查看: 770|回复: 1
在ISE生成bit文件时,产生了这个ERROR怎么办?
发表于 2019-8-28 15:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
8 v5 S. P* A. `2 |' N6 R7 o  Z5 ^
& x( E$ W2 s7 D( m) S
PhysDesignRules:2100 - Issue with pin connections and/or configuration on
: j( W7 N$ u+ \0 _   block:<U_ila_pro_0/U0/I_NO_D.U_ILA/I_DQ.U_DQQ/DLY_9.DLY_9_GEN[39].I_SRLT_NE_0+ K7 d6 h/ t) i5 |# B" M( ?* S( ~
   .DLY9/SRL16E>:<LUT_OR_MEM6>.  For RAMMODE programming set with DPRAM32,
# t1 _: A& n! `" g   SPRAM32 or SRL16 the DI2 input pin must be connected.
% `0 \- Z: F7 i请教大神,在ISE生成bit文件时,产生了这个ERROR怎么办?感谢!
GMT+8, 2025-10-13 01:18 , Processed in 0.125000 second(s), 23 queries , Gzip On.
