本帖最后由 hpucq 于 2019-9-24 16:55 编辑 7 z6 ]! f9 m! A
9 y8 T/ `2 G3 b. |2 m使用的SPI的x4模式,配置电路如下图所示:
/ S0 f4 Q2 F+ c% Z$ `1 y3 q+ d' z Y下载的时候出现的信息如下:( O: d# g# e! ~8 T
Attempting to identify devices in the boundary-scan chain configuration...5 O5 J f3 t9 n! ^( e- N4 Q- d
INFO:iMPACT - Current time: 2015/9/24 12:57:17 `: [) @; t6 g4 `
PROGRESS_START - Starting Operation.
3 x! X( J5 Z4 t1 T0 u* [% p+ I! J) @Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6slx45, Version : 4
+ @; q) c: n I8 j3 ^+ j" q# }INFO:iMPACT:1777 - & E6 [% y% \( S! ^" n
Reading C:/Xilinx/14.7/ISE_DS/ISE/spartan6/data/xc6slx45.bsd...* E8 f& i0 F5 C
INFO:iMPACT:501 - '1': Added Device xc6slx45 successfully.3 Y5 o2 v. h% n4 R+ z2 B' Z
% f4 H+ _8 d# v* B----------------------------------------------------------------------
( l6 h# @6 e: L: \8 J5 xdone.5 d: j6 j3 c; [9 U/ ?; I/ u" G- _
PROGRESS_END - End Operation.9 K0 m$ `3 T- Q
Elapsed time = 0 sec.: \" b* B2 H7 d9 [3 {
'1': Loading file 'D:/Project/Xilinx/ad_da_test/lrd_lest.bit' ...
) S& S: R0 W/ D. a4 N0 {done.
+ m- ?% C& M f) IINFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
% L/ H, [0 I& S8 P+ Tbut the original bitstream file remains unchanged.
$ h2 P( t& x; SUserID read from the bitstream file = 0xFFFFFFFF.
* ?4 Q* D" |, V' o; w" ^% uData width read from the bitstream file = 1.
9 g/ c9 V$ K; Q, MINFO:iMPACT:501 - '1': Added Device xc6slx45 successfully.
, w# _, [! n6 L2 ?0 m5 ?: ?( `----------------------------------------------------------------------5 o# f1 ^6 g' L0 n7 a/ Z# H
----------------------------------------------------------------------2 |$ v/ l- X, F3 G8 j. R& E5 C
INFO:iMPACT - Current time: 2015/9/24 12:57:451 b) {0 u6 L0 S% y d! I
PROGRESS_START - Starting Operation.( t! D X9 {% ?+ [5 \& Z
Maximum TCK operating frequency for this device chain: 25000000.6 z; v# |0 s+ j/ W* ^+ n3 \) A5 q
Validating chain...
# B$ F( \- R7 E/ JBoundary-scan chain validated successfully.+ T, D; N* c6 S
'1': Programming device...
- s3 Z( I8 @3 p; N) H# [) F) {LCK_cycle = NoWait.
/ D1 V8 V) I) h9 {) T9 n* QLCK cycle: NoWait
' j" r0 D: `8 F+ \) s; gdone., n4 [$ g3 M$ d0 {
'1': Reading status register contents...$ s, O3 g; D) K7 C# e
[0] CRC ERROR : 0
1 K L7 T U& Q9 v4 F[1] IDCODE ERROR : 0. o+ u4 i7 z- y3 a' e) A
[2] DCM LOCK STATUS : 0- ]1 T# G+ {: W/ V) F' S
[3] GTS_CFG_B STATUS : 0# M3 N( w( X- O. Y7 T
[4] GWE STATUS : 0. [$ r7 ]( R5 r
[5] GHIGH STATUS : 0
0 P% G: C1 \# P a* A[6] DECRYPTION ERROR : 0
8 h, H0 g& y- |7 [1 d8 g[7] DECRYPTOR ENABLE : 02 O+ X' g. [" b# _
[8] HSWAPEN PIN : 0
" s/ ]1 q+ C/ a7 c( I[9] MODE PIN M[0] : 0, D9 C5 ]; G5 a" s* X
[10] MODE PIN M[1] : 0, y$ \ y8 E0 J7 j7 C/ H, a) j) E
[11] RESERVED : 0
: h) l% o5 B4 {# c) g5 Q$ u' d, w[12] INIT_B PIN : 0. [- {. | K( `$ q: P( x
[13] DONE PIN : 0
; z8 F `' o5 f8 B C[14] SUSPEND STATUS : 0# ]# Z5 ?8 b- k. V
[15] FALLBACK STATUS : 0) H5 @ Y5 w; ~$ Z3 M' r: q; j
INFO:iMPACT:2219 - Status register values:' f' w9 P2 Q- l
INFO:iMPACT - 0000 0000 0000 0000
9 A' P- |& W; K" T: X0 r1 M/ hINFO:iMPACT:579 - '1': Completed downloading bit file to device.$ f8 g6 B) _2 a5 Q# u3 `4 m6 h
INFO:iMPACT:188 - '1': Programming completed successfully.
; E; r" i6 _- g/ s" v6 PLCK_cycle = NoWait.
\% J1 G$ u' a+ d. K5 JLCK cycle: NoWait
+ v+ K+ |5 n$ b# R! @. Q# s( u0 gINFO:iMPACT - '1': Checking done pin....done.( d6 D6 }! s8 {8 S# B7 j4 x2 @
'1': Programming terminated. DONE did not go high. C2 E0 m! i/ e9 Q. o2 a
PROGRESS_END - End Operation.9 q" ^) m$ M( p+ @
Elapsed time = 3 sec.8 F0 T9 v3 d) O6 G" ~
, U" ^; A1 q8 F& B& w$ n! V1 s& |1 P
求大神帮帮忙。。。感觉电路没有错误啊!!!使用USB可以下载其他的芯片!!!USB应该没有问题。非常感谢!
+ g+ h5 z' t( H* b0 ^% C/ S: ]5 Q: N+ ]8 }0 ]+ z3 L
: E/ l1 U% O( y# N! Y3 z' F/ \
Flash; F# b0 O% t6 B, ^
7 N! l! r* G. M% C' T3 G
7 x/ R, E% |: W z# X5 G
' U( i/ X* c% {1 xSP6 x" {2 \2 }3 j& _5 L: j4 j. u! V
" u& T- @ z/ G# I9 C
2 o( p% E; J0 T) _( c; L
# w5 i& Q; g6 a# Y0 k$ T5 [
' d; `: D9 a9 D) d- `
' S' n; V9 s! }7 \0 k/ [3 @ |
