本帖最后由 坐对群山青 于 2019-7-31 15:11 编辑 3 |# s) c" L" \0 g8 _' F% x* F/ J
. s* C2 ?; _ u/ D" I ]
mentor Graphics xpedition Enterprise VX.2.5 Update 3
8 `! D9 e$ Q- z1 _1 D/ k) f2 T
" j4 Y% Q2 i, ^! QMentor Graphics Corporation, a Siemens business, has unveiled Xpedition Enterprise VX.2.5 Update 3. The latest releases of Xpedition address the increasing complexity of today's advanced system designs through an emphasis on both ease-of-use and team productivity.
. e" p! O& ?% P* u8 h
6 X5 l) Q- m5 r7 F+ IWhat's New in Xpedition - VX.2.5 7 z$ w. M* A4 [8 ~) c2 g
System Design 9 U, |$ {% u) X6 J
- New DRCS 6 E: a3 s, Z" W. ]
In VX.2.5 new system design rule checks were created to review system integrity. Rule checks include cross-probing from integrity results to the specific item of interest can be enabled, verification that reference designators are unique in a single board and ensuring that the board connectors and have been placed inside a board outline. Cable declarations are locked and names forwarded to the cable designer insuring that the required information is ready for correct by construction cable design.9 h2 w1 d p/ M9 O7 E
- Connector Management Enhancements
1 F4 V" G4 R( k, l. A/ e4 ~2 [The generic symbol pin order for schematic connector does not always achieve the designers desired results. In VX.2.5, users can now use the library symbol pin order column to easily edit pin numbers and the order. Pin orders can now be easily copied from an Excel spreadsheet and the connectors can be place by the pin numbers alpha-numeric value.
7 @7 u) l0 i; C: F. tData Management4 ^5 ^. \' ]1 T( t6 u: u7 {
- NX 3D model support in EDM
+ `$ h' K' _% O% MEDM In VX.2.5 along with Siemens NX breaks down barriers with 3D model management. NX models can now be imported and exported in the EDM library cockpit ensuring tight integration, model integrity and accelerates collaboration.
( Q5 i. ]9 L3 _' F0 i- Support for viewing net class & net topology in collaboration viewer
& P) G# p$ b9 U' Y. @In VX.2.5, EDM Collaborate now allows users to view the net class and net topology information in the properties view. Whether you are viewing the schematic or layout, the information is available in properties and when selecting a net.* b% m! u6 ?( J
Layout' r$ @8 R0 V9 q4 ^. k' ?
- Semi-trunk routing
L: V0 R+ r w4 zIn VX.2.5, a new capability called Semi Trunk routing has been added to Sketch Planning. This capability allows the user to create a Sketch plan that will only be routed on one end of the plan. By choosing the new command, Route Semi-Trunk, the Sketch plan will be optimized for the end opposite the Route to Dot, and then routed. This can help the user to pre-route inteRFaces that may still require placement or pin and gate swapping optimization. To complete optimization of an FPGA or ASIC, and insure the placement of the interface is complete, the user can easily Reverse the Sketch plan to optimize the other end. / V( _3 z5 l3 [2 D+ o% s
- New graphic triad to control 3D view % [1 ~1 I$ e& X! L3 h& h8 t, s
In VX.2.5 we have added a new graphic orientation triad that enables users to quickly and easily control the 3D view.
: o% I) ]7 F4 X) s; ]6 R( i- Improved 3D violation identification
: |7 U$ R3 ~! D1 ~$ X, x) ~9 hVX.2.5 brings improvements to the online 3D DRC enabling users to identify critical interference issues quickly. From the hazard explorer users can select on interference issues and jump to their location to both view and resolve issues in the 3D environment.
% V( o! }2 w- P9 f1 CDesign Validation6 |4 L. P6 k& L( O B, z) Q: l
- New electrical rule checks
, r8 @/ V/ L8 nVX.2.5 brings several new electrical DRC checks. For Signal integrity, a new reference rule for traces vs. specific power net. There is also a new Min/Max routed comp to comp length rule. Additionally, there is a new Adjacent layer routing parallel coupling check as well as a new trace width check in BGA area vs. pin pad width, For Power integrity, there is now a new check for stitching via spacing. For ESD, therre is a new check to ensure that components are aligned and finally, for Safety, there is a new rule that checks the distance between soldermask/silkscreen and any objects. ' D3 D7 C$ @. J2 w6 {) ^/ h& Z
- Parasitic extraction for AMS
( W |2 Q% Y, |2 E. c! ]8 I# jIn VX.2.5, the tool now integrates directly with HyperLynx advanced solvers for automatic board parasitic extraction. You can also select nets on the schematics, extract layout parasitic effects of selected nets, insert generated parasitic effects into simulation and evaluate the parasitic effects both with and without parasitics. 4 K) x' b1 F' c' n+ J, {
下载地址
+ D/ v+ k: P: p2 ~! G# G' w* i8 M- h; M, g
