from PySide import QtCore, QtGui% @1 e# c' T+ q0 j% }6 A0 I
EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  & u- j+ @1 p- E5 d2 C
 class Ui_MainWindow(object):( J+ _# ]2 L/ U$ N# ^8 u
 def setupUi(self, MainWindow):
 3 I3 n6 v! q# W( t* c( N        MainWindow.setObjectName("MainWindow")2 i; F$ z, k' r& b
 MainWindow.resize(423, 325)" }9 M- j( u- @; s- m: X& ~
 icon = QtGui.QIcon()$ z. {7 }, G0 D3 P0 J; u# Q6 k, |& M
 icon.addPixmap(QtGui.QPixmap("C:/pads_scripts/QT_GUI/BGA_GUI_001/blp.bmp"), QtGui.QIcon.Normal, QtGui.QIcon.Off)) h) L% g. _! B' D; D5 L
 MainWindow.setWindowIcon(icon)
 5 v/ t+ p! @8 F        self.centralwidget = QtGui.QWidget(MainWindow)& V! H; t' {, s$ u" R& U$ D
 self.centralwidget.setObjectName("centralwidget")2 F: M8 a6 t+ H: `8 C" }
 self.rc_select_btn = QtGui.QPushButton(self.centralwidget)
 " J5 n( O, n6 u0 e1 e9 k# f        self.rc_select_btn.setGeometry(QtCore.QRect(10, 260, 71, 38))& q5 p4 N6 q0 T% S. t
 self.rc_select_btn.setObjectName("rc_select_btn")5 h; h7 Q; K1 x2 [
 self.bga_select_btn = QtGui.QPushButton(self.centralwidget)2 P2 [3 t3 y- h! O
 self.bga_select_btn.setGeometry(QtCore.QRect(250, 260, 71, 38))( u* g) }3 ]! e& Z
 self.bga_select_btn.setObjectName("bga_select_btn")
 3 x0 O5 i, ]4 T- M% g1 z5 P6 C        self.move_btn = QtGui.QPushButton(self.centralwidget)3 [# y7 f# v! h# o
 self.move_btn.setGeometry(QtCore.QRect(180, 130, 61, 41))
 # X0 N( X- |7 \; b. F        self.move_btn.setObjectName("move_btn")
 & G! [% g7 x) [0 w. o' ~* K8 M        self.rc_cnl_btn = QtGui.QPushButton(self.centralwidget)- e$ E3 u4 T- g; W9 R/ s' b
 self.rc_cnl_btn.setGeometry(QtCore.QRect(100, 260, 71, 38))
 ( \! {1 W3 E" B. ]/ Z        self.rc_cnl_btn.setObjectName("rc_cnl_btn")
 . _( U/ f+ B2 r, L; n% u. o        self.bga_cnl_btn = QtGui.QPushButton(self.centralwidget)- l) a# y7 C" U8 J. B2 Q% O6 @0 e
 self.bga_cnl_btn.setGeometry(QtCore.QRect(340, 260, 71, 38))
 4 e* b  `: o& j# E6 ?        self.bga_cnl_btn.setObjectName("bga_cnl_btn")6 M; ]3 ?9 a% K9 B* }) F& g4 c$ ?
