查看: 1686|回复: 4
求大神指点一下这些warning,非常感谢!
发表于 2019-8-13 11:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 abcde1234 于 2019-8-13 17:59 编辑 9 v* V4 {, C. G6 _
, {: b+ T) _+ j& d
# \! n  V6 x1 E3 o求大神指点一下这些warning,非常感谢!
9 j, O/ |+ I: J# J" b% D
2 Y9 u& o0 _+ a  N! s  k我前仿过了。后仿现在还没加sdf(理想条件下),出现x态。考虑是不是warning导致的内部逻辑不通。  I6 Z5 ]/ k  ?3 l6 V! T
现在把各种警告贴上来,求指点,困扰我好久了。
5 i2 g/ E8 t' O& i哪些警告是必须消除的。。。: t7 g  V0 F% t- e1 e, H+ z
第一种:20处左右:Warning:  Undriven register 'r_reg[MEMO][DATAOUT][16]' is connected to primary output 'r_out[MEMO][DATAOUT][16]'. (ELAB-832)5 T- C- o( F. H4 R" |
第二种:1处:Warning:  ./encode.vhd:103: DEFAULT branch of CASE statement cannot be reached. (ELAB-311)
, y4 e5 v) U7 M第三种:50处:Warning: In design 'rt1553', cell 'C22054' does not drive any nets. (LINT-1). E2 ]4 f1 ?4 D8 |  _3 Y
第四:800多处。。。Warning: In design 'rt1553', port 'r_out[BLOCK_CIR_ADDRESS][15]' is not connected to any nets. (LINT-28)
0 I# Q8 y% `8 p& X  {$ m: m$ C7 E第五:70处: Warning: In design 'rt1553', output port 'memi[DATAIN][15]' is connected directly to output port 'r_out[MEMI][DATAIN][15]'. (LINT-31)$ p9 T) p5 B3 ]( P: q
第六:3处:Warning: In design 'TOP1553', a pin on submodule 'memory' is connected to logic 1 or logic 0. (LINT-32)
8 p4 b+ g% f. Y: F: ]& \+ x   Pin 'read_b' is connected to logic 1. # Z6 o# p+ r6 v5 K5 A
第七:90处:   Warning: In design 'TOP1553', net 'memory/data5[0]' has multiple drivers (unknown wired-logic type). (LINT-38) 8 |$ ?0 u' y4 y& y4 X+ S* X3 a% N
第八:1处:    Warning: Design 'TOP1553' contains 8 high-fanout nets. A fanout number of 1000 will be used for delay calculations involving these nets. (TIM-134)
, K6 `" T1 t, S- n1 r9 E+ b第九:1处:  Warning: DesignWare synthetic library dw_foundation.sldb is added to the synthetic_library in the current command. (UISN-40)4 s% u/ j/ o, ?2 X. A! T" W$ G
第十:150处:  Warning: Unable to determine wired-logic type for multiple-driver net 'memory/data1[12]'. (TRANS-5)( o4 J9 W$ o3 h4 ^1 c
Information: Assuming multiple-driver net 'memory/data1[12]' is a wired-AND. (TRANS-6)
+ w7 |$ \% I5 a! b, E9 n  eWarning: Unable to determine wired-logic type for multiple-driver net 'memory/data1[13]'. (TRANS-5)
+ X" V2 F5 y* Z' M, h! H1 Z第十一:5000多处:  Warning: Target library contains no replacement for register 'regs/r_sys_reg[MUX1M_10M]' (**FFGEN**). (TRANS-4)
# i4 i, J: \, w' @& M& l
/ ?9 u" p/ E% K+ g4 \  [9 U另外。。。因为有个dpram模块,我使用了shared variable,是不是会导致不可综合啊?
1 a: j$ q! ^: Y$ y5 G. `elabrate之前的error:    不知道是不是有影响
' w4 y+ H5 {0 Z- g7 ]* z& r0 wError: Cannot create procedure named 'group_variable' - existing command。& e4 u) z% ~5 W
; g: \0 |  ?+ X, ~$ F
    2019-11-20 15:05
    发表于 2019-8-13 17:57 | 只看该作者
    . y8 d3 v! U; Z9 p+ w# H, h
    信号一层一层的去找,看最后是哪个信号导致了x态。好像没有别的办法,并且跟你这些warning,也不一定有关系。2 D. v2 Z% n8 Y+ W9 s+ u+ Z
    * z" v. @% M, i# ?; @$ w不过你可以尝试这一招:
    * y$ M1 v( p3 i) o   在你的设计中,变量声明的时候,赋个初值。 不过你用的是VHDL,可以在声明变量时赋初值么?
    不能给初值啊~ 麻烦啊。门级网表我除了顶层,下面的都不认识啊。谢谢大神。  详情 回复 发表于 2019-8-13 17:58
     楼主| 发表于 2019-8-13 17:58 | 只看该作者
    Colbie 发表于 2019-8-13 17:57# D3 D3 W. n4 V7 ^# v
    信号一层一层的去找,看最后是哪个信号导致了x态。好像没有别的办法,并且跟你这些warning,也不一定有关 ...
    " P$ B5 M  h* G8 q, Q6 ]
    2 E- E5 L2 g) A不能给初值啊~5 Y( I3 G* y6 l3 B, ]1 G4 n
    2019-11-19 15:19
    发表于 2019-8-13 18:00 | 只看该作者
    7 S: k, Q! q8 Y2 ?8 x
    '第六:3处:Warning: In design 'TOP1553', a pin on submodule 'memory' is connected to logic 1 or logic 0. (LINT-32)) z7 V8 n/ I5 L2 U! n& u8 W
       Pin 'read_b' is connected to logic 1. "
    + k0 a* T( a& o$ Q这个告警,你可以看看。有可能是没有低脉冲出现过,所以对应的寄存器、memory就没有初值,就可能导致后续逻辑也跟着出现x态。
    发表于 2019-8-13 18:03 | 只看该作者
    后仿出现x态,不一定跟这些告警有关的。
    ' w! q' ]8 |2 v  p1 T& ]; o你还是得从仿真出现x态的地方出发,一个信号一个信号的往前查,只有找到源头了,才知道是什么原因。没有捷径的,还是老老实实查信号吧。. n! O, S* ?- J1 b* R4 F3 B* `
    ' I+ Y% Y$ U7 Z  f' B% Q如果查到不知道是什么功能的单元,就只能去看综合网表了,看看是你代码中的那个部分综合出来的。
    , f3 w- R" ^3 k* C  W" }; U0 q! W
    6 L) }) r5 z: C% a6 ^* U然后 你可以使用一些综合编译指令,把你设计内部的一些信号名保持住,以方便定位。
    0 e' w9 P2 t/ K
    GMT+8, 2025-10-13 03:42 , Processed in 0.125000 second(s), 24 queries , Gzip On.
