如题:FRFT程序运行时说Not enough input arguments. 是怎么回事???
! C4 Z/ H6 k" S6 p2 b% S X. Y' y, }1 c2 _, ~/ u9 M
function Faf = frft(f, a)
( s1 q- X# S/ l K8 I) i1 f* Q, t4 g% The fast Fractional Fourier Transform- j, {7 z0 I. z3 g. S; i9 C
% input: f = samples of the signal
3 ?# H3 [ d& J% a = fractional power
# f* A! T! n) E( B7 S: i {" D) e5 X% output: Faf = fast Fractional Fourier transform error(nargchk(2, 2, nargin)); f = f( ;
- \3 y. ~ }) t J/ f3 }8 tN = length(f); y, Y: V9 O0 o9 E% t
shft = rem((0:N-1)+fix(N/2),N)+1;+ k, g1 z: M$ S; M' H; m
sN = sqrt(N);
2 h* u# Q6 Y/ m/ Z/ n, F: Q4 r6 Da = mod(a,4); % do special cases; C% R ^' Z- C3 s* X
if (a==0), Faf = f; return; end;
/ C# o3 ]3 M5 N, y( wif (a==2), Faf = flipud(f); return; end;( Y% j0 H6 P% ^9 U% E. l
if (a==1), Faf(shft,1) = fft(f(shft))/sN; return; end . `% W m2 X* |) v! B/ n
if (a==3), Faf(shft,1) = ifft(f(shft))*sN; return; end % reduce to interval 0.5 < a < 1.5) C& S% Q4 F! l# \6 d6 d- ]$ R! E
if (a>2.0), a = a-2; f = flipud(f); end! _7 W- T$ K8 x f) _- Y6 h
if (a>1.5), a = a-1; f(shft,1) = fft(f(shft))/sN; end
6 p6 B) B X$ c2 r( Nif (a<0.5), a = a+1; f(shft,1) = ifft(f(shft))*sN; end % the general case for 0.5 < a < 1.5
- c9 g- j( b3 @5 e( E# @/ balpha = a*pi/2;
9 R+ w. m: P( d' v" W: T5 |tana2 = tan(alpha/2);
/ H* L2 X3 @8 K" M7 K7 i0 }6 l; ksina = sin(alpha);8 |$ R& E. r* R) |$ Z
f = [zeros(N-1,1) ; interp(f) ; zeros(N-1,1)]; % chirp premultiplication
4 U/ z5 l, W# ~0 U& |- Ichrp = exp(-i*pi/N*tana2/4*(-2*N+2:2*N-2)'.^2);
3 B! v& w, }5 T$ X# p; S5 y' M) {f = chrp.*f; % chirp convolution9 v/ v9 j5 \4 v* A0 {. b
c = pi/N/sina/4;
7 k: _, s/ }; D! i3 F0 b0 WFaf = fconv(exp(i*c*(-(4*N-4):4*N-4)'.^2),f);
' x) Y0 L0 A1 q) R% d WFaf = Faf(4*N-3:8*N-7)*sqrt(c/pi); % chirp post multiplication
1 C( ]% I% b8 ~& p3 VFaf = chrp.*Faf; % normalizing constant
, Q$ w3 _+ u N K8 EFaf = exp(-i*(1-a)*pi/4)*Faf(N:2:end-N+1); %%%%%%%%%%%%%%%%%%%%%%%%%
e! \+ z% F: P5 mfunction xint=interp(x)
# A+ `, t9 t. O8 C% sinc interpolation N = length(x);
5 h, `- e7 T! Jy = zeros(2*N-1,1);
; g! v3 X$ p- [. Y4 j' K* ry(1:2:2*N-1) = x;6 u G" u$ Z0 c4 V5 {) x# O) Q& R
xint = fconv(y(1:2*N-1), sinc([-(2*N-3) 2*N-3)]'/2));$ S5 K) C: O$ {4 G. [0 z: {
xint = xint(2*N-2:end-2*N+3); %%%%%%%%%%%%%%%%%%%%%%%%%- r# E% F% L+ n5 Y1 [/ y4 I) \7 X
function z = fconv(x,y)/ L7 n3 ?2 c) Z! S
% convolution by fft N = length([x( ;y( ])-1;
* I! |$ M9 u* Z1 H6 |" S! LP = 2^nextpow2(N);
& @& F, P3 q& h+ Oz = ifft( fft(x,P) .* fft(y,P));
) v$ D; V! K6 p& z7 B9 jz = z(1:N);
9 { U' \1 i: m' g5 y* Y4 v- K# t+ _; n
