TA的每日心情 | 怒 2019-11-20 15:01 |
签到天数: 1 天 [LV.1]初来乍到
为何加上if(P1=0x0F){keyNo=0xFF;return;} //无按键按下时提前返回,程序就无法正常运行了?请大神们看看* F% S5 b8 B- |. N7 q- f
, Y- S3 O/ M7 {6 I5 P: y$ |+ M
& t- K( ^& V* t- Z) Pvoid main()1 h& e% A* e+ o/ a5 Y
{, L: [- Z# @ s! ^
P0 = 0xFF;
5 c* e( u4 Z- A) |7 @" J while(1): @. A# C! v* e6 o/ r( V5 f
- ?0 m- @4 E9 y0 [: ^: o/ N- p" ~8 H Keys_Scan();
( @9 p4 b7 ?0 @$ E3 R* w IF (keyNo == 0xFF) {delay_ms(10);continue;}
! }$ O& }1 p) z7 P% j8 t+ q, g$ k P0 = SEG_CODE[keyNo];Beep();
* r* w7 h' N. e+ W3 R& N while (Keys_Scan(), keyNo != 0xFF);6 }6 |- w# a" m/ x
- ^) f4 e' m+ k/ ], S}1 N2 z/ @# U" K6 U$ s! a& ~
void Keys_Scan()
7 G$ N5 [. h/ V& I5 W! _{ : ?+ c. M5 }* W. X5 L* w' z
P1=0x0F;delay_ms(1); ^2 c; a {' N- B; K9 v
// if(P1=0x0F){keyNo=0xFF;return;} //无按键按下时提前返回
8 |/ z) y! K& ]( }& r9 f //按键后00001111将变成0000XXXX,X中1个为0,3个为1
4 ?9 E- m8 V/ p* u# e+ t //下面判断按键发生在0~3列中的那一列* B* G3 L0 x9 a8 d+ N
switch(P1)
. M! `6 q0 G" j4 p8 t) s( q8 r {% n, v4 T9 ~7 c# _. l
case 0x0E:keyNo = 0; break;
$ u3 a6 |# c5 B! C M4 f case 0x0D:keyNo = 1; break;
/ r- T* F) A7 s) f- t S4 g case 0x0B:keyNo = 2; break;2 x8 h' z0 B- ?9 q- I |% {
case 0x07:keyNo = 3; break;# g ~0 n. Z Y: x: ]
default: keyNo = 0xFF;return;
: A7 V' A* E+ S$ Z$ o }
5 D. v1 E/ }2 ?5 \ P1 = 0xF0; delay_ms(1);
8 h5 P/ R- j5 N% \+ Z* I //判断按键发生在哪一行并且加上列号确定准确的位置
8 Y8 T) H( a) l4 c/ I switch (P1)% W/ S) q9 x7 h' q
1 _, E+ C! F, o, m8 ^ case 0xE0: keyNo +=0; break;
) ?6 C% t: q: I* O. B case 0xD0: keyNo +=4; break;( J2 X& Y2 g, A; ]" H" i4 ?! m& u
case 0xB0: keyNo +=8; break;
) d' d J- H8 s! D case 0x70: keyNo +=12;break;
: w4 y, f, I) B- f& K default: keyNo = 0xFF;
) L- Y/ F9 V0 i! J8 d( A% [" W8 J: Z }
* J% I7 {4 _, X
5 J9 F% O' k% x$ t: y/ T2 P9 ]& n/ f. t) ], h! N
