查看: 347|回复: 1
[毕业设计] 开关稳压电源毕业设计
发表于 2019-10-30 11:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
开关稳压电源
摘要:本设计应用隔离型回扫式DC-DC电源变换技术完成开关稳压电源的设计及制作。系统主要由整流滤波电路,DC-DC变换电路,单片机显示与控制电路三部分组成。开关电源的集成控制由脉宽调制控制芯片UC3843及相关电路完成,利用单片机进行D/A转换,完成对输出电压的键盘设定和步进调整,同时由单片机A/D采集数据利用数码管显示出输出电压和电流。系统具有输出电压可调范围宽、噪声纹波电压低和DC-DC变换效率高等特点。此外,该系统还具有过流保护功能,排除过流故障后,电源能自动恢复为正常状态。
关键字:DC- DC,整流滤波,脉宽调制,A/D采集,D/A转换
AbstractThe stabilized voltage switching supply is designed and manufactured by DC-DC power transfer with isolation and feedback. The supply includes rectification and filtering circuit, DC-DC transfer unit, controller controlling circuit and liquid crystal display module. The swiching supply is controlled by pulse width modulation IC UC3843. The output voltage can be regulated step by step by a microcontroller, a key and a D/A converter. The output voltage and current of the switching supply are collected by a A/D converter and displayed in Nixie tubes. The switching supply have some advantage such as wide output voltage, low noise ripple, high transfer efficiency. In addition, the swiching supply can realize current foldback.
Keyword:DC-DC transfer, rectification and filtering, , microcontroller, A/D collecting data,D/A converting
1 k6 m( D5 w9 W
游客,如果您要查看本帖隐藏内容请回复
0 T7 |% ]; I; y1 T2 ~7 Q2 h0 }6 P6 {! T$ A
1 W: L) K- ]% `
" {" F: ]0 i( V: z% p* X# X
GMT+8, 2025-10-1 09:14 , Processed in 0.156250 second(s), 26 queries , Gzip On.
