查看: 511|回复: 8
多发多收探测雷达定位精度分析
    2019-11-20 15:05
    发表于 2019-10-15 07:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    多发多收探测雷达定位精度分析
      W& ]+ i4 ?4 j& R; |
    (电波科学学报2016年第31卷第一期)
    , `, }- W' b3 n! b. Z
    5 X" n$ n: L6 G- Y! X1 h' G4 _" `摘要:多发多收是提高雷达系统定位精度的重要手段之一,为分析不同形式多发多收定位精度,采用二维定位几何精度稀释分析方法,分别针对两发两收、两发四收和三发三收三种探测方式进行了仿真分析,结果表明:两发四收探测系统定位精度比两发两收系统整体上提高,在基线近区提高比较明显;三发三收 探测系统克服了两发两收探测系统在基线上定位盲区的缺点,但与两发四收探测系统相比,除基线附近外, 在三站围成的定位区域内定位性能并没有明显提高.仿真结果为多发多收探测系统选取、布站提供了理论参考,具有一定的工程应用价值。
    & G8 g# O0 `) D$ F3 b4 |" ]9 e( \# f% y
    关键词:多发多收;雷达;几何精度稀释
    / x( G3 P  p- h/ o& w6 x( Q+ l$ Q0 X( T" v
    Abstract: Multi-transmit multi-receive (MTMR) is an important mean to improve the positioning accuracy of the radar system. To analyze the positioning accuracy of different MTMR systems, we use two-dimensional positioning GDOP analysis method to simulate the systems of two-transmit two-receive, transmit four-receive and three-transmit three-receive (2T2R,2T4R,3T3R).The results show that: two-conl一 pared with the 2T2R,the ment much more obviously positioning accuracy of the 2T4R system is overall improved and the improve-in the near baseline zone:the 3T3R overcomes the defects of the 2T2R that has positioning blind zone on the baseline gion tion rounded by the results provide three stations is ',however,compared with the not obviously improved except 2T4R,positioning accuracy of the re-in the near baseline zone. The simula-theoretical reference in MTMR detection system selection and radar station deploy-ment,and thus is valuable to radar configuration applications.
    9 H  H+ G9 ~) R  ?' u7 \4 c' ^7 S2 N1 }$ k" R
    Keywords: multi-transmit multi-receive;radar;GDOP ) Y4 t0 v9 D! T8 \5 M" c
    + p# C- k9 y7 A$ t2 |
    1 l2 Y: @6 K9 f/ R$ x9 y$ R  Z
    游客,如果您要查看本帖隐藏内容请回复
    8 I: s# u: ]6 y4 l- f6 Z* A  f6 N8 ~+ d6 t5 n# r: C
    2020-1-3 15:00
  • 签到天数: 21 天
    [LV.4]偶尔看看III
    发表于 2019-10-15 08:45 | 只看该作者
      Thank youThank you
    发表于 2019-10-15 09:04 | 只看该作者
    啥玩意,多波束雷达?
    2023-3-24 15:36
  • 签到天数: 68 天
    [LV.6]常住居民II
    发表于 2019-10-16 10:44 | 只看该作者
    学习学习,感谢分享
    发表于 2019-10-23 14:06 | 只看该作者
    谢谢,这是什么?" L( Z4 c6 V8 ^8 D# U
    发表于 2019-10-29 14:37 | 只看该作者
    学习,感觉很有用
    GMT+8, 2025-10-31 15:18 , Processed in 0.156250 second(s), 26 queries , Gzip On.
