查看: 2960|回复: 6
8片 DDR Layout Guidelines and Topology:
发表于 2009-8-1 13:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Layout Guidelines and Topology:7 Y* f9 M* X$ m* k5 @
The following are the routing guidelines followed for DDR memory inteRFace section:
$ d/ s0 m/ Y9 F4 }* f% e$ F# [* ?1. Controlled impedance for single ended trace is Z0 = 60 ohm.
6 J, u4 Y3 o" b+ c* L, ~( \2. DQ, strobe, and clock signals are referenced to VSS.
$ B: R& {3 _: S* a2 {# G3. Address, command, and control signals are referenced to VDD.
$ k( k* s* X: c  u, ^' n, B4 S4. The length of address, command, and control signals are matched to clock with +/- 100 mil: ?* I: ^$ a( a
tolerance./ u9 j( Q& s: b$ v& A$ p) Z
5. DQ <0..7> & DM signals are length matched with respect to DQS with +/- 100 mil tolerance' o% ~4 g$ q" P: M: X$ Y7 t& O5 Z
(byte lane).! T+ S% @0 D2 M1 |3 H* _: {) |8 d
6. Each byte lanes are routed on same layer.: x/ c9 ~, ]7 C, Y* F/ E+ c! ~% H* j
7. Byte lane to byte lane is matched to clock with +/- 500 mils.
' B5 l% ^$ h  s8. CK & CK# are matched with +/- 30 mil and are routed as diff pair with 120 ohm differential4 M" C4 q1 d2 D& W
impedance.6 Q$ h. G5 x  g  g. D% b- P; \
9. Clock - pair to pair matching tolerance is +/- 30 mil.3 o: M5 r& w0 A4 V0 @( A% y
10. Trace to trace spacing is 2X and signal group to group spacing is 3X.; ?- i9 T; D! v6 j9 _7 n7 Z+ r6 {8 q. J& h
11. DQS signals are routed in the middle of the byte lane (DQ<0..7>).
: D3 U$ C: b9 _9 ~7 F) I$ I12. Clock trace split point to DRAM is less than 1 inch.: {) e: ^1 L# R; m6 O
13. VTT and VREF islands are separated with the minimum spacing of 150mils.9 k7 e6 @! |2 m- e7 E
14. VTT island width = 150 mil min.; 250 mil preferred.
7 ^7 i, Z& \+ |- s, O15. VREF signal is routed with 20–25 mil minimum trace.
& P  j: D) Y" B/ ]" v& D% p15. All signals are routed with minimum of 3X spacing between other signals
/ m1 I* T" c0 z7 {. K16. Layer biasing is followed for dual strip layers.
6 M5 a. q4 `' v$ K1 ]$ RFigure 1 shows the data bus topology and figure 2 shows the address/control bus topology.
 楼主| 发表于 2009-8-1 13:58 | 只看该作者
元件放置方法:/ F$ ?9 u" Y+ K7 s/ J# \) }! J
: i/ B$ U2 g# y5 f$ {) i: I  I数据线拓扑:  c2 Q- `; l+ y: A3 C) T: |
! z5 J; F; I* {5 A) B' v+ Q- p
地址线拓扑:2 c3 X$ x8 s! P+ J" v+ ]. V
( P: P+ p; ?$ \2 J( h( w- N时钟线拓扑:
; s7 ]! r6 A& }4 I$ w4 X, U/ v# e
发表于 2011-8-25 20:15 | 只看该作者
瞄 画个立体的更直观2 y$ I" d7 c. B' j" T
头像被屏蔽
发表于 2011-9-16 14:27 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
    擦汗
    2019-11-20 15:04
    发表于 2011-9-18 16:15 | 只看该作者
    谢谢楼主,学习了
    发表于 2011-9-19 10:13 | 只看该作者
    原档
    Memory Controller and DDR DRAM Design Analysis Document.pdf
    275.22 KB, 下载次数: 132, 下载积分: 威望 -5
    发表于 2013-12-29 20:42 | 只看该作者
    谢谢楼主、楼上的
    GMT+8, 2025-7-6 12:23 , Processed in 0.140625 second(s), 27 queries , Gzip On.
