原来一直在用pads2005的,后朋友推荐说2007 sp4 版本不错,就在网上下了一个试安装。按照说明安装时,运行bat文件老是出错,就将bat文件以编辑方式打开(选中文件,单击鼠标右键,选中弹出菜单中的“编辑”)。文件内容如下:
& ]' Y& N2 j: c7 E# W& v1 F@echo off1 W- m1 S! u; n$ x, @ J3 f% ~# A) s
@echo TITLE 馒头PADS2007.4 请稍等!/ v! s- c5 L1 a+ d y2 S; T
@echo 置换mgls.dll
9 h5 P; s$ C$ H, v. M@copy mgls.dll C:\mentorGraphics\2007.4PADS\MGC_HOME.ixn\lib
1 T; ?$ G% [ A% X3 ]# P) v@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\hyperlynx3 k/ y/ Z& z0 Y! D
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\Programs
# h; y, m3 z( E3 T@copy mgls.dll C:\MentorGraphics\2007.4PADS\MGC_HOME.ixn\lib\lib
! ]1 h8 b# p; J5 {) ?@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog8 F. ]( C8 P ^: ]) q1 `1 |
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\common\win32\lib
# k# l$ F m. Y$ H# Q9 F0 D@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\common\win32\_bin
) u* l1 C" |& U# }+ X( q@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\in' K! k* n& m r0 K
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\is" j" u) u, r" R7 I
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\pr$ [9 Y8 y: P* ]9 e2 {3 P+ i9 e! P
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\sm* ~1 G# ]6 \5 H
@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\viewanalog\sn y" y' C- s$ S1 ]+ q* U. B
@copy mgls.dll C:\MentorGraphics\2007.4PADS\MGC_HOME.ixn\pkgs\icwave.ixn\lib\lib
: Q4 u; F& ]4 A# V' a1 N@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\fusion\win32\bin
, M7 F4 k5 K& U6 E@copy mgls.dll C:\MentorGraphics\2007.4PADS\SDD_HOME\sim\van_vss\win32\pgm\dir
7 r) a. ]+ L1 T4 p: i+ c@echo mgls.dll置换完毕!7 p$ S, ?8 o; z& T& v; u
@cls
1 w. E! i5 b, i( s& S: U& w; |% G@echo 破解中,请稍等!9 f' m1 @% \+ `8 |- a
@echo off; K' W0 C& l( ]9 ~: [" f( S
@copy license.src C:\MentorGraphics\2007.4PADS
6 E' l+ o) e! Y. Q7 C@copy LICENSE.TXT C:\MentorGraphics\2007.4PADS3 D# k7 T2 u5 R) S0 ]+ F0 k- b
@copy MakeLic.bat C:\MentorGraphics\2007.4PADS9 i3 M3 x, X- c5 ?5 R0 k
@copy MGLS.DLL C:\MentorGraphics\2007.4PADS% E8 C5 b4 A2 l7 U! ~& M0 a2 [
@copy MentorKG.exe C:\MentorGraphics\2007.4PADS9 T% x4 E- J) v
@copy Environment.reg C:\MentorGraphics\2007.4PADS+ [+ b' e9 ?+ y: P$ O
cls
3 w# }6 k, q2 |5 b0 F% _% b@cd/d c:\MentorGraphics\2007.4PADS\
+ M4 x6 d1 P: g2 l0 g@MentorKG.exe
- Y1 c. E5 _+ G" Y: T@call MakeLic.bat* R; i1 l& y3 u9 j( T1 h
@cls
6 i. O( M4 l6 @, r@echo 导入注册表信息窗口请选择“Yes”
9 i3 r7 L- s" j& p( O@pause
7 ]; b( D9 i' a: q# t@regedit Environment.reg; e- ~2 W ^6 \' }! }1 q
@cls3 @1 x$ {# P, T V4 w
@echo 如果没有成功,请自设环境变量,MGLS_LICENSE_FILE=
v. w4 _7 P6 R9 s: Z1 |9 G@echo C:\MentorGraphics\2007.4PADS\licensefile.dat, ]5 w& B w0 n% m! X6 Y, ? U( z
@echo 然后运行 「开始」菜单\程序\Mentor Graphics SDD\* v9 h- ]! M y/ \' A. e! I# _7 y
@echo Licensing Tools\Install License.lnk
& d0 @' V6 V3 H$ C; F6 C@echo 设置LICENSE文件为你的"licensefile.dat"1 j( Y# e) Z/ J. C" H$ Z4 t7 ^
@echo ~~祝你好运!~~
5 |. R2 O8 T3 v# i& r& p' R$ BPAUSE
; f, {" _8 {' M/ Q% s
" F5 {# e* K. C* \: U2 s# p看了一下dat文件的内容后,发现如果只是按照下载的安装说明将dat文件拷到c(或D)盘根目录下就会找不到需要拷贝的mgls.dll,license.src等文件。对此,个人认为两种常用的解决方法。$ M+ ?7 w' N& f3 R |4 u
方法1:将所要复制的或要调用的文件一并复制到c(或D)盘根目录下,实在不知道有那些文件需要被bat文件使用的话,就干脆将整个CRACK文件中的文件都复制到到c(或D)盘根目录下;
* \1 L* N, p. `9 b! V; k方法2:在bat文件中为要被复制的文件和要被调用的文件加上正确的路径;
! r- y; X- o5 m- p% l, X/ `9 T以上仅是个人的一点看法和心得体会,水平有限难免有遗漏错误之处,请大家不吝指出。 |
