查看: 633|回复: 5
原理图自动化检查工具
    2021-4-22 15:40
  • 签到天数: 73 天
    [LV.6]常住居民II
    发表于 2019-11-28 09:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    现在的原理图设计越来越复杂,我想找一个原理图的自动化检查工具,来提高设计效率. 例如mentorxpedition® Valydate Schematic Analysis,有没有谁能推荐一个原理图的自动化检查工具?
    2021-4-22 15:40
  • 签到天数: 73 天
    [LV.6]常住居民II
     楼主| 发表于 2019-11-28 16:45 | 只看该作者
    我感觉Mentor的这种原理图检查工具功能挺强的,只是它的数据库是联网的,对我这样小公司的人来说是不太可能的.难道大家都没有想用工具去检查原理图?人很容易形成定势思维,对错误视而不见.下面是Mentor的Valydate的介绍
    - @& g8 A1 P& e- V# W" O* p, j. I0 c) |3 I% [. S
    Pin voltage parametric verification for maximum, minimum, and logic thresholds5 R  `" d+ n7 z6 r7 `& z6 M) H# G
    Bus flip errors (MSB to LSB, TX and RX errors)
    $ ^. h+ J& R1 A8 }% r5 Q1 l" nFull multi-board and backplane interface verification
    0 C8 l% {' W- f7 a2 T) U+ MPin function compatibility tests
    6 Y- R+ L" O/ @7 o5 K2 v2 sSymbol mismatch (to datasheet)* q6 n7 z. v: K) o
    Driver/receiver technology matching
    ) M9 k: F; Q- _9 V6 R: X$ E6 hDiode orientation verification; \. K4 q+ L9 d8 Y6 |- D% w
    Driver/receiver function matching
    $ y7 z% ^' [6 D* \! i& MPower/ground/open collector/drain shorts6 g! C( _+ M& c1 y! w! ]! G
    Capacitor decoupling sufficiency checks6 R" O  {" ^% ^7 P* I) U
    Capacitor voltage derating (to user derating rules)
    ( L1 Z& }. a/ t  @! o: tRedundant resistors (on a net detection)
    : v; A# n2 g6 n6 h* O3 f3 N* w' m5 [  X: R4 T; p) n, |
    Open collector/drain verification+ ?- M, ]+ w6 R
    Poor design practice checks (e.g. using pull-ups, pull downs when needed...)5 X; ]2 c8 q" B. A* P/ r& p8 U' g. A
    Power/ground plane connection verification
    ; x$ L4 K! X7 E) d- X% cComponent power checks: y3 Q& v: ^# g4 Q: ~' y8 x
    Multiple or missing power supplies (on a net)
    . f  Y2 j* q7 n6 D8 W9 o' n7 ADifferential pin verification
    4 u5 ?/ A$ S! S1 M3 b) h% S4 L( rUnconnected nets or bus detection
    9 J, N& k' k# ^+ n6 ], s. ~6 cOff-board nets detection. H4 e; f: Z) P% Y' `
    Overloaded pins identification% G9 j, a2 s2 c9 [: O
    Unconnected mandatory pins identification
    - b9 ]! T( v/ T' D- m1 @1 B$ S) Y+ @Nets missing driver
    - r) D" |7 {0 _Nets missing receiver
    发表于 2019-11-28 17:35 | 只看该作者
    软件自带的有啊,不知够不够你用?
    2021-4-22 15:40
  • 签到天数: 73 天
    [LV.6]常住居民II
     楼主| 发表于 2019-11-28 17:43 | 只看该作者
    软件自带的还是太弱了,比如一个FPGA它的管腿既可以输入也可以输出,IO的电压也是随Bank电压而变的.而我们的原理图工具是这种IO属性是建库的时候定的,根本不能随着设计的不同而改变它的PIN的属性,所以就没有办法检查了.% ?! v+ }; g' m: C+ _, N8 J
    GMT+8, 2025-11-5 18:20 , Processed in 0.125000 second(s), 23 queries , Gzip On.
