查看: 582|回复: 2
[毕业设计] 基于单片机的智能温控风扇设计
发表于 2019-9-30 14:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于单片机的智能温控风扇设计3 e: P4 D$ Q% n5 k7 G: e
( o% h: n& ?1 N1 q
摘 要在日常生活中发现传统风扇的使用有些不方便的地方, 比如在很多的地区昼夜温差大,人们睡觉时一般依靠风扇的定时功能, 这样可能出现风扇因定时到了而关闭, 但温度并没有降低很多, 也有可能温度降低了很多但定时没有到, 风扇还在转动。 为解决这个问题本文简绍了一种智能温控风扇系统,具有温度检测和显示功能,使用 STC89C52单片机作为系统对风扇的转速进行控制。% ?- u8 S9 k- U( Q2 D
此风扇设计两个档位, 由单片机根据 DS18B20温度传感器传来的数字信号进行控
制,当温度高于上限值时,风扇较快转动;当温度处于上限值与下限之间时,风扇较慢转动;当温度低于下限时,风扇停止转动。
! y/ f2 c8 g6 N" _
6 d8 K9 W+ P0 p( y* S) X关键字
2 }  S; d2 o4 h5 e7 l$ o2 W- g3 k6 `- X
/ {( G7 Z  H3 }" F
单片机;智能控制;温度传感器
; }; h! ]& L  {- e1 B+ G1 D( O- `% Y" p* }6 {* I* C
  e" S$ R& o8 H7 j
7 `9 M" R2 n5 ~& c4 ^The Design of Intelligent Temperature Controlled Fan Based on mcu 6 x6 R8 i3 N1 x' u6 l. U
Abstract
  l( B. |0 ]4 m8 L3 H# E/ X0 c
There are some inconvenient places in the use of traditional fan in daily life, such as many regions of the temperature difference between day and night, people generally rely on timing function of fan, the fan may be shut down when the timer goes , but temperature did not reduce a lot of, In order to solve this problem, this paper introduces a fan system controlled by temperature , which has the function of temperature detection and display, and control the speed of the fan by using STC89C52 single chip microcomputer as the system. : `8 I  j4 }+ m! v
; m  P# L$ u5 n$ w
The fan design two stalls, it is controlled by MCU according to temperature sensor DS18B20 digital signal, when the temperature is higher than the upper limit value, fan fast rotation; when the temperature is between upper limit and lower limits, fan slower moving; when the temperature is below the limit, fan stops rotating 5 B3 \; F- r$ }
0 s# K, r1 M1 X' U' ~Key words
" k( c; ^% V6 J2 N1 R
9 ]" l$ ~6 S& G' \- NMCU; Intelligent control; Temperature sensor$ f' o* }- K/ e. x9 O/ W0 k1 O
9 ^; `# }! Q4 K
* z, X8 G9 I/ m. g
游客,如果您要查看本帖隐藏内容请回复
' h* l( n# u  ~1 I+ o" e6 M2 `- I5 H( ~: M. Q
3 H% X0 ^% L- y9 O
发表于 2021-12-5 14:48 | 只看该作者
GMT+8, 2025-10-5 17:56 , Processed in 0.140625 second(s), 26 queries , Gzip On.
