查看: 571|回复: 1
看一下AGM FPGA,pin to pin兼容Altera
发表于 2019-7-31 14:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1 C5 u: _/ L4 ?4 M, e. @& t国内最好的FPGA,有cpld,FPGA等多种规格器件
5 l% O" K4 w) r8 P! I目前大尺寸LED控制,大屏控制器,小屏驱动器应用领域巨大
' O4 A; ~. v9 O2 Z! D完美兼容Altera
' H& J9 C8 ?7 {5 FEPM240T100系列;EPM570T100系列;EPM576T144系列+ F7 m4 q& N% e
EP3C5E1440 q; m7 K3 f) h% ~  O3 O! B6 h% F
EP3CE6E22- D7 d0 ~; c0 b8 q& X
EP3C5F2566 ?6 j8 N' l5 L" ]$ ~" k
EP4CE6F17
* `3 v2 C/ w/ e3 DEP3C10E144
: e5 v  E  \+ u2 @EP4CE10E22
7 Z, L0 T+ g; ~+ {0 OEP3C16F256
: K6 R+ i0 J1 D' c0 g1 m3 hEP4CE15F17
- \/ U  F2 d4 o8 i, ?中国芯,民族魂- B1 A8 x8 X! M3 {( o
) y0 W% b: x/ T2 z- O- c
! Y% O  F4 F( m  _. c+ N
AG256 CPLDs is the low cost CPLDs. This instant-on, non-volatile CPLD family targets general-purpose and low-density logic. The logic density is 256 Logic Elements with LQFP-100 package.
' {- w6 b" e' g6 ~5 `2 A: f- F6 S
9 |: |+ X' h3 T9 x4 r: C
2 B$ G) {7 L9 T
Low-Cost and low-power CPLD# g) J9 ^. W" }1 V& J! w4 G
Instant-on, non-volatile standard compatible architecture.
# v; {6 Z5 d- Q( p; vUp to 4 global clock lines in the global clock network that drive throughout the entire device.8 j- {3 X1 d/ M  S- s5 E7 B
Provides programmable fast propagation delay and clock-to-output times.+ `+ O( j5 ?7 ^' K5 Y$ ]
UFM supports non-volatile storage up to 256 Kbits.6 x  |3 ?" d% Y7 k4 d4 W, X+ t
Supports 3.3-V, 2.5-V, 1.8-V, and 1.5-V logic level
/ b# Q# H9 D, _' f' \Programmable slew rate, drive strength, bus-hold, programmable pull-up resistors, open-drain output, Schmitt triggers and programmable input delay.9 S; l! Q7 n* p2 M$ Q- F- S
Built-in Joint Test Action Group (JTAG) boundary-scan test (BST) circuitry complaint with IEEE Std. 1149.1-1990
3 T, A5 }' W, |4 Q  T2 L1 IISP circuitry compliant with IEEE Std. 1532# r* F* S6 v4 T2 H: u( s
3.3-V, 2.5-V, 1.8-V, 1.5-V LVCMOS and LVTTL standards6 {# \* X( v2 C! O
Emulated LVDS output (LVDS_E_3R)% x& o: j! H7 n( G  v& P6 Y  `
Emulated RSDS output (RSDS_E_3R)" _# F( R: w( Q: v* o1 k( s
$ X0 |. M( m$ w! `. g$ ^
% x4 U* z, g, C) O5 u. x
! s; E6 ?# i6 r+ E9 M" J* Y) n
$ W# U" b  L/ E) D( E" c* v( S
( @8 H7 l$ u- l3 B5 u
' y: |, y% l5 f1 \0 z6 q1 Q' X0 w# I
$ n5 q/ o! j2 ^3 f7 J& p  v5 l5 r5 _! V8 W$ W
GMT+8, 2025-10-12 09:28 , Processed in 0.125000 second(s), 23 queries , Gzip On.
