查看: 2193|回复: 2
what is quad stack and Quad die DDR SDRAM
发表于 2009-6-30 23:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Dear All:
0 o- E) B7 K: A9 ?   Would you please help explian the quad stack and quad die ddr sdram?7 q" X0 B& t- k
   Any tips will be great appreciated!
发表于 2009-7-1 09:29 | 只看该作者
Some question, you means the design of the stack up and the signal termination of the DDR SDRAM? Can you describe it detailed?
发表于 2009-7-2 09:56 | 只看该作者
As far as I know, bardshen should be mentioned "Quad-stacked/quad-die DDR2 SDRAM".
# h: B0 m8 }/ k6 ?8 M7 N3 l4 AThere is no quad-stacked DDR SDRAM according to "Double Data Rate (DDR) SDRAM Specification(JESD79D)".
GMT+8, 2025-10-11 17:37 , Processed in 0.156250 second(s), 24 queries , Gzip On.
