$ B* x# Y3 r, L& M5 t
8 `& s5 K" J# ]
Virtex-6采用BPI模式,Flash用的XCF128,在通过FPGA向flash中下载mcs文件时,每次都是运行到12%就停下不动了。2 T1 U. J0 R4 ~4 w+ W
强制断电退出后,iMPACT的提示如下:
/ \/ ~% z3 B- NPROGRESS_START - Starting Operation.
8 g$ H; j/ o' aMaximum TCK operating frequency for this device chain: 66000000.
: h4 X$ g+ L* B/ DValidating chain...2 I3 i; U3 r1 a7 [
Boundary-scan chain validated successfully.) a0 o( C1 E$ \/ X! o8 s
1: Device Temperature: Current Reading: 34.63 C, Min. Reading: 34.13 C, Max. Reading: 38.56 C2 ~2 G# _, I3 X; V& @
1: VCCINT Supply: Current Reading: 1.008 V, Min. Reading: 1.002 V, Max. Reading: 1.020 V
" V+ h) c- [( r$ M$ u# K) `1: VCCAUX Supply: Current Reading: 2.496 V, Min. Reading: 2.479 V, Max. Reading: 2.505 V) z; j; x: C6 O W, q; }; w
'1': BPI access core not detected. BPI access core will be downloaded to the device to enable operations.3 \! ? L0 @1 ]4 K& F3 f
INFO:iMPACT - Downloading core file C:/Xilinx1/14.7/ISE_DS/ISE/virtex6/data/xc6vsx315t_jbpi.cor.9 S# k# e0 M* e* ^* p
'1': Downloading core...
0 [- u4 J& i2 \# Y) ZMatch_cycle = NoWait. A" S( b. s( A" y* _4 y
Match cycle: NoWait: d- T6 X+ t% b2 b( S9 M
LCK_cycle = NoWait.8 j& j9 b5 E/ p& @+ p
LCK cycle: NoWait. y: q4 s$ d2 i5 @# n- H6 F
done.
, ?! Y' M8 ?, x% T* NINFO:iMPACT:2219 - Status register values:: |6 v* W1 u3 Z' L7 T U }
INFO:iMPACT - 0011 0001 0101 1100 0001 1011 1100 0000
1 @: [ L" S6 ?; P; N- a1 fINFO:iMPACT:2492 - '1': Completed downloading core to device.' t: M. }# T- L0 [; e/ [+ N! ^
'1': BPI access core not detected. BPI access core will be downloaded to the device to enable operations.; J, B4 @$ U% k0 t/ f2 L7 B
INFO:iMPACT - Downloading core file C:/Xilinx1/14.7/ISE_DS/ISE/virtex6/data/xc6vsx315t_jbpi.cor.- p4 s7 V" u* a
'1': Downloading core...* ]8 t$ C+ z3 [8 b# z( Z
Match_cycle = NoWait.0 S% d6 \4 j& Z" ?9 R
Match cycle: NoWait2 d# x) ~0 S1 r" b+ c3 y
LCK_cycle = NoWait.) p) w `! j5 E9 }; P; |7 s) F# N% L
LCK cycle: NoWait
7 Y G5 n. W1 \% H2 Udone.# o8 L+ r0 x- V) ]0 R) d
0 J" x3 \9 [3 }* D8 RINFO:iMPACT - 0011 0001 0101 1100 0001 1011 1100 0000
* F* S9 Q# z8 z4 D GINFO:iMPACT:2492 - '1': Completed downloading core to device.* b; Q: d) L2 p2 R, y2 ]8 z0 i
Cable speed is default to 3Mhz or lower for BPI operations.
1 l& }' C+ f' |4 r# oCurrent cable speed is set to 3.000 Mhz.
, W' T, T; R8 z, q/ ?! R$ ~INFO:iMPACT - Core Status Register: [80] : 1
# F9 N/ ]- f0 Z# z' x1 j( o4 AINFO:iMPACT - Core Status Register: [81] : 1! F* _' R0 t& m, C4 D a
INFO:iMPACT - Core Status Register: [82] : 1
# H4 t; q- y$ XINFO:iMPACT - Core Status Register: [83] : 1
1 J6 s+ s& z; j6 [& k9 _9 iINFO:iMPACT - Core Status Register: [84] : 1( i+ x1 E ^! k) m G0 S
INFO:iMPACT - Core Status Register: [85] : 1
1 ~0 L) c/ j- D% v tINFO:iMPACT - Core Status Register: [86] : 1
* w' W6 z$ q+ z3 x' q) r* _INFO:iMPACT - Core Status Register: [87] : 1 U$ P( E; k$ `: W9 T
INFO:iMPACT - Core Status Register: [88] : 1
) p6 }: x) K$ C5 e3 G' j1 rINFO:iMPACT - Core Status Register: [89] : 1
; ?5 g' F4 ^& K9 NINFO:iMPACT - Core Status Register: [90] : 1
0 ]+ R4 V) P: a9 p) v2 j: IINFO:iMPACT - Core Status Register: [91] : 1
0 p+ h% D! K( v; { N- xINFO:iMPACT - Core Status Register: [92] : 14 l9 e9 m+ X0 y& [/ q
INFO:iMPACT - Core Status Register: [93] : 1' M! I/ e+ I* R j0 B
INFO:iMPACT - Core Status Register: [94] : 1$ \% y0 ?# ^# |& x
INFO:iMPACT - Core Status Register: [95] : 14 z/ G4 U' n: P) p& f8 x6 l8 y
'1': Errors encountered while loading microprogram.# s) R1 p8 I- O* J }
PROGRESS_END - End Operation.
& W) I- x4 X( K5 O" T# R0 }哪位大神帮忙分析下,非常感谢! |
