查看: 569|回复: 2
FPGA --- Verilog基础知识(有符号数运算规则,加减运算,乘法运算中的符号位拓展...
发表于 2019-7-30 15:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
rule of thumb
* R! F( x# p% K7 m7 f0 k7 u' i" F  e9 r
1 l5 q0 ?9 {" x  A, E$ |5 t8 P7 O" {
  • The format of the signed type is two’s complement. 有符号数均为补码表示
  • If any operand in an expression is unsigned the operation is considered to be unsigned. 只有计算表达式右边有无符号数,整个计算式都按照无符号数规则运算
  • 只有算式右边全为有符号数,运算才会自动补齐所需的bit数,n+n=n+1.n*n=2n
  • The value -4 represented as a 3bit signed hex value would be specified as -3’sh4. A decimal number is always signed. verilog2001中用’s来特别声明有符号数,十进制的数都是有符号数
  • Type casting using $unsigned will make the operation unsigned. The operand will be sign extended with 0’s if necessary. $usigned()函数在高位补0
  • A=$signed(B) will extend using sign bit. $unsigned()函数会在高位补与符号位相同的bit7 x/ Y; c9 q' U& b
7 v+ o* Q! a# U3 e# W' H( W4 K4 H, Q
: O$ x$ t  ^: i: q5 N' ?* X0 ~4 Ybasic signed addition$ l' i5 W2 G/ V( r) W# F6 O6 `
- @3 _2 B3 ]9 }" J: _5 u. z; x' ?
; B# J6 r4 Q  S# o" s4 g
游客,如果您要查看本帖隐藏内容请回复
# j0 w, t- Z$ f. g9 h6 j6 {) x0 }7 ~8 ~* H# U+ a3 }
! S% F) J6 r1 }
发表于 2019-7-30 16:24 | 只看该作者
看看FPGA都可以做什么用途
GMT+8, 2025-10-12 20:57 , Processed in 0.140625 second(s), 26 queries , Gzip On.