 self.label = QtGui.QLabel(self.centralwidget)  r- T1 Z1 b0 J; G) s6 _  A/ V
 self.label.setGeometry(QtCore.QRect(10, 10, 131, 16))
 % \2 A  d) ~: \% m. c        self.label.setObjectName("label")4 \% k* Y4 _+ p1 n
 self.label_2 = QtGui.QLabel(self.centralwidget)
 ) ~2 A" ]. d$ S: C  `        self.label_2.setGeometry(QtCore.QRect(250, 10, 131, 16))- ~* W, }5 j3 b9 ^( V) h
 self.label_2.setObjectName("label_2")
 ' w& u6 W& |$ G4 K) I        self.lineEdit = QtGui.QLineEdit(self.centralwidget)
 ' L5 H; j0 a2 s' L3 c* O8 P6 \        self.lineEdit.setGeometry(QtCore.QRect(10, 30, 161, 21))
 3 E* w1 l1 [! p4 m        self.lineEdit.setObjectName("lineEdit")9 E/ a2 P' @. t4 d; r$ c6 D
 self.lineEdit.setText('')
 . @/ ]8 B; n  y8 L% _. y" [        self.lineEdit_2 = QtGui.QLineEdit(self.centralwidget)1 f9 M5 D$ x* Q3 \+ R: @
 self.lineEdit_2.setGeometry(QtCore.QRect(250, 30, 161, 21))! U- ~  @/ ?+ Z- T# o, ]  Z
 self.lineEdit_2.setObjectName("lineEdit_2")
 4 _1 D- ^0 D, z0 O        self.listWidget = QtGui.QListWidget(self.centralwidget)
 5 p. a8 G2 [: [0 |6 _# Z& A        self.listWidget.setGeometry(QtCore.QRect(10, 60, 161, 192))+ s6 [" k  ^: l: M* ^
 self.listWidget.setObjectName("listWidget")% w$ e7 \) p" E) N% D8 E
 self.listWidget.setSortingEnabled(True)
 - o& B8 j6 J4 m/ d& e7 K# N* x' D        self.listWidget_2 = QtGui.QListWidget(self.centralwidget)7 ?  u' G3 O6 l
 self.listWidget_2.setGeometry(QtCore.QRect(250, 60, 161, 192))
 2 S1 M+ P6 ]5 e8 x% l        self.listWidget_2.setObjectName("listWidget_2")
 & X" E, k& z/ o5 Z- i' J" H        MainWindow.setCentralWidget(self.centralwidget)
 % p/ A8 \5 B. I; ]        self.statusbar = QtGui.QStatusBar(MainWindow)
 & H! x9 E5 y4 l1 W8 e5 i% o        self.statusbar.setObjectName("statusbar")) d1 N; }9 ^: j: |0 A! S5 K
 MainWindow.setStatusBar(self.statusbar)
 : M5 f2 j! ]- M& V- ^+ }( q4 e: j/ }% D
 self.retranslateUi(MainWindow)$ k8 O5 }- c9 u" o( U. S8 G
 QtCore.QMetaObject.connectSlotsByName(MainWindow)
 ; b5 C' d; ^& e( U7 v+ H( `
 : E5 d. l3 ^$ n. L    def retranslateUi(self, MainWindow):
 ! o6 g7 }2 R6 ?% H9 y, k        MainWindow.setWindowTitle(QtGui.QApplication.translate("MainWindow", "BGA Placement Tool", None, QtGui.QApplication.UnicodeUTF8))3 w$ ?3 K. U$ }- q+ Y
 self.rc_select_btn.setText(QtGui.QApplication.translate("MainWindow", "Select", None, QtGui.QApplication.UnicodeUTF8))
 & j* c# Y9 n2 I        self.bga_select_btn.setText(QtGui.QApplication.translate("MainWindow", "Select", None, QtGui.QApplication.UnicodeUTF8))
 7 f9 a) Q4 @& B1 n4 b        self.move_btn.setText(QtGui.QApplication.translate("MainWindow", "Move", None, QtGui.QApplication.UnicodeUTF8))7 C/ T- F9 d: f- l
 self.rc_cnl_btn.setText(QtGui.QApplication.translate("MainWindow", "Cancel", None, QtGui.QApplication.UnicodeUTF8))
 / X* c- q' a! _9 d        self.bga_cnl_btn.setText(QtGui.QApplication.translate("MainWindow", "Cancel", None, QtGui.QApplication.UnicodeUTF8))
 5 X  n% k8 f! F1 c6 e, S        self.label.setText(QtGui.QApplication.translate("MainWindow", "Component: R/C", None, QtGui.QApplication.UnicodeUTF8))
 - \* L7 n4 A; _& O, n6 P( I6 E% s! [        self.label_2.setText(QtGui.QApplication.translate("MainWindow", "Component: BGA", None, QtGui.QApplication.UnicodeUTF8)): k0 n: k( {% j, I. G( C* t+ ^5 K
 + D* @/ z) D" r; Z0 e3 b8 H1 _* K$ }
 ! \& j1 C/ b$ S6 O
