                 MT8127                                MT81631 C2 q8 l% A8 }) D* _# D; C6 D! m
+ z% v( M4 l* g' e. W% U! y; C
2 J9 U/ c, E+ T6 c$ |: s) e) d& EApps CPU          4x Cortex-A7, 1.3GHz            4x Cortex-A7, 1.3GHz             4x Cortex-A53, 1.3GHz
- b) b/ r1 ~9 G, w3 Y6 W
3 u" }1 ?9 l- _, b" M  I0 x4 E' \
3 k9 m5 X: T9 }4 `/ y+ x+ X+ a1 G5 RMemory      PCDDR3/LPDDR2 1066Mbps     PCDDR3/LPDDR3 1333Mbps    PCDDR3/LPDDR3 1600Mbps
  [5 E% K# W: |: _" y        /LPDDR2 1066Mbps                 /LPDDR2 1066Mbps
& A7 D: w& v/ U/ `% Q- X
: u4 w& N5 c: K
# V- ]5 h) ?$ J/ a5 {: X
Camera               13MP ISP                                   13MP ISP                                  13MP ISP
) B9 G" b& O! Z! N3 `3 B0 R$ M7 e6 _7 h# }
1 O' m# B8 t7 s: K% k6 qVideo                  1080p 30fps                             1080p 30fps                                  1080p 30fps
* F1 n+ K. |2 |5 U7 fDecode                                                     HEVC / MPEG-4 / H.264 / VC-1       HEVC / MPEG-4 / H.264 / VC-1$ z1 A6 G* V! L4 R9 `1 x/ e
# I+ A8 g4 T; r5 I- T, ^3 L
5 g' C1 ?2 A1 T: a# S1 a
Graphics          ARM Mali400-MP2               ARM Mali450-MP4                          Mali-T720 MP2
" Y3 v. g( m5 }7 j                               500MHz                             416 MHz                                           @416MHz; D2 N5 c. @: ^* Z- j* x+ W
                       53.25MT/s, 1000MP/s            90Mtri/s,1.6Gpix/s                            92Mtri/s, 0.8Gpix/s- W' m7 I' O9 z/ @; _3 M
  s& `7 h3 _5 N' ]" R+ _; V% o
# M0 r0 ~$ F5 m" @) E$ X- E
Display                1280x800                                     1280x800                                     1280x8005 Z4 p5 u) ~+ L. {
+ c8 s5 y5 p4 K" y! s, y
: ?+ J/ e0 V$ [2 y
Modem            HSPA+ Rel. 8                                    NA                                                NA) E; a6 x2 z9 F9 I' ]2 L8 V5 n
                        21Mbps/5.76Mbps, j" ^) d1 b  x0 A6 S1 }
/ H5 w' J/ A2 a% [2 {, z" \1 M
; u5 z0 t2 T+ yConnectivity         Integrated                                Integrated                                    Integrated( [, }' k) ]4 ^
                       Wi-Fi abgn/BT/FM/GPS         Wi-Fi abgn/BT/FM/GPS              Wi-Fi abgn/BT/FM/GPS
4 s2 s7 z0 d6 E' s$ V( @
$ O7 F6 b  n1 K: w* ^
  @/ t5 z7 V2 j8 L
+ ~7 C6 D5 ^; O6 \# @
% S3 v9 s/ y5 h. \; u: a: l
+ x* K* Z. m( `  C& p
                                    MT8163V/A                                 MT8163V/B
4 v6 l4 C; N. B. h& m" m  ?! P& u1 V, d* Z8 l8 n
- k; E+ f+ J1 Q* q" E
CPU                Cortex-A53 x 4, 1.5GHz                     Cortex-A53 x 4, 1.3GHz1 @2 r# f, s6 d4 q6 o: J1 Q) N
6 R) }( a5 ^% ~& q
( G( v2 I( Y& X. |1 W
Graphics             Mali-T720 MP2                                      Mali-T720 MP2
/ n! f' p% q% Q& y/ o                             @600MHz                                              @520MHz1 g2 F" a6 a2 i
                         133Mtri/s, 1.2Gpix/s                           115Mtri/s, 1.0Gpix/s
9 Q0 {6 ~1 s* u& H* p: U& y& F1 g0 e5 h3 q' \& j
; ?- `; R. J# L9 D" e
Memory             DDR3x32 1600Mbps                             DDR3x32 1600Mbps
) u( |: u3 a+ z/ z                          LPDDR3x32 1600Mbps                         LPDDR3x32 1600Mbps5 D2 |3 {: j" n% Y# e4 P
                          LPDDR2x32 1066Mbps                         LPDDR2x32 1066Mbps; X$ M* `3 g+ |0 }, ^( H1 W/ w
) [& B$ `- ^' J# w, L8 u! v! `
* M: K& g) ~0 j# r5 ~8 C- N
Camera                     13MP ISP                                                 13MP ISP) r. q; b) w) ?  M6 [6 v* v
) g& t4 Y6 \* [& Z6 n
" C6 b, ?. b6 b1 s( X& c
$ z& f! a6 k$ |0 e6 [' q0 t  pDecode             HEVC / MPEG-4 / H.264 / VC-1               HEVC / MPEG-4 / H.264 / VC-1
$ I: t* u+ J7 A9 P( S( L, j! O  {
. `! x$ l+ L" n
Video Encode            1080p 30fps                                               1080p 30fps
6 ]; q; r" d2 t
0 k* d0 V" ^" Y5 ]) q
' y3 [0 H3 c2 z% A4 {2 T" ^% O
Display                     WUXGA 1920x1200 60fps                     FWXGA 1366x768 60fps+ Y' o9 p$ L% m
                                    MIPI / LVDS                                         MIPI / LVDS- k( r$ @/ k0 m. b* N; W
                                     Built-in HDMI                                      Built-in HDMI* C* x, \; z) v% b( m8 q/ {& D) O
, D7 v2 c& I5 D! D
2 f) H7 R4 L: b
Connectivity             Embedded                                              Embedded9 V* ]) ?/ R- B
                         Wi-Fi abgn/BT/FM/GPS BB                     Wi-Fi abgn/BT/FM/GPS BB
( V# X$ D7 F+ B5 H" j/ c$ H( x  M
  d3 ]- x9 B) \& r8 s9 f1 j  P7 O, _# M
, m1 D1 g2 S% c
PCB                       Normal PCB 4-layer                                  Normal PCB 4-layer
/ W& [: K7 B( I9 t( E& {: Z! t! F
# J( E" E2 v" ^! \2 J6 J) _
6 Q6 t4 Q3 ]7 ]7 @
! g6 ?- J; R0 Q* }9 p2 G9 m; z
GMT+8, 2025-10-11 13:29 , Processed in 0.140625 second(s), 23 queries , Gzip On.
