查看: 1202|回复: 1
I2C Verilog的实现(一)
发表于 2019-8-14 15:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TestBench 程序
" _% X) E: M2 W0 z: B% p, i2 M8 ]* h
$ S: `- z: w+ ~! x- `8 p
  • `timescale 1ns / 1ps
  • module test(
  • sda
  •         reg        scl;
  •         inout sda;
  •         reg        sda_out;
  •         wire        sda_in;
  •         reg        [7:0]        data;
  •         reg start_flag, stop_flag;
  •         assign sda = sda_out ? 1'bz : 1'b0;
  •         assign sda_in = sda;
  •         pullup( sda );
  •         I2CTEST testmine(.SDA(sda), .SCL(scl));
  •         initial
  •                 begin
  •                    scl = 0;
  •                         sda_out = 0;
  •                         data = 8'h27;
  •                         start_flag = 0;
  •                         #160000;
  •                         start ( );
  •                 end
  •         always
  •         begin
  •            #50000 scl = ~scl;
  •    end
  •         always @ (posedge start_flag)
  •         begin
  •            repeat (8)
  •               begin
  •                  wait ( scl == 0 );
  •                                 #20000;
  •                                 sda_out = data[7];
  •                                 #40000;
  •                                 data = data << 1;
  •                         end
  •                         wait (~ scl);
  •                         #20000;
  •                         sda_out = 1;
  •                         #160000;
  •                         stop ( );
  •         end
  •         always @ ( posedge stop_flag)
  •         begin
  • //           sda_out = 0;
  • //           #50000;
  •            sda_out = 1;
  •         end
  •         task start;
  •         begin
  •                 wait (scl == 0);
  •                 #20000;
  •                 sda_out = 1;
  •                 wait ( scl == 1 );
  •                 #20000;
  •                 sda_out = 0;
  •                 start_flag = 1;
  •         end
  •         endtask
  •         task stop;
  •         begin
  •                 #20000;
  •                 sda_out = 0;
  •                 wait ( scl ==1 );
  •                 #20000;
  •                 sda_out = 1;
  •                 stop_flag = 1;
  •                 end
  •         endtask
  • endmodule
  • / y/ w. {1 d$ d! q& E8 _# x
+ _/ ]; ]  z+ U  s
1 u+ ]; n' U% {5 r0 t. fI2C程序% ~  k% S! g* }7 [$ g8 C
1 `& c! |/ A! \! A% s( f# o) v
  • module I2CTEST(
  • SDA, SCL
  • input SCL;
  • inout SDA;
  • // The 7-bits address that we want for our I2C slave
  • parameter I2C_ADR = 7'h13;
  • //start,stop condition judgement
  • wire start, stop;
  • reg sda1, sda2;
  • reg sda11;
  • always @ ( posedge SCL )
  • sda1 <= SDA;
  • always @ ( negedge SCL )
  • sda2 <= SDA;
  • sda11 <= sda1;
  • assign start = sda11 & (!sda2);
  • assign stop = sda2 & ( !sda11 );
  • //count setting
  • reg [3:0]  bitcont;
  • wire bit_ack = bitcont[3];
  • always @ ( posedge SCL or posedge start)
  • begin
  •     if ( start )
  •     bitcont <=  4'h6;
  •     else
  •     begin
  •         if (bit_ack)
  •         bitcont <= 4'h6;
  •         else
  •         bitcont <= bitcont -4'h1;
  •     end
  • end
  • //get sda using posedge scl
  • reg sdar;
  • always @ ( posedge SCL ) sdar <= SDA;
  • //address match
  • reg addr_match, op_read;
  • always @ ( negedge SCL or posedge start )
  • begin
  •     if ( start )
  •     begin
  •         addr_match <= 1'h1;
  •         op_read <= 1'h0;
  •     end
  •     else
  •     begin
  •         if( (bitcont == 6) & (sdar != I2C_ADR[6])) addr_match <= 1'h0;
  •         if( (bitcont == 5) & (sdar != I2C_ADR[5])) addr_match <= 1'h0;
  •         if( (bitcont == 4) & (sdar != I2C_ADR[4])) addr_match <= 1'h0;
  •         if( (bitcont == 3) & (sdar != I2C_ADR[3])) addr_match <= 1'h0;
  •         if( (bitcont == 2) & (sdar != I2C_ADR[2])) addr_match <= 1'h0;
  •         if( (bitcont == 1) & (sdar != I2C_ADR[1])) addr_match <= 1'h0;
  •         if( (bitcont == 0) & (sdar != I2C_ADR[0])) addr_match <= 1'h0;
  •         if( bitcont == 0 ) op_read <= sdar;
  •     end
  • end
  • //send ack
  • reg ack_assert;
  • begin
  •     if ( bit_ack & addr_match & op_read )
  •     ack_assert <= 1'h1;
  •     else
  •     ack_assert <= 1'h0;
  • end
  • //control SDA line
  • assign SDA = ack_assert ? 1'h0 : 1'hz;
  • pullup ( SDA );
  • endmodule4 r5 j* G' j- {, r
0 _8 _2 h, _# H9 R! ^7 @) ^
2 \" z* B# g1 }. S. |
8 T# J4 X/ @8 j- v
6 |. w# q0 H" {, ?" N
# b' _; K2 O/ U; \! i- N
GMT+8, 2025-10-13 01:18 , Processed in 0.125000 second(s), 23 queries , Gzip On.
